T2110052201-000
T2110052201-000
    HUMIREL(泰科)
    母头 模块 灰色 5 位置 张力夹
T2110052201-000 数据手册
T2110052201-000 Rectangular Contact Inserts, Contact Insert, Socket, 5 Pole Configuration, Spring Terminal, 5 Position, 14 – 20 AWG Wire Size, HDC HMN T2110052201-000  ACTIVE HDC | HDC HMN TE Internal #: T2110052201-000 Rectangular Contact Inserts, Contact Insert, Socket, 5 Pole Configuration, Spring Terminal, 5 Position, 14 – 20 AWG Wire Size, HDC HMN View on TE.com > Connectors > Rectangular Connectors > Rectangular Contact Inserts Rectangular Connector Insert Type: Contact Insert Contact Type: Socket Pole Configuration: 5 Termination Method to Wire & Cable: Spring Terminal Number of Positions: 5 Features Product Type Features Rectangular Connector Insert Type Contact Insert Sealable No Configuration Features Number of Positions 5 Contact Features Contact Type Socket Pole Configuration 5 Contact Current Rating (Max) 16 A Termination Features Termination Method to Wire & Cable Spring Terminal Dimensions Wire Size .5 – 2.5 mm² Operation/Application  Circuit Application For support call+1 800 522 6752 Power & Signal 01/03/2024 12:30AM | Page 1 T2110052201-000 Rectangular Contact Inserts, Contact Insert, Socket, 5 Pole Configuration, Spring Terminal, 5 Position, 14 – 20 AWG Wire Size, HDC HMN Circuit Application Power & Signal Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant EU ELV Directive 2000/53/EC Compliant China RoHS 2 Directive MIIT Order No 32, 2016 No Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) Does not contain REACH SVHC Halogen Content Low Bromine/Chlorine - Br and Cl < 900 ppm per homogenous material. Also BFR /CFR/PVC Free Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach Compatible Parts TE Part # T1500063000-000 TE Part # T1010062100-000 TE Part # T2110052101-000 TE Part # T2070064201-000 H6B-AG H6B-KDBP HMN-005-MS H6BN-T2-F Also in the Series HDC HMN  For support call+1 800 522 6752 01/03/2024 12:30AM | Page 2 T2110052201-000 Rectangular Contact Inserts, Contact Insert, Socket, 5 Pole Configuration, Spring Terminal, 5 Position, 14 – 20 AWG Wire Size, HDC HMN Connector Contacts(2) Connector Hardware(16) Insertion & Extraction Tools(1) Rectangular Contact Inserts(119) Customers Also Bought TE Part #T2040242101-000 TE Part #T1210100120-000 TE Part #T2070244001-000 TE Part #T2090002101-004 HE-024-M H10B-TS-M20 H24BN-T6 PNEU-C-M6.0 TE Part #T2030002040-000 TE Part #T1470242132-000 TE Part #T1620480132-000 TE Part #T2040244101-007 CEF-4.0 H24B-SGRH-M32 H48B-SDR-LB-M32 HE-024-MC TE Part #T1210244132-000 H24B-TS-M32 Documents Product Drawings HMN-005-FS English CAD Files 3D PDF 3D Customer View Model ENG_CVM_CVM_T2110052201-000_B.2d_dxf.zip  English For support call+1 800 522 6752 01/03/2024 12:30AM | Page 3 T2110052201-000 Rectangular Contact Inserts, Contact Insert, Socket, 5 Pole Configuration, Spring Terminal, 5 Position, 14 – 20 AWG Wire Size, HDC HMN ENG_CVM_CVM_T2110052201-000_B.2d_dxf.zip English Customer View Model ENG_CVM_CVM_T2110052201-000_B.3d_igs.zip English Customer View Model ENG_CVM_CVM_T2110052201-000_B.3d_stp.zip English By downloading the CAD file I accept and agree to the Terms and Conditions of use. Datasheets & Catalog Pages Heavy Duty Connectors English Product Specifications Application Specification English  For support call+1 800 522 6752 01/03/2024 12:30AM | Page 4
T2110052201-000 价格&库存
很抱歉,暂时无法提供与“T2110052201-000”相匹配的价格&库存,您可以联系我们找货
T2110052201-000
    • 24+62.5789424+8.10210
    • 72+56.2948672+7.28850
    库存:72
    T2110052201-000
    • 204+40.78295
    • 300+39.15067
    • 552+37.53048
    • 1104+34.83418
    • 2100+32.63362
    • 3000+29.93733
    库存:73
    T2110052201-000
      • 12+58.69446
      • 204+58.69446
      • 300+56.34519
      • 552+54.02078
      • 1104+50.13019
      • 2100+46.97297
      • 3000+43.08238
      库存:33
      T2110052201-000
        • 12+58.69446
        • 204+58.69446
        • 300+56.34519
        • 552+54.02078
        • 1104+50.13019
        • 2100+46.97297
        • 3000+43.08238
        库存:40
