T2030722101-000
T2030722101-000
    HUMIREL(泰科)
    电源连接器 14-26AWG 72Pin(6x12)
T2030722101-000 数据手册
4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 RELEASED FOR PUBLICATION REVISIONS ALL RIGHTS RESERVED. BY - P B 77.5 B1 D C 27 D M4 SCREW RECOMMENDED TIGHTENING TORQUE 1.2Nm , 1.2Nm ( 1.2 ) 4X M3 SCREW RECOMMENDED TIGHTENING TORQUE 0.5Nm 4X M3 , 0.5Nm : 1. 2. 84.3 B A TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: mm 77.5 PANEL CUT OUT FOR INSERTS FOR USING WITHOUT HODDS/HOUSINGS 1470-19 (3/13) DL CW ECR-16-015492 21NOV2016 QY CW ECR-21-105887 26JUL2021 BS CW ECR-22-150866 20SEP2022 DL CW : : : : : ( D C PC 250V 10A >=400M ^ : 4 KV 3 UL94V-0 500 0.14-2.5 mm² (26-14 AWG) . : T20200X10XX000) B 36 27 3.3 24SEP2015 TYPE-1,T2030722101-000,TE LOGO -1,T2030722101-000,TE LOGO THIS DRAWING IS A CONTROLLED DOCUMENT. 4X APVD 68.5 18 7.75 DWN ECR-15-013292 : : : : : 34 C DATE NOTES: 1. TECHNICAL CHARACTERISTICS: INSULATION MATERIAL: PC RATED VOLTAGE: 250 V RATED CURRENT: 10 A INSULATION RESISTANCE: >=400M ^ RATED IMPULSE VOLTAGE: 4 KV POLLUTION DEGREE: 3 FLAMMABILITY: UL94V-0 MATING CYCLES: 500 CYCLES WIRE RANGE: 0.14-2.5 mm² (26-14 AWG) CONTACT TYPE: CRIMP CONTACT 2. CONTACT NEED TO BE ORDERED SEPARATELY. (ORDER No. REFER TO DRAWING:T20200X10XX000) 34.9 18.8 M4 DESCRIPTION LTR MATERIAL 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - DWN 29OCT2014 CHK 29OCT2014 APVD 29OCT2014 David Wang Chris Wang Xiang Xu TE Connectivity NAME PRODUCT SPEC HDD-072-M A 108-137043 APPLICATION SPEC - 114-137043 WEIGHT Customer Drawing SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO - T2030722101000 SCALE 1:1 SHEET 1 OF 2 REV D 4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 RELEASED FOR PUBLICATION BY - 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. P DESCRIPTION LTR - DATE SEE SHEET 1 DWN APVD - - - D D NOTE: SEE SHEET 1 : 1 C C TYPE-2,T2030722101-001,STAINLESS STEEL SCREW,NO LOGO -2,T2030722101-001, , LOGO B B ALL DIMENSIONS ARE SAME AS TYPE 1, EXCEPT THOSE DEFINED IN THIS TYPE. , 1 T2030722101-001 HDD-072-M T2030722101-000 HDD-072-M PART NUMBER THIS DRAWING IS A CONTROLLED DOCUMENT. TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: mm A MATERIAL 1470-19 (3/13) 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - HDD-072 MALE INSERT, STAINLESS STEEL SCREW,NO LOGO HDD-072 , , LOGO TYPE-2 -2 HDD-072 MALE INSERT HDD-072 TYPE-1 -1 PART DESCRIPTION DWN 29OCT2014 CHK 29OCT2014 APVD 29OCT2014 David Wang Chris Wang Xiang Xu TYPE TE Connectivity NAME PRODUCT SPEC HDD-072-M A 108-137043 APPLICATION SPEC - 114-137043 WEIGHT Customer Drawing SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO - T2030722101000 SCALE 1:1 SHEET 2 OF 2 REV D
T2030722101-000 价格&库存
很抱歉,暂时无法提供与“T2030722101-000”相匹配的价格&库存,您可以联系我们找货
T2030722101-000
  • 10+130.03873
  • 25+113.34106
  • 40+98.27567
  • 50+95.96629
  • 100+91.37171
  • 250+86.66831
  • 500+79.75225
库存:22
T2030722101-000
    • 1+49.21992
    库存:1
    T2030722101-000
      库存:20
      T2030722101-000
        • 10+187.15851
        • 25+163.13132
        • 40+141.44097
        • 50+138.12216
        • 100+131.50940
        • 250+124.73505
        • 500+114.77862
        库存:22
