T2040063201-000
T2040063201-000
    HUMIREL(泰科)
    胶壳及附件 6Pin(2x3) 14–20AWG
T2040063201-000 数据手册
4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT REVISIONS ALL RIGHTS RESERVED. P 5 D 1 20 RELEASED FOR PUBLICATION BY - 20 2 3 A 35 B 51 4X 4 X M3 screw, recommended tightening torque 0.5Nm n3 ( 23.3 ) 17.3 Panel cut our for inserts for use without hoods/housings : 1. 0 M4 screw, recommended tightening torque 1.2Nm B 06APR2015 GY CW ECR-15-013759 29SEP2015 DW CW ECR-21-106515 08JUL2021 SQ CW : : : : : : : : : : : : THIS DRAWING IS A CONTROLLED DOCUMENT. TOLERANCES UNLESS OTHERWISE SPECIFIED: A MATERIAL 1470-19 (3/13) 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH D - - DWN 06APR2015 CHK 06APR2015 APVD 06APR2015 Gino.Yao Chris.Wang Xiang.Xu PRODUCT SPEC C PC 500V 16A >=400M ^ 6KV 3 UL94V-0 500 -40 $ C~+125 $ C 0.5mm²~2.5mm² (AWG20-AWG14) B HE-006-FS mm APVD INITIAL RELEASE 0 DIMENSIONS: DWN NOTES: 1. TECHNICAL CHARACTERISTICS: INSULATION MATERIAL: PC RATED VOLTAGE: 500V RATED CURRENT: 16A INSULATION RESISTANCE: >=400M ^ RATED IMPULSE VOLTAGE: 6KV POLLUTION DEGREE: 3 FLAMMABILITY: UL94V-0 MATING CYCLES: 500 CYCLES OPERATION TEMPERATURE: -40 $ C~+125 $ C WIRE RANGE: 0.5mm²~2.5mm² (AWG20-AWG14) CONTACT TYPE: SPRING CLAMP .3 1.2 34.5 C DATE 36 14 33.8 27 C 44 DESCRIPTION LTR T2040063201-000 DESCRIPTION PART NUMBER TE Connectivity NAME HE-006-FS A 108-137044 APPLICATION SPEC - 114-137044 WEIGHT Customer Drawing SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO - T2040063201000 SCALE 1:1 SHEET 1 OF 1 REV C
T2040063201-000 价格&库存
很抱歉,暂时无法提供与“T2040063201-000”相匹配的价格&库存,您可以联系我们找货
T2040063201-000
    • 1+26.66888
    库存:1
    T2040063201-000
    • 20+70.24873
    • 50+68.54390
    • 100+65.31560
    • 250+61.99057
    • 500+56.97281
    • 1000+52.83768
    库存:8
    T2040063201-000
      • 20+93.66005
      • 50+91.43508
      • 100+87.01000
      • 250+82.60978
      • 500+75.95973
      库存:8
