T2050722101-000
T2050722101-000
    HUMIREL(泰科)
    线对线连接器 12-26AWG 72Pin
T2050722101-000 数据手册
4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 RELEASED FOR PUBLICATION REVISIONS ALL RIGHTS RESERVED. BY - P DESCRIPTION LTR A B D C 111 M4 THREAD, RECOMMENDED TIGHTENING TORQUE 1.2Nm 33 C 1.2 05MAR2015 DW CW ECR-15-015267 22OCT2015 DW CW ECR-21-111798 03SEP2021 WQR CW : : : : : : : : : : : : : 27 PANEL CUT FOR INSERTS FOR USE WITHOUT HOODS/ HOUSINGS 7 98 104 4X 2. 3.3 ( THIS DRAWING IS A CONTROLLED DOCUMENT. TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: mm A 104 MATERIAL 1470-19 (3/13) 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - DWN 05MAR2015 CHK 05MAR2015 APVD 05MAR2015 David Wang Chris Wang Xiang Xu B . : T20300X10XX000) HEEE-072-M 36 T2050722101-000 DESCRIPTION PART NUMBER TE Connectivity NAME PRODUCT SPEC HEEE-072-M A 108-137068 APPLICATION SPEC - 114-137068 WEIGHT Customer Drawing D C PC 400V 16A >=400M ^ 6KV 3 UL94V-0 500 -40 $ C~+125 $ C 0.14mm²~4mm² (AWG26-AWG12) 21 27 APVD INITIAL 1. 4X M3 THREAD, RECOMMENDED TIGHTENING TORQUE 0.5Nm B DWN NOTES: 1. TECHNICAL CHARACTERISTICS: INSULATION MATERIAL: PC RATED VOLTAGE: 400V RATED CURRENT: 16A INSULATION RESISTANCE: >=400M ^ RATED IMPULSE VOLTAGE: 6KV POLLUTION DEGREE: 3 FLAMMABILITY: UL94V-0 MATING CYCLES: 500 CYCLES OPERATION TEMPERATURE: -40 $ C~+125 $ C WIRE RANGE: 0.14mm²~4mm² (AWG26-AWG12) CONTACT TYPE: CRIMP CONTACT 2. CONTACTS NEED TO BE ORDERED SEPARATELY. (ORDER No. REFER TO DRAWING: T20300X10XX000) 34 17.3 DATE SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO - T2050722101000 SCALE 1:1 SHEET 1 OF 1 REV C
T2050722101-000 价格&库存
很抱歉,暂时无法提供与“T2050722101-000”相匹配的价格&库存,您可以联系我们找货
T2050722101-000
    • 1+99.33840
    • 10+86.19696
    库存:1
    T2050722101-000
      库存:70
      T2050722101-000
        • 1+90.14040
        库存:1
        T2050722101-000
        • 6+164.40136
        • 15+161.36652
        • 29+158.33168
        • 45+152.16527
        • 50+148.67097
        库存:74
        T2050722101-000
          • 6+236.61748
          • 15+232.24212
          • 29+227.87919
          • 45+219.00417
          • 50+213.97002
          库存:34
          T2050722101-000
            • 6+236.61748
            • 15+232.24212
            • 29+227.87919
            • 45+219.00417
            • 50+213.97002
            库存:40
            T2050722101-000
            • 1+301.361781+39.03689
