4
THIS DRAWING IS UNPUBLISHED.
C
COPYRIGHT
RELEASED FOR PUBLICATION
1
REVISIONS
ALL RIGHTS RESERVED.
BY -
3
P
A
B
51
C
DATE
DWN
APVD
INITIAL RELEASE
06APR2015
GY
CW
ECR-15-013759
29SEP2015
DW
CW
ECR-21-106515
08JUL2021
SQ
CW
D
33.8
D
DESCRIPTION
LTR
NOTES:
1. TECHNICAL CHARACTERISTICS:
INSULATION MATERIAL: PC
RATED VOLTAGE: 500V
RATED CURRENT: 16A
INSULATION RESISTANCE: >=400M ^
RATED IMPULSE VOLTAGE: 6KV
POLLUTION DEGREE: 3
FLAMMABILITY: UL94V-0
MATING CYCLES: 500 CYCLES
OPERATION TEMPERATURE: -40 $ C~+125 $ C
WIRE RANGE: 0.5mm²~2.5mm² (AWG20-AWG14)
CONTACT TYPE: SPRING CLAMP
M4 screw, recommended tightening torque 1.2Nm
4 X M3 screw, recommended tightening torque 0.5Nm
34.1
1.
1.2
( 21.1 )
19.1
C
5
35
PC
500V
16A
>=400M ^
6KV
3
UL94V-0
500
-40 $ C~+125 $ C
B
36
14
27
27
B
C
44
HE-006-MS
4X
THIS DRAWING IS A CONTROLLED DOCUMENT.
.3
n3
44
Panel cut our for inserts for
use without hoods/housings
A
mm
MATERIAL
1470-19 (3/13)
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
DIMENSIONS:
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
DWN
06APR2015
CHK
06APR2015
APVD
06APR2015
Gino.Yao
Chris.Wang
Xiang.Xu
PRODUCT SPEC
T2040063101-000
DESCRIPTION
PART NUMBER
TE Connectivity
NAME
HE-006-MS
A
108-137044
APPLICATION SPEC
114-137044
WEIGHT
Customer Drawing
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2040063101000
SCALE
1:1
SHEET
1
OF
1
REV
C
很抱歉,暂时无法提供与“T2040063101-000”相匹配的价格&库存,您可以联系我们找货
