T2040103201-000
T2040103201-000
    HUMIREL(泰科)
    胶壳及附件 10Pin(2x5) 14–20AWG
T2040103201-000 数据手册
4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 RELEASED FOR PUBLICATION 1 20 REVISIONS ALL RIGHTS RESERVED. BY - P 5 A 48 B D B1 64 36 33.8 14 27 C 4X .3 n3 57 PANEL CUT OUT FOR INSERTS FOR USE WITHOUT HOODS/HOUSING M4 SCREW, RECOMMENDED TIGHTENING TORQUE 1.2Nm M4 , 1.2Nm HE-010-FS T2040103201-000 HE-010-FS ECR-15-013759 29SEP2015 DW CW ECR-16-009892 13JUL2016 RL CW ECR-21-106515 13AUG2021 SQ CW : : : : : : : : : : TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: mm A MATERIAL 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - C PC 500V 16A >=400M ^ 6KV 3 UL94V-0 500 0.5mm²~2.5mm² (AWG20-AWG14) : B HE-010 FEMALE INSERT, WIIH STAINLESS STEEL SCREW, SPRING CLAMP HE-010 , , HE-010 FEMALE INSERT, SPRING CLAMP HE-010 , PART DESCRIPTION DWN 09APR2015 CHK 09APR2015 APVD 09APR2015 Gino.Yao Chris.Wang Xiang.Xu STAINLESS STEEL STAINLESS STEEL STEEL STEEL FIXING SCREW MAT'L GROUND CONTACT SCREW MAT'L TE Connectivity NAME PRODUCT SPEC HE-010-FS A 108-137044 APPLICATION SPEC - D NOTES: 1. TECHNICAL CHARACTERISTICS: INSULATION MATERIAL: PC RATED VOLTAGE: 500V RATED CURRENT: 16A INSULATION RESISTANCE: >=400M ^ RATED IMPULSE VOLTAGE: 6KV POLLUTION DEGREE: 3 FLAMMABILITY: UL94V-0 MATING CYCLES: 500 CYCLES WIRE RANGE: 0.5mm²~2.5mm² (AWG20-AWG14) CONTACT FINISH: SILVER PLATED CONTACT TYPE: SPRING CLAMP PART NUMBER THIS DRAWING IS A CONTROLLED DOCUMENT. 114-137044 WEIGHT Customer Drawing 1470-19 (3/13) CW ( 23.3 ) 57 T2040103201-001 APVD GY : 27 B DWN 09APR2015 : 4X M3 SCREW RECOMMENDED TIGHTENING TORQUE 0.5Nm 4 X M3 , 0.5Nm DATE INITIAL RELEASE 1. 17.3 1.2 34.5 C DESCRIPTION LTR SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO - T2040103201000 SCALE 1:1 SHEET 1 OF 1 REV C
T2040103201-000 价格&库存
很抱歉,暂时无法提供与“T2040103201-000”相匹配的价格&库存,您可以联系我们找货
T2040103201-000
    • 20+89.06095
    • 50+87.01000
    • 100+82.78380
    • 250+78.53274
    库存:141
    T2040103201-000
    • 1+28.84140
    库存:1
    T2040103201-000
      • 1+78.60365
      • 2+76.25012
      • 3+75.21915
      库存:4
      T2040103201-000
        • 20+89.06095
        • 50+87.01000
        • 100+82.78380
        • 250+78.53274
        库存:79
