4
THIS DRAWING IS UNPUBLISHED.
C
COPYRIGHT 20
2
3
RELEASED FOR PUBLICATION
REVISIONS
ALL RIGHTS RESERVED.
BY -
1
P
DESCRIPTION
LTR
B2
B3
D
B4
M3 SCREW,RECOMMENDED
TIGHTENING TORQUE 0.2Nm
M3 ,
0.2Nm
C
DWN
APVD
ECR-16-009730
06JUL2016
BS
CW
ECR-16-018198
10FEB2017
QY
CW
ECR-18-016602
08NOV2018
CH
CW
ECR-21-117384
09NOV2021
WQR
CW
D
NOTES:
1. TECHNICAL CHARACTERISTICS:
INSULATION MATERIAL: PC
RATED VOLTAGE: 400V
RATED CURRENT: 16A
INSULATION RESISTANCE: >=400M ^
RATED IMPULSE VOLTAGE: 4KV
POLLUTION DEGREE: 3
FLAMMABILITY: UL94V-0
MATING CYCLES: 500 CYCLES
WIRE RANGE: 0.14-4.0mm² (26-12AWG)
CONTACT TYPE: CRIMP CONTACT
2. CONTACT NEED TO BE ORDERED SEPARATELY.
(ORDER No. REFER TO DRAWING:T20300X10XX000)
M3 ,
0.2Nm
C
1.
30.70
39.40
21.00
DATE
21.00
B
2.
C
PC
400V
16A
>=400M ^
: 4KV
3
UL94V-0
500
: T20300X10XX000)
B
TYPE-1:T2080052101-000,TE LOGO
TYPE-2:T2080052101-001,STAINLESS STEEL SCREW,TE LOGO
-2:T2080052101-001,
,TE LOGO
THIS DRAWING IS A CONTROLLED DOCUMENT.
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
DIMENSIONS:
mm
A
GROUNDING CONTACT TYPE: SCREW CONTACT
GROUNDING CONTACT FINISH: SILVER PLATED
WIRE RANGE: 2.5mm (AWG14)
:2.5mm²(AWG14)
1470-19 (3/13)
MATERIAL
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
10JAN2015
DAVID.WANG
CHK
10JAN2015
CHRIS.WANG
APVD
10JAN2015
XIANG.XU
DWN
PRODUCT SPEC
TE Connectivity
NAME
HQ-005-M
A
108-137054
APPLICATION SPEC
114-137054
WEIGHT
Customer Drawing
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2080052101000
SCALE
2:1
SHEET
1
OF
2
REV
C
4
C
COPYRIGHT 20
2
3
REVISIONS
BY -
1
P
DESCRIPTION
LTR
D
DATE
SEE SHEET 1
DWN
APVD
D
NOTES:
SEE SHEET 1
C
C
TYPE-4:T2080052101-003, THIS TYPE IS SAME
AS TYPE-1, ONLY DIFFERENT MALE
GROUNDING CONTACT.
-4:T2080052101-003,
-1,
B
T2080052101-003
ALL DIMENSIONS ARE SAME AS TYPE-1,
EXCEPT THOSE DEFINED IN THIS TYPE.
-1
HQ-005-M
T2080052101-002
HQ-005-M
T2080052101-001
HQ-005-M
T2080052101-000
HQ-005-M
PART NUMBER
SCALE
A
1:1
mm
TYPE-3:T2080052101-002,STAINLESS STEEL SCREW,NO LOGO
-3:T2080052101-002,
, LOGO
MATERIAL
1470-19 (3/13)
TOLERANCES UNLESS
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
TYPE-4
-4
HQ-005 MALE INSERT,
HQ-005
, LOGO
TYPE-3
-3
HQ-005 MALE INSERT, STAINLESS STEEL SCREW
HQ-005
HQ-005 MALE INSERT
HQ-005
10JAN2015
DAVID.WANG
CHK
10JAN2015
CHRIS.WANG
APVD
10JAN2015
XIANG.XU
TYPE-1
-1
TYPE
DWN
PRODUCT SPEC
TE Connectivity
NAME
HQ-005-M
A
108-137054
APPLICATION SPEC
B
TYPE-2
-2
PART DESCRIPTION
DIMENSIONS:
HQ-005 MALE INSERT
HQ-005
114-137054
WEIGHT
Customer Drawing
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2080052101000
SCALE
2:1
SHEET
2
OF
2
REV
C
很抱歉,暂时无法提供与“T2080052101-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 40+27.64004
- 50+26.96294
- 100+25.71757
- 250+24.37546
- 500+22.45300
- 1000+20.83280
- 国内价格
- 1+43.08205
- 10+39.68714
- 25+35.71947
