HEAVY DUTY
CONNECTORS
HCM/IP68 Hoods/Housings Series
OVERVIEW
PRODUCT SPECIFICATION
Heavy duty connectors (HDC) from TE Connectivity
(TE) have excellent and reliable performance in harsh
environments. They are mainly used for data, signal, or
power connection between different devices or functional
units, the modular and standard interface can maximize
application efficiency. Heavy duty connectors can be widely
used in different industrial environments.
HCM insert series HCM250 has a current of up to 250A, and
HCM350 has a current of up to 350A. The Latest HCM650
has a current of up to 650A.
TE’s HCM high-current series together with IP68 hoods/
housing can easily satisfy the high current requirements
in harsh environments. The HCM series has a maximum
current of up to 650A, the contact position is selectable
from 1 to 4, and the IP68 housing can provide a stable and
reliable environmental protection (Salt spraying time of up
to 500 hours is provided). This solution can easily meet
customer’s high current needs in harsh environment.
PRODUCT APPLICATION
Strong and reliable product design makes it widely used in
• New Energy
• Rail
• Power
INDUSTRIAL /// HEAVY DUTY CONNECTORS - HCM SERIES
• Inserts of crimping type, different wire diameter is
provided according to customer needs
(HCM250: 35-70mm2, HCM350: 35-120mm2,
HCM650: 35 - 240 mm2)
• Crimping contacts, excellent shock resistance capacity
• Excellent withstand voltage and insulation performance
(HCM650 extends rated voltage up to 4000V, and
withstand voltage up to 12KV)
• Insert solutions of 1-4 positions are available, suitable for
IP68 hoods/housings with optional single/multiple outlets
IP68 hoods/housings series
• IP68 aluminum hoods and housing, made of aluminum
alloy, together with powder coating surface treatment,
strong and reliable, provide reliable protection in harsh
outdoor environment
• Corrosion resistance confirmed by salt spray testing
of 500h
• Stainless screw locking ensures reliable, water, dust and
pressure tight connection
• Full range of products H6BPR -H32BPR
Heavy Duty Connectors
High Current Solutions – TE – Heavy Duty Connectors HCM/IP68 Hoods/Housings Series
MECHANICAL PERFORMANCES
STANDARDS AND SPECIFICATIONS
• High current, HCM250 - 2000V/250A; HCM350 2000V/350A; HCM650 - 4000V/650A
Standards:
• Insert mating cycle ≥ 500
• Installation method: screw locking
• Anticorrosion hoods/housing with salt spraying
resistance of 500H
• Durable and reliable structure
• EN 61984: Connectors - Safety requirements and tests
• IEC 60068: Environmental testing
• IEC 60512: Connectors for electronic equipment - Test and
measurements
• IEC 60529: Degrees of Protection Provided by Enclosures
(IP Code)
• Operating temperature: -40°C to +125°C
• IEC 60664-1: Insulation coordination for equipment within
low-voltage systems (Part 1)
PRODUCT BENEFITS/FEATURES
• EN 61373: Railway application - Rolling stock equipment Shock and vibration test
