T4151320004-007
T4151320004-007
    HUMIREL(泰科)
    TE CONNECTIVITY - T4151320004-007 - SENSOR CORD, 4P, M12 RCPT-FREE END, 10M
T4151320004-007 数据手册
PRODUCT CATALOG TITLE M8/M12 CONNECTOR SYSTEM M8/M12 CONNECTOR SYSTEM TE CONNECTIVITY’S M8 / M12 Connector System for machine industrial automation and control applications provides a solution for the increasing needs of sensor connections that safely and reliably secure the communication in industrial environments. This connector system also finds applications outside of its traditional industries where a compact reliable connection system with environmental protection is required. TE Connectivity (TE) solution includes an extensive connector range of PCB headers, cable assemblies and I/O boxes, and provides users with an interface that supports higher bandwidth needs – meeting the requirements of up to 10Gb/s. TE also offers shielded and un-shielded Cat5e and Cat6A cable assembly variants. A predefined offering in length of 1, 3, 5 and 10 meters covers a vast range of customer needs on the market. For rewiring on site a wide range of field serviceable connectors are provided, allowing versatile systems to be quickly and easily established. Additional styles are available on request including alternative mounting arrangements for panel mount connectors and double ended cable assemblies. TE’S INDUSTRIAL COMMUNICATIONS PRODUCTS PLAY A VITAL ROLE IN FACTORY AUTOMATION. TE’s industrial communications products are widespread throughout today’s networked factories, and play a critical role in driving the efficiency of many manufacturing processes. Used extensively in material INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM handling equipment, our industrial communications solutions are also found throughout the automotive and food and beverage industries, as well as in the many manufacturing applications of industrial robots. With the development of smaller industrial ethernet products, TE’s solutions are also excellent for vision systems, common in security equipment and mail sortation devices. PAGE 2 M8/M12 CONNECTOR SYSTEM TE M8/M12 CONNECTOR SYSTEM – APPLICATIONS MACHINERY FACTORY AUTOMATION TE’s M8/M12 Connector System includes a broad range of straight, angled, LED and multi-position field installable and board connectors that are easily intermateable. Next to cable assemblies for serial and bus communication, TE also offers industrial ethernet patch cables with overmolded X-coded M12 connectors that are available for future proof applications with up to 10 Gb/s data transmission. Customized cable assemblies offer a solution for your specific needs in different lengths, temperatures or flexibility. When communication simply needs to work in industrial environments, TE’s M8/M12 system and broad industrial communications portfolio offer time-tested reliability that meet industry standards. Whether it is for controllers and sensors or robotics and molding machines, the M8/M12 connector system offers you a solution that is time-saving, error reduced and without the use of tools. INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 3 Table of Content M8/M12 Connectors Page 8 TE Part Number Definition Page 9 M8 Straight Field Installable Page 12 M8 Angled Field Installable Page 13 M8 Panel Mount R/A PCB Page 14 M8 Panel Mount Straight PCB Page 15 M8 Panel Mount Solder Wire Page 16 M8 Panel Mount 200mm Wire Page 17 M12 Straight Field Installable A, B, D Coded Page 18 M12 Panel Mount R/A PCB Page 22 M12 Panel Mount Straight PCB – Rear Mounting Page 24 M12 Panel Mount Straight PCB – Front Mounting Page 25 M12 Panel Mount Solder Wire – Rear Mounting Page 26 M12 Panel Mount Solder Wire – Front Mounting Page 27 M12 Panel Mount 200mm Wire – Front Mounting Page 28 M12 Panel Mount 200mm Wire – Rear Mounting Page 29 M12 Power Solutions Page 30 M12 S, T Coded Page 32 M12 X-Coded Page 31 Accessories Page 32 Sensor/Actuator M8/M12 A-Code Cable Assemblies Page 35 M8 3-4Pos Single Ended Cable Assemblies Page 40 M12 A-Code 2-8Pos Single Ended Cable Assemblies Page 38 M8 3-4Pos Double Ended Cable Assemblies Page 43 M12 A-Code 2-8Pos Double Ended Cable Assemblies Page 41 M8 To M12 A-Code 3-4Pos Double Ended Cable Assemblies Page 44 M8 Cable Specifications Page 47 M12 Cable Specifications Page 48 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 4 Table of Content M12 Fieldbus Cable Assembly Connectivity (Profibus, DeviceNet / CanOpen, CC Link) Page 49 M12 CC-Link A-Code 4Pos Cable Assemblies Single Ended PVC Page 51 M12 CC-Link A-Code 4Pos Cable Assemblies Double Ended PVC Page 51 M12 Devicenet A-Code 5Pos Cable Assemblies Single Ended PUR Page 52 M12 Devicenet A-Code 5Pos Cable Assemblies Double Ended PUR Page 52 M12 Devicenet A-Code 5Pos Cable Assemblies Single Ended PVC Page 52 M12 Devicenet A-Code 5Pos Cable Assemblies Double Ended PVC Page 52 M12 Profibus B-Code 2Pos Cable Assemblies Single Ended PUR Torsion Page 53 M12 Profibus B-Code 2Pos Cable Assemblies Double Ended PUR Torsion Page 53 M12 Profibus B-Code 2Pos Cable Assemblies Single Ended PUR Flex/Drag Chain Page 53 M12 Profibus B-Code 2Pos Cable Assemblies Double Ended PUR Flex/Drag Chain Page 54 M12 Industrial Ethernet D-Code Cable Assembly Connectivity Page 55 M12 Ethernet D-Code 4Pos Cable Assemblies Single Ended Type C PUR Page 57 M12 Ethernet D-Code 4Pos Cable Assemblies Double Ended Type C PUR Page 57 M12 Ethernet D-Code 4Pos Cable Assemblies Single Ended Type B FRNC Page 60 M12 Ethernet D-Code 4Pos Cable Assemblies Double Ended Type B FRNC Page 60 M12 Ethernet D-Code 4Pos Cable Assemblies Single Ended Type B PVC Page 60 M12 Ethernet D-Code 4Pos Cable Assemblies Double Ended Type B PVC Page 60 M12 Ethernet D-Code 4Pos Cable Assemblies Single Ended Type B PVC Red Page 61 M12 Ethernet D-Code 4Pos Cable Assemblies Double Ended Type B PVC Red Page 61 M12 X-Code Cordsets And M12 X-Code To Rj45 Cordsets Page 67 M12 X-Code 8pos Single & Double Ended Tpe Cable Assemblies Page 72 M12 X-Code 8pos Single & Double Ended Pur & Pvc Cable Assemblies Page 73 M12 L-Code Cable Assemblies Page 74 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 5 M8/M12 CONNECTOR SYSTEM M8/M12 CONNECTORS TE’s M8/M12 connectors continues to fill the ongoing needs for sensor connection in industrial machinery and factory automation. A