4
THIS DRAWING IS UNPUBLISHED.
C
COPYRIGHT
2
3
1
RELEASED FOR PUBLICATION
REVISIONS
ALL RIGHTS RESERVED.
BY -
P
DESCRIPTION
LTR
A2
77.5
A3
D
B
B1
DATE
DWN
APVD
ECR-15-004309
18MAR2015
DW
CW
ECR-15-007632
25MAY2015
DW
CW
ECR-15-014907
14OCT2015
DL
CW
ECR-16-015492
09NOV2016
QY
CW
D
27
18.5
33.5
( 1.2 )
C
M4 SCREW,RECOMMENDED
TIGHTENING TORQUE 1.2Nm
M4 ,
1.2Nm
4X M3 SCREW,RECOMMENDED
TIGHTENING TORQUE 0.5Nm
4X M3 ,
0.5Nm
NOTES:
1. TECHNICAL CHARACTERISTICS:
INSULATION MATERIAL: PC
RATED VOLTAGE: 500 V
RATED CURRENT: 16 A
INSULATION RESISTANCE: >=400M ^
RATED IMPULSE VOLTAGE: 6 KV
POLLUTION DEGREE: 3
FLAMMABILITY: UL94V-0
MATING CYCLES: 500 CYCLES
OPERATION TEMPERATURE: -40-+125 $ C
WIRE RANGE: 0.14-4 mm² (26-12 AWG)
CONTACT TYPE: CRIMP CONTACT
2. CONTACT NEED TO BE ORDERED SEPARATELY.
(ORDER No. REFER TO DRAWING:T20300X10XX000)
1.
34
PANEL CUT FOR INSERTS FOR USE
WITHOUT HOODS/ HOUSINGS
B
5
( 83.9 )
2.
TYPE-1,T2050322101-000,WITH TE LOGO
-1,T2050322101-000, TE LOGO
68.5
C
PC
500V
16A
>=400M ^
: 6 KV
3
UL94V-0
500
-40-+125 $ C
B
: T20300X10XX000)
14
27
36
THIS DRAWING IS A CONTROLLED DOCUMENT.
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
DIMENSIONS:
A
4X
3.3
mm
77.5
MATERIAL
1470-19 (3/13)
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
DWN
11JUN2014
CHK
11JUN2014
APVD
11JUN2014
David Wang
Chris Wang
Xiang Xu
TE Connectivity
NAME
PRODUCT SPEC
HEE-032-M
A
108-106137
APPLICATION SPEC
114-106137
WEIGHT
Customer Drawing
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2050322101000
SCALE
1:1
SHEET
1
OF
2
REV
B1
4
C
COPYRIGHT
BY -
2
3
1
REVISIONS
P
DESCRIPTION
LTR
DATE
SEE SHEET 1
DWN
APVD
D
D
NOTE:
ALL SPEC REFER TO TYPE 1
TYPE 1
C
C
TYPE-2,T2050322101-001,WITH STAINLESS STEEL SCREW,WITHOUT LOGO
-2,T2050322101-001,
, LOGO
B
B
T2050322101-001
HEE-032-M
T2050322101-000
HEE-032-M
PART NUMBER
mm
TOLERANCES UNLESS
A
MATERIAL
1470-19 (3/13)
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
TYPE-2
-2
HEE-032 MALE INSERT
HEE-032
TYPE-1
-1
PART DESCRIPTION
DIMENSIONS:
HEE-032 MALE INSERT,
HEE-032
, LOGO
DWN
11JUN2014
CHK
11JUN2014
APVD
11JUN2014
David Wang
Chris Wang
Xiang Xu
TYPE
TE Connectivity
NAME
PRODUCT SPEC
HEE-032-M
A
108-106137
APPLICATION SPEC
114-106137
WEIGHT
Customer Drawing
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2050322101000
SCALE
1:1
SHEET
2
OF
2
REV
B1
很抱歉,暂时无法提供与“T2050322101-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+95.33868
- 2+93.24550
- 3+91.24604
