T4111401021-000
T4111401021-000
    HUMIREL(泰科)
    2 针位圆形连接器 插座,公形引脚 螺钉
T4111401021-000 数据手册
T4111401021-000 Standard Circular Connectors, Wire-to-Wire, 2 Position, Sealable, Wire & Cable, Signal, PBT, B Polarization Code, Polyamide 66 GF25, M12 Connector T4111401021-000  ACTIVE M12 Connector TE Internal #: T4111401021-000 Standard Circular Connectors, Wire-to-Wire, 2 Position, Sealable, Wire & Cable, Signal, PBT, B Polarization Code, Polyamide 66 GF25, M12 Connector View on TE.com > Connectors > Circular Connectors > Standard Circular Connectors > M12 Field Installable Unshielded Connector System: Wire-to-Wire Number of Positions: 2 Sealable: Yes Connector & Contact Terminates To: Wire & Cable Contact Current Rating (Max): 4 A All M12 Field Installable Unshielded (102) Features Product Type Features Prewired No Product Type Connector Assembly Accessory Color Black Assembly Type Electrical Connector Connector System Wire-to-Wire Sealable Yes Connector & Contact Terminates To Wire & Cable Circular Connector Type Plug Shell Type Plastic Configuration Features  Factory Installed Backshell No Keying B Number of Positions 2 For support call+1 800 522 6752 01/03/2024 12:31AM | Page 1 T4111401021-000 Standard Circular Connectors, Wire-to-Wire, 2 Position, Sealable, Wire & Cable, Signal, PBT, B Polarization Code, Polyamide 66 GF25, M12 Connector Number of Positions 2 Number of Power Positions 0 Number of Signal Positions 2 Contacts Preloaded Yes Electrical Characteristics Operating Voltage 250 VAC Body Features Peripheral Seal Material Silicone Environmental Protection IP67 O-Ring Material Silicone Environmental Protection Type Elastomer Sealed Shell Base Material PBT Circular Connector Insulation Material Type Polyamide 66 GF25 Contact Features Contact Current Rating (Max) 4A Reverse Gender No Circular Connector Contact Type Pin Mechanical Attachment Mating Retention Type Threaded Coupling Mating Alignment With Polarization Code B Mating Alignment Type Keyed Housing Features Circular Connector Shell Size 20 Dimensions Wire Size .82 – .2 mm² Usage Conditions IP Dust Sealing Level 6 IP Water Sealing Level IP67 Operating Temperature Range -40 – 85 °C[-40 – 185 °F] Operation/Application  Durability Rating 100 Cycles Circuit Application Signal For support call+1 800 522 6752 01/03/2024 12:31AM | Page 2 T4111401021-000 Standard Circular Connectors, Wire-to-Wire, 2 Position, Sealable, Wire & Cable, Signal, PBT, B Polarization Code, Polyamide 66 GF25, M12 Connector Circuit Application Signal Shielded No Industry Standards UL Flammability Rating UL 94HB Packaging Features Packaging Quantity 1 Other Field Serviceable Yes Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Compliant with Exemptions China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) SVHC > Threshold: Pb (3.7% in Component Part) Article Safe Usage Statements: Do not eat, drink or smoke when using this product. Wash thoroughly after handling. Recycle if possible and dispose of the article by following all applicable governmental regulations relevant to your geographic location. Halogen Content Not Low Halogen - contains Br or Cl > 900 ppm. Solder Process Capability Not applicable for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach Compatible Parts  For support call+1 800 522 6752 01/03/2024 12:31AM | Page 3 T4111401021-000 Standard Circular Connectors, Wire-to-Wire, 2 Position, Sealable, Wire & Cable, Signal, PBT, B Polarization Code, Polyamide 66 GF25, M12 Connector TE Part # CAT-C73765-M1G TE Part # CAT-C73765-M1H TE Part # CAT-C73765-M1F TE Part # T4110401021-000 M12 Panel Mount Solder Cups M12 Panel Mount PCB M12 Panel Mount Wire M12,FEMALE,STRAIGHT,B CODE,2P, PG7,GOLD TE Part # T4131412021-001 TE Part # T4141412021-001 TE Part # T4171110402-801 TE Part # T4171110402-802 M12,REAR MOUNT,FEMALE,B,2P, M12,REAR MOUNT,FEMALE,B,2P, M12,REAR MOUNT,FEMALE,B,2P,0.2 M12,REAR MOUNT,FEMALE,B,2P,0.5 SOLDER WIRE SOLDER PCB M WIRE M WIRE M8/M12 Cable Assemblies(230) Standard Circular Connectors(801) Also in the Series M12 Connector Connector Caps & Covers(5) Connector Hardware(12) Customers Also Bought  TE Part #6609037-9 TE Part #1658644-1 TE Part #1658643-1 TE Part #2-332004-0 20EP1=F7773 S0 HDP-20,RCPT,SIZE 2, 15 POSN,CL HDP-20,RCPT,SIZE 1, 9 POSN,CLI SMA JAM NUT, PASSIVATED TE Part #1-1614883-2 TE Part #NB17632001 TE Part #7-1419135-2 TE Part #6334-232-2558 CPF0805 200K 0.1% 25PPM 1K RL TAT-125-1-1/2-0-STK PT581024 SHL RECP ASSY For support call+1 800 522 6752 01/03/2024 12:31AM | Page 4 T4111401021-000 Standard Circular Connectors, Wire-to-Wire, 2 Position, Sealable, Wire & Cable, Signal, PBT, B Polarization Code, Polyamide 66 GF25, M12 Connector TE Part #2560-222-2031 TE Part #6313-202-2500 CONT PIN O RING Documents Product Drawings M12,MALE,STRAIGHT,B CODE,2P,PG7,GOLD English CAD Files Customer View Model ENG_CVM_CVM_T4111401021-000_B.3d_igs.zip English Customer View Model ENG_CVM_CVM_T4111401021-000_B.3d_stp.zip English Customer View Model ENG_CVM_CVM_T4111401021-000_B.2d_dxf.zip English 3D PDF 3D By downloading the CAD file I accept and agree to the Terms and Conditions of use. Product Specifications English  For support call+1 800 522 6752 01/03/2024 12:31AM | Page 5
T4111401021-000 价格&库存
很抱歉,暂时无法提供与“T4111401021-000”相匹配的价格&库存,您可以联系我们找货
