4
THIS DRAWING IS UNPUBLISHED.
C
1
RELEASED FOR PUBLICATION
REVISIONS
ALL RIGHTS RESERVED.
BY -
COPYRIGHT
2
3
P
A
111
B
C
33.8
D
19.1
34.1
( 21.1 )
1.
27
2.
B
GY
CW
ECR-15-013759
13Oct2015
DW
CW
ECR-21-106515
21JUL2021
SQ
CW
36
14
27
THIS DRAWING IS A CONTROLLED DOCUMENT.
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
DIMENSIONS:
mm
Panel cut out for inserts for using
without hoods/housings
1470-19 (3/13)
D
C
PC
500V
16A
>=400M ^
6KV
3
UL94V-0
500
-40 $ C~+125 $ C
0.14mm²~4mm² (AWG26-AWG12)
: T20300X10XX000)
B
104
95
104
APVD
07Jan2015
HE-024-MC 25-48
A
DWN
INITIAL
4 X M3 thread, recommended
tightening torque 0.5Nm
5
DATE
NOTES:
1. TECHNICAL CHARACTERISTICS:
INSULATION MATERIAL: PC
RATED VOLTAGE: 500V
RATED CURRENT: 16A
INSULATION RESISTANCE: >=400M ^
RATED IMPULSE VOLTAGE: 6KV
POLLUTION DEGREE: 3
FLAMMABILITY: UL94V-0
MATING CYCLES: 500 CYCLES
OPERATION TEMPERATURE: -40 $ C~+125 $ C
WIRE RANGE: 0.14mm²~4mm² (AWG26-AWG12 )
CONTACT TYPE: CRIMP CONTACT
2. CONTACTS NEED TO BE ORDERED SEPARATELY.
(ORDER No. REFER TO DRAWING:T20300X10XX000)
M4 thread, recommended
tightening torque 1.2Nm
C
DESCRIPTION
LTR
4X n 3.3
MATERIAL
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
DWN
05Jan2015
CHK
05Jan2015
APVD
05Jan2015
Gino.Yao
Chris.Wang
Xiang.Xu
DESCRIPTION
T2040484101-000
PART NUMBER
TE Connectivity
NAME
PRODUCT SPEC
HE-024-MC 25-48
A
108-137044
APPLICATION SPEC
114-137044
WEIGHT
CUSTOMER DRAWING
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2040484101000
SCALE
1:1
SHEET
1
OF
1
REV
C
很抱歉,暂时无法提供与“T2040244201-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+91.31078
- 50+89.22254
- 100+84.82232
- 250+80.53397
- 500+74.16981
- 1000+68.78762
- 国内价格 香港价格
- 1+129.019631+16.70936
- 10+109.6272110+14.19784
- 25+102.7625225+13.30879
- 50+97.8554250+12.67327
- 100+93.18612100+12.06855
- 250+87.35600250+11.31349
- 500+83.19052500+10.77402
- 1000+79.225351000+10.26049
- 国内价格
- 20+66.78052
- 50+65.25323
- 100+62.03321
- 250+58.90228
- 500+54.24406
- 1000+50.31130
- 国内价格
- 20+91.31078
- 50+89.22254
- 100+84.82232
- 250+80.53397
- 500+74.16981
- 1000+68.78762
