4
THIS DRAWING IS UNPUBLISHED.
C
COPYRIGHT
2
3
1
RELEASED FOR PUBLICATION
REVISIONS
ALL RIGHTS RESERVED.
BY -
P
A
A1
111
D
B
33.8
B1
17.3
1.
1.2
32.3
( 21.1 )
C
M4 SCREW,RECOMMENDED
TIGHTENING TORQUE 1.2Nm
M4 ,
1.2Nm
DATE
DWN
APVD
INITIAL
05JAN2015
GY
CW
ECR-15-004309
24MAR2015
GY
CW
ECR-15-013759
26SEP2015
DW
CW
ECR-16-011988
27AUG2016
YC
CW
NOTES:
1. TECHNICAL CHARACTERISTICS:
INSULATION MATERIAL: PC
RATED VOLTAGE: 500V
RATED CURRENT: 16A
INSULATION RESISTANCE: >=400M ^
RATED IMPULSE VOLTAGE: 6KV
POLLUTION DEGREE: 3
FLAMMABILITY: UL94V-0
MATING CYCLES: 500 CYCLES
WIRE RANGE: 0.5mm²~2.5mm² (AWG20-AWG14)
CONTACT TYPE: SCREW CLAMP (M3)
24X M3 SCREW,RECOMMENDED
TIGHTENING TORQUE 0.5Nm
24X M3 ,
0.5Nm
TYPE 1,T2040242101-000,WITH LOGO
1,T2040242101-000, LOGO
DESCRIPTION
LTR
C
PC
500V
16A
>=400M ^
6KV
3
UL94V-0
500
(M3)
27
104
D
B
B
5
95
36
14
27
4X M3 ,
0.5Nm
THIS DRAWING IS A CONTROLLED DOCUMENT.
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
DIMENSIONS:
104
A
PANEL CUT FOR INSERTS FOR USE
WITHOUT HOODS/ HOUSINGS
1470-19 (3/13)
mm
4X n 3.3
MATERIAL
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
DWN
12AUG2014
CHK
12AUG2014
APVD
12AUG2014
GINO YAO
CHRIS WANG
XIANG XU
TE Connectivity
NAME
PRODUCT SPEC
HE-024-M
A
108-137044
APPLICATION SPEC
114-137044
WEIGHT
CUSTOMER DRAWING
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2040242101000
SCALE
1:1
SHEET
1
OF
2
REV
B1
4
C
COPYRIGHT
BY -
2
3
1
REVISIONS
P
DESCRIPTION
LTR
DATE
DWN
APVD
SEE SHEET 1
D
D
NOTE:
ALL SPEC REFER TO TYPE 1
TYPE 1
TYPE 2,T2040242101-001,WITHOUT LOGO
2,T2040242101-001, LOGO
C
C
B
B
T2040242101-000
HE-024-M
T2040242101-001
HE-024-M
PART NUMBER
TOLERANCES UNLESS
DIMENSIONS:
mm
A
MATERIAL
1470-19 (3/13)
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
DWN
12AUG2014
CHK
12AUG2014
APVD
12AUG2014
GINO YAO
CHRIS WANG
XIANG XU
PRODUCT SPEC
HE-024 MALE INSERT
HE-024
TYPE 1
HE-024 MALE INSERT,WITHOUT LOGO
HE-024 , LOGO
TYPE 2
PART DESCRIPTION
TYPE
TE Connectivity
NAME
HE-024-M
A
108-137044
APPLICATION SPEC
114-137044
WEIGHT
CUSTOMER DRAWING
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2040242101000
SCALE
1:1
SHEET
2
OF
2
REV
B1
很抱歉,暂时无法提供与“T2040242101-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+110.50331
- 10+108.29558
- 20+106.12742
