T4142512051-000
T4142512051-000
    HUMIREL(泰科)
    5 针位圆形连接器 插座,公形引脚 焊接
T4142512051-000 数据手册
T4142512051-000 Standard Circular Connectors, Wire-to-Panel, 5 Position, Sealable, Printed Circuit Board, Signal, Reverse Gender, Nickel, Brass, M12 Connector T4142512051-000  ACTIVE M12 Connector TE Internal #: T4142512051-000 Standard Circular Connectors, Wire-to-Panel, 5 Position, Sealable, Printed Circuit Board, Signal, Reverse Gender, Nickel, Brass, M12 Connector View on TE.com > Connectors > Circular Connectors > Standard Circular Connectors > M12 Panel Mount PCB Connector System: Wire-to-Panel Number of Positions: 5 Sealable: Yes Connector & Contact Terminates To: Printed Circuit Board Contact Current Rating (Max): 4 A All M12 Panel Mount PCB (111) Features Product Type Features Product Type Connector Assembly Accessory Color Black Assembly Type Electrical Connector Connector System Wire-to-Panel Sealable Yes Connector & Contact Terminates To Printed Circuit Board Circular Connector Type Plug Shell Type Metal Configuration Features  Keying & Polarized Position Locations D Factory Installed Backshell No Keying D Number of Positions 5 For support call+1 800 522 6752 01/03/2024 12:33AM | Page 1 T4142512051-000 Standard Circular Connectors, Wire-to-Panel, 5 Position, Sealable, Printed Circuit Board, Signal, Reverse Gender, Nickel, Brass, M12 Connector Number of Positions 5 Number of Power Positions 0 Number of Signal Positions 5 Contacts Preloaded Yes Electrical Characteristics Operating Voltage 60 VAC Body Features Peripheral Seal Material Silicone Environmental Protection IP67 O-Ring Material Silicone Environmental Protection Type Elastomer Sealed Shell Plating Material Nickel Shell Base Material Brass Circular Connector Insulation Material Type Polyamide 66 GF25 Contact Features Contact Current Rating (Max) 4A Reverse Gender Yes Circular Connector Contact Type Pin Mechanical Attachment Polarization Code D Housing Features Circular Connector Shell Size 18 Usage Conditions IP Water Sealing Level IP67 Operating Temperature Range -40 – 85 °C[-40 – 185 °F] Operation/Application Circuit Application Signal Shielded No Industry Standards UL Flammability Rating UL 94HB Packaging Features Packaging Quantity  Other For support call+1 800 522 6752 1 01/03/2024 12:33AM | Page 2 T4142512051-000 Standard Circular Connectors, Wire-to-Panel, 5 Position, Sealable, Printed Circuit Board, Signal, Reverse Gender, Nickel, Brass, M12 Connector Other Field Serviceable No Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Compliant with Exemptions China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) SVHC > Threshold: Pb (4% in Component Part) Article Safe Usage Statements: Do not eat, drink or smoke when using this product. Wash thoroughly after handling. Recycle if possible and dispose of the article by following all applicable governmental regulations relevant to your geographic location. Halogen Content Low Halogen - Br, Cl, F, I < 900 ppm per homogenous material. Also BFR/CFR/PVC Free Solder Process Capability Not applicable for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach Compatible Parts TE Part # T4110502051-000 M12,FEMALE,STRAIGHT,D CODE,5P, PG9,GOLD  Also in the Series M12 Connector For support call+1 800 522 6752 01/03/2024 12:33AM | Page 3 T4142512051-000 Standard Circular Connectors, Wire-to-Panel, 5 Position, Sealable, Printed Circuit Board, Signal, Reverse Gender, Nickel, Brass, M12 Connector Also in the Series M12 Connector Connector Caps & Covers(5) Connector Hardware(12) M8/M12 Cable Assemblies(230) Standard Circular Connectors(801) Customers Also Bought TE Part #T4111502051-000 TE Part #T4130012121-000 TE Part #2-2176094-6 TE Part #2-2176094-8 M12,MALE,STRAIGHT,D CODE,5P, PG9,GOLD M12,REAR MOUNT,MALE,A,12P, SOLDER WIRE RP 2A 0.25W 221K 0.1% 25PPM 1K RL RP 2A 0.25W 232K 0.1% 25PPM 1K RL TE Part #306194-003 TE Part #6-2271129-2 TE Part #YDTS26F11-98SNV001 TE Part #794187-1 44AM1121-22-9/96-9 M12,FEMALE,A CODE,R/A,12P,PG9, SHIELD(AU) PLUG ASSY 03P MINI UMNL2 CAP HSG UL94V0 TE Part #1-2176094-6 RP 2A 0.25W 169K 0.1% 25PPM 1K RL Documents Product Drawings M12,FRONT MOUNTING,MALE,D CODE,5P English CAD Files Customer View Model ENG_CVM_CVM_T4142512051-000_B.3d_igs.zip  English For support call+1 800 522 6752 01/03/2024 12:33AM | Page 4 T4142512051-000 Standard Circular Connectors, Wire-to-Panel, 5 Position, Sealable, Printed Circuit Board, Signal, Reverse Gender, Nickel, Brass, M12 Connector English Customer View Model ENG_CVM_CVM_T4142512051-000_B.3d_stp.zip English Customer View Model ENG_CVM_CVM_T4142512051-000_B.2d_dxf.zip English 3D PDF 3D By downloading the CAD file I accept and agree to the Terms and Conditions of use. Product Specifications English Agency Approvals UL English  For support call+1 800 522 6752 01/03/2024 12:33AM | Page 5
T4142512051-000 价格&库存
很抱歉,暂时无法提供与“T4142512051-000”相匹配的价格&库存,您可以联系我们找货
T4142512051-000
  • 30+37.33702
  • 65+36.67201
  • 150+36.00701
  • 200+34.59236
  • 250+33.81854
库存:375
T4142512051-000
    • 30+53.73489
    • 65+52.77778
    • 150+51.82067
    • 200+49.78215
    • 250+48.67588
    库存:188
    T4142512051-000
      • 30+53.73489
      • 65+52.77778
      • 150+51.82067
      • 200+49.78215
      • 250+48.67588
      库存:112
      T4142512051-000
        • 30+53.73489
        • 65+52.77778
        • 150+51.82067
        • 200+49.78215
        • 250+48.67588
        库存:75
        T4142512051-000
          • 11+70.9577111+9.18690
          • 50+66.4192150+8.59930
          • 100+57.25493100+7.41280
          • 250+56.20758250+7.27720
          库存:300