• 250A/350A/650A high current solutions
(250A/350A/650A)
Product Specifications:
• Aluminum alloy housing, durable structure, strong and
reliable, with long service life
• 108-137171: HCM250 Insert Series Product Specification
• IP68 protection degree, providing reliable connection in
harsh outdoor environment
• 108-137074: HCM650 Insert Series Product Specification
• RoHS compliant
MATERIAL
• Hoods/housings: Aluminum alloy
• Seals: Rubber, conductive rubber
• Materials of locks/fasteners: Stainless steel (screw locking)
• Surface treatment: Powder coating/deactivation + powder
coating (EMC series)
• 108-137073: HCM350 Insert Series Product Specification
• 108-137014: IP68 Hood and Housing Series Product
Specification
• 108-137191: IP68 EMC Hood and Housing Series Product
Specification
• 114-137171: HCM250 Insert Series Application Specification
• 114-137073: HCM350 Insert Series Application Specification
• 114-137074: HCM650 Insert Series Application Specification
• 114-137014: IP68 Hood and Housing Series Application
Specification
• 114-137191: IP68 EMC Hood and Housing Series Application
Specification
PRODUCT OFFERING
Solution
Series
HCM250
Components
HCM350
Description
Comments
T1920160125-000
H16BPR-TGH-M25
Housing
T1930160000-000
H16BPR-AG
Female Inserts
T2192503201-000
HCM250-FC
Crimp terminal
Male Inserts
T2192503101-000
HCM250-MC
Crimp terminal
Frame
T0924028544-000
H16BRP-2P-250-FRAME
T2192502035-000
HCM250-FC-35
Crimp area acc. to DIN EN 46 235
T2192502050-000
HCM250-FC-50
Female
Contacts
Depends on cable diameter
T2192502070-000
HCM250-FC-70
T2192501035-000
HCM250-MC-35
T2192501050-000
HCM250-MC-50
T2192501070-000
HCM250-MC-70
Hood
T1920160125-000
H16BPR-TGH-M25
Housing
T1930060000-000
H6BPR-AG
Female Inserts
T2193503201-000
HCM350-FC
Crimp terminal
Male Inserts
T2193503101-000
HCM350-MC
Crimp terminal
Frame
T0924015115-000
H6BPR-1P-350-FRAME
T2193502035-000
HCM350-FC-35
T2193502050-000
HCM350-FC-50
T2193502070-000
HCM350-FC-70
T2193502095-000
HCM350-FC-95
T2193502120-000
HCM350-FC-120
T2193501035-000
HCM350-MC-35
T2193501050-000
HCM350-MC-50
T2193501070-000
HCM350-MC-70
T2193501095-000
HCM350-MC-95
T2193501120-000
HCM350-MC-120
Male Contacts
1 Pos
PN
Hood
Female
Contacts
Male Contacts
PAGE 3
PRODUCT OFFERING
Solution
Series
HCM250
Components
Comments
H16BPR-TGH-2M25
Housing
T1930160000-000
H16BPR-AG
Female Inserts
T2192503201-000
HCM250-FC
Crimp terminal
Male Inserts
T2192503101-000
HCM250-MC
Crimp terminal
Frame
T0924028544-000
H16BRP-2P-250-FRAME
T2192502035-000
HCM250-FC-35
T2192502050-000
HCM250-FC-50
Female
Contacts
T2192502070-000
HCM250-FC-70
T2192501035-000
HCM250-MC-35
T2192501050-000
HCM250-MC-50
T2192501070-000
HCM250-MC-70
Hood
T1920160225-000
H16BPR-TGH-2M25
Housing
T1930160000-000
H16BPR-AG
Female Inserts
T2193503201-000
HCM350-FC
Crimp terminal
Crimp terminal
Male Inserts
T2193503101-000
HCM350-MC
Frame
T0924027845-000
H16BPR-2P-350-FRAME
