EN45545 COMPLIANT
HDC INSERTS
TE Connectivity (TE) ’s new range of inserts for heavy duty connectors
comply with the EN45545 European standard on flame retardancy for
materials and products in railway rolling stock.
The modular inserts provide customers with a high level of flexibility
when configuring railway connector systems. They can be configured to
hold anywhere from 1 to 216 pins and enable signal, data and power to
be transmitted via one single connector.
NEED PRODUCT
GROUP PHOTO
The EN45545 standard includes specifications on fire, smoke and
toxicity (FST) compliance. It provides three classifications of hazard
level, HL1, HL2 and HL3, with HL3 being the highest. The new inserts
from TE meet R22 and R23 requirement set on level HL3. They have an
operating temperature range that extends from - 40°C to 125°C.
APPLICATIONS
BENEFITS
• Rolling stock: traction converters, power distribution, inter-car
jumpers
ELECTRICAL
• HDD:
10A / 250V
• HEE:
16A / 500V
• HEEE:
16A / 400V and 16A / 500V
• HMN:
Modular system, various performance
levels from 5A to 200A and 50V to 1000V
• Compliance with safety regulations
• Reliable electrical connection
• High flexibility and possibility of creating
a customized interface
• Time-saving with easy assembly of the
modular inserts
• Decrease installation cost with system
modularity design
MECHANICAL
• Operating temperature range from -40°C to 125°C
MATERIAL
• Material approved according to R22 and R23 requirement set for
hazard levels: HL1, HL2 and HL3, per EN45545, with Oxygen index per
EN ISO 4589-2 / Smoke density per EN ISO 5659-2 / Toxicity per NF
X 70-100-1/-2
APPLICATIONS AND SPECIFICATIONS
• EN45545: Fire protection on railway vehicles -Railway applications
• EN61984: Connectors - safety requirements and tests
• EN 50467: Electrical connectors - requirements and test - Railway
applications
• IEC 60512: Connectors for electronic equipment -Test and
measurements
• IEC 60664-1: Insulation coordination for equipment within lowvoltage systems (Part 1)
• EN 61373: Rolling stock equipment - shock and vibration test Railway applications
INDUSTRIAL /// EN45545 COMPLIANT HDC INSERTS
KEY FEATURES
• Fire, smoke and toxicity compliance per the
EN45545
• Several insert series, with possible pin
configuration from 1 to 216 pins in 1 connector
• Modular system with a time-saving one-piece
connector frame
PRODUCT OFFERINGS
HDC Insert Series
HDD Series
HEE Series
HEEE Series
Part number
Description
Poles
Current
Voltage
T2031082101-007
HDD-108-M
108+PE
10A
250V
T2032162101-007
HDD-108-M 109-216
108+PE
10A
250V
T2031082201-007
HDD-108-F
108+PE
10A
250V
T2032162201-007
HDD-108-F 109-216
108+PE
10A
250V
T2050102101-007
HEE-010-M
10+PE
16A
500V
T2050102201-007
HEE-010-F
10+PE
16A
500V
T2050182101-007
HEE-018-M
18+PE
16A
500V
T2050182201-007
HEE-018-F
18+PE
16A
500V
T2050322101-007
HEE-032-M
32+PE
16A
500V
T2050642101-007
HEE-032-M 33-64
32+PE
16A
500V
T2050322201-007
HEE-032-F
32+PE
16A
500V
T2050642201-007
HEE-032-F 33-64
32+PE
16A
500V
T2050462101-007
HEE-046-M
46+PE
16A
500V
T2050922101-007
HEE-046-M 47-92
46+PE
16A
500V
T2050462201-007
HEE-046-F
46+PE
16A
500V
T2050922201-007
HEE-046-F 47-92
46+PE
16A
500V
T2050202101-007
HEEE-020-M
20+PE
16A
400V
T2050202201-007
HEEE-020-F
20+PE
16A
400V
T2050323101-007
HEEE-032-M
32+PE
16A
400V
T2050323201-007
HEEE-032-F
32+PE
16A
400V
T2050402101-007
HEEE-040-M
40+PE
16A
500V
500V
T2050802101-007
HEEE-040-M 41-80
40+PE
16A
T2050402201-007
HEEE-040-F
40+PE
16A
500V
T2050802201-007
HEEE-040-F 41-80
40+PE
16A
500V
T2050482101-007
HEEE-048-M
48+PE
16A
400V
T2050962101-007
HEEE-048-M 49-96
48+PE
16A
400V