connection standard for many years, these products also find applications outside of their traditional industries where a compact reliable connection system with environmental protection is required. TE’s M8/M12 connector portfolio includes A, B, D, S, T, and X-coded (up to 10 Gb/s) versions to serve various customer needs. The connectors are also available in shielded and unshielded versions, to support Gigabit Ethernet applications. M8/M12 – THE CODINGS -40 °C to 85 °C Ambient temperature for M12: A-coding: Actuator-sensor plug connections for DeviceNet, IO link and Profibus -40 °C to 85 °C Current rating: B-coding: Fieldbus connections for Profibus and Interbus 4 and 5 pins: 4 A per pin 8 and 12 pins: 2 A per pin IP rating: IP67/IP68 As specifications vary for D-coding: Industrial Ethernet, Profinet, Ethernet/IP and EtherCat different parts, please refer to your TE contact for detailed information. S-coding: Motor, Frequency-convertors, motor operated switches, PSUs for Power, 620 V, 12 A Application Specifications for M8 M12 Connectors and Cable Assemblies: T-coding: Fieldbus comp, passive distribution boxes, motors, PSUs for Power, 63 V, 12 A 114-32127, 114-137008, 114-137144 and 114-137144-1 Product Specifications: X-coding: Cat6A, high-speed 10Gbit rugged industrial Ethernet applications IEC 61076-2-109 Connectors: 108-3641, 108-19483, 108-106140 X-coded: 108-137008 Pins Rated Maximum Current per pin Pollution grade M8 3 60 V 4 A 3 M8 4 30 V 4 A 3 M12 3 250 V 4 A 3 M12 4 250 V 4 A 3 Size INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM Ambient temperature for M8: M12 5 60V 4 A 3 M12 8 60 V 2 A 3 M12 12 30 V 2 A 3 PAGE 6 M8/M12 CONNECTOR SYSTEM TE Part Number Definition M8M12 Field Installable Connector PNs: T401/T411 T 4 X 1 X X X X XX X — XXX Sequence Number 000 (default) Contact Plating 1-Gold 2-Silver Number Of Contacts 02-2 poles 03-3 poles 04-4 poles ...... Cable Outlet Types 1-PG7 2-PG9 Body Material Type 0-Plastic/Unshielded 1- Metal/Shielded Code Type 0-A code 4-B code 5-D code Interface Type 0- Straight Female 1- Straight Male 2- Right Angle Female 3- Right Angle Male Application Type 1- Screw contact Category 0-M8 1-M12 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 7 M8/M12 CONNECTOR SYSTEM TE Part Number Definition M8M12 Panel Mount Connector PNs: T403/T404/T413/T414/T407 T 4 X X X X X X XX X — XXX Sequence Number 000 (default) Contact Plating 1-Gold Number Of Contacts 02-2 poles 03-3 poles 04-4 poles ...... Mount Screw Types 2-PG9 7-M10 4-M8 Body Material Type 1- Unshielded 3-Shielded Code Type 0-A code 4-B code 5-D code Panel Mount Types 0-Rear Mount Male Panel 1-Rear Mount Female Panel 2-Front Mount Male Panel 3-Front Mount Female Pane 5-Rear Mount Female Panel RA Application Type 3- Panel Solder Wire 4-Panel Solder PCB Category 0-M8 1-M12 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 8 M8/M12 CONNECTOR SYSTEM TE Part Number Definition M8M12 Panel Mount Connector with Wire PNs: T407/T417 T 4 X 7 X X X X X XX — XXX Sequence Number 000 (default) Number Of Contacts 02-2 poles 03-3 poles 04-4 poles ...... Code Type 0-A code 4-B code 5-D code Double end 0-NA Cable Material Type 1-PVC Wire Panel Mount Types 0-Rear Mount Male Panel 1-Rear Mount Female Panel 2-Front Mount Male Panel 3-Front Mount Female Panel Single End 1- Single End Application Type 7-Panel with Wire Category 0-M8 1-M12 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 9 M8/M12 CONNECTOR SYSTEM TE Part Number Definition M8 Cable Assembly PNs: T405/T406 T 4 0 X X X X X X XX — 00X Cable Length 001- 0.5M 002- 1.0M 003- 1.5M 004- 3.0M 005- 5.0M 006- 7.0M 007- 10.0M Contact Poles 03-3 poles 04-4 poles ...... Code Type 0-A code Double End 0-NA 1-M8 Straight 2-M8 Right Angle Male 3-M8 Straight Female 4-M8 Right Angle Female 5-M12 Straight Male 6-M12 Right Angle Male 7-M12 Straight Female 8-M12 Right Angle Female Cable Material Type 0-NA 1-Black PVC 2-Gray PUR Single end 0-NA 1-M8 Straight Male 2-M8 Right Angle Male 3-M8 Straight Female 4-M8 Right Angle Female Shape Type 1-Single End 2-Double End Application Type 5-Cable Assembly Unshielded 6-Cable Assembly Shielded INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 10 M8/M12 CONNECTOR SYSTEM TE Part Number Definition M12 Cable Assembly PNs: T415/T416 1 Cable Length 001- 0.5M 002- 1.0M 003- 1.5M 004- 3.0M 005- 5.0M 006- 7.0M 007- 10.0M Contact Poles 02-2 poles 03-3 poles 04-4 poles ...... Code Type 0-A code 4-B code 5-D code Double End 0-NA 1-M12 Straight Male 2-M12 Right Angle Male 3-M12 Straight Female 4-M12 Right Angle Female Cable Material Type 0-NA 1-Black PVC 2-Gray PUR Single end 0-NA 1-M12 Straight Male 2-M12 Right Angle Male 3-M12 Straight Female 4-M12 Right Angle Female Shape Type 1-Single End 2-Double End Application Type 5-Cable Assembly Unshielded 6-Cable Assembly Shielded INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 11 M8/M12 CONNECTOR SYSTEM M8 Straight Field Installable Male Series Female Series All dimensions in mm. Temperature range: -40 to +85° C. Products can also be obtained with silver-plated contacts upon request. TE Part Number TE Part Number M8 Male Screw Connection, Straight, Unshielded M8 Female Screw Connection, Straight, Unshielded 3-Pole T4011008031-000 3-Pole T4010008031-000 4-Pole T4011008041-000 4-Pole T4010008041-000 M8 Male Screw Connection, Straight, Shielded M8 Female Screw Connection, Straight, Shielded 3-Pole T4011019031-000 3-Pole T4010019031-000 4-Pole T4011019041-000 4-Pole T4010019041-000 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 12 M8/M12 CONNECTOR SYSTEM M8 Angled Field Installable 13.50 REF Male Series Female Series All dimensions in mm. Temperature range: -40 to +85° C. Products can also be obtained with silver-plated contacts upon request. TE Part Number M8 Male Right Angled, Unshielded TE Part Number M8 Female Right Angled, Unshielded 3-Pole T4013008031-000 3-Pole T4012008031-000 4-Pole T4013008041-000 4-Pole T4012008041-000 M8 Male Right Angled, Shielded M8 Female Right Angled, Shielded 3-Pole T4013019031-000 3-Pole T4010019031-000 4-Pole T4013019041-000 4-Pole T4010019041-000 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 13 M8/M12 CONNECTOR SYSTEM M8 Panel Mount R/A PCB Male Series Female Series All dimensions in mm. Temperature range: -40 to +85° C. TE Part Number M8, Male, Rear