T4112012021-000
Standard Circular Connectors, Wire-to-Wire, 2 Position, Sealable, Wire & Cable,
Signal, Nickel, Brass, A Polarization Code, M12 Connector
T4112012021-000
ACTIVE
M12 Connector
TE Internal #: T4112012021-000
Wire & Cable, Signal, Nickel, Brass, A Polarization Code, M12
Connector
View on TE.com >
Connectors > Circular Connectors > Standard Circular Connectors
Connector System: Wire-to-Wire
Number of Positions: 2
Sealable: Yes
Connector & Contact Terminates To: Wire & Cable
Contact Current Rating (Max): 4 A
Features
Product Type Features
Prewired
No
Product Type
Connector Assembly
Accessory Color
Black
Assembly Type
Electrical Connector
Connector System
Wire-to-Wire
Sealable
Yes
Wire & Cable
Circular Connector Type
Receptacle
Shell Type
Metal
Configuration Features
Keying & Polarized Position Locations
A
Factory Installed Backshell
With
Keying
A
Number of Positions
2
Number of Power Positions
For support call+1 800 522 6752
01/03/2024 12:31AM | Page 1
T4112012021-000
Number of Signal Positions
2
Contacts Preloaded
Yes
Electrical Characteristics
Operating Voltage
250 VAC
Voltage
250 Vrms
Body Features
Peripheral Seal Material
Silicone
Environmental Protection
IP67
O-Ring Material
Silicone
Environmental Protection Type
Elastomer Sealed
Shell Plating Material
Nickel
Shell Base Material
Brass
Circular Connector Insulation Material Type
Polyamide 66 GF25
Contact Features
4A
Reverse Gender
No
Circular Connector Contact Type
Socket
Mechanical Attachment
Mating Retention Type
Threaded Coupling
Mating Alignment
With
Polarization Code
A
Mating Alignment Type
Keyed
Housing Features
Circular Connector Shell Size
Dimensions
Wire Size
.82 – .2 mm²
Usage Conditions
IP Dust Sealing Level
6
IP Water Sealing Level
IP67
Operating Temperature Range
-40 – 85 °C[-40 – 185 °F]
Operation/Application
Durability
Rating
For support call+1
800 522 6752
100 Cycles
01/03/2024 12:31AM | Page 2
T4112012021-000
Durability Rating
100 Cycles
Circuit Application
Signal
Shielded
Yes
Industry Standards
UL Flammability Rating
UL 94HB
Other
Position Locations Omitted
Field Serviceable
Yes
Product Compliance
For compliance documentation, visit the product page on TE.com>
EU RoHS Directive 2011/65/EU
Compliant with Exemptions
EU ELV Directive 2000/53/EC
China RoHS 2 Directive MIIT Order No 32, 2016
Restricted Materials Above Threshold
EU REACH Regulation (EC) No. 1907/2006
Current ECHA Candidate List: JUNE 2023
(235)
Candidate List Declared Against: JUNE
2023 (235)
SVHC > Threshold:
Pb (4% in Component Part)
Article Safe Usage Statements:
Do not eat, drink or smoke when using this product. Wash thoroughly after
handling. Recycle if possible and dispose of the article by following all applicable
governmental regulations relevant to your geographic location.
Halogen Content
Low Halogen - Br, Cl, F, I < 900 ppm per
homogenous material. Also BFR/CFR/PVC
Free
Solder Process Capability
Not applicable for solder process capability
Product Compliance Disclaimer
This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge
based on the information they provided. This information is subject to change. The part numbers that TE has identified as
EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent
chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these
limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products
will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part
numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous
materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits
as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides
on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on
requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach
Compatible Parts
01/03/2024 12:31AM | Page 3
T4112012021-000
Compatible Parts
TE Part # T4113012021-000
M12 M, 2P GOLD A_CODE RA
SHIELDED PG9
Also in the Series M12 Connector
Connector Caps & Covers(5)
Connector Hardware(12)
M8/M12 Cable Assemblies(230)
Standard Circular Connectors(801)
Customers Also Bought
TE Part #1734742-8
TE Part #T4130012021-000
.5 FPC VT ZIF Type-A 8 CONT
M12,REAR MOUNT,MALE,A,2P,
SOLDER WIRE
Documents
Product Drawings
M12 F, 2P GOLD A_CODE RA SHIELDED PG9
English
CAD Files
Customer View Model
ENG_CVM_CVM_T4112012021-000_B.3d_igs.zip
English
Customer View Model
ENG_CVM_CVM_T4112012021-000_B.3d_stp.zip
English
Customer View Model
ENG_CVM_CVM_T4112012021-000_B.2d_dxf.zip
English
3D PDF
3D
01/03/2024 12:31AM | Page 4
T4112012021-000
3D PDF
3D
By downloading the CAD file I accept and agree to the Terms and Conditions of use.
Product Specifications
English
01/03/2024 12:31AM | Page 5
