T4110401031-000
Standard Circular Connectors, Wire-to-Wire, 3 Position, Sealable, Wire & Cable,
Signal, PBT, B Polarization Code, Polyamide 66 GF25, M12 Connector
T4110401031-000
ACTIVE
M12 Connector
TE Internal #: T4110401031-000
Wire & Cable, Signal, PBT, B Polarization Code, Polyamide 66
GF25, M12 Connector
View on TE.com >
Connectors > Circular Connectors > Standard Circular Connectors > M12 Field Installable Unshielded
Connector System: Wire-to-Wire
Number of Positions: 3
Sealable: Yes
Connector & Contact Terminates To: Wire & Cable
Contact Current Rating (Max): 4 A
All M12 Field Installable Unshielded (102)
Features
Product Type Features
Prewired
No
Product Type
Connector Assembly
Accessory Color
Black
Assembly Type
Electrical Connector
Connector System
Wire-to-Wire
Sealable
Yes
Wire & Cable
Circular Connector Type
Receptacle
Shell Type
Plastic
Configuration Features
Factory Installed Backshell
No
Keying
B
Number of Positions
3
For support call+1 800 522 6752
01/03/2024 12:31AM | Page 1
T4110401031-000
Number of Positions
3
Number of Power Positions
Number of Signal Positions
3
Contacts Preloaded
Yes
Electrical Characteristics
Operating Voltage
250 VAC
Body Features
Peripheral Seal Material
Silicone
Environmental Protection
IP67
O-Ring Material
Silicone
Environmental Protection Type
Elastomer Sealed
Shell Base Material
PBT
Circular Connector Insulation Material Type
Polyamide 66 GF25
Contact Features
4A
Reverse Gender
No
Circular Connector Contact Type
Socket
Mechanical Attachment
Mating Retention Type
Threaded Coupling
Mating Alignment
With
Polarization Code
B
Mating Alignment Type
Keyed
Housing Features
Circular Connector Shell Size
Dimensions
Wire Size
.82 – .2 mm²
Usage Conditions
IP Dust Sealing Level
6
IP Water Sealing Level
IP67
Operating Temperature Range
-40 – 85 °C[-40 – 185 °F]
Operation/Application
Durability Rating
100 Cycles
Circuit Application
Signal
01/03/2024 12:31AM | Page 2
T4110401031-000
Circuit Application
Signal
Shielded
No
Industry Standards
UL Flammability Rating
UL 94HB
Packaging Features
Packaging Quantity
1
Other
Field Serviceable
Yes
Product Compliance
For compliance documentation, visit the product page on TE.com>
EU RoHS Directive 2011/65/EU
Compliant with Exemptions
EU ELV Directive 2000/53/EC
China RoHS 2 Directive MIIT Order No 32, 2016
Restricted Materials Above Threshold
EU REACH Regulation (EC) No. 1907/2006
Current ECHA Candidate List: JUNE 2023
(235)
Candidate List Declared Against: JUNE
2023 (235)
SVHC > Threshold:
Pb (4% in Component Part)
Article Safe Usage Statements:
Do not eat, drink or smoke when using this product. Wash thoroughly after
handling. Recycle if possible and dispose of the article by following all applicable
governmental regulations relevant to your geographic location.
Halogen Content
Not Low Halogen - contains Br or Cl > 900
ppm.
Solder Process Capability
Not applicable for solder process capability
Product Compliance Disclaimer
This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge
based on the information they provided. This information is subject to change. The part numbers that TE has identified as
EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent
chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these
limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products
will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part
numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous
materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits
as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides
on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on
requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach
Compatible Parts
01/03/2024 12:31AM | Page 3
T4110401031-000
TE Part # T4111401031-000
TE Part # CAT-C73765-M1G
TE Part # CAT-C73765-M1H
TE Part # CAT-C73765-M1F
M12,MALE,STRAIGHT,B CODE,3P,
PG7,GOLD
M12 Panel Mount Solder Cups
M12 Panel Mount PCB
M12 Panel Mount Wire
TE Part # T4130412031-001
TE Part # T4140412031-001
TE Part # T4171010403-801
TE Part # T4171010403-802
M12,REAR MOUNT,MALE,B,3P,
M12,REAR MOUNT,MALE,B,3P,0.2M
M12,REAR MOUNT,MALE,B,3P,0.5M
SOLDER WIRE
SOLDER PCB
WIRE
WIRE
M8/M12 Cable Assemblies(230)
Standard Circular Connectors(801)
Also in the Series M12 Connector
Connector Caps & Covers(5)
Connector Hardware(12)
Customers Also Bought
TE Part #89-03KA-0U
TE Part #T4131012041-000
TE Part #1734839-5
TE Part #T4171010402-001
3K PSIA 316L MV PRESSURE SENSOR
FPC CONN. 0.5MM PITCH T/C, 5P
M12,REAR MOUNTING,MALE,B,2P,0.2
M WIRE
TE Part #59250
TE Part #3-1474644-8
TE Part #5-826936-0
TE Part #ANT-916-JJB-HT-T
T-HEAD PIDG 26-14 ASSY
FSN-24A-14
AMP AMPMODU II PIN HDR.
Antenna Mini Straight Hi-Temp
916MHz THM
01/03/2024 12:31AM | Page 4
T4110401031-000
TE Part #992008-000
AD-1377-CRIMP-TOOL-3-CVTY
Documents
Product Drawings
M12,FEMALE,STRAIGHT,B CODE,3P,PG7,GOLD
English
CAD Files
Customer View Model
ENG_CVM_CVM_T4110401031-000_B.3d_igs.zip
English
Customer View Model
ENG_CVM_CVM_T4110401031-000_B.3d_stp.zip
English
Customer View Model
ENG_CVM_CVM_T4110401031-000_B.2d_dxf.zip
English
3D PDF
3D
By downloading the CAD file I accept and agree to the Terms and Conditions of use.
Product Specifications
English
01/03/2024 12:31AM | Page 5
