T2111032201-000
T2111032201-000
    HUMIREL(泰科)
    线对线连接器 10-18AWG 3Pin
T2111032201-000 数据手册
4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 1 20 RELEASED FOR PUBLICATION BY - 2 3 REVISIONS ALL RIGHTS RESERVED. P B TYPE 1 1 D DESCRIPTION LTR B1 C D 14.6 C DWN APVD ECR-15-018270 09DEC2015 DW CW ECR-18-018657 29NOV2018 CD CW ECR-19-006822 21MAY2019 BS CW ECR-21-111798 23SEP2021 WQR CW NOTES: 1. TECHNICAL CHARACTERISTICS: INSULATION MATERIAL: PC RATED VOLTAGE: 690V RATED CURRENT: 40A INSULATION RESISTANCE: >=400M ^ RATED IMPULSE VOLTAGE: 8KV POLLUTION DEGREE: 3 FLAMMABILITY: UL94V-0 MATING CYCLES: 500 CYCLES OPERATION TEMPERATURE: -40~+125 $ C WIRE RANGE: 1~6 mm² (18~10 AWG) CONTACT TYPE: CRIMP CONTACT 2. CONTACT NEED TO BE ORDERED SEPARATELY. (ORDER No. REFER TO DRAWING:T20400X20XX000) 47.7 : 1. : : : : : : : : : : : 34.4 B 2. THIS DRAWING IS A CONTROLLED DOCUMENT. TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: mm A MATERIAL 1470-19 (3/13) DATE 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - DWN 16APR2015 CHK 16APR2015 APVD 16APR2015 David Wang Chris.Wang Xiang.Xu PRODUCT SPEC C PC 690V 40A >=400M ^ : 8KV 3 UL94V-0 500 -40~+125 $ C 1~6 mm² (18~10 AWG) ( B . : T20400X20XX000) TE Connectivity NAME HMN-003-F A 108-137118 APPLICATION SPEC - 114-137118 WEIGHT Customer Drawing D SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO - T2111032201000 SCALE 1:1 SHEET 1 OF 2 REV D 4 THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 RELEASED FOR PUBLICATION BY - 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. P - TYPE 2:NO LOGO 2: LOGO D DESCRIPTION LTR DATE SEE SHEET 1 DWN APVD - - - D 14.6 NOTES: SEE SHEET 1 : SHEET 1 C C 47.7 NO LOGO LOGO B B 34.4 T2111032201-002 HMN-003-F T2111032201-000 HMN-003-F PART NUMBER THIS DRAWING IS A CONTROLLED DOCUMENT. TOLERANCES UNLESS OTHERWISE SPECIFIED: DIMENSIONS: mm A MATERIAL 1470-19 (3/13) 0 1 2 3 4 PLC PLC PLC PLC PLC ANGLES - FINISH - - HMN-003 FEMALE MODULE INSERT HMN-003 , LOGO HMN-003 FEMALE MODULE INSERT HMN-003 PART DESCRIPTION DWN 16APR2015 CHK 16APR2015 APVD 16APR2015 David Wang Chris.Wang Xiang.Xu PRODUCT SPEC ,NO LOGO TYPE2 2 TYPE1 1 TYPE TE Connectivity NAME HMN-003-F A 108-137118 APPLICATION SPEC - 114-137118 WEIGHT Customer Drawing SIZE CAGE CODE A3 00779 DRAWING NO RESTRICTED TO - T2111032201000 SCALE 3:2 SHEET 2 OF 2 REV D
T2111032201-000 价格&库存
很抱歉,暂时无法提供与“T2111032201-000”相匹配的价格&库存,您可以联系我们找货
T2111032201-000
  • 1+78.391581+10.13668
  • 12+65.7545912+8.50261
  • 36+60.8442136+7.86766
  • 60+58.6893360+7.58901
  • 108+56.30561108+7.28078
  • 252+53.03856252+6.85832
  • 504+50.50879504+6.53120
  • 1008+48.100451008+6.21978
库存:35
T2111032201-000
    • 36+75.56197
    • 60+65.18292
    • 204+55.94743
    • 300+53.73489
    • 552+51.52235
    • 1104+47.78092
    • 2100+44.76043
    库存:9
    T2111032201-000
      • 1+17.87908
      库存:1
      T2111032201-000
        • 36+52.49914
        • 60+45.29290
        • 204+38.87258
        • 300+37.33702
        • 552+35.80146
        • 1104+33.20190
        • 2100+31.09806
        库存:9
        T2111032201-000
          • 1+67.86720
          • 10+66.61440
          • 24+65.77200
          • 96+48.70530
          库存:19