Mount, PCB, R/A, Unshielded TE Part Number M8, Female, Rear Mount, PCB, R/A, Unshielded 3-Pole 2-2172067-2 3-Pole 2-2172068-2 4-Pole 3-2172067-2 4-Pole 3-2172068-2 M8, Male, Rear Mount, PCB, R/A, Shielded M8, Female, Rear Mount, PCB, R/A, Shielded 3-Pole 2-2172093-2 3-Pole 2-2172091-2 4-Pole 3-2172093-2 4-Pole 3-2172091-2 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 14 M8/M12 CONNECTOR SYSTEM M8 Panel Mount Straight PCB Male Series Female Series All dimensions in mm. Temperature range: -40 to +85° C. Products can also be obtained with silver-plated contacts upon request. TE Part Number TE Part Number M8, Male, Rear Mount, PCB, Straight, Unshielded M8, Female, Rear Mount, PCB, Straight, Unshielded 3-Pole T4040014031-000 3-Pole T4041017031-000 4-Pole T4040014041-000 4-Pole T4041017041-000 M8, Male, Front Mount, PCB, Straight, Unshielded M8, Female,Front Mount, PCB, Straight, Unshielded 3-Pole T4042014031-000 3-Pole T4043014031-000 4-Pole T4042014041-000 4-Pole T4043014041-000 M8, Male, Rear Mount, PCB, Straight, Shielded M8, Female, Rear Mount, PCB, Straight, Shielded 3-Pole T4040034031-000 3-Pole T4041037031-000 4-Pole T4040034041-000 4-Pole T4041037041-000 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 15 M8/M12 CONNECTOR SYSTEM M8 Panel Mount Solder Wire Male Series Female Series All dimensions in mm. Temperature range: -40 to +85° C. TE Part Number TE Part Number M8, Male, Rear Mount, Solder Wire, Straight M8, Female, Rear Mount, Solder Wire, Straight 3-Pole T4030014031-000 3-Pole T4031017031-000 4-Pole T4030014041-000 4-Pole T4031017041-000 M8, Male, Front Mount, Solder Wire, Straight M8, Female, Front Mount, Solder Wire, Straight 3-Pole T4032014031-000 3-Pole T4033014031-000 4-Pole T4032014041-000 4-Pole T4033014041-000 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 16 M8/M12 CONNECTOR SYSTEM M8 Panel Mount 200mm Wire Male Series Female Series All dimensions in mm. Temperature range: -40 to +85 ° C. TE Part Number TE Part Number M8, Male, Rear Mount, 200mm Wire, Straight M8, Female, Rear Mount, 200mm Wire, Straight 3-Pole T4070014031-001 3-Pole T4071017031-001 4-Pole T4070014041-001 4-Pole T4071017041-001 M8, Male, Front Mount, 200mm Wire, Straight M8, Female, Front Mount, 200mm Wire, Straight 3-Pole T4070014031-001 3-Pole T4073014031-001 4-Pole T4070014041-001 4-Pole T4073014041-001 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 17 M8/M12 CONNECTOR SYSTEM M12 Straight Field Installable A, B, D Coded Male Series All dimensions in mm. Temperature range: -40 to +85 ° C. Products can also be obtained with silver-plated contacts upon request. TE Part Number TE Part Number A coding – M12 Male Screw Connection, Straight, Unshielded A coding – M12 Male Screw Connection, Straight, Shielded 2-Pole 2-Pole 3-Pole 4-Pole 5-Pole PG7 T4111001021-000 PG9 T4111002021-000 PG7 T4111001031-000 PG9 T4111002031-000 PG7 T4111001041-000 PG9 T4111002041-000 PG7 T4111001051-000 PG9 T4111002051-000 8-Pole PG9 T4111002081-000 12-Pole PG9 6-2271110-2 3-Pole 4-Pole 5-Pole PG7 T4111011021-000 PG9 T4111012021-000 PG7 T4111011031-000 PG9 T4111012031-000 PG7 T4111011041-000 PG9 T4111012041-000 PG7 T4111011051-000 PG9 T4111012051-000 8-Pole PG9 T4111012081-000 12-Pole PG9 6-2271111-2 B coding – M12 Male Screw Connection, Straight, Unshielded B coding – M12 Male Screw Connection, Straight, Shielded 2-Pole 2-Pole 3-Pole 4-Pole 5-Pole PG7 T4111401021-000 PG9 T4111402021-000 PG7 T4111401031-000 PG9 T4111402031-000 PG7 T4111401041-000 PG9 T4111402041-000 PG7 T4111401051-000 PG9 T4111402051-000 3-Pole 4-Pole 5-Pole PG7 T4111411021-000 PG9 T4111412021-000 PG7 T4111411031-000 PG9 T4111412031-000 PG7 T4111411041-000 PG9 T4111412041-000 PG7 T4111411051-000 PG9 T4111412051-000 D coding – M12 Male Screw Connection, Straight, Unshielded D coding – M12 Male Screw Connection, Straight, Shielded 2-Pole 2-Pole 3-Pole 4-Pole 5-Pole PG7 T4111501021-000 PG9 T4111502021-000 PG7 T4111501031-000 PG9 T4111502031-000 PG7 T4111501041-000 PG9 T4111502041-000 PG7 T4111501051-000 PG9 T4111502051-000 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM 3-Pole 4-Pole 5-Pole PG7 T4111511021-000 PG9 T4111512021-000 PG7 T4111511031-000 PG9 T4111512031-000 PG7 T4111511041-000 PG9 T4111512041-000 PG7 T4111511051-000 PG9 T4111512051-000 PAGE 18 M8/M12 CONNECTOR SYSTEM M12 Straight Field Installable A, B, D Coded Female Series All dimensions in mm. Temperature range: -40 to +85 ° C. Products can also be obtained with silver-plated contacts upon request. TE Part Number TE Part Number A coding – M12 Female Screw Connection, Straight, Unshielded A coding – M12 Female Screw Connection, Straight, Shielded 2-Pole 2-Pole 3-Pole 4-Pole 5-Pole PG7 T4110001021-000 PG9 T4110002021-000 PG7 T4110001031-000 PG9 T4110002031-000 PG7 T4110001041-000 PG9 T4110002041-000 PG7 T4110001051-000 PG9 T4110002051-000 8-Pole PG9 T4110002081-000 12-Pole PG9 6-2271116-2 3-Pole 4-Pole 5-Pole PG7 T4110011021-000 PG9 T4110012021-000 PG7 T4110011031-000 PG9 T4110012031-000 PG7 T4110011041-000 PG9 T4110012041-000 PG7 T4110011051-000 PG9 T4110012051-000 8-Pole PG9 T4110012081-000 12-Pole PG9 6-2271117-2 B coding – M12 Female Screw Connection, Straight, Unshielded B coding – M12 Female Screw Connection, Straight, Shielded 2-Pole 2-Pole 3-Pole 4-Pole 5-Pole PG7 T4110401021-000 PG9 T4110402021-000 PG7 T4110401031-000 PG9 T4110402031-000 PG7 T4110401041-000 PG9 T4110402041-000 PG7 T4110401051-000 PG9 T4110402051-000 3-Pole 4-Pole 5-Pole PG7 T4110411021-000 PG9 T4110412021-000 PG7 T4110411031-000 PG9 T4110412031-000 PG7 T4110411041-000 PG9 T4110412041-000 PG7 T4110411051-000 PG9 T4110412051-000 D coding – M12 Female Screw Connection, Straight, Unshielded D coding – M12 Female Screw Connection, Straight, Shielded 2-Pole 2-Pole 3-Pole 4-Pole 5-Pole PG7 T4110501021-000 PG9 T4110502021-000 PG7 T4110501031-000 PG9 T4110502031-000 PG7 T4110501041-000 PG9 T4110502041-000 PG7 T4110501051-000 PG9 T4110502051-000 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM 3-Pole 4-Pole 5-Pole PG7 T4110511021-000 PG9 T4110512021-000 PG7 T4110511031-000 PG9 T4110512031-000 PG7 T4110511041-000 PG9 T4110512041-000 PG7 T4110511051-000 PG9 T4110512051-000 PAGE 19 M8/M12 CONNECTOR SYSTEM M12 Angled Field Installable A, B, D Coded Male Series All dimensions in mm. Temperature range: -40 to +85° C. Products