T2040163101-000
T2040163101-000
    HUMIREL(泰科)
    胶壳及附件 16Pin(2x8) 14–20AWG
T2040163101-000 数据手册
4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 1 20 RELEASED FOR PUBLICATION REVISIONS ALL RIGHTS RESERVED. BY - P 5 84.5 D 2 3 A 68.5 B B1 .3 n3 19.1 PANEL CUT OUT FOR INSERTS FOR USE WITHOUT HOODS/HOUSING : 1. ( 21.1 ) 1.2 34.1 C M4 SCREW, RECOMMENDED TIGHTENING TORQUE 1.2Nm M4 , 1.2Nm 27 B T2040163101-001 HE-016-MS T2040163101-000 HE-016-MS 15APR2015 CY CW ECR-15-013759 09OCT2015 DW CW ECR-16-009892 13JUL2016 RL CW ECR-21-106515 09JUL2021 SQ CW : : : : : : : : : : TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: mm A MATERIAL 1470-19 (3/13) 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - PART DESCRIPTION DWN 15APR2015 CHK 15APR2015 APVD 15APR2015 Gino.Yao Chris.Wang Xiang.Xu C B HE-016 MALE INSERT, SPRING CLAMP HE-016 , PRODUCT SPEC STAINLESS STEEL STAINLESS STEEL STEEL STEEL FIXING SCREW MAT'L GROUND CONTACT SCREW MAT'L TE Connectivity NAME HE-016-MS A 108-137044 APPLICATION SPEC - D PC 500V 16A >=400M ^ 6KV 3 UL94V-0 500 0.5mm²~2.5mm² (AWG20-AWG14) : HE-016 MALE INSERT, STAINLESS STEEL SCREW, SPRING CLAMP HE-016 , , PART NUMBER THIS DRAWING IS A CONTROLLED DOCUMENT. APVD INITIAL RELEASE : 77.5 DWN NOTES: 1. TECHNICAL CHARACTERISTICS: INSULATION MATERIAL: PC RATED VOLTAGE: 500V RATED CURRENT: 16A INSULATION RESISTANCE: >=400M ^ RATED IMPULSE VOLTAGE: 6KV POLLUTION DEGREE: 3 FLAMMABILITY: UL94V-0 MATING CYCLES: 500 CYCLES WIRE RANGE: 0.5mm²~2.5mm² (AWG20-AWG14) CONTACT FINISH: SILVER PLATED CONTACT TYPE: SPRING CLAMP 4X 4X M3 SCREW RECOMMENDED TIGHTENING TORQUE 0.5Nm 4 X M3 , 0.5Nm DATE 36 14 33.8 27 C 77.5 DESCRIPTION LTR 114-137044 WEIGHT Customer Drawing SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO - T2040163101000 SCALE 4:5 SHEET 1 OF 1 REV C
T2040163101-000 价格&库存
很抱歉,暂时无法提供与“T2040163101-000”相匹配的价格&库存,您可以联系我们找货
T2040163101-000
    • 15+127.90470
    • 50+124.85935
    • 100+118.93024
    • 250+112.85197
    • 500+103.87751
    • 1000+96.27035
    库存:39
    T2040163101-000
    • 1+38.55211
    库存:1
    T2040163101-000
    • 15+88.86887
    • 50+86.75295
    • 100+82.62991
    • 250+78.41015
    • 500+72.17120
    • 1000+66.88743
    库存:39
