T4031017041-000
T4031017041-000
    HUMIREL(泰科)
    T4031017041-000
T4031017041-000 数据手册
4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 1 20 REVISIONS ALL RIGHTS RESERVED. BY - 20 2 3 P LTR A D 5 PIN 4 2.0 2 4 DESCRIPTION DATE INITIAL RELEASE DWN APVD N.P 19DEC2016 X.X D 3 1 M8X1 M10X0.75 6 PIN 3 PIN 1 SW 12 SW 11 C NOTES: C 1. TECHNICAL DATA: SEE TABLE 1 2 . CONTACT SOLIDER CUP. 3. THE WIRE COLOR FOR SOLIDERING: PIN 1 BROWN; PIN 2 WHITE; PIN 3 BLUE; PIN 4 BLACK; 4. ALL PRODUCT MUST COMPLIANCE WITH ROHS AND REACH. 15.0 PIN 4 2.0 PIN 2 3.0 1. 2. : : ; SW 9 3. :PIN 1 4. 2 1 ,PIN 2 ,PIN 3 ,PIN 4 ; ROHS REACH. PIN 1 B B PIN 3 5.0 10.1 +0.1 0 0.5 X45 $ TABLE 1 TECHNICAL DATA RATED IMPULSE VOLTAGE RATED VOLTAGE RATED CURRENT A OVERVOLTAGE CATEGORY MATERIAL GROUP DEGREE OF PROTECTION TEMPERATURE T4031017031-000 T4031017041-000 O-RING 6 COPPER ALLOY NUT 5 RUBBER O-RING 4 COPPER ALLOY BODY NUT 3 PA66 HOUSING 2 COPPER ALLOY CONTACT 1 MATERIAL DESCRIPITON 1500V 800V RPC-M8-FF-4CON-M10-LAU 4 60V 30V RPC-M8-FF-3CON-M10-LAU 3 3A II II IP67 -40 $ C~85 $ C 9.1 THIS DRAWING IS A CONTROLLED DOCUMENT. +0.1 0 DIMENSIONS: mm PANEL THICK 2.5~4.5mm RECOMMENDED PANEL SIZE MATERIAL TBD material_2 1471-9 (3/13) RUBBER TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH DWN 28NOV2016 CHK 28NOV2016 APVD 28NOV2016 Nick Pan Kobby Zhao Xiang Xu TYPE NAME 108-106140 APPLICATION SPEC - finish_spec_2 114-137144-1 WEIGHT CUSTOMER DRAWING T4031017041-000 T4031017031-000 POS . PART NUMBER TE Connectivity PRODUCT SPEC 0.25 0.15 0.10 ITEM SIZE A M8 PANEL CONNECTOR SOLDERING WIRE FEMALE SIDE, UNSHIELDED, REAR MOUNTING A2 CAGE CODE - DRAWING NO T40310170X1000 SCALE 5:1 SHEET 1 OF RESTRICTED TO - 1 REV A
T4031017041-000 价格&库存
很抱歉,暂时无法提供与“T4031017041-000”相匹配的价格&库存,您可以联系我们找货
T4031017041-000
    • 1+75.55680
    • 10+72.93240
    库存:2
    T4031017041-000
    • 1+88.871051+11.44964
    • 10+75.5027810+9.72735
    • 25+70.7710125+9.11773
    • 50+67.3924150+8.68245
    • 100+64.17532100+8.26798
    • 250+60.15923250+7.75057
    • 500+57.28985500+7.38090
    • 1000+54.558571000+7.02902
    T4031017041-000
    • 1+75.35360
    • 10+65.67537
    • 25+58.80000
    • 50+53.58957
    • 100+52.00848
    库存:76