T2050482201-007
HEEE-048-F
48+PE
16A
400V
400V
T2050962201-007
HEEE-048-F 49-96
48+PE
16A
T2050643101-007
HEEE-064-M
64+PE
16A
500V
T2051283101-007
HEEE-064-M 65-128
64+PE
16A
500V
T2050643201-007
HEEE-064-F
64+PE
16A
500V
T2051283201-007
HEEE-064-F 65-128
64+PE
16A
500V
T2050722101-007
HEEE-072-M
72+PE
16A
400V
T2051442101-007
HEEE-072-M 73-144
72+PE
16A
400V
T2050722201-007
HEEE-072-F
72+PE
16A
400V
T2051442201-007
HEEE-072-F 73-144
72+PE
16A
400V
Contacts
CDM/F(10A)
DDM/F(10A)
CJM/F(10A)
CEM/F(16A)
DEM/F(16A)
CEM/F(16A)
DEM/F(16A)
CEM/F(16A)
DEM/F(16A)
PRODUCT OFFERINGS
HDC Insert Series
HMN Series
Part number
Description
Poles
Current
Voltage
T2111013101-007
HMN-001-MC
1
200A
1000V
T2111013201-007
HMN-001-FC
1
200A
1000V
T2111020101-007
HMN-002-MC
2
70A
1000V
T2111020201-007
HMN-002-FC
2
70A
1000V
T2111028101-007
HMN-D2-MC
2
100A
1000V
T2111028201-007
HMN-D2-FC
2
100A
1000V
T2111032101-007
HMN-003-M
3
40A
690V
T2111032201-007
HMN-003-F
3
40A
690V
T2111042101-007
HMN-004-M
4
40A
830V
T2111042201-007
HMN-004-F
4
40A
830V
T2111062101-007
HMN-006-M
6
16A
500V
T2111062201-007
HMN-006-F
6
16A
500V
T2111063101-007
HMN-006-PM
6
16A
830V
T2111063201-007
HMN-006-PF
6
16A
830V
T2111082101-007
HMN-008-M
8
16A
400V
T2111082201-007
HMN-008-F
8
16A
400V
T2111092101-007
HMN-009-M
9
5A
50V
T2111092201-007
HMN-009-F
9
5A
50V
T2111122101-007
HMN-012-M
12
10A
250V
T2111122201-007
HMN-012-F
12
10A
250V
T2111172101-007
HMN-017-M
17
10A
160V
T2111172201-007
HMN-017-F
17
10A
160V
T2111202101-007
HMN-020-M
16A
500V
T2111202201-007
HMN-020-F
16A
500V
T2111252101-007
HMN-025-M
25
5A
50V
T2111252201-007
HMN-025-F
25
5A
50V
T2111027101-007
HMN-Q1-M
1+1
16A
50V
T2111027201-007
HMN-Q1-F
1+1
16A
50V
T2111027101-701
HMN-Q2-M
4+4
10A
50V
T2111027201-701
HMN-Q2-F
4+4
10A
50V
T2111027101-702
HMN-Q3-M
8+8
5A
50V
T2111027201-702
HMN-Q3-F
8+8
5A
50V
T2580011154-007
PIN-Q1-M
1
16A
50V
T2580012154-007
PIN-Q1-F
1
16A
50V
T2580031154-007
PIN-Q2-M
4
10A
50V
T2580032154-007
PIN-Q2-F
4
10A
50V
T2580081154-007
PIN-Q3-M
8
5A
50V
T2580082154-007
PIN-Q3-F
8
5A
50V
T2580011154-701
PIN-Q2-M1
1
10A
50V
T2580012154-701
PIN-Q2-F1
1
10A
50V
T3110009902-007
HMN-DM
Contacts
CHM/F(200A)
CSM/F(70A)
CNM/F(100A)
CMM/F(40A)
DMM/F(40A)
CMM/F(40A)
DMM/F(40A)
CEM/F(16A)
DEM/F(16A)
CEM/F(16A)
DEM/F(16A)
CAM/F(5A)
DAM/F(5A)
CDM/F(10A)
DDM/F(10A)
CDM/F(10A)
DDM/F(10A)
CEM/F(16A)
DEM/F(16A)
CAM/F(5A)
DAM/F(5A)
CEM/F(16A)
DEM/F(16A)
CDM/F(10A)
DDM/F(10A)
CAM/F(5A)
DAM/F(5A)
CEM/F(16A)
DEM/F(16A)
CDM/F(10A)
DDM/F(10A)
CAM/F(5A)
DAM/F(5A)
CDM/F(10A)
DDM/F(10A)
Blind Module
te.com
© 2018 TE Connectivity. All Rights Reserved. TE, TE Connectivity, and the TE connectivity (logo) are trademarks of the TE Connectivity Ltd. family of companies. Other logos, product and Company
names mentioned herein may be trademarks of their respective owners.
While TE has made every reasonable effort to ensure the accuracy of the information in this brochure, TE does not guarantee that it is error-free, nor does TE make any other representation, warranty or
guarantee that the information is accurate, correct, reliable or current. TE reserves the right to make any adjustments to the information contained herein at any time without notice. TE expressly disclaims
all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability or fitness for a particular purpose. The dimensions in this catalog
are for reference purposes only and are subject to change without notice. Specifications are subject to change without notice. Consult TE for the latest dimensions and design specifications.
1-1773952-4 SL 05/2018
很抱歉,暂时无法提供与“T2050462101-007”相匹配的价格&库存,您可以联系我们找货
