T4145035031-001
Standard Circular Connectors, Wire-to-Board, 3 Position, Sealable, Panel Mount,
Nickel, Brass, A Polarization Code, Polyamide GF, M12 Connector
T4145035031-001
ACTIVE
M12 Connector
TE Internal #: T4145035031-001
Panel Mount, Nickel, Brass, A Polarization Code, Polyamide GF,
M12 Connector
View on TE.com >
Connectors > Circular Connectors > Standard Circular Connectors > M12 Panel Mount PCB
Connector System: Wire-to-Board
Number of Positions: 3
Sealable: Yes
Connector Mounting Type: Panel Mount
Reverse Gender: No
All M12 Panel Mount PCB (111)
Features
Product Type Features
Product Type
Connector Assembly
Accessory Color
Black
Prewired
No
Assembly Type
Electrical Connector
Connector System
Wire-to-Board
Sealable
Yes
Circular Connector Type
Receptacle
Shell Type
Metal
Configuration Features
Number of Positions
3
Number of Power Positions
Number of Signal Positions
3
Body Features
For support call+1 800 522 6752
01/03/2024 12:52AM | Page 1
T4145035031-001
Body Features
Shell Plating Material
Nickel
Shell Base Material
Brass
Circular Connector Insulation Material Type
Polyamide GF
Contact Features
Reverse Gender
No
Circular Connector Contact Type
Socket
Mechanical Attachment
Panel Mount
Polarization Code
A
Mating Alignment Type
Keyed
Mating Retention
With
Housing Features
Circular Connector Shell Size
12
Usage Conditions
IP Water Sealing Level
7
IP Dust Sealing Level
6
Operating Temperature Range
-40 – 85 °C[-40 – 185 °F]
Operation/Application
Shielded
Yes
Industry Standards
UL Flammability Rating
UL 94HB
Product Compliance
For compliance documentation, visit the product page on TE.com>
EU RoHS Directive 2011/65/EU
Compliant with Exemptions
EU ELV Directive 2000/53/EC
China RoHS 2 Directive MIIT Order No 32, 2016
Restricted Materials Above Threshold
EU REACH Regulation (EC) No. 1907/2006
Current ECHA Candidate List: JUNE 2023
(235)
Candidate List Declared Against: JUNE
2023 (235)
SVHC > Threshold:
Pb (3.7% in Component Part)
Article Safe Usage Statements:
01/03/2024 12:52AM | Page 2
T4145035031-001
Do not eat, drink or smoke when using this product. Wash thoroughly after
handling. Recycle if possible and dispose of the article by following all applicable
governmental regulations relevant to your geographic location.
Halogen Content
Not Low Halogen - contains Br or Cl > 900
ppm.
Solder Process Capability
Not applicable for solder process capability
Product Compliance Disclaimer
This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge
based on the information they provided. This information is subject to change. The part numbers that TE has identified as
EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent
chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these
limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products
will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part
numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous
materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits
as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides
on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on
requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach
Compatible Parts
TE Part # T4111001031-000
M12,MALE,STRAIGHT,A CODE,3P,
PG7,GOLD
Also in the Series M12 Connector
Connector Caps & Covers(5)
Connector Hardware(12)
M8/M12 Cable Assemblies(230)
Standard Circular Connectors(801)
Customers Also Bought
01/03/2024 12:52AM | Page 3
T4145035031-001
TE Part #1534791-1
TE Part #1-1719434-1
TE Part #T4040034031-000
TE Part #T4145415021-001
ADAPTER 180DEG 4/7POS
4 POS DIA 2.5 SOCKET CONNECTOR
HSG
M8 Panel Mount PCB
M12 R/A F PNLREAR STAMPED PIN BCODE 2P
TE Part #8-1437657-0
TE Part #90759-2
TE Part #5510310004
TE Part #2-2176365-0
8PCV-04-006=#8 TRIBARRIER
PROCRIMP DIE MINI UNIV MNL
PD-CAP-3/16-0
RQ 0603 63R4 0.1% 10PPM 1K RL
Documents
Product Drawings
M12 R/A F PNL STAMPED PIN A-CODE 3P SHLD
English
CAD Files
Customer View Model
ENG_CVM_CVM_T4145035031-001_B.3d_igs.zip
English
Customer View Model
ENG_CVM_CVM_T4145035031-001_B.3d_stp.zip
English
Customer View Model
ENG_CVM_CVM_T4145035031-001_B.2d_dxf.zip
English
3D PDF
3D
By downloading the CAD file I accept and agree to the Terms and Conditions of use.
Product Specifications
English
Instruction Sheets
Instruction Sheet (U.S.)
English
Agency Approvals
UL
English
01/03/2024 12:52AM | Page 4
T4145035031-001
01/03/2024 12:52AM | Page 5