T2193502035-000
HCM350-FC-35
T2193502050-000
HCM350-FC-50
T2193502070-000
HCM350-FC-70
T2193502095-000
HCM350-FC-95
T2193502120-000
HCM350-FC-120
T2193501035-000
HCM350-MC-35
T2193501050-000
HCM350-MC-50
T2193501070-000
HCM350-MC-70
T2193501095-000
HCM350-MC-95
T2193501120-000
HCM350-MC-120
T1920240332-409
H24BPR-TGH-XL-3M32EMC-C
Anti-corrosion performance, ,
3xM32 threads
Female
Contacts
2 Pos
Male Contacts
Hood
HCM650
Description
T1920160225-000
Male Contacts
HCM350
PN
Hood
Housing
T1930240000-409
H24BPR-AG-EMC-C
High anticorrosion performance
Blind Plug
T3165320111-000
BLIND-32-M
Metal blind plug M32
Female Inserts
T2196503201-000
HCM650-FC
Crimp terminal
Male Inserts
T2196503101-000
HCM650-MC
Crimp terminal
Frame
T0924311125-000
H24BPR-3P-650-RRAME
3 Positions Frame
T2196502070-001
HCM650-FC-70
T2196502095-001
HCM650-FC-95
T2196502120-001
HCM650-FC-120
T2196502150-001
HCM650-FC-150
T2196502185-001
HCM650-FC-185
T2196501070-001
HCM650-MC-70
T2196501095-001
HCM650-MC-95
T2196501120-001
HCM650-MC-120
T2196501150-001
HCM650-MC-150
T2196501185-001
HCM650-MC-185
Female
Contacts
Male Contacts
PAGE 4
PRODUCT OFFERING
Solution
Series
Components
PN
H24BPR-TGH-XL-3M25
Housing
T1930240000-000
H24BPR-AG
Female Inserts
T2192503201-000
HCM250-FC
Crimp terminal
Male Inserts
T2192503101-000
HCM250-MC
Crimp terminal
T0924049044-100
T0924049044-200
HCM250
Female
Contacts
Male Contacts
H24BPR-4P-250-MFRAME
H24BPR-4P-250-FFRAME
T2192502035-000
HCM250-FC-35
T2192502050-000
HCM250-FC-50
T2192502070-000
HCM250-FC-70
T2192501035-000
HCM250-MC-35
T2192501050-000
HCM250-MC-50
T2192501070-000
HCM250-MC-70
Hood
T1920240325-002
H24BPR-TGH-XL-3M25
Housing
T1930240000-000
H24BPR-AG
Female Inserts
T2193503201-000
HCM350-FC
Crimp terminal
Male Inserts
T2193503101-000
HCM350-MC
Crimp terminal
Frame
T0924311044-000
H24BRP-3P-350-FRAME
T2193502035-000
HCM350-FC-35
T2193502050-000
HCM350-FC-50
T2193502070-000
HCM350-FC-70
T2193502095-000
HCM350-FC-95
T2193502120-000
HCM350-FC-120
T2193501035-000
HCM350-MC-35
T2193501050-000
HCM350-MC-50
T2193501070-000
HCM350-MC-70
T2193501095-000
HCM350-MC-95
T2193501120-000
HCM350-MC-120
Hood
T1920240332-409
3xM32 threads
Housing
T1930240000-409
H24BPR-AG-EMC-C
Mounting frame
T1990240001-001
H24BPR-FRAME
Female Inserts
T2196503201-000
HCM650-FC
Crimp terminal
Male Inserts
T2196503101-000
HCM650-MC
Crimp terminal
Frame
T0924311125-000
H24BPR-3P-650-RRAME
3 Positions Frame
T2196502070-001
HCM650-FC-70
T2196502095-001
HCM650-FC-95
T2196502120-001
HCM650-FC-120
T2196502150-001
HCM650-FC-150
T2196502185-001
HCM650-FC-185
T2196501070-001
HCM650-MC-70
T2196501095-001
HCM650-MC-95
T2196501120-001
HCM650-MC-120
T2196501150-001
HCM650-MC-150
T2196501185-001
HCM650-MC-185
Female
Contacts
3 Pos
Male Contacts
HCM650
Comments
T1920240325-002
Frame
HCM350
Description
Hood
Female
Contacts
Male Contacts
PAGE 5
PRODUCT OFFERING
Solution
Series
Components
Comments
H24BPR-TGH-XL-4M25
Housing
