T2030242201-000
T2030242201-000
    HUMIREL(泰科)
    线对线连接器 14-26AWG 24Pin(4x6)
T2030242201-000 数据手册
4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 RELEASED FOR PUBLICATION REVISIONS ALL RIGHTS RESERVED. BY - P A 50.4 D DESCRIPTION LTR B 34 B1 ( 26.4 ) 16.5 34.8 : 1. B : : : : : 4X M3 SCREW RECOMMENDED TIGHTENING TORQUE 0.5Nm 4X M3 , 0.5Nm 2. 27 44 DWN APVD INITIAL RELEASE 16MAR2015 DL CW ECR-15-013292 24SEP2015 DL CW ECR-16-015492 15NOV2016 QY CW NOTES: 1. TECHNICAL CHARACTERISTICS: INSULATION MATERIAL: PC RATED VOLTAGE: 250 V RATED CURRENT: 10 A INSULATION RESISTANCE: >=400M ^ RATED IMPULSE VOLTAGE: 2.5 KV POLLUTION DEGREE: 2 FLAMMABILITY: UL94V-0 MATING CYCLES: 500 CYCLES WIRE RANGE: 0.14-2.5 mm² (26-14 AWG) CONTACT TYPE: CRIMP CONTACT 2. CONTACT NEED TO BE ORDERED SEPARATELY. (ORDER No. REFER TO DRAWING: T20200X20XX000) M4 SCREW RECOMMENDED TIGHTENING TORQUE 1.2Nm M4 , 1.2Nm C DATE : : : : : ( C PC 250V 10A >=400M ^ : 2.5 KV 2 UL94V-0 500 0.14-2.5 mm² (26-14 AWG) . : T20200X20XX000) B TYPE-1,T2030242201-000,TE LOGO -1,T2030242201-000,TE LOGO 36 18 27 44 THIS DRAWING IS A CONTROLLED DOCUMENT. TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: 7.75 A 35 4X PANEL CUT OUT FOR INSERTS FOR USING WITHOUT HOODS/HOUSINGS 1470-19 (3/13) D mm 3.3 MATERIAL 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - DWN 16MAR2015 CHK 16MAR2015 APVD 16MAR2015 DAVID LI CHRIS WANG XU XIANG TE Connectivity NAME PRODUCT SPEC HDD-024-F A 108-137043 APPLICATION SPEC - 114-137043 WEIGHT CUSTOMER DRAWING SIZE A3 CAGE CODE - DRAWING NO RESTRICTED TO T2030242201000 SCALE 1:1 SHEET - 1 OF 2 REV B1 4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 RELEASED FOR PUBLICATION BY - 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. P DESCRIPTION LTR - DATE SEE SHEET 1 DWN APVD - - - D D NOTE: SEE SHEET 1 : 1 C C TYPE-2,T2030242201-002,STAINLESS STEEL SCREW,NO LOGO -2,T2030242201-002, , LOGO B B T2030242201-002 HDD-024-F T2030242201-000 HDD-024-F HDD-024 FEMALE INSERT,CRIMPING SPLIT TYPE, STAINLESS STEEL SCREW,NO LOGO HDD-024 , , , LOGO HDD-024 FEMALE INSERT,CRIMPING SPLIT TYPE HDD-024 , PART NUMBER ALL DIMENSIONS ARE SAME AS TYPE 1, EXCEPT THOSE DEFINED IN THIS TYPE. , 1 mm A MATERIAL 1470-19 (3/13) TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - TYPE-1 -1 PART DESCRIPTION THIS DRAWING IS A CONTROLLED DOCUMENT. DIMENSIONS: TYPE-2 -2 FINISH - - DWN 16MAR2015 CHK 16MAR2015 APVD 16MAR2015 DAVID LI CHRIS WANG XU XIANG TYPE TE Connectivity NAME PRODUCT SPEC HDD-024-F A 108-137043 APPLICATION SPEC - 114-137043 WEIGHT CUSTOMER DRAWING SIZE A3 CAGE CODE - DRAWING NO RESTRICTED TO T2030242201000 SCALE 1:1 SHEET - 2 OF 2 REV B1
T2030242201-000 价格&库存
很抱歉,暂时无法提供与“T2030242201-000”相匹配的价格&库存,您可以联系我们找货
T2030242201-000
  • 20+71.97774
  • 50+70.24873
  • 100+66.88743
  • 250+63.52613
  • 500+58.44791
  • 1000+54.22815
库存:83
T2030242201-000
  • 1+36.02480
库存:1
T2030242201-000
    • 20+103.59162
    • 50+101.10562
    • 100+96.27035
    • 250+91.43508
    • 500+84.12624
    • 1000+78.04797
    库存:83
    T2030242201-000
    • 1+137.473031+17.84149
    • 10+116.8355310+15.16312
    • 30+108.1161330+14.03150
    • 50+104.2871550+13.53457
    • 100+99.31105100+12.88877
    • 250+93.09769250+12.08238
    • 500+88.65888500+11.50631
    • 1000+84.432951000+10.95786
    库存:1
