T2070164001-000
T2070164001-000
    HUMIREL(泰科)
    胶壳及附件 重载连接器 H16BN-T4
T2070164001-000 数据手册
4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 RELEASED FOR PUBLICATION REVISIONS ALL RIGHTS RESERVED. BY - P A1 77.5 D DESCRIPTION LTR A2 B DWN APVD ECR-16-000601 14JAN2016 DW CW ECR-16-017508 12DEC2016 RL CW ECR-18-005861 03AUG2018 YC CW ECR-21-122216 09DEC2021 WQR CW D 27 C DATE NOTES: 1. TECHNICAL CHARACTERISTICS: FRAME MATERIAL: DIE CAST ZINC ALLOY NUMBER OF MODULES: 4 SURFACE: ZINC PLATED MATING CYCLES: 500 CYCLES 4X M3 SCREW RECOMMENDED TIGHTENING TORQUE 0.5Nm 4X M3 0.5Nm : : : 4 : : 500 C 2 15.7 30.3 C : 1. 2X M4 SCREW,RECOMMENDED TIGHTENING TORQUE1.2Nm 2X M4 , 1.2Nm 34 84.5 B PANEL CUT FOR FRAME USE WITHOUT HOODS/ HOUSINGS 4X 3.3 T2070164001-000 SHOWN ABOVE WITHOUT MARK T2070164001-000, 77.5 T2070164001-000 H16BN-T4 T2070164101-000 H16BN-T4-M T2070164201-000 H16BN-T4-F H16BN MODULE FRAME H16BN H16BN MALE MODULE FRAME H16BN H16BN FEMALE MODULE FRAME H16BN 35 27 20.5 PART NUMBER 4X R 2 THIS DRAWING IS A CONTROLLED DOCUMENT. TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: mm A 64 85.5 1470-19 (3/13) MATERIAL 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - DWN 28FEB2015 CHK 28FEB2015 APVD 28FEB2015 DAVID WANG CHRIS WANG XIANG XU B PART DESCRIPTION TE Connectivity NAME PRODUCT SPEC H16BN-T4 A 108-137057 APPLICATION SPEC - 114-137057 WEIGHT Customer Drawing SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO - T2070164001000 SCALE 1:1 SHEET 1 OF 2 REV C 4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 RELEASED FOR PUBLICATION BY - 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. P DESCRIPTION LTR - DATE SEE SHEET 1 DWN APVD - - - D D T2070164101-000,H16BN-T4-M SHOWN WITH MARK,ALL DIMENSIONS THE SAME TO T2070164001-000 T2070164101-000,H16BN-T4-M, , T2070164001-000 C C T2070164201-000,H16BN-T4-F SHOWN WITH MARK,ALL DIMENSIONS THE SAME TO T2070164001-000 T2070164201-000,H16BN-T4-F, , T2070164001-000 B B THIS DRAWING IS A CONTROLLED DOCUMENT. TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: mm A MATERIAL 1470-19 (3/13) 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - DWN 28FEB2015 CHK 28FEB2015 APVD 28FEB2015 DAVID WANG CHRIS WANG XIANG XU TE Connectivity NAME PRODUCT SPEC H16BN-T4 A 108-137057 APPLICATION SPEC - 114-137057 WEIGHT Customer Drawing SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO - T2070164001000 SCALE 1:1 SHEET 2 OF 2 REV C
T2070164001-000 价格&库存
很抱歉,暂时无法提供与“T2070164001-000”相匹配的价格&库存,您可以联系我们找货
T2070164001-000
    • 8+37.10977
    库存:120
    T2070164001-000
      T2070164001-000
        • 15+124.23785
        • 30+121.91344
        • 55+119.60146
        库存:6
        T2070164001-000
          • 15+124.23785
          • 30+121.91344
          • 55+119.60146
          库存:1
          T2070164001-000
            • 15+124.23785
            • 30+121.91344
            • 55+119.60146
            库存:20
            T2070164001-000
              • 8+30.77320
              库存:104
              T2070164001-000
              • 15+90.86070
              • 30+89.16796
              • 55+87.47522
              库存:107
              T2070164001-000
              • 1+43.79249
