T4051420003-005
T4051420003-005
    HUMIREL(泰科)
    TE CONNECTIVITY - T4051420003-005 - SENSOR CORD, 3P, M8 RCPT-FREE END, 5M
T4051420003-005 数据手册
T4051420003-005 M8/M12 Cable Assemblies, Sensor/Actuator, 3 Positions, A M8/M12 Cable Assembly Keying, Receptacle, M8 Pigtail, Cable Assembly Length 5000 mm T4051420003-005  ACTIVE TE Internal #: T4051420003-005 M8/M12 Cable Assemblies, Sensor/Actuator, 3 Positions, A M8 /M12 Cable Assembly Keying, Receptacle, M8 Pigtail, Cable Assembly Length 5000 mm View on TE.com > Cable Assemblies > Copper Cable Assemblies > M8/M12 Cable Assemblies > M8 FEMALE R/A SINGLE ENDED CABLE ASSY M8/M12 Application Type: Sensor/Actuator Number of M8/M12 Cable Assembly Positions: 3 M8/M12 Cable Assembly Keying: A M8/M12 Cable Assembly Connector Type: Receptacle M8/M12 Cable Assembly Type: M8 Pigtail All M8 FEMALE R/A SINGLE ENDED CABLE ASSY (56) Features Product Type Features LED Without Cable Type PUR Product Type Cable Assembly Assembly Type Pigtail M8/M12 Cable Assembly Connector Type Receptacle M8/M12 Cable Assembly Type M8 Pigtail M8/M12 Cable Assembly Shielded No Configuration Features Number of M8/M12 Cable Assembly Positions 3 M8/M12 Cable Assembly Keying A M8/M12 Cable Assembly Configuration Single Ended Electrical Characteristics Operating Voltage  Body Features For support call+1 800 522 6752 60 VAC 02/18/2021 05:31PM | Page 1 T4051420003-005 M8/M12 Cable Assemblies, Sensor/Actuator, 3 Positions, A M8/M12 Cable Assembly Keying, Receptacle, M8 Pigtail, Cable Assembly Length 5000 mm Body Features Wire Color Brown, Blue, Black Cable Exit Angle Right Angle Environmental Protection With Insulation Material PUR Conductor Material Copper Alloy Cable Jacket Color Gray Contact Features Contact Current Rating 3A Mechanical Attachment Screw & Hole Thread Size M8 Housing Features M8/M12 Cable Assembly Housing Material Nylon Dimensions Wire Size .25 mm² Cable Assembly Length 5000 mm Operation/Application M8/M12 Application Type Sensor/Actuator Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Compliant with Exemptions China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUN 2020 (209) Candidate List Declared Against: JAN 2020 (205) SVHC > Threshold: Pb (1.9% in Pb-Alloy in Copper) Article Safe Usage Statements: Do not eat, drink or smoke when using this product. Wash thoroughly after handling. Recycle if possible and dispose of the article by following all applicable governmental regulations relevant to your geographic location. Halogen Content Not Yet Reviewed for halogen content Solder Process Capability Not applicable for solder process capability Product Compliance Disclaimer  For support call+1 800 522 6752 02/18/2021 05:31PM | Page 2 T4051420003-005 M8/M12 Cable Assemblies, Sensor/Actuator, 3 Positions, A M8/M12 Cable Assembly Keying, Receptacle, M8 Pigtail, Cable Assembly Length 5000 mm Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach Compatible Parts TE Part # CAT-SE594-M1B TE Part # CAT-SE594-M1U M8 MALE R/A SINGLE ENDED CABLE M8 MR -M12 FS CABLE ASSEMBLY ASSY Customers Also Bought  TE Part #T1210320140-000 TE Part #T1270102129-000 TE Part #T1490160129-000 TE Part #T2050002025-000 H32B-TS-M40 H10B-TSBH-PG29 H16B-SDRH-BO-PG29 CNF-25 TE Part #T1340240132-000 TE Part #T3609210111-000 TE Part #T2050001035-000 TE Part #T2050002035-000 H24B-TGH-RO-M32 DLX-21-MTS CNM-35 CNF-35 For support call+1 800 522 6752 02/18/2021 05:31PM | Page 3 T4051420003-005 M8/M12 Cable Assemblies, Sensor/Actuator, 3 Positions, A M8/M12 Cable Assembly Keying, Receptacle, M8 Pigtail, Cable Assembly Length 5000 mm TE Part #T4051320003-005 TE Part #T1440102225-000 M8 FEMALE STRAIGHT SINGLE END H10B-SGR-2M25 CABLE ASSY Documents Product Drawings M8 CABLE RA FEMALE 5M 3P PUR CABLE English CAD Files 3D PDF 3D Customer View Model ENG_CVM_CVM_T4051420003-005_A.2d_dxf.zip English Customer View Model ENG_CVM_CVM_T4051420003-005_A.3d_igs.zip English Customer View Model ENG_CVM_CVM_T4051420003-005_A.3d_stp.zip English By downloading the CAD file I accept and agree to the Terms and Conditions of use. Datasheets & Catalog Pages M8 / M12 Connector System Catalog English Product Specifications Application Specification English  For support call+1 800 522 6752 02/18/2021 05:31PM | Page 4
T4051420003-005 价格&库存
很抱歉,暂时无法提供与“T4051420003-005”相匹配的价格&库存,您可以联系我们找货