can also be obtained with silver-plated contacts upon request. Temperature range: -25 to +85 TE Part Number TE Part Number A coding – M12 Male Screw Connection, Angled, Unshielded A coding – M12 Male Screw Connection, Angled, Shielded 2-Pole 2-Pole 3-Pole 4-Pole 5-Pole PG7 T4113001021-000 PG9 T4113002021-000 PG7 T4113001031-000 PG9 T4113002031-000 PG7 T4113001041-000 PG9 T4113002041-000 PG7 T4113001051-000 PG9 T4113002051-000 8-Pole PG9 T4113002081-000 12-Pole PG9 6-2271122-2 3-Pole 4-Pole 5-Pole PG7 T4113011021-000 PG9 T4113012021-000 PG7 T4113011031-000 PG9 T4113012031-000 PG7 T4113011041-000 PG9 T4113012041-000 PG7 T4113011051-000 PG9 T4113012051-000 8-Pole PG9 T4113012081-000 12-Pole PG9 6-2271123-2 B coding – M12 Male Screw Connection, Angled, Unshielded B coding – M12 Male Screw Connection, Angled, Shielded 2-Pole 2-Pole 3-Pole 4-Pole 5-Pole PG7 T4113401021-000 PG9 T4113402021-000 PG7 T4113401031-000 PG9 T4113402031-000 PG7 T4113401041-000 PG9 T4113402041-000 PG7 T4113401051-000 PG9 T4113402051-000 3-Pole 4-Pole 5-Pole PG7 T4113411021-000 PG9 T4113412021-000 PG7 T4113411031-000 PG9 T4113412031-000 PG7 T4113411041-000 PG9 T4113412041-000 PG7 T4113411051-000 PG9 T4113412051-000 D coding – M12 Male Screw Connection, Angled, Unshielded D coding – M12 Male Screw Connection, Angled, Shielded 2-Pole 2-Pole 3-Pole 4-Pole 5-Pole PG7 T4113501021-000 PG9 T4113502021-000 PG7 T4113501031-000 PG9 T4113502031-000 PG7 T4113501041-000 PG9 T4113502041-000 PG7 T4113501051-000 PG9 T4113502051-000 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM 3-Pole 4-Pole 5-Pole PG7 T4113511021-000 PG9 T4113512021-000 PG7 T4113511031-000 PG9 T4113512031-000 PG7 T4113511041-000 PG9 T4113512041-000 PG7 T4113511051-000 PG9 T4113512051-000 PAGE 20 M8/M12 CONNECTOR SYSTEM M12 Angled Field Installable A, B, D Coded Female Series All dimensions in mm. Temperature range: -40 to +85° C. Products can also be obtained with silver-plated contacts upon request. TE Part Number TE Part Number A coding – M12 Female Screw Connection, Angled, Unshielded A coding – M12 Female Screw Connection, Angled, Shielded 2-Pole 2-Pole 3-Pole 4-Pole 5-Pole PG7 T4112001021-000 PG9 T4112002021-000 PG7 T4112001031-000 PG9 T4112002031-000 PG7 T4112001041-000 PG9 T4112002041-000 PG7 T4112001051-000 PG9 T4112002051-000 8-Pole PG9 T4112002081-000 12-Pole PG9 6-2271128-2 3-Pole 4-Pole 5-Pole PG7 T4112011021-000 PG9 T4112012021-000 PG7 T4112011031-000 PG9 T4112012031-000 PG7 T4112011041-000 PG9 T4112012041-000 PG7 T4112011051-000 PG9 T4112012051-000 8-Pole PG9 T4112012081-000 12-Pole PG9 6-2271129-2 B coding – M12 Female Screw Connection, Angled, Unshielded B coding – M12 Female Screw Connection, Angled, Shielded 2-Pole 2-Pole 3-Pole 4-Pole 5-Pole PG7 T4112401021-000 PG9 T4112402021-000 PG7 T4112401031-000 PG9 T4112402031-000 PG7 T4112401041-000 PG9 T4112402041-000 PG7 T4112401051-000 PG9 T4112402051-000 3-Pole 4-Pole 5-Pole PG7 T4112411021-000 PG9 T4112412021-000 PG7 T4112411031-000 PG9 T4112412031-000 PG7 T4112411041-000 PG9 T4112412041-000 PG7 T4112411051-000 PG9 T4112412051-000 D coding – M12 Female Screw Connection, Angled, Unshielded D coding – M12 Female Screw Connection, Angled, Shielded 2-Pole 2-Pole 3-Pole 4-Pole 5-Pole PG7 T4112501021-000 PG9 T4112502021-000 PG7 T4112501031-000 PG9 T4112502031-000 PG7 T4112501041-000 PG9 T4112502041-000 PG7 T4112501051-000 PG9 T4112502051-000 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM 3-Pole 4-Pole 5-Pole PG7 T4112511021-000 PG9 T4112512021-000 PG7 T4112511031-000 PG9 T4112512031-000 PG7 T4112511041-000 PG9 T4112512041-000 PG7 T4112511051-000 PG9 T4112512051-000 PAGE 21 M8/M12 CONNECTOR SYSTEM M12 Panel Mount R/A PCB Male Series All dimension in mm. Temperatur range: -40 to +85° C. TE Part Number TE Part Number A coding – M12, Male, Rear Mount, PCB, R/A, Unshielded B coding – M12, Male, Rear Mount, PCB, R/A, Unshielded 4-Pole T41440015041-000 5-Pole 5-Pole T41440015051-000 T4144415051-000 B coding – M12, Male, Rear Mount, PCB, R/A, Shielded A coding – M12, Male, Rear Mount, PCB, R/A, Shielded 4-Pole (45 degrees) 5-Pole T4144435051-000 3-2172094-2 4-Pole T4144035041-000 D coding – M12, Male, Rear Mount, PCB, R/A, Unshielded 5-Pole T4144035051-000 4-Pole 8-Pole T4144035081-000 T4144515041-000 D coding – M12, Male, Rear Mount, PCB, R/A, Shielded 4-Pole INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM T4144535041-000 PAGE 22 M8/M12 CONNECTOR SYSTEM M12 Panel Mount R/A PCB Female Series All dimensions in mm. Temperature range: -40 to +85° C. TE Part Number TE Part Number A coding - M12, Female, Rear Mount, PCB, R/A, Unshielded B coding - M12, Female, Rear Mount, PCB, R/A, Unshielded 2-Pole T4145015021-001 2-Pole T4145415021-001 3-Pole T4145015031-001 3-Pole T4145415031-001 4-Pole T4145015041-001 4-Pole T4145415041-001 5-Pole T4145015051-001 5-Pole T4145415051-001 A coding - M12, Female, Rear Mount, PCB, R/A, Shielded B coding - M12, Female, Rear Mount, PCB, R/A, Shielded 2-Pole T4145035021-001 2-Pole T4145435021-001 3-Pole T4145035031-001 3-Pole T4145435031-001 4-Pole T4145035041-001 4-Pole T4145435041-001 3-2172095-2 5-Pole T4145435051-001 4-Pole (45 degrees) 5-Pole T4145035051-001 8-Pole 5-2172079-2 D coding - M12, Female, Rear Mount, PCB, R/A, Unshielded 2-Pole T4145515021-001 3-Pole T4145515031-001 4-Pole T4145515041-001 5-Pole T4145515051-001 D coding - M12, Female, Rear Mount, PCB, R/A, Shielded INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM 2-Pole T4145535021-001 3-Pole T4145535031-001 4-Pole T4145535041-001 5-Pole T4145535051-001 PAGE 23 M8/M12 CONNECTOR SYSTEM M12 Panel Mount Straight PCB – Rear Mounting Male Series Female Series All dimensions in mm. Temperature range: -40 to +85° C. TE Part Number TE Part Number A coding – M12 Male, Rear Mounting, Straight A coding – M12 Female, Rear Mounting, Straight 2-Pole T4140012021-000 2-Pole T4141012021-000 3-Pole T4140012031-000 3-Pole T4141012031-000 4-Pole T4140012041-000 4-Pole T4141012041-000 5-Pole T4140012051-000 5-Pole T4141012051-000 B coding – M12 Male, Rear Mounting, Straight B coding – M12 Female, Rear Mounting, Straight 2-Pole T4140412021-000 2-Pole 3-Pole T4140412031-000 3-Pole T4141412031-000 4-Pole T4140412041-000 4-Pole T4141412041-000 5-Pole T4140412051-000 5-Pole T4141412051-000 T4141412021-000 D coding – M12 Male, Rear Mounting, Straight