T2111032101-007
T2111032101-007
    HUMIREL(泰科)
    TE CONNECTIVITY - T2111032101-007 - HEAVY DUTY INSERT, PLUG, 3POS, 10AWG
T2111032101-007 数据手册
EN45545 COMPLIANT HDC INSERTS TE Connectivity (TE) ’s new range of inserts for heavy duty connectors comply with the EN45545 European standard on flame retardancy for materials and products in railway rolling stock. The modular inserts provide customers with a high level of flexibility when configuring railway connector systems. They can be configured to hold anywhere from 1 to 216 pins and enable signal, data and power to be transmitted via one single connector. NEED PRODUCT GROUP PHOTO The EN45545 standard includes specifications on fire, smoke and toxicity (FST) compliance. It provides three classifications of hazard level, HL1, HL2 and HL3, with HL3 being the highest. The new inserts from TE meet R22 and R23 requirement set on level HL3. They have an operating temperature range that extends from - 40°C to 125°C. APPLICATIONS BENEFITS • Rolling stock: traction converters, power distribution, inter-car jumpers ELECTRICAL • HDD: 10A / 250V • HEE: 16A / 500V • HEEE: 16A / 400V and 16A / 500V • HMN: Modular system, various performance levels from 5A to 200A and 50V to 1000V • Compliance with safety regulations • Reliable electrical connection • High flexibility and possibility of creating a customized interface • Time-saving with easy assembly of the modular inserts • Decrease installation cost with system modularity design MECHANICAL • Operating temperature range from -40°C to 125°C MATERIAL • Material approved according to R22 and R23 requirement set for hazard levels: HL1, HL2 and HL3, per EN45545, with Oxygen index per EN ISO 4589-2 / Smoke density per EN ISO 5659-2 / Toxicity per NF X 70-100-1/-2 APPLICATIONS AND SPECIFICATIONS • EN45545: Fire protection on railway vehicles -Railway applications • EN61984: Connectors - safety requirements and tests • EN 50467: Electrical connectors - requirements and test - Railway applications • IEC 60512: Connectors for electronic equipment -Test and measurements • IEC 60664-1: Insulation coordination for equipment within lowvoltage systems (Part 1) • EN 61373: Rolling stock equipment - shock and vibration test Railway applications INDUSTRIAL /// EN45545 COMPLIANT HDC INSERTS KEY FEATURES • Fire, smoke and toxicity compliance per the EN45545 • Several insert series, with possible pin configuration from 1 to 216 pins in 1 connector • Modular system with a time-saving one-piece connector frame EN45545 COMPLIANT HDC INSERTS PRODUCT OFFERINGS HDC Insert Series HDD Series HEE Series HEEE Series Part number Description Poles Current Voltage T2031082101-007 HDD-108-M 108+PE 10A 250V T2032162101-007 HDD-108-M 109-216 108+PE 10A 250V T2031082201-007 HDD-108-F 108+PE 10A 250V T2032162201-007 HDD-108-F 109-216 108+PE 10A 250V T2050102101-007 HEE-010-M 10+PE 16A 500V T2050102201-007 HEE-010-F 10+PE 16A 500V T2050182101-007 HEE-018-M 18+PE 16A 500V T2050182201-007 HEE-018-F 18+PE 16A 500V T2050322101-007 HEE-032-M 32+PE 16A 500V T2050642101-007 HEE-032-M 33-64 32+PE 16A 500V T2050322201-007 HEE-032-F 32+PE 16A 500V T2050642201-007 HEE-032-F 33-64 32+PE 16A 500V T2050462101-007 HEE-046-M 46+PE 16A 500V T2050922101-007 HEE-046-M 47-92 46+PE 16A 500V T2050462201-007 HEE-046-F 46+PE 16A 500V T2050922201-007 HEE-046-F 47-92 46+PE 16A 500V T2050202101-007 HEEE-020-M 20+PE 16A 400V T2050202201-007 HEEE-020-F 20+PE 16A 400V T2050323101-007 HEEE-032-M 32+PE 16A 400V T2050323201-007 HEEE-032-F 32+PE 16A 400V T2050402101-007 HEEE-040-M 40+PE 16A 500V 500V T2050802101-007 HEEE-040-M 41-80 40+PE 16A T2050402201-007 HEEE-040-F 40+PE 16A 500V T2050802201-007 HEEE-040-F 41-80 40+PE 16A 500V T2050482101-007 HEEE-048-M 48+PE 16A 400V T2050962101-007 HEEE-048-M 49-96 48+PE 16A 400V T2050482201-007 HEEE-048-F 48+PE 16A 400V 