4
THIS DRAWING IS UNPUBLISHED.
C
1
RELEASED FOR PUBLICATION
REVISIONS
ALL RIGHTS RESERVED.
BY -
COPYRIGHT
2
3
P
DESCRIPTION
LTR
A
D
A1
111
B
33.8
C
19.1
34.1
1.
1.2
( 21.1 )
DWN
APVD
INITIAL
05Jan2015
GY
CW
ECR-15-004309
24Mar2015
GY
CW
ECR-15-013759
26Sep2015
DW
CW
ECR-21-106515
21JUL2021
SQ
CW
NOTES:
1. TECHNICAL CHARACTERISTICS:
INSULATION MATERIAL: PC
RATED VOLTAGE: 500V
RATED CURRENT: 16A
INSULATION RESISTANCE: >=400M ^
RATED IMPULSE VOLTAGE: 6KV
POLLUTION DEGREE: 3
FLAMMABILITY: UL94V-0
MATING CYCLES: 500 CYCLES
OPERATION TEMPERATURE: -40 $ C~+125 $ C
WIRE RANGE: 0.5mm²~2.5mm² (AWG20-AWG14)
CONTACT TYPE: SPRING CLAMP
M4 screw, recommended
tightening torque 1.2Nm
C
DATE
27
4 X M3 screw, recommended
tightening torque 0.5Nm
D
C
PC
500V
16A
>=400M ^
6KV
3
UL94V-0
500
-40 $ C~+125 $ C
B
B
95
104
HE-024-MS
THIS DRAWING IS A CONTROLLED DOCUMENT.
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
DIMENSIONS:
104
A
Panel cut out for inserts for using
without hoods/housings
1470-19 (3/13)
mm
4X n 3.3
MATERIAL
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
DWN
18Aug2014
CHK
18Aug2014
APVD
18Aug2014
Gino.Yao
Chris.Wang
Xiang.Xu
T2040243101-000
DESCRIPTION
36
14
27
5
PART NUMBER
TE Connectivity
NAME
PRODUCT SPEC
HE-024-MS
A
108-137044
APPLICATION SPEC
114-137044
WEIGHT
CUSTOMER DRAWING
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2040243101000
SCALE
1:1
SHEET
1
OF
1
REV
C
很抱歉,暂时无法提供与“T2040243101-000”相匹配的价格&库存,您可以联系我们找货
