4
THIS DRAWING IS UNPUBLISHED.
C
COPYRIGHT
2
3
1
RELEASED FOR PUBLICATION
REVISIONS
ALL RIGHTS RESERVED.
BY -
P
A1
111
D
DESCRIPTION
LTR
B
B1
33.8
C
19.1
34.1
1.
1.2
( 21.1 )
27
2.
B
95
36
THIS DRAWING IS A CONTROLLED DOCUMENT.
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
DIMENSIONS:
mm
A
104
PANEL CUT FOR INSERTS FOR USING
WITHOUT HOODS/ HOUSINGS
1470-19 (3/13)
APVD
ECR-15-004309
24Mar2015
GY
CW
ECR-15-013759
10Oct2015
DW
CW
ECR-16-015492
17NOV2016
QY
CW
ECR-21-106515
21JUL2021
SQ
CW
D
C
PC
500V
16A
>=400M ^
6KV
3
UL94V-0
500
0.14mm²~4mm² (AWG26-AWG12)
: T20300X10XX000)
B
104
14
27
5
4X M3 SCREW,RECOMMENDED
TIGHTENING TORQUE 0.5Nm
4X M3 ,
0.5Nm
TYPE-1,T2040244101-000,TE LOGO
DWN
NOTES:
1. TECHNICAL CHARACTERISTICS:
INSULATION MATERIAL: PC
RATED VOLTAGE: 500V
RATED CURRENT: 16A
INSULATION RESISTANCE: >=400M ^
RATED IMPULSE VOLTAGE: 6KV
POLLUTION DEGREE: 3
FLAMMABILITY: UL94V-0
MATING CYCLES: 500 CYCLES
WIRE RANGE: 0.14mm²~4mm² (AWG26-AWG12 )
CONTACT TYPE: CRIMP CONTACT
2. CONTACTS NEED TO BE ORDERED SEPARATELY.
(ORDER No. REFER TO DRAWING:T20300X10XX000)
M4 SCREW,RECOMMENDED
TIGHTENING TORQUE 1.2Nm
M4 ,
1.2Nm
C
DATE
4X n 3.3
MATERIAL
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
DWN
19Aug2014
CHK
19Aug2014
APVD
19Aug2014
Gino.Yao
Chris.Wang
Xiang.Xu
TE Connectivity
NAME
PRODUCT SPEC
HE-024-MC
A
108-137044
APPLICATION SPEC
114-137044
WEIGHT
CUSTOMER DRAWING
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2040244101000
SCALE
1:1
SHEET
1
OF
2
REV
C
4
C
COPYRIGHT
BY -
2
3
1
REVISIONS
P
DESCRIPTION
LTR
DATE
SEE SHEET 1
DWN
APVD
D
D
NOTE:
SEE SHEET 1
1
C
C
TYPE-2,T2040244101-001,STAINLESS STEEL SCREW,NO LOGO
-2,T2040244101-001,
, LOGO
B
B
ALL SPEC DIMENSION REFER TO TYPE 1
TYPE 1
T2040244101-001
HE-024-MC
T2040244101-000
HE-024-MC
PART NUMBER
TOLERANCES UNLESS
DIMENSIONS:
mm
A
MATERIAL
1470-19 (3/13)
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
HE-024 MALE INSERT,CRIMPING,
HE-024 ,
, LOGO
TYPE-2
-2
HE-024 ,
TYPE-1
-1
PART DESCRIPTION
DWN
19Aug2014
CHK
19Aug2014
APVD
19Aug2014
Gino.Yao
Chris.Wang
Xiang.Xu
TYPE
TE Connectivity
NAME
PRODUCT SPEC
HE-024-MC
A
108-137044
APPLICATION SPEC
114-137044
WEIGHT
CUSTOMER DRAWING
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2040244101000
SCALE
1:1
SHEET
2
OF
2
REV
C
很抱歉,暂时无法提供与“T2040244101-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+123.309921+15.97295
- 10+104.8299610+13.57915
- 25+98.2584125+12.72790
- 50+93.5683550+12.12038
- 100+89.10344100+11.54202
- 250+83.52846250+10.81986
- 500+79.54530500+10.30390
- 1000+75.754001000+9.81280
- 国内价格
- 15+64.00977
- 50+62.48630
- 100+59.51192
- 250+56.42871
- 500+51.91877
- 1000+48.18265