D coding – M12 Female, Rear Mounting, Straight 2-Pole T4140512021-000 2-Pole 3-Pole T4140512031-000 3-Pole T4141512031-000 4-Pole T4140512041-000 4-Pole T4141512041-000 5-Pole T4140512051-000 5-Pole T4141512051-000 T4141512021-000 A-coding - M12 Male, Rear Mounting, Solder PCB A-coding - M12 Female, Rear Mounting, Solder PCB 8-Pole T4140012081-000 8-Pole T4141012081-000 12-Pole T4140012121-000 12-Pole T4141012121-000 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 24 M8/M12 CONNECTOR SYSTEM M12 Panel Mount Straight PCB – Front Mounting Male Series Female Series All dimensions in mm. Temperature range: -40 to +85° C. TE Part Number TE Part Number A coding – M12 Male, Front Mounting, Straight A coding – M12 Female, Front Mounting, Straight 2-Pole T4142012021-000 2-Pole 3-Pole T4142012031-000 3-Pole T4143012031-000 4-Pole T4142012041-000 4-Pole T4143012041-000 5-Pole T4142012051-000 5-Pole T4143012051-000 T4143012021-000 B coding – M12 Male, Front Mounting, Straight B coding – M12 Female, Front Mounting, Straight 2-Pole T4142412021-000 2-Pole T4143412021-000 3-Pole T4142412031-000 3-Pole T4143412031-000 4-Pole T4142412041-000 4-Pole T4143412041-000 5-Pole T4142412051-000 5-Pole T4143412051-000 D coding – M12 Male, Front Mounting, Straight D coding – M12 Female, Front Mounting, Straight 2-Pole T4142512021-000 2-Pole T4143512021-000 3-Pole T4142512031-000 3-Pole T4143512031-000 4-Pole T4142512041-000 4-Pole T4143512041-000 5-Pole T4142512051-000 5-Pole T4143512051-000 A-coding - M12 Male, Front Mounting, Solder PCB A-coding - M12 Female, Front Mounting, Solder PCB 8-Pole T4142012081-000 8-Pole T4143012081-000 12-Pole T4142012121-000 12-Pole T4143012121-000 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 25 M8/M12 CONNECTOR SYSTEM M12 Panel Mount Solder Wire – Rear Mounting Male Series Female Series All dimensions in mm. Temperature range: -40 to +85° C. TE Part Number TE Part Number A coding – M12 Male, Rear Mounting, Straight A coding – M12 Female, Rear Mounting, Straight 2-Pole T4130012021-000 2-Pole T4131012021-000 3-Pole T4130012031-000 3-Pole T4131012031-000 4-Pole T4130012041-000 4-Pole T4131012041-000 5-Pole T4130012051-000 5-Pole T4131012051-000 B coding – M12 Male, Rear Mounting, Straight B coding – M12 Female, Rear Mounting, Straight 2-Pole T4130412021-000 2-Pole 3-Pole T4130412031-000 3-Pole T4131412031-000 4-Pole T4130412041-000 4-Pole T4131412041-000 5-Pole T4130412051-000 5-Pole T4131412051-000 T4131412021-000 D coding – M12 Male, Rear Mounting, Straight D coding – M12 Female, Rear Mounting, Straight 2-Pole T4130512021-000 2-Pole T4131512021-000 3-Pole T4130512031-000 3-Pole T4131512031-000 4-Pole T4130512041-000 4-Pole T4131512041-000 5-Pole T4130512051-000 5-Pole T4131512051-000 A-coding - M12 Male, Rear Mounting, Solder Wire A-coding - M12 Female, Rear Mounting, Solder Wire 8-Pole T4130012081-000 8-Pole T4131012081-000 12-Pole T4130012121-000 12-Pole T4131012121-000 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 26 M8/M12 CONNECTOR SYSTEM M12 Panel Mount Solder Wire – Front Mounting Male Series Female Series All dimensions in mm. Temperature range: -40 to +85° C. TE Part Number TE Part Number A coding – M12 Male, Front Mounting, Straight A coding – M12 Female, Front Mounting, Straight 2-Pole T4132012021-000 2-Pole T4133012021-000 3-Pole T4132012031-000 3-Pole T4133012031-000 4-Pole T4132012041-000 4-Pole T4133012041-000 5-Pole T4132012051-000 5-Pole T4133012051-000 B coding – M12 Male, Front Mounting, Straight B coding – M12 Female, Front Mounting, Straight 2-Pole T4132412021-000 2-Pole T4133412021-000 3-Pole T4132412031-000 3-Pole T4133412031-000 4-Pole T4132412041-000 4-Pole T4133412041-000 5-Pole T4132412051-000 5-Pole T4133412051-000 D coding – M12 Male, Front Mounting, Straight D coding – M12 Female, Front Mounting, Straight 2-Pole T4132512021-000 2-Pole T4133512021-000 3-Pole T4132512031-000 3-Pole T4133512031-000 4-Pole T4132512041-000 4-Pole T4133512041-000 5-Pole T4132512051-000 5-Pole T4133512051-000 A-coding - M12 Male, Front Mounting, Solder Wire A-coding - M12 Female, Front Mounting, Solder Wire 8-Pole T4132012081-000 8-Pole T4133012081-000 12-Pole T4132012121-000 12-Pole T4133012121-000 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 27 M8/M12 CONNECTOR SYSTEM M12 Panel Mount 200mm Wire – Front Mounting Male Series Female Series All dimensions in mm. Temperature range: -40 to +85° C. TE Part Number TE Part Number A coding – M12 Male, Front Mounting, 200mm wire A coding – M12 Female, Front Mounting, 200mm wire 2-Pole T4171210002-001 2-Pole T4171310002-001 3-Pole T4171210003-001 3-Pole T4171310003-001 4-Pole T4171210004-001 4-Pole T4171310004-001 5-Pole T4171210005-001 5-Pole T4171310005-001 B coding – M12 Male, Front Mounting, 200mm wire B coding – M12 Female, Front Mounting, 200mm wire 2-Pole T4171210402-001 2-Pole T4171310402-001 3-Pole T4171210403-001 3-Pole T4171310403-001 4-Pole T4171210404-001 4-Pole T4171310404-001 5-Pole T4171210405-001 5-Pole T4171310405-001 D coding – M12 Male, Front Mounting, 200mm wire D coding – M12 Female, Front Mounting, 200mm wire 2-Pole T4171210502-001 2-Pole T4171310502-001 3-Pole T4171210503-001 3-Pole T4171310503-001 4-Pole T4171210504-001 4-Pole T4171310504-001 5-Pole T4171210505-001 5-Pole T4171310505-001 A-coding - M12 Male, Front Mounting, 200mm wire A-coding - M12 Female, Front Mounting, 200mm wire 8-Pole T4171220008-001 8-Pole T4171320008-001 12-Pole T4171230012-001 12-Pole T4171330012-001 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 28 M8/M12 CONNECTOR SYSTEM M12 Panel Mount 200mm Wire – Rear Mounting Male Series Female Series All dimensions in mm. Temperature range: -40 to +85° C. TE Part Number TE Part Number A coding – M12 Male, Rear Mounting, 200mm wire A coding – M12 Female, Rear Mounting, 200mm wire 2-Pole T4171010002-001 2-Pole T4171110002-001 3-Pole T4171010003-001 3-Pole T4171110003-001 4-Pole T4171010004-001 4-Pole T4171110004-001 5-Pole T4171010005-001 5-Pole T4171110005-001 B coding – M12 Male, Rear Mounting, 200mm wire B coding – M12 Female, Rear Mounting, 200mm wire 2-Pole T4171010402-001 2-Pole T4171110402-001 3-Pole T4171010403-001 3-Pole T4171110403-001 4-Pole T4171010404-001 4-Pole T4171110404-001 5-Pole T4171010405-001 5-Pole T4171110405-001 D coding – M12 Male, Rear Mounting, 200mm