4
THIS DRAWING IS UNPUBLISHED.
C
COPYRIGHT
3
1
RELEASED FOR PUBLICATION
REVISIONS
ALL RIGHTS RESERVED.
BY -
P
DESCRIPTION
LTR
B1
B2
D
B3
C
DATE
DWN
APVD
ECR-15-016505
11NOV2015
DL
CW
ECR-16-009730
06JUL2016
BS
CW
ECR-16-018198
13FEB2017
QY
CW
ECR-21-117384
09NOV2021
WQR
CW
D
NOTES:
M3
C
1. TECHNICAL CHARACTERISTICS:
INSULATION MATERIAL: PC
RATED VOLTAGE: 400 V
RATED CURRENT: 16 A
INSULATION RESISTANCE: >=400M ^
RATED IMPULSE VOLTAGE: 4 KV
POLLUTION DEGREE: 3
FLAMMABILITY: UL94V-0
MATING CYCLES: 500 CYCLES
WIRE RANGE: 0.14-4.0 mm² (26-12 AWG)
CONTACT TYPE: CRIMP CONTACT
2. CONTACT NEED TO BE ORDERED SEPARATELY.
(ORDER No. REFER TO DRAWING:T20300X20XX000)
M3 SCREW
RECOMMENDED
TIGHTENING
TORQUE 0.2Nm
0.2Nm
40.1
31.4
1.
2.
M3 SCREW RECOMMENDED
TIGHTENING TORQUE 0.2Nm
M3
0.2Nm
B
THIS DRAWING IS A CONTROLLED DOCUMENT.
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
DIMENSIONS:
mm
1470-19 (3/13)
: T20300X20XX000)
B
TYPE-2:T2080052201-001 STAINLESS STEEL SCREW,TE LOGO
-2:T2080052201-001
,TE LOGO
21
GROUNDING CONTACT TYPE: SCREW CONTACT
GROUNDING CONTACT FINISH: SILVER PLATED
WIRE RANGE: 2.5mm (AWG14)
:2.5mm²(AWG14)
PC
400V
16A
>=400M ^
: 4 KV
3
UL94V-0
500
TYPE-1:T2080052201-000 TE LOGO
21
A
C
MATERIAL
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
DWN
10JAN2015
CHK
10JAN2015
APVD
10JAN2015
David Wang
Chris Wang
Xiang Xu
TE Connectivity
NAME
PRODUCT SPEC
HQ-005-F
A
108-137054
APPLICATION SPEC
114-137054
WEIGHT
Customer Drawing
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2080052201000
SCALE
2:1
SHEET
1
OF
2
REV
C
4
C
COPYRIGHT
3
BY -
1
REVISIONS
P
DESCRIPTION
LTR
DATE
SEE SHEET 1
DWN
APVD
D
D
NOTES:
SEE SHEET 1
1
C
C
TYPE-3:T2080052201-002 STAINLESS STEEL SCREW,NO LOGO
-3:T2080052201-002
, LOGO
B
ALL DIMENSIONS ARE SAME AS TYPE 1,
EXCEPT THOSE DEFINED IN THIS TYPE.
1
T2080052201-002
HQ-005-F
T2080052201-001
HQ-005-F
T2080052201-000
HQ-005-F
PART NUMBER
TOLERANCES UNLESS
DIMENSIONS:
A
MATERIAL
1470-19 (3/13)
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
TYPE-3
-3
HQ-005 FEMALE INSERT
HQ-005
TYPE-1
-1
HQ-005 FEMALE INSERT, STAINLESS STEEL SCREW
HQ-005
FINISH
DWN
10JAN2015
CHK
10JAN2015
APVD
10JAN2015
David Wang
Chris Wang
Xiang Xu
TYPE
TE Connectivity
NAME
PRODUCT SPEC
HQ-005-F
A
108-137054
APPLICATION SPEC
114-137054
WEIGHT
Customer Drawing
B
TYPE-2
-2
PART DESCRIPTION
mm
HQ-005
, LOGO
SIZE
CAGE CODE
A3 00779
DRAWING NO
RESTRICTED TO
T2080052201000
SCALE
2:1
SHEET
2
OF
2
REV
C
很抱歉,暂时无法提供与“T2080052201-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+43.15494
- 10+39.63507
- 25+35.84443
- 国内价格
- 40+29.87687
- 50+29.06677
- 100+27.72467
- 250+26.28584
- 500+24.21828
- 1000+22.42881
- 国内价格 香港价格
- 1+57.055241+7.41579
- 10+48.4629410+6.29900
- 30+44.8417230+5.82833
- 50+43.2531450+5.62186
- 100+41.18925100+5.35360
- 250+38.61045250+5.01842
- 500+36.76838500+4.77900
- 1000+35.014711000+4.55106
- 2500+32.825372500+4.26650