T1930240000-000
H24BPR-AG
Female Inserts
T2192503201-000
HCM250-FC
Crimp terminal
Male Inserts
T2192503101-000
HCM250-MC
Crimp terminal
T0924049044-100
H24BPR-4P-250-M-FRAME
T0924049044-200
H24BPR-4P-250-F-FRAME
T2192502035-000
HCM250-FC-35
T2192502050-000
HCM250-FC-50
T2192502070-000
HCM250-FC-70
T2192501035-000
HCM250-MC-35
T2192501050-000
HCM250-MC-50
T2192501070-000
HCM250-MC-70
Hood
T1926320163-001
H32BPR-TGXH-4S-M63
Housing
T1936320000-000
H32BPR-AG-4S
Female Inserts
T2193503201-000
HCM350-FC
Crimp terminal
Male Inserts
T2193503101-000
HCM350-MC
Crimp terminal
Frame
T0924048581-000
H32BRP-4P-350-FRAME
T2193502035-000
HCM350-FC-35
T2193502050-000
HCM350-FC-50
T2193502070-000
HCM350-FC-70
T2193502095-000
HCM350-FC-95
T2193502120-000
HCM350-FC-120
T2193501035-000
HCM350-MC-35
T2193501050-000
HCM350-MC-50
T2193501070-000
HCM350-MC-70
T2193501095-000
HCM350-MC-95
T2193501120-000
HCM350-MC-120
HCM250
Female
Contacts
Male Contacts
HCM350
Description
T1920240425-002
Frame
4 Pos
PN
Hood
Female
Contacts
Male Contacts
PAGE 6
Overall dimensions of products
HIGH CURRENT SERIES
HCM250 insert
Male insert
T2192503101-000
Female insert
HCM250-MC
T2192503201-000
HCM250-FC
HCM250 pin
Pin contact
T21925010XX-000
PART NUMBER
PIN
CONTACT
SOCKET
CONTACT
Socket contact
HCM250-MC-XX
DESCRIPTION
T21925020XX-000
DIA d1
DIA d2
HCM250-FC-XX
WIRE GUAGE
STRIPPING LENGTH
mm2
mm
T2192501035-000
HCM250-MC-35
8.4
12.5
35
22
T2192501050-000
HCM250-MC-50
10.2
14.5
50
22
T2192501070-000
HCM250-MC-70
11.7
16.5
70
22
PART NUMBER
DESCRIPTION
DIA d1
DIA d2
WIRE GUAGE
STRIPPING LENGTH
mm2
mm
T2192502035-000
HCM250-FC-35
8.4
12.5
35
22
T2192502050-000
HCM250-FC-50
10.2
14.5
50
22
T2192502070-000
HCM250-FC-70
11.7
16.5
70
22
PAGE 7
HIGH CURRENT SERIES
HCM350 insert
Male insert
T2193503101-000
Female insert
HCM350-MC
T2193503201-000
HCM350-FC
HCM350 pin
Pin contact
T21935010XX-000
PART NUMBER
PIN
CONTACT
HCM350-MC-XX
DESCRIPTION
T21935020XX-000
DIA d1
DIA d2
L1
L2
HCM350-FC-XX
C1
C2
WIRE
GUAGE
STRIPPING
LENGTH
mm2
mm
T2193501035-000
HCM350-MC-35
8.2
12.5
52.5
26
7
26
T2193501050-000
HCM350-MC-50
10
14.5
55
28.5
7
22
50
28
T2193501070-000
HCM350-MC-70
11.5
16.5
55
28.5
5
22
70
28
T2193501095-000
HCM350-MC-95
13.5
19
58
30.5
5
23
95
30
T2193501120-000
HCM350-MC-120
15.5
21
58
24
3.5
20.5
120
24
C2
WIRE
GUAGE
STRIPPING
LENGTH
mm2
mm
PART NUMBER
SOCKET
CONTACT
Socket contact
DESCRIPTION
T2193502035-000
HCM350-FC-35
T2193502050-000
T2193502070-000
DIA d1
DIA d2
L1
L2
8.2
12.5
57
26
HCM350-FC-50
10
14.5
59.5
HCM350-FC-70
11.5
16.5
59.5
C1
7
26
28.5
7
22
50
28
28.5
5
22
70
28
T2193502095-000
HCM350-FC-95
13.5
19
62.5
30.5
5
23
95
30
T2193502120-000
HCM350-FC-120
15.5
21
62.5
24
3.5
20.5
120
24
PAGE 8
HIGH CURRENT SERIES
HCM650 insert
Male insert
T2196503101-000
Female insert
HCM650-MC
T2196503201-000
HCM650-FC
HCM650 pin
Pin contact
T2196501XXX-001
Socket contact
HCM650-MC-XX
T2196502XXX-001
HCM650-FC-XX
PART NUMBER
TYPE
DRAWING NO.
