T2070104001-000
T2070104001-000
    HUMIREL(泰科)
    胶壳及附件 重载连接器 H10BN-T3
T2070104001-000 数据手册
4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 1 20 RELEASED FOR PUBLICATION REVISIONS ALL RIGHTS RESERVED. BY - 20 2 3 P DESCRIPTION LTR A A1 57 D A2 DWN APVD INITIAL 28FEB2015 DW CW ECR-16-000601 14JAN2016 DW CW ECR-16-017508 10DEC2016 RL CW ECR-21-122216 08DEC2021 WQR CW D 27 B DATE NOTES: 1. TECHNICAL CHARACTERISTICS: FRAME MATERIAL: DIE CAST ZINC ALLOY NUMBER OF MODULES: 3 SURFACE: ZINC PLATED MATING CYCLES: 500 CYCLES 4X M3 SCREW RECOMMENDED TIGHTENING TORQUE 0.5Nm 4X M3 0.5Nm 2X M4 SCREW,RECOMMENDED TIGHTENING TORQUE1.2Nm 2X M4 , 1.2Nm 4X R 2 T2070104001-000 SHOWN ABOVE WITHOUT MARK T2070104001-000, 49 mm 66 PANEL CUT FOR FRAME USE WITHOUT HOODS/ HOUSINGS 1470-19 (3/13) TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: MATERIAL 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH T2070104001-000 H10BN-T3 T2070104101-000 H10BN-T3-M T2070104201-000 H10BN-T3-F H10BN MODULE FRAME H10BN H10BN MALE MODULE FRAME H10BN H10BN FEMALE MODULE FRAME H10BN PART NUMBER THIS DRAWING IS A CONTROLLED DOCUMENT. A B 34 57 35 3.3 27 4X C 64.1 20.5 B : : : 3 : : 500 15.7 30.3 2 C : 1. - - DWN 28FEB2015 CHK 28FEB2015 APVD 28FEB2015 DAVID WANG CHRIS WANG XIANG XU PART DESCRIPTION TE Connectivity NAME PRODUCT SPEC H10BN-T3 A 108-137057 APPLICATION SPEC - 114-137057 WEIGHT Customer Drawing SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO - T2070104001000 SCALE 1:1 SHEET 1 OF 2 REV B 4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 RELEASED FOR PUBLICATION BY - 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. P DESCRIPTION LTR - DATE SEE SHEET 1 DWN APVD - - - D D T2070104101-000,H10BN-T3-M SHOWN WITH MARK,ALL DIMENSIONS THE SAME TO T2070104001-000 T2070104101-000,H10BN-T3-M, , T2070104001-000 C C T2070104201-000,H10BN-T3-F SHOWN WITH MARK,ALL DIMENSIONS THE SAME TO T2070104001-000 T2070104201-000,H10BN-T3-F, , T2070104001-000 B B THIS DRAWING IS A CONTROLLED DOCUMENT. TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: mm A MATERIAL 1470-19 (3/13) 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - DWN 28FEB2015 CHK 28FEB2015 APVD 28FEB2015 DAVID WANG CHRIS WANG XIANG XU TE Connectivity NAME PRODUCT SPEC H10BN-T3 A 108-137057 APPLICATION SPEC - 114-137057 WEIGHT Customer Drawing SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO - T2070104001000 SCALE 1:1 SHEET 2 OF 2 REV B
T2070104001-000 价格&库存
很抱歉,暂时无法提供与“T2070104001-000”相匹配的价格&库存,您可以联系我们找货
T2070104001-000
  • 1+40.00001
库存:1
