T2020642201-000
T2020642201-000
    HUMIREL(泰科)
    电源连接器 64Pin 26–14AWG
T2020642201-000 数据手册
4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 RELEASED FOR PUBLICATION 1 20 REVISIONS ALL RIGHTS RESERVED. BY - P B ( 110.4 ) D B1 B2 C 34 4X M3 SCREW RECOMMENDED TIGHTENING TORQUE 0.5Nm 4X M3 , 0.5Nm M4 SCREW RECOMMENDED TIGHTENING TORQUE 1.2Nm M4 , 1.2Nm 38.6 20.4 : 1. 2. B 4X CW ECR-15-017530 02DEC2015 GY CW ECR-16-015492 12NOV2016 QY CW ECR-21-105750 01JUL2021 BS CW ( D C PC 250V 10A >=400M ^ : 4 KV 3 UL94V-0 500 0.14-2.5 mm² (26-14 AWG) . : T20200X20XX000) B 3.3 TYPE-2,T2020642201-001,STAINLESS STEEL SCREW,TE LOGO -2,T2020642201-001, ,TE LOGO 27 36 THIS DRAWING IS A CONTROLLED DOCUMENT. TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: mm 104 PANEL CUT FOR INSERTS FOR USE WITHOUT HOODS/ HOUSINGS 1470-19 (3/13) DL TYPE-1,T2020642201-000,TE LOGO -1,T2020642201-000,TE LOGO 18 A APVD 24SEP2015 : : : : : 27 95 DWN ECR-15-013292 : : : : : 104 7.75 DATE NOTES: 1. TECHNICAL CHARACTERISTICS: INSULATION MATERIAL: PC RATED VOLTAGE: 250 V RATED CURRENT: 10 A INSULATION RESISTANCE: >=400M ^ RATED IMPULSE VOLTAGE: 4 KV POLLUTION DEGREE: 3 FLAMMABILITY: UL94V-0 MATING CYCLES: 500 CYCLES WIRE RANGE: 0.14-2.5 mm² (26-14 AWG) CONTACT TYPE: CRIMP CONTACT 2. CONTACT NEED TO BE ORDERED SEPARATELY. (ORDER No. REFER TO DRAWING:T20200X20XX000) ( 1.2 ) C DESCRIPTION LTR MATERIAL 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - DWN 30OCT2014 CHK 30OCT2014 APVD 30OCT2014 David Wang Chris Wang Xiang Xu TE Connectivity NAME PRODUCT SPEC HD-064-F A 108-137042 APPLICATION SPEC - 114-137042 WEIGHT Customer Drawing SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO - T2020642201000 SCALE 1:1 SHEET 1 OF 2 REV C 4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 RELEASED FOR PUBLICATION BY - 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. P DESCRIPTION LTR - DATE SEE SHEET 1 DWN APVD - - - D D NOTE: SEE SHEET 1 : 1 C C TYPE-3,T2020642201-002,STAINLESS STEEL SCREW,NO LOGO -3,T2020642201-002, , LOGO B T2020642201-002 HD-064-F T2020642201-001 HD-064-F T2020642201-000 HD-064-F mm A MATERIAL 1470-19 (3/13) TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - HD-064 FEMALE INSERT HD-064 TYPE-1 -1 FINISH - - DWN 30OCT2014 CHK 30OCT2014 APVD 30OCT2014 David Wang Chris Wang Xiang Xu TYPE TE Connectivity NAME PRODUCT SPEC HD-064-F A 108-137042 APPLICATION SPEC - 114-137042 WEIGHT Customer Drawing B TYPE-2 -2 PART DESCRIPTION THIS DRAWING IS A CONTROLLED DOCUMENT. DIMENSIONS: TYPE-3 -3 HD-064 FEMALE INSERT,STAINLESS STEEL SCREW HD-064 , PART NUMBER ALL DIMENSIONS ARE SAME AS TYPE 1, EXCEPT THOSE DEFINED IN THIS TYPE. , 1 HD-064 FEMALE INSERT, STAINLESS STEEL SCREW,NO LOGO HD-064 , , LOGO SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO - T2020642201000 SCALE 1:1 SHEET 2 OF 2 REV C
T2020642201-000
1. 物料型号:文档中提到了几种不同的物料型号,例如T2020642201-000、T2020642201-001和T2020642201-002,它们都与HD-064母头有关。
2. 器件简介:文档中提到了TE Connectivity的HD-064母头,这是一种用于电气连接的组件。
3. 引脚分配:文档中没有明确提到引脚分配,但提到了不同类型(TYPE)的HD-064母头。
4. 参数特性: - 绝缘电阻:≥400MΩ - 额定脉冲电压:4kV - 污染等级:3 - 阻燃等级:UL94V-0 - 配对周期:500次 - 适用线材范围:0.14-2.5 mm² (26-14 AWG) - 接触类型:压接接触 - 额定电压:250V - 额定电流:10A
5. 功能详解:文档中提到了HD-064母头的技术特性,包括绝缘电阻、额定脉冲电压、污染等级、阻燃等级、配对周期、线材范围、接触类型、额定电压和额定电流。
6. 应用信息:文档中提到了应用规格114-137042和尺寸笼码CAGE CODE A3,但没有提供更详细的应用信息
7. 封装信息:文档中提到了不同类型(TYPE)的HD-064母头,但没有提供详细的封装信息
T2020642201-000 价格&库存
很抱歉,暂时无法提供与“T2020642201-000”相匹配的价格&库存,您可以联系我们找货
T2020642201-000
    • 1+46.48546
    库存:1