DESCRIPTION
Dia
d1
Dia
d2
L1
L2
L3
Number of
crimps X
WIRE
GAUGE
mm2
STRIPPING
LENGTH
mm
T2196501070-001
HCM650-MC-70
T2196501XXX000
HCM650 Male Contact,
70mm2, Silver Plating
11.75
16.5
22
10
25
1
70
42
T2196501095-001
HCM650-MC-95
T2196501XXX000
95mm2, Silver Plating
13.5
19
24.5
9
26
1
95
42
T2196501120-001
HCM650-MC-120
T2196501XXX000
120mm2, Silver Plating
15.5
21
26.5
8
27
1
120
42
T2196501150-001
HCM650-MC-150
T2196501XXX000
150mm2, Silver Plating
17
23.5
29
5
30
2
150
42
T2196501185-001
HCM650-MC-185
T2196501XXX000
185mm2, Siiver Plating
19
25.5
31
3
28
2
185
42
T2196502070-001
HCM650-FC-70
T2196502XXX000
HCM650 Female Contact,
11.75
16.5
22
10
25
1
70
42
T2196502095-001
HCM650-FC-95
T2196502XXX000
13.5
19
24.5
9
26
1
95
42
T2196502120-001
HCM650-FC-120
T2196502XXX000
15.5
21
26.5
8
27
1
120
42
T2196502150-001
HCM650-FC-150
T2196502XXX000
17
23.5
29
5
30
2
150
42
T2196502185-001
HCM650-FC-185
T2196502XXX000
19
25.5
31
3
28
2
185
42
PAGE 9
IP68 HOUSING
IP68 hoods (H16BPR) – Diagonal locking
IP68 housings (H16BPR) – Diagonal locking
T1920160140-000
H16BPR-TGH-M40
T1930160000-000
H16BPR-AG
T1920160140-009
H16BPR-TGH-M40-EMC-C
T1930160000-009
H16BPR-AG-EMC-C
IP68 hoods (H24BPR) – quadrangled locking
T1916240163-001
H24BPR-TSH-4S-M63
IP68 housings (H24BPR) – quadrangled locking
T1936240000-000
H24BPR-AG-4S
PAGE 10
HCM HIGH CURRENT SOLUTIONS
HCM250
HCM250 male inserts + IP68 hoods/housings
PAGE 11
HCM350
HCM350 male insert + IP68 hood
HCM350 female insert + IP68 housing
PAGE 12
HCM650
te.com
© 2018 TE Connectivity. All Rights Reserved.
TE Connectivity, TE Connectivity (logo) and Every Connection Counts are trademarks. All other logos, products and/or company names referred to herein might be trademarks of their
respective owners.
While TE has made every reasonable effort to ensure the accuracy of the information in this brochure, TE does not guarantee that it is error-free, nor does TE make any other
representation, warranty or guarantee that the information is accurate, correct, reliable or current. TE reserves the right to make any adjustments to the information contained herein at
any time without notice. TE expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability
or fitness for a particular purpose. The dimensions in this catalog are for reference purposes only and are subject to change without notice. Specifications are subject to change without
notice. Consult TE for the latest dimensions and design specifications.
1-1773934-1 SL 10/18 Tangence
PAGE 13
