4
THIS DRAWING IS UNPUBLISHED.
C
COPYRIGHT
1
RELEASED FOR PUBLICATION
REVISIONS
ALL RIGHTS RESERVED.
BY -
3
P
A
D
B
84.5
B1
33.8
C
34.5
17.3
1.2
( 23.3 )
1.
4X M3 SCREW,RECOMMENDED
TIGHTENING TORQUE 0.5Nm
4X M3 ,
0.5Nm
68.5
2.
36
14
27
B
4X
.3
n3
77.5
PANEL CUT FOR INSERTS FOR USING
WITHOUT HOODS/ HOUSINGS
APVD
16APR2015
GY
CW
ECR-15-013759
12OCT2015
DW
CW
ECR-16-015492
16NOV2016
QY
CW
ECR-21-106515
19JUL2021
SQ
CW
D
C
PC
500V
16A
>=400M ^
6KV
3
UL94V-0
500
0.14mm²~4mm² (AWG26-AWG12)
: T20300X20XX000)
B
77.5
TYPE-1,T2040164201-000,TE LOGO
THIS DRAWING IS A CONTROLLED DOCUMENT.
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
DIMENSIONS:
mm
A
MATERIAL
1470-19 (3/13)
DWN
INITIAL RELEASE
27
5
DATE
NOTES:
1. TECHNICAL CHARACTERISTICS:
INSULATION MATERIAL: PC
RATED VOLTAGE: 500V
RATED CURRENT: 16A
INSULATION RESISTANCE: >=400M ^
RATED IMPULSE VOLTAGE: 6KV
POLLUTION DEGREE: 3
FLAMMABILITY: UL94V-0
MATING CYCLES: 500 CYCLES
WIRE RANGE: 0.14mm²~4mm² (AWG26-AWG12 )
CONTACT TYPE: CRIMP CONTACT
2. CONTACTS NEED TO BE ORDERED SEPARATELY.
(ORDER No. REFER TO DRAWING:T20300X20XX000)
M4 SCREW,RECOMMENDED
TIGHTENING TORQUE 1.2Nm
M4 ,
1.2Nm
C
DESCRIPTION
LTR
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
DWN
16APR2015
CHK
16APR2015
APVD
16APR2015
Gino.Yao
Chirs.Wang
Xiang.Xu
PRODUCT SPEC
TE Connectivity
NAME
HE-016-FC
A
108-137044
APPLICATION SPEC
114-137044
WEIGHT
CUSTOMER DRAWING
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2040164201000
SCALE
1:1
SHEET
1
OF
2
REV
C
4
C
COPYRIGHT
BY -
2
3
1
REVISIONS
P
DESCRIPTION
LTR
DATE
SEE SHEET 1
DWN
APVD
D
D
NOTE:
SEE SHEET 1
1
C
C
TYPE-2,T2040164201-001,STAINLESS STEEL SCREW,NO LOGO
-2,T2040164201-001,
, LOGO
B
B
ALL SPEC DIMENSION REFER TO TYPE 1
TYPE 1
HE-016-FC
T2040164201-000
HE-016-FC
PART NUMBER
TOLERANCES UNLESS
DIMENSIONS:
mm
A
MATERIAL
1470-19 (3/13)
T2040164201-001
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
HE-016 FEMALE INSERT,CRIMPING,
HE-016 ,
, LOGO
TYPE-2
-2
HE-016 ,
TYPE-1
-1
PART DESCRIPTION
DWN
16APR2015
CHK
16APR2015
APVD
16APR2015
Gino.Yao
Chirs.Wang
Xiang.Xu
PRODUCT SPEC
TYPE
TE Connectivity
NAME
HE-016-FC
A
108-137044
APPLICATION SPEC
114-137044
WEIGHT
CUSTOMER DRAWING
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2040164201000
SCALE
1:1
SHEET
2
OF
2
REV
C
很抱歉,暂时无法提供与“T2040164201-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+19.13156
- 10+16.23284
- 30+13.33412
