4
REVISIONS
ALL RIGHTS RESERVED.
P
LTR
B
C
6.0
D
PG9
13 REF.
3.0
2
4
60V
POLLUTION DEGREE
3
3
3
3
II
MATERIAL GROUP
II
CONTACT RESISTANCE
INSULATION RESISTANCE
DEGREE OF PROTECTION
OPERATION TEMPERATURE
>100M ^
-40~85 $ C
-40~85 $ C
+0.1
T4141012021-000
15.4
>100M ^
IP67
-40~85 $ C
T4141012031-000
IP67
-40~85 $ C
RECOMMENDED PANEL CUTOUT
T4141012041-000
PIN 1
PIN 1
PIN 1
PIN 2
T4141012051-000
PIN 1
PIN 2
PIN 4
45.0 $
DIMENSIONS:
mm
1471-9 (3/13)
PA66
4-
PART NUMBER
TYPE
CONTACT
5
METAL NUT
2 3 4 5
4
O-RING
1 1 1 1
3
M12,MALE,METAL BODY
1 1 1 1
2
M12,MALE HSG
MATERIAL
5-
MATERIAL
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
0 PLC
1 PLC
2 PLC
3 PLC
4 PLC
ANGLES
FINISH
0.2
0.2
0.2
DWN
16FEB2016
CHK
16FEB2016
APVD
16FEB2016
BO GAO
KOBBY ZHAO
XIANG XU
1 1 1 1
1
DESCRIPTION
1 1 1 1
ITEM
TE Connectivity
NAME
PRODUCT SPEC
108-106140
APPLICATION SPEC
114-137144
WEIGHT
CUSTOMER DRAWING
B
RPC-M12-FF-5CON-PG9-LBU
45.0 $
A
3-
RPC-M12-FF-4CON-PG9-LBU
RPC-M12-FF-3CON-PG9-LBU
PIN 5
THIS DRAWING IS A CONTROLLED DOCUMENT.
2-
T4141012041-000
COPPER ALLOY
PLATING
45.0 $
RPC-M12-FF-2CON-PG9-LBU
PIN 3
RECOMMENDED DRILLING DIAGRAM
45.0 $
2
3
4
5
T4141012021-000
RUBBER
PIN 4
IEC61076-2-101
ROHS
TEC-138-705
REACH
TEC-138-705
02:
03:
04:
05:
COPPER ALLOY
80u''NICKEL PLATED
PIN 3
1
1: 3u''
COPPER ALLOY
BLACK
PIN 4
T4141012051-000
80u''NICKEL PLATED
PIN 3
1:
2:
3:
4:
5:
6:
T4141012031-000
3u''GOLD PLATED
PIN 3
C.W
T41410120X1-000
PIN ARRANGEMENT
A-CODE
B
C.D
CONTACT FINISH:
1; GOLD 3u''
NUMBER OF PINS:
02: 2 PINS
03: 3 PINS
04: 4 PINS
05: 5 PINS
Ch1x45 $
100M ^
IP67
22JUL2019
T41410120X1-000
II
100M ^
ECR-19-009136
NOTE:
1. TECHNICAL DATA: SEE TABLE 1
2. RECOMMENDED MOUNT PANEL SEE DETAIL
3. PRODUCT COMPLIES WITH IEC61076-2-101
4. ALL MATERIALS TO BE ROHS COMPLIANT
5. ALL MATERIALS TO BE REACH COMPLIANT
6. PN INFORMATION FOR ASSEMBLY PARTS
+0.1
II
II
很抱歉,暂时无法提供与“T4141012041-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+67.47004
- 60+58.83119
- 150+55.91014
- 200+51.00029
- 250+49.93131
- 1000+48.99906
- 5000+47.81821
- 国内价格
- 20+67.47004
- 60+58.83119
- 150+55.91014
- 200+51.00029
- 250+49.93131
- 1000+48.99906
- 5000+47.81821
- 国内价格 香港价格
- 1+67.741491+8.49419
- 10+60.4832410+7.58407
- 25+57.9359825+7.26466
- 50+43.3873850+5.44040
- 国内价格
- 1+53.48160
- 10+52.26120
- 30+51.45120