400V T2050962201-007 HEEE-048-F 49-96 48+PE 16A T2050643101-007 HEEE-064-M 64+PE 16A 500V T2051283101-007 HEEE-064-M 65-128 64+PE 16A 500V T2050643201-007 HEEE-064-F 64+PE 16A 500V T2051283201-007 HEEE-064-F 65-128 64+PE 16A 500V T2050722101-007 HEEE-072-M 72+PE 16A 400V T2051442101-007 HEEE-072-M 73-144 72+PE 16A 400V T2050722201-007 HEEE-072-F 72+PE 16A 400V T2051442201-007 HEEE-072-F 73-144 72+PE 16A 400V INDUSTRIAL /// EN45545 COMPLIANT HDC INSERTS Contacts CDM/F(10A) DDM/F(10A) CJM/F(10A) CEM/F(16A) DEM/F(16A) CEM/F(16A) DEM/F(16A) CEM/F(16A) DEM/F(16A) EN45545 COMPLIANT HDC INSERTS PRODUCT OFFERINGS HDC Insert Series HMN Series Part number Description Poles Current Voltage T2111013101-007 HMN-001-MC 1 200A 1000V T2111013201-007 HMN-001-FC 1 200A 1000V T2111020101-007 HMN-002-MC 2 70A 1000V T2111020201-007 HMN-002-FC 2 70A 1000V T2111028101-007 HMN-D2-MC 2 100A 1000V T2111028201-007 HMN-D2-FC 2 100A 1000V T2111032101-007 HMN-003-M 3 40A 690V T2111032201-007 HMN-003-F 3 40A 690V T2111042101-007 HMN-004-M 4 40A 830V T2111042201-007 HMN-004-F 4 40A 830V T2111062101-007 HMN-006-M 6 16A 500V T2111062201-007 HMN-006-F 6 16A 500V T2111063101-007 HMN-006-PM 6 16A 830V T2111063201-007 HMN-006-PF 6 16A 830V T2111082101-007 HMN-008-M 8 16A 400V T2111082201-007 HMN-008-F 8 16A 400V T2111092101-007 HMN-009-M 9 5A 50V T2111092201-007 HMN-009-F 9 5A 50V T2111122101-007 HMN-012-M 12 10A 250V T2111122201-007 HMN-012-F 12 10A 250V T2111172101-007 HMN-017-M 17 10A 160V T2111172201-007 HMN-017-F 17 10A 160V T2111202101-007 HMN-020-M 20 16A 500V T2111202201-007 HMN-020-F 20 16A 500V T2111252101-007 HMN-025-M 25 5A 50V T2111252201-007 HMN-025-F 25 5A 50V T2111027101-007 HMN-Q1-M 1+1 16A 50V T2111027201-007 HMN-Q1-F 1+1 16A 50V T2111027101-701 HMN-Q2-M 4+4 10A 50V T2111027201-701 HMN-Q2-F 4+4 10A 50V T2111027101-702 HMN-Q3-M 8+8 5A 50V T2111027201-702 HMN-Q3-F 8+8 5A 50V T2580011154-007 PIN-Q1-M 1 16A 50V T2580012154-007 PIN-Q1-F 1 16A 50V T2580031154-007 PIN-Q2-M 4 10A 50V T2580032154-007 PIN-Q2-F 4 10A 50V T2580081154-007 PIN-Q3-M 8 5A 50V T2580082154-007 PIN-Q3-F 8 5A 50V T2580011154-701 PIN-Q2-M1 1 10A 50V T2580012154-701 PIN-Q2-F1 1 10A 50V T3110009902-007 HMN-DM Contacts CHM/F(200A) CSM/F(70A) CNM/F(100A) CMM/F(40A) DMM/F(40A) CMM/F(40A) DMM/F(40A) CEM/F(16A) DEM/F(16A) CEM/F(16A) DEM/F(16A) CAM/F(5A) DAM/F(5A) CDM/F(10A) DDM/F(10A) CDM/F(10A) DDM/F(10A) CEM/F(16A) DEM/F(16A) CAM/F(5A) DAM/F(5A) CEM/F(16A) DEM/F(16A) CDM/F(10A) DDM/F(10A) CAM/F(5A) DAM/F(5A) CEM/F(16A) DEM/F(16A) CDM/F(10A) DDM/F(10A) CAM/F(5A) DAM/F(5A) CDM/F(10A) DDM/F(10A) Blind Module te.com © 2018 TE Connectivity. All Rights Reserved. TE, TE Connectivity, and the TE connectivity (logo) are trademarks of the TE Connectivity Ltd. family of companies. Other logos, product and Company names mentioned herein may be trademarks of their respective owners. While TE has made every reasonable effort to ensure the accuracy of the information in this brochure, TE does not guarantee that it is error-free, nor does TE make any other representation, warranty or guarantee that the information is accurate, correct, reliable or current. TE reserves the right to make any adjustments to the information contained herein at any time without notice. TE expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability or fitness for a particular purpose. The dimensions in this catalog are for reference purposes only and are subject to change without notice. Specifications are subject to change without notice. Consult TE for the latest dimensions and design specifications. 1-1773952-4    SL 05/2018 INDUSTRIAL /// EN45545 COMPLIANT HDC INSERTS
T2111032101-007 价格&库存
很抱歉,暂时无法提供与“T2111032101-007”相匹配的价格&库存,您可以联系我们找货
T2111032101-007
    • 48+53.32470
    • 84+52.24329
    库存:192
    T2111032101-007
    • 48+37.04683
    • 84+36.29719
    库存:192
