T2050102101-000
T2050102101-000
    HUMIREL(泰科)
    线对线连接器 12-26AWG
T2050102101-000 数据手册
4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 RELEASED FOR PUBLICATION REVISIONS ALL RIGHTS RESERVED. BY - P A B 51 D B1 C 4X M3 SCREW,RECOMMENDED TIGHTENING TORQUE 0.5Nm 4X M3 , 0.5Nm DL CW ECR-15-014907 14OCT2015 DL CW ECR-16-015492 18NOV2016 QY CW ECR-21-106767 09JUL2021 BS CW : : : : : : 18.5 DETAIL A 44 M4 SCREW,RECOMMENDED TIGHTENING TORQUE 1.2Nm M4 , 1.2Nm 2. D : : : : : ( C PC 500V 16A >=400M ^ : 6 KV 3 UL94V-0 500 0.14-4 mm² (26-12 AWG) . :T20300X10XX-000) B 27 B APVD 09MAR2015 1. 33.5 C DWN INITIAL RELEASE ( 21.15 ) 4:1 TYPE-1,T2050102101-000,TE LOGO -1,T2050102101-000,TE LOGO A DATE NOTES: 1. TECHNICAL CHARACTERISTICS: INSULATION MATERIAL: PC RATED VOLTAGE: 500 V RATED CURRENT: 16 A INSULATION RESISTANCE: >=400M ^ RATED IMPULSE VOLTAGE: 6 KV POLLUTION DEGREE: 3 FLAMMABILITY: UL94V-0 MATING CYCLES: 500 CYCLES WIRE RANGE: 0.14-4 mm² (26-12 AWG) CONTACT TYPE: CRIMP CONTACT 2. CONTACT NEED TO BE ORDERED SEPARATELY. (ORDER No. T20300X10XX-000) 34 DETAIL DESCRIPTION LTR 36 27 14 44 THIS DRAWING IS A CONTROLLED DOCUMENT. TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: A 5 35 PANEL CUT FOR INSERTS FOR USING WITHOUT HOODS/ HOUSINGS 1470-19 (3/13) 4X mm n 3.3 MATERIAL 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - DWN 09MAR2015 CHK 09MAR2015 APVD 09MAR2015 DAVID LI CHRIS WANG XU XIANG TE Connectivity NAME PRODUCT SPEC HEE-010-M A 108-106137 APPLICATION SPEC - 114-106137 WEIGHT Customer Drawing SIZE A3 CAGE CODE - DRAWING NO RESTRICTED TO - T2050102101000 SCALE 1:1 SHEET 1 OF 3 REV C 4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 RELEASED FOR PUBLICATION 1 20 REVISIONS ALL RIGHTS RESERVED. BY - P DESCRIPTION LTR - DATE SEE SHEET 1 DWN APVD - - - D D NOTE: SEE SHEET 1 : DETAIL 4:1 1 B C C DETAIL B TYPE-2,T2059102101-000,NO TE LOGO -2,T2059102101-000, TE LOGO B B ALL SPEC DIMENSION REFER TO TYPE 1 TYPE 1 THIS DRAWING IS A CONTROLLED DOCUMENT. TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: mm A MATERIAL 1470-19 (3/13) 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - DWN 09MAR2015 CHK 09MAR2015 APVD 09MAR2015 DAVID LI CHRIS WANG XU XIANG TE Connectivity NAME PRODUCT SPEC HEE-010-M A 108-106137 APPLICATION SPEC - 114-106137 WEIGHT Customer Drawing SIZE A3 CAGE CODE - DRAWING NO RESTRICTED TO - T2050102101000 SCALE 1:1 SHEET 2 OF 3 REV C 4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 RELEASED FOR PUBLICATION BY - 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. P DESCRIPTION LTR - DATE SEE SHEET 1 DWN APVD - - - D D NOTES: SEE SHEET 1 : 1 C C TYPE-3,T2050102101-001,STAINLESS STEEL SCREW,NO LOGO -3,T2050102101-001, , LOGO B T2050102101-001 ALL SPEC DIMENSION REFER TO TYPE 1 TYPE 1 T2059102101-000 HEE-010-M T2050102101-000 HEE-010-M PART NUMBER THIS DRAWING IS A CONTROLLED DOCUMENT. TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: mm A MATERIAL 1470-19 (3/13) HEE-010-M 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - HEE-010 MALE INSERT, STAINLESS STEEL SCREW,NO LOGO HEE-010 , , LOGO TYPE-3 -3 HEE-010 MALE INSERT HEE-010 TYPE-1 -1 HEE-010 MALE INSERT,NO TE LOGO HEE-010 , TE LOGO TYPE-2 -2 PART DESCRIPTION DWN 09MAR2015 CHK 09MAR2015 APVD 09MAR2015 DAVID LI CHRIS WANG XU XIANG TYPE TE Connectivity NAME PRODUCT SPEC HEE-010-M A 108-106137 APPLICATION SPEC - 114-106137 WEIGHT Customer Drawing B SIZE A3 CAGE CODE - DRAWING NO RESTRICTED TO - T2050102101000 SCALE 1:1 SHEET 3 OF 3 REV C
T2050102101-000 价格&库存
很抱歉,暂时无法提供与“T2050102101-000”相匹配的价格&库存,您可以联系我们找货
T2050102101-000
  • 20+55.34052
  • 50+54.09515
  • 100+51.44722
库存:112
T2050102101-000
    • 20+79.65144
    • 50+77.86152
    • 100+74.04551
    库存:10
    T2050102101-000
      • 20+79.65144
      • 50+77.86152
      • 100+74.04551
      库存:90
      T2050102101-000
        • 1+146.82600
        • 10+143.12160
        库存:5
        T2050102101-000
          • 1+28.92197
          库存:5
          T2050102101-000
          • 1+126.925831+16.43165
          • 10+107.8693410+13.96462
          • 30+99.8181530+12.92233
          • 50+96.2834850+12.46473
          • 100+91.68894100+11.86993
          • 250+85.95238250+11.12728
          • 500+81.85430500+10.59675
          • 1000+77.952321000+10.09161
          库存:17
