4
THIS DRAWING IS UNPUBLISHED.
C
COPYRIGHT
3
1
RELEASED FOR PUBLICATION
REVISIONS
ALL RIGHTS RESERVED.
BY -
P
DESCRIPTION
LTR
A1
110.4
B
D
C
DWN
APVD
ECR-15-009224
23JUN2015
DL
CW
ECR-15-013292
24SEP2015
DL
CW
ECR-21-105887
26JUL2021
BS
CW
ECR-22-150866
27SEP2022
DL
CW
D
34
D
DATE
SCALE
NOTES:
1. TECHNICAL CHARACTERISTICS:
INSULATION MATERIAL: PC
RATED VOLTAGE: 250 V
RATED CURRENT: 10 A
INSULATION RESISTANCE: >=400M ^
RATED IMPULSE VOLTAGE: 4 KV
POLLUTION DEGREE: 3
FLAMMABILITY: UL94V-0
MATING CYCLES: 500 CYCLES
WIRE RANGE: 0.14-2.5 mm² (26-14 AWG)
CONTACT TYPE: CRIMP CONTACT
2. CONTACT NEED TO BE ORDERED SEPARATELY.
(ORDER No. REFER TO DRAWING: T20200X20XX000)
1:2
M4 SCREW
RECOMMENDED TIGHTENING TORQUE 1.2Nm
( 26.4 )
32.8
C
14.5
4 X M3 SCREW
RECOMMENDED TIGHTENING TORQUE 0.5Nm
1.
104
27
B
2.
C
PC
250V
10A
>=400M ^
: 4 KV
3
UL94V-0
500
B
: T20200X20XX000)
104
36
18
27
HDC-HDD-108F 109-216
THIS DRAWING IS A CONTROLLED DOCUMENT.
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
DIMENSIONS:
mm
A
7.75
95
PANEL CUT OUT FOR INSERTS FOR USING
WITHOUT HOODS/HOUSINGS
1470-19 (3/13)
3.3
MATERIAL
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
DWN
18MAR2015
CHK
18MAR2015
APVD
18MAR2015
DAVID LI
CHRIS WANG
XU XIANG
PRODUCT SPEC
T2032162201-000
DESCRIPTION
PART NUMBER
TE Connectivity
NAME
A
108-137043
APPLICATION SPEC
114-137043
WEIGHT
CUSTOMER DRAWING
SIZE
A3
CAGE CODE
DRAWING NO
RESTRICTED TO
T2032162201000
SCALE
1:1
SHEET
1
OF
1
REV
D
很抱歉,暂时无法提供与“T2032162201-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+208.147775+27.00700
- 20+175.3144220+22.74690
- 40+167.9116740+21.78640
- 国内价格 香港价格
- 45+170.8628045+22.16931
- 国内价格
- 10+103.46271
- 25+101.47979
- 45+95.78492
- 50+93.52391
- 100+88.97769
- 国内价格
- 10+148.91140
- 25+146.05250
- 45+137.86113
- 50+134.60447
- 100+128.06629
- 国内价格
- 10+148.91140
- 25+146.05250
- 45+137.86113
- 50+134.60447
- 100+128.06629
- 国内价格
- 10+148.91140
- 25+146.05250
- 45+137.86113
- 50+134.60447
- 100+128.06629
- 国内价格
- 10+148.91140
- 25+146.05250
- 45+137.86113
- 50+134.60447
- 100+128.06629