wire D coding – M12 Female, Rear Mounting, 200mm wire 2-Pole T4171010502-001 2-Pole T4171110502-001 3-Pole T4171010503-001 3-Pole T4171110503-001 4-Pole T4171010504-001 4-Pole T4171110504-001 5-Pole T4171010505-001 5-Pole T4171110505-001 A-coding - M12 Male, Rear Mounting, 200mm wire A-coding - M12 Female, Rear Mounting, 200mm wire 8-Pole T4171020008-001 8-Pole T4171120008-001 12-Pole T4171030012-001 12-Pole T4171130012-001 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 29 M8/M12 CONNECTOR SYSTEM M12 Power Solutions M12 L-coding Straight solder pcb Type Poles Mounting TE Part Number Male 2 Rear T4140L12031-000 Male 3 Rear T4140L12041-000 Male 4 Rear T4140L12051-000 Type Poles Mounting TE Part Number Female 2 Rear T4141L12031-000 Female 3 Rear T4141L12041-000 Female 4 Rear T4141L12051-000 M12 S, T coded Female Series Male Series All dimensions in mm. Temperature range: -40 to +85° C. TE Part Number TE Part Number S coding - M12 Male Screw Connection, Straight, Shielded S coding - M12 Female Screw Connection, Straight, Shielded 3-Pole 3-Pole plus PE 2120951-1 plus PE 2120950-1 T coding - M12 Male Screw Connection, Straight, Shielded T coding – M12 Female Screw Connection, Straight, Shielded 4-Pole 4-Pole 3-2172096-2 3-2172097-2 T coding - M12 Male, Front Mounting M20 x 1.5 T coding – M12 Female, Front Mounting M20 x 1.5 4-Pole 4-Pole INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM 2120947-1 2120946-1 PAGE 30 M8/M12 CONNECTOR SYSTEM M12 X-Coded M12 X-Coded PCB Connector M12 Pin Connector Cable Assembly All dimensions in mm. Temperature range: -40 to +85° C. Description TE Part Number M12 X-Coded PCB Connector TE Part Number M12 Pin Connector Cable Assembly Female Panel Mount Solder PCB Connector 2232331-1 Female Panel Mount Solder Wire 2271195-1 M12 X-Coded Field Installable Connector Male Connector installable (IDC): 5.5 - 9 mm cable diameter Length 2327989-1 1 m 2241021-1 2 m 2241021-2 3 m 2241021-3 4 m 2241021-4 5 m 2241021-5 10 m 2241021-6 PRELIMINARY INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 31 M8/M12 CONNECTOR SYSTEM Accessories Dust Caps 2823563-1 2823064-1 2823065-1 All dimensions in mm. Temperature range: -40 to +85° C. TE Part Number Dust Caps M8, Dust Cap, Female, IP67, without sleeve 2823563-1 M12, Dust Cap, Female, IP67, without sleeve 2823064-1 M12, Dust Cap, Female, IP67, with sleeve 2823065-1 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 32 M8/M12 CONNECTOR SYSTEM Nuts for Panel Mount connectors 2823423-1 2823066-1 All dimensions in mm. TE Part Number Nuts for Panel Mount connectors Nut for M8 Panel Mount connector 2823423-1 Nut for M12 Panel Mount connector 2823066-1 PRELIMINARY INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 33 M8/M12 CONNECTOR SYSTEM Explore more from te.com: M8/M12 Connectors te.com/m8m12 M8M12 Cable Assemblies te.com/m8m12cableassemblies FIND THE PART NUMBERS AND INFORMATION YOU ARE LOOKING FOR Additional Information View the video Read more about the connector and cable assembly See our M8/M12 connector system video and learn portfolio on the M8/M12 website - in many different about the product features, benefits and languages. applications. Download the product flyer Find the products Find all information you need at one glance in the If you are looking for a specific product or part M8/M12 connector system product flyer. number, the M8/M12 website is the place to look. Find the images, drawings, technical specifications and much more. INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 34 M8/M12 CONNECTOR SYSTEM SENSOR/ACTUATOR M8/M12 A-CODE M8/M12 A-coded cable assemblies are designed for applications such as sensors, robotics & production machinery & equipment, where extreme temperatures and harsh environments are likely to be encountered. These cable assemblies are also ideal for non-industrial applications where compact, robust and reliable connections are required to withstand rigorous environmental elements. TE provides a full solution with shielded and non-shielded cable assembly options that help customers easily connect to advanced industrial networks. The new product line meets the IP67 rating for protection against dust and water ingress; they also provide protection against electromagnetic radiation, chemicals and mechanical stress commonly found in industrial environments. Designed as industry standard solutions, these quick-turn cable assemblies help to reduce unnecessary downtime and help maintain continuous operations in critical conditions. TE’s cross-industry expertise allows it to offer customized solutions through a broad cable assembly portfolio that includes connectivity to many industry standards serving various customer needs. TE’s M8/M12 cable assemblies are available as single-ended or double-ended, in straight and angled versions, with shielded and un-shielded variants. Various cable types are offered depending on the application requirements. Cable sheathing is in PVC or PUR. The predefined offering in length of 0.5, 1, 1.5, 3, 5, 7 and 10 meters covers a vast range of customer needs on the market. Customized cable assemblies in different lengths provide a solution for specific needs. All can be used in combination with TE’s male/female connectors and I/O Modules. KEY FEATURES BENEFITS • IP67 rated: dust and waterproof • M12 Cable Assemblies are IP67 sealed and tested in TE’s factory to eliminate the possibility of false wiring & to ensure robust connection • Overmolded PVC or PUR cable assemblies/Shielded & non shielded versions • Key options: A coded • M12 Positions: 2, 3, 4, 5 & 8 poles • M8 Positions: 3 & 4 poles • M8 & M12 single ended cable assemblies • Reduce downtime in harsh environments with reliable industry standard solution that includes quick turn, prototype cable assemblies. • Full solution offering including customized and general market cable assemblies enables 1-stopshopping and reduced TCO • M8 & M12 double ended cable assemblies • M8 to M12 cable assemblies • Cable length options: 0.5 m, 1 m, 1.5 m, 3 m, 5 m, 7 m, and 10 m INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 35 M8/M12 CONNECTOR SYSTEM APPLICATIONS MATERIALS • Industrial Communications • Contact: Brass, Gold Flash Plating • Industrial Machinery • Nut: Brass, Nickel plating • Industrial automation • O-ring: