T4032014031-000
T4032014031-000
    HUMIREL(泰科)
    T4032014031-000
T4032014031-000 数据手册
4 RELEASED FOR PUBLICATION THIS DRAWING IS UNPUBLISHED. C COPYRIGHT 20 2 3 1 20 REVISIONS ALL RIGHTS RESERVED. BY - P LTR A SW10 INITIAL RELEASE DWN APVD N.P 01AUG2016 X.X M8X0.5 D VIEW A PIN 1 DATE 2 PIN 4 D DESCRIPTION PIN 3 C C 16.8 VIEW A 3POS. 6.5 NOTES: 2.0 2.0 1 PIN 4 PIN 2 1. TECHNICAL DATA: SEE TABLE 1 2 . CONTACT SOLIDER CUP; 3. THE WIRE COLOR FOR SOLIDERING: PIN 1 BROWN; PIN 2 WHITE; PIN 3 BLUE; PIN 4 BLACK; 4. ALL PRODUCT MUST COMPLIANCE WITH ROHS AND REACH. M8X1 SW 7 2 1. : 2. 3 :PIN 1 4. 3.0 1 ; 3. B : ,PIN 2 ,PIN 3 ; ROHS REACH. B PIN 3 PIN 1 4 VIEW A 4POS. 5 Min. 2.5mm Max. 3.5mm RECOMMENDED PANEL THCIKNESS 7.1 +0.1 0 +0.1 0 TABLE 1 TECHNICAL DATA 8.1 RATED IMPULSE VOLTAGE RATED VOLTAGE A RATED CURRENT POLLETION DEGREE PANEL MOUNTING HOLE SIZE OVERVOLTAGE CATEGORY MATERIAL GROUP DEGREE OF PROTECTION TEMPERATURE 1471-9 (3/13) ,PIN 4 T4032014031-000 T4032014041-000 1500V 800V 60V 30V THIS DRAWING IS A CONTROLLED DOCUMENT. 3A DIMENSIONS: 3 mm II II IP67 -40 $ C~85 $ C MATERIAL material_2 TOLERANCES UNLESS OTHERWISE SPECIFIED: 0 PLC 1 PLC 2 PLC 3 PLC 4 PLC ANGLES FINISH DWN 01AUG2016 CHK 01AUG2016 APVD 01AUG2016 Nick Pan Kobby Zhao Xiang Xu finish_spec_2 CUSTOMER DRAWING RUBBER O-RING 4 COPPER ALLOY BODY NUT 3 PA66 HOUSING 2 COPPER ALLOY CONTACT 1 MATERIAL DESCRIPITON RPC-M8-MB-3CON-M8-LAU 3 TYPE ITEM T4032014041-000 T4032014031-000 POS . PART NUMBER TE Connectivity NAME 108-106140 114-137144-1 WEIGHT - 5 4 APPLICATION SPEC - NUT RPC-M8-MB-4CON-M8-LAU PRODUCT SPEC 0.25 0.15 COPPER ALLOY SIZE A M8 PANEL CONNECTOR MALE SIDE SOLDER TYPE WITHOUT WIRE FRONT MOUNTING A2 CAGE CODE - DRAWING NO RESTRICTED TO T40320140X1000 SCALE 7:1 SHEET 1 OF - 1 REV A
T4032014031-000 价格&库存
很抱歉,暂时无法提供与“T4032014031-000”相匹配的价格&库存,您可以联系我们找货
T4032014031-000
  • 1+42.44680
  • 10+40.32238
  • 25+39.51010
库存:53
