4
THIS DRAWING IS UNPUBLISHED.
C
COPYRIGHT
3
1
RELEASED FOR PUBLICATION
REVISIONS
ALL RIGHTS RESERVED.
BY -
P
DESCRIPTION
LTR
A
A1
44
D
A2
DWN
APVD
INITIAL
28FEB2015
DW
CW
ECR-16-000601
14JAN2016
DW
CW
ECR-16-017508
10DEC2016
RL
CW
ECR-21-122216
08DEC2021
WQR
CW
D
27
B
DATE
NOTES:
1. TECHNICAL CHARACTERISTICS:
FRAME MATERIAL: DIE CAST ZINC ALLOY
NUMBER OF MODULES: 2
SURFACE: ZINC PLATED
MATING CYCLES: 500 CYCLES
4X M3 SCREW
RECOMMENDED TIGHTENING
TORQUE 0.5Nm
4X M3
0.5Nm
2
1.
15.7
30.3
C
C
51
34
2X M4 SCREW,RECOMMENDED
TIGHTENING TORQUE 1.2Nm
2X M4
1.2Nm
: 2
: 500
44
4X R 2
35
3.3
27
4X
20.5
B
T2070064001-000 SHOWN ABOVE
WITHOUT MARK
T2070064001-000,
35
mm
52
A
PANEL CUT FOR FRAME USE
WITHOUT HOODS/ HOUSINGS
1470-19 (3/13)
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
DIMENSIONS:
MATERIAL
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
H6BN MODULE FRAME
H6BN
T2070064001-000
H6BN-T2
T2070064101-000
H6BN-T2-M
T2070064201-000
H6BN-T2-F
PART NUMBER
THIS DRAWING IS A CONTROLLED DOCUMENT.
DWN
28FEB2015
CHK
28FEB2015
APVD
28FEB2015
DAVID WANG
CHRIS WANG
XIANG XU
B
H6BN MALE MODULE FRAME
H6BN
H6BN FEMALE MODULE FRAME
H6BN
PART DESCRIPTION
TE Connectivity
NAME
PRODUCT SPEC
H6BN-T2
A
108-137057
APPLICATION SPEC
114-137057
WEIGHT
Customer Drawing
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2070064001000
SCALE
1:1
SHEET
1
OF
2
REV
B
4
C
COPYRIGHT
BY -
2
3
1
REVISIONS
P
DESCRIPTION
LTR
DATE
SEE SHEET 1
DWN
APVD
D
D
T2070064101-000,H6BN-T2-M SHOWN
WITH MARK,ALL DIMENSIONS THE SAME TO T2070064001-000
T2070064101-000,H6BN-T2-M,
T2070064001-000
C
C
T2070064201-000,H6BN-T2-F SHOWN
T2070064201-000,H6BN-T2-F,
T2070064001-000
B
B
TOLERANCES UNLESS
DIMENSIONS:
mm
A
MATERIAL
1470-19 (3/13)
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
DWN
28FEB2015
CHK
28FEB2015
APVD
28FEB2015
DAVID WANG
CHRIS WANG
XIANG XU
PRODUCT SPEC
TE Connectivity
NAME
H6BN-T2
A
108-137057
APPLICATION SPEC
114-137057
WEIGHT
CUSTOMER DRAWING
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2070064001000
SCALE
1:1
SHEET
2
OF
2
REV
B
很抱歉,暂时无法提供与“T2070064001-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+121.974091+15.85624
- 10+103.6390110+13.47274
- 30+95.9027130+12.46704
- 50+92.5094550+12.02593
- 100+88.09407100+11.45195
- 250+82.58198250+10.73539
- 500+78.64435500+10.22351
- 1000+74.894941000+9.73610