Silicon rubber • Robotics • Spring: Stainless steel • Machine tools • Over-molding: TPU • Semiconductor manufacturing • Housing: PA • Manufacturing of solenoid and sensor valves • M12 Cable: 22 AWG, 2/3/4/5 core, with or without Foil, Drain, Braid Shield RoHS; Cable Jacket material: PVC or PUR • Process control systems • Vision systems • Electronics manufacturing • M12 Cable: 24 AWG, 8 core, with or without Foil, Drain, Braid Shield RoHS; Cable Jacket material: PVC or PUR • M8 Cable: 24 AWG,3/4 core, with or without Foil, Drain, Braid Shield RoHS; Cable Jacket material: PVC or PUR MECHANICAL • Durability: 100 cycles STANDARDS & APPLICATIONS • Degree of protection: IP67 • Product Specification: 108-106140 • Temperature Ratings: • Application Specification: 114-137144 (M12) 114-137144-1(M8) – PVC: • Fixed: -40°C to +80°C • UL Standard: UL2238 • Flexible: -25°C to +80°C • IEC 61076-2-101: Detail specification for M12 connectors with screw-locking – PUR: • Fixed: -10°C to +80°C • Flexible: -5°C to +80°C ELECTRICAL • Voltage rating • IEC 61076-2-104: Detail specification with M8 screw-locking or snap-locking • IEC 60512: Electromechanical components for electronic equipment; basic testing procedure and measuring methods • IEC-60529: Degree of protection provided by enclosures (IP Code) – M12: • 250V (≤4 way) • 60V (5 way) • 30V (>5 way) – M8: • 60V (3 way) • 30V (4 & 5 pos) • Current rating – M12 A Coding • 2 – 5 ways = 4A • 6 – 8 ways = 2 A – M8: 3A • Insulation Resistance: 100MΩ Min. INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 36 M8/M12 CONNECTOR SYSTEM M8 Single Ended Cable Assembly PVC/PUR JACKET M8 cable assemblies T405/T406 series TPU OVER MOLDING STANDARD: IEC61076-2-104 MALE CORE MALE CRIMP PIN T40 S A X W Y S Application Type - Shield/ Unshielded 5 Unshielded 6 Shield A Single/Double 1 Single end 2 Double end X Connector Type for Single End 1 M8 Straight, Male 2 M8 Right angle, Male 3 M8 Straight, Female 4 M8 Right angle, Female W Cable Material Type 1 Black PVC 2 Gray PUR 0 MN -00L MN Position -00L Cable Length 03 3P -001 0.5M 04 4P -002 1.0M -003 1.5M Y Connector Type for Double End -004 3.0M 0 N/A -005 5.0M 1 M8 Straight, Male -006 7.0M 2 M8 Right angle, Male -007 10.0M 3 M8 Straight, Female -XXX Customized Cable Length 4 M8 Right angle, Female -XX0 XX M 5 M12 Straight, Male -XX5 XX.5 M 6 M12 Right angle, Male 7 M12 Straight, Female 8 M12 Right angle, Female Wiring Diagram-M8 cable assembly Unshielded* From Pin Poles 3 4 To Pin Wiring Diagram-M8 cable assembly Shielded* From Pin Poles 3 4 To Pin 1 Brown Brown 1 1 Brown Brown 1 2 - White 2 2 - White 2 3 Blue Blue 3 3 Blue Blue 3 4 Black Black 4 4 Black Black 4 Shielded Metal Nut Metal Nut Shielded * This wire diagram is applicable to all M8 cable assemblies listed in this flyer. INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 37 M8/M12 CONNECTOR SYSTEM PRODUCT OFFERINGS - M8 Single Ended Cable Assembly M8 STR SINGLE ENDED CABLE ASSEMBLY PN Part Description T4051320003-001 M8 FS 3P PUR CABLE 0.5M T4061320003-001 M8 FS 3P PUR CABLE 0.5M SH T4051310003-001 M8 FS 3P PVC CABLE 0.5M T4061310003-001 M8 FS 3P PVC CABLE 0.5M SH T4051320004-001 M8 FS 4P PUR CABLE 0.5M T4061320004-001 M8 FS 4P PUR CABLE 0.5M SH T4051310004-001 M8 FS 4P PVC CABLE 0.5M T4061310004-001 M8 FS 4P PVC CABLE 0.5M SH PN Part Description T4051120003-001 M8 MS 3P PUR CABLE 0.5M T4061120003-001 M8 MS 3P PUR CABLE 0.5M SH T4051110003-001 M8 MS 3P PVC CABLE 0.5M T4061110003-001 M8 MS 3P PVC CABLE 0.5M SH T4051120004-001 M8 MS 4P PUR CABLE 0.5M T4061120004-001 M8 MS 4P PUR CABLE 0.5M SH T4051110004-001 M8 MS 0.5M 4P PVC CABLE 0.5M T4061110004-001 M8 MS 4P PVC CABLE 0.5M SH Pos 3 Type Female Straight Cable Material Shielded/Unshielded PUR PVC PUR 4 PVC Pos 3 Type Male Straight Cable Material PUR PVC PUR 4 PVC Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Shielded/Unshielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded M8 R/A SINGLE ENDED CABLE ASSEMBLY PN T4051420003-001 Part Description T4061420003-001 M8 FR 3P PUR CABLE 0.5M SH T4051410003-001 M8 FR 3P PVC CABLE 0.5M T4061410003-001 M8 FR 3P PVC CABLE 0.5M SH T4051420004-001 M8 FR 4P PUR CABLE 0.5M T4061420004-001 M8 FR 4P PUR CABLE 0.5M SH T4051410004-001 M8 FR 4P PVC CABLE 0.5M T4061410004-001 M8 FR 4P PVC CABLE 0.5M SH PN Pos Type M8 FR 3P PUR CABLE 0.5M Part Description T4051220003-001 M8 MR 3P PUR CABLE 0.5M T4061220003-001 M8 MR 3P PUR CABLE 0.5M SH T4051210003-001 M8 MR 3P PVC CABLE0.5M T4061210003-001 M8 MR 3P PVC CABLE 0.5M SH T4051220004-001 M8 MR 4P PUR CABLE 0.5M T4061220004-001 M8 MR 4P PUR CABLE 0.5M SH T4051210004-001 M8 MR 4P PVC CABLE 0.5M T4061210004-001 M8 MR 4P PVC CABLE 0.5M SH INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM Female Right Angle  Cable Material PUR 3 PVC PUR 4 PVC Pos Type Cable Material PUR 3 Male Right Angle PVC PUR 4 PVC Shielded/Unshielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Shielded/Unshielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded PAGE 38 M8/M12 CONNECTOR SYSTEM M12 Single Ended Cable Assembly PVC/PUR M12 cable assemblies T415/T416 series TPU OVER MOLDING STANDARD: IEC61076-2-101 MALE CORE MALE CRIMP PIN T41 S A X W Y C MN -00L S Shield/Unshielded MN Position -00L Cable Length 5 Unshielded 03 3P -001 0.5M 6 Shield 04 4P -002 1.0M 05 5P -003 1.5M 08 8P -004 3.0M A Single/Double End 1 Single end 2 Double end -005 5.0M Y Connector Type for Double End -006 7.0M 0 N/A -007 10.0M X Connector Type for Single End 1 M12 Straight, Male -XXX Customized Cable Length 1 M12 Straight, Male 2 M12 Right angle, Male -XX0 XX M 2 M12 Right angle, Male 3 M12 Straight, Female -XX5 XX.5 M 3 M12 Straight, Female 4 M12 Right angle, Female 4 M12 Right angle, Female C Code 0 A Code W Cable Material Type 1 Black PVC 2 Gray PUR Wiring Diagram-M12 cable assembly Unshielded* Poles From Pin 2 3 4 5 8 1 Brown Brown Brown Brown White Wiring Diagram-M12 cable assembly Shielded* To Pin From Pin 1 1 Poles 2 3 4 5 8 Brown Brown Brown Brown White To Pin 1 2 - - White White Brown 2 2 - - White White Brown 2 3 Blue Blue Blue Blue Green 3 3 Blue Blue Blue Blue Green 3 4 - Black Black Black Yellow 4 4 - Black Black Black Yellow 4 5 - - - Gray Gray 5 5 - - - Gray Gray 5 6 - - - - Pink 6 6 - - - - Pink 6 7 - - - - Blue 7 7 - - - - Blue 7 8 - - - - Red 8 8 - - - - Red 8 Shielded Metal