T2050322201-000
T2050322201-000
    HUMIREL(泰科)
    线对线连接器 12-26AWG 32Pin(4x8)
T2050322201-000 数据手册
4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 1 20 RELEASED FOR PUBLICATION REVISIONS ALL RIGHTS RESERVED. BY - 20 2 3 P A2 77.5 D DESCRIPTION LTR A3 B B1 DATE DWN APVD ECR-15-004309 18MAR2015 DW CW ECR-15-007632 25MAY2015 DW CW ECR-15-014907 14OCT2015 DL CW ECR-16-015492 09NOV2016 QY CW D 27 NOTES: 1. TECHNICAL CHARACTERISTICS: INSULATION MATERIAL: PC RATED VOLTAGE: 500 V RATED CURRENT: 16 A INSULATION RESISTANCE: >=400M ^ RATED IMPULSE VOLTAGE: 6 KV POLLUTION DEGREE: 3 FLAMMABILITY: UL94V-0 MATING CYCLES: 500 CYCLES OPERATION TEMPERATURE: -40-+125 $ C WIRE RANGE: 0.14-4 mm² (26-12 AWG) CONTACT TYPE: CRIMP CONTACT 2. CONTACT NEED TO BE ORDERED SEPARATELY. (ORDER No. REFER TO DRAWING:T20300X20XX000) 18.3 36 ( 1.2 ) C M4 SCREW, RECOMMENDED TIGHTENING TORQUE 1.2Nm M4 , 1.2Nm 34 : 1. : : : : : 4X M3 SCREW,RECOMMENDED TIGHTENING TORQUE 0.5Nm 4X M3 , 0.5Nm : : : : : : ( 83.9 ) B 2. PANEL CUT FOR INSERTS FOR USE WITHOUT HOODS/ HOUSINGS 5 TYPE-1,T2050322201-000,WITH TE LOGO -1,T2050322201-000, TE LOGO THIS DRAWING IS A CONTROLLED DOCUMENT. 27 36 3.3 77.5 TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: mm A 1470-19 (3/13) PC 500V 16A >=400M ^ : 6 KV 3 UL94V-0 500 -40-+125 $ C 0.14-4 mm² (26-12 AWG) ( B . : T20300X20XX000) 68.5 14 4X C MATERIAL 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - DWN 11JUN2014 CHK 11JUN2014 APVD 11JUN2014 David Wang Chris Wang Xiang Xu TE Connectivity NAME PRODUCT SPEC HEE-032-F A 108-106137 APPLICATION SPEC - 114-106137 WEIGHT Customer Drawing SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO T2050322201000 SCALE 1:1 SHEET - 1 OF 2 REV B1 4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 RELEASED FOR PUBLICATION BY - 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. P DESCRIPTION LTR - DATE SEE SHEET 1 DWN APVD - - - D D NOTE: ALL SPEC REFER TO TYPE 1 : TYPE 1 C C TYPE-2,T2050322201-001,WITH STAINLESS STEEL SCREW,WITHOUT LOGO -2,T2050322201-001, , LOGO B B T2050322201-001 HEE-032-F T2050322201-000 HEE-032-F PART NUMBER mm TOLERANCES UNLESS OTHERWISE SPECIFIED: A MATERIAL 1470-19 (3/13) 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH TYPE-2 -2 HEE-032 FEMALE INSERT HEE-032 TYPE-1 -1 PART DESCRIPTION THIS DRAWING IS A CONTROLLED DOCUMENT. DIMENSIONS: HEE-032 FEMALE INSERT, WITH STAINLESS STEEL SCREW,WITHOUT LOGO HEE-032 , , LOGO - - DWN 11JUN2014 CHK 11JUN2014 APVD 11JUN2014 David Wang Chris Wang Xiang Xu TYPE TE Connectivity NAME PRODUCT SPEC HEE-032-F A 108-106137 APPLICATION SPEC - 114-106137 WEIGHT Customer Drawing SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO T2050322201000 SCALE 1:1 SHEET - 2 OF 2 REV B1
T2050322201-000
物料型号: - TYPE-1: T2050322201-000, 带有TE标志 - TYPE-2: T2050322201-001, 带有不锈钢螺钉,无标志
器件简介: - HEE-032-FEMALE INSERT,用于电气连接的插座元件
引脚分配: - 未提供详细的引脚分配信息
参数特性: - 工作温度:-40°C 至 +125°C - 绝缘电阻:≥400MΩ - 绝缘材料:PC(聚碳酸酯) - 额定电压:500V - 额定电流:16A - 额定脉冲电压:6kV - 污染等级:3 - 可燃性:UL94V-0 - 配对周期:500次 - 适用导线范围:0.14-4 mm² (26-12 AWG) - 接触类型:压接接触
功能详解: - 该插座元件设计用于电气连接,具有特定的工作温度和电气参数
应用信息: - 适用于电气连接,具体应用场景未详细说明
封装信息: - 未提供封装信息
T2050322201-000 价格&库存
很抱歉,暂时无法提供与“T2050322201-000”相匹配的价格&库存,您可以联系我们找货
T2050322201-000
  • 1+18.43380
库存:1
T2050322201-000
  • 1+154.498661+19.97794