Nut Metal Nut Metal Nut Metal Nut Metal Nut Shielded * This wire diagram is applicable to all M12 cable assemblies listed in this flyer. INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 39 M8/M12 CONNECTOR SYSTEM PRODUCT OFFERINGS - M12 A-Code Single Ended Cable Assembly M12 A-CODE STR SINGLE ENDED CABLE ASSEMBLY PN Part Description T4151320002-001 M12 FS 2P PUR CABLE 0.5M T4161320002-001 M12 FS 2P PUR CABLE 0.5M SH T4151310002-001 M12 FS 2P PVC CABLE 0.5M T4161310002-001 M12 FS 2P PVC CABLE 0.5M SH T4151320003-001 M12 FS 3P PUR CABLE 0.5M T4161320003-001 M12 FS 3P PUR CABLE 0.5M SH T4151310003-001 M12 FS 3P PVC CABLE 0.5M T4161310003-001 M12 FS 3P PVC CABLE 0.5M SH T4151320004-001 M12 FS 4P PUR CABLE 0.5M T4161320004-001 M12 FS 4P PUR CABLE 0.5M SH T4151310004-001 M12 FS 4P PVC CABLE 0.5M T4161310004-001 M12 FS 4P PVC CABLE 0.5M SH T4151320005-001 M12 FS 5P PUR CABLE 0.5M T4161320005-001 M12 FS 5P PUR CABLE 0.5M SH T4151310005-001 M12 FS 5P PVC CABLE 0.5M T4161310005-001 M12 FS 5P PVC CABLE 0.5M SH T4151320008-001 M12 FS 8P PUR CABLE 0.5M T4161320008-001 M12 FS 8P PUR CABLE 0.5M SH T4151310008-001 M12 FS 8P PVC CABLE 0.5M T4161310008-001 M12 FS 8P PVC CABLE 0.5M SH PN Part Description T4151120002-001 M12 MS 2P PUR CABLE 0.5M T4161120002-001 M12 MS 2P PUR CABLE 0.5M SH T4151110002-001 M12 MS 2P PVC CABLE 0.5M T4161110002-001 M12 MS 2P PVC CABLE 0.5M SH T4151120003-001 M12 MS 3P PUR CABLE 0.5M T4161120003-001 M12 MS 3P PUR CABLE 0.5M SH T4151110003-001 M12 MS 3P PVC CABLE 0.5M T4161110003-001 M12 MS 3P PVC CABLE 0.5M SH T4151120004-001 M12 MS 4P PUR CABLE 0.5M T4161120004-001 M12 MS 4P PUR CABLE 0.5M SH T4151110004-001 M12 MS 4P PVC CABLE 0.5M T4161110004-001 M12 MS 4P PVC CABLE 0.5M SH T4151120005-001 M12 MS 5P PUR CABLE 0.5M T4161120005-001 M12 MS 5P PUR CABLE 0.5M SH T4151110005-001 M12 MS 5P PVC CABLE 0.5M T4161110005-001 M12 MS 5P PVC CABLE 0.5M SH T4151120008-001 M12 MS 8P PUR CABLE 0.5M T4161120008-001 M12 MS 8P PUR CABLE 0.5M SH T4151110008-001 M12 MS 8P PVC CABLE 0.5M T4161110008-001 M12 MS 8P PVC CABLE 0.5M SH INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM Code Pos Type Cable Materials PUR 2 PVC PUR 3 Female Straight PVC PUR A 4 PVC PUR 5 PVC PUR 8 PVC Code Pos Type Cable Materials PUR 2 PVC PUR 3 Male Straight PVC PUR A 4 PVC PUR 5 PVC PUR 8 PVC Shield/Unshielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Shield/Unshielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shielded Unshielded Shield PAGE 40 M8/M12 CONNECTOR SYSTEM M12 A-CODE R/A SINGLE ENDED CABLE ASSEMBLY PN Part Description T4151420002-001 M12 FR 2P PUR CABLE 0.5M T4161420002-001 M12 FR 2P PUR CABLE 0.5M SH T4151410002-001 M12 FR 2P PVC CABLE 0.5M T4161410002-001 M12 FR 2P PVC CABLE 0.5M SH T4151420003-001 M12 FR 3P PUR CABLE 0.5M T4161420003-001 M12 FR 3P PUR CABLE 0.5M SH T4151410003-001 M12 FR 3P PVC CABLE 0.5M T4161410003-001 M12 FR 3P PVC CABLE 0.5M SH T4151420004-001 M12 FR 4P PUR CABLE 0.5M T4161420004-001 M12 FR 4P PUR CABLE 0.5M SH T4151410004-001 M12 FR 4P PVC CABLE 0.5M T4161410004-001 M12 FR 4P PVC CABLE 0.5M SH T4151420005-001 M12 FR 5P PUR CABLE 0.5M T4161420005-001 M12 FR 5P PUR CABLE 0.5M SH T4151410005-001 M12 FR 5P PVC CABLE 0.5M T4161410005-001 M12 FR 5P PVC CABLE 0.5M SH T4151420008-001 M12 FR 8P PUR CABLE 0.5M T4161420008-001 M12 FR 8P PUR CABLE 0.5M SH T4151410008-001 M12 FR 8P PVC CABLE 0.5M T4161410008-001 M12 FR 8P PVC CABLE 0.5M SH PN Part Description T4151220002-001 M12 MR 2P PUR CABLE 0.5M T4161220002-001 M12 MR 2P PUR CABLE 0.5M SH T4151210002-001 M12 MR 2P PVC CABLE 0.5M T4161210002-001 M12 MR 2P PVC CABLE 0.5M SH T4151220003-001 M12 MR 3P PUR CABLE 0.5M T4161220003-001 M12 MR 3P PUR CABLE 0.5M SH T4151210003-001 M12 MR 3P PVC CABLE 0.5M T4161210003-001 M12 MR 3P PVC CABLE 0.5M SH T4151220004-001 M12 MR 4P PUR CABLE 0.5M T4161220004-001 M12 MR 4P PUR CABLE 0.5M SH T4151210004-001 M12 MR 4P PVC CABLE 0.5M T4161210004-001 M12 MR 4P PVC CABLE 0.5M SH T4151220005-001 M12 MR 5P PUR CABLE 0.5M T4161220005-001 M12 MR 5P PUR CABLE 0.5M SH T4151210005-001 M12 MR 5P PVC CABLE 0.5M T4161210005-001 M12 MR 5P PVC CABLE 0.5M SH T4151220008-001 M12 MR 8P PUR CABLE 0.5M T4161220008-001 M12 MR 8P PUR CABLE 0.5M SH T4151210008-001 M12 MR 8P PVC CABLE 0.5M T4161210008-001 M12 MR 8P PVC CABLE 0.5M SH INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM Code Pos Type Cable Materials PUR 2 PVC PUR 3 Female PVC PUR A 4 PVC PUR 5 PVC PUR 8 PVC Code Pos Type Cable Materials PUR 2 PVC PUR 3 Male PVC PUR A 4 PVC PUR 5 PVC PUR 8 PVC Shield/Unshielded Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Shield/Unshielded Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield PAGE 41 M8/M12 CONNECTOR SYSTEM PRODUCT OFFERINGS - M8 to M8 Double Ended Cable Assembly M8 MALE STR – FEMALE STR DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4052123003-001 M8 MS 3P – M8 FS 3P PUR CABLE 0.5M T4062123003-001 M8 MS 3P – M8 FS 3P PUR CABLE 0.5M SH T4052113003-001 M8 MS 3P – M8 FS 3P PVC CABLE 0.5M T4062113003-001 M8 MS 3P – M8 FS 3P PVC CABLE 0.5M SH T4052123004-001 M8 MS 4P – M8 FS 4P PUR CABLE 0.5M T4062123004-001 M8 MS 4P – M8 FS 4P PUR CABLE 0.5M SH T4052113004-001 M8 MS 4P – M8 FS 4P PVC CABLE 0.5M T4062113004-001 M8 MS 4P – M8 FS 4P PVC CABLE 0.5M SH Pos Type Cable Materials MS-FS PUR 3 PVC PUR 4 PVC Shield/ Unshielded Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield M8 MALE STR – FEMALE R/A DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4052124003-001 M8 MS 3P – M8 FR 3P PUR CABLE 0.5M T4062124003-001 M8 MS 3P – M8 FR 3P PUR CABLE 0.5M SH T4052114003-001 M8 MS 3P – M8 FR 3P PVC CABLE 0.5M T4062114003-001 M8 MS 3P – M8 FR 3P PVC CABLE 0.5M SH T4052124004-001 M8 MS 4P – M8 FR 4P PUR CABLE 0.5M T4062124004-001 M8 MS 4P – M8 FR 4P PUR CABLE 0.5M SH T4052114004-001 M8 MS 4P – M8 FR 4P PVC CABLE 0.5M T4062114004-001 M8 MS 4P – M8 FR 4P PVC CABLE 0.5M SH Pos Type Cable Materials MS-FR PUR 3 PVC PUR 4 PVC Shield/ Unshielded Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield M8 MALE R/A – FEMALE R/A DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4052224003-001 M8 MR 3P – M8 FR 3P PUR CABLE 0.5M T4062224003-001 M8 MR 3P – M8 FR 3P PUR CABLE 0.5M SH T4052214003-001 M8 MR 3P – M8 FR 3P PVC CABLE 0.5M T4062214003-001 M8 MR 3P – M8 FR 3P PVC CABLE 0.5M SH T4062224004-001 M8 MR 4P – M8 FR 3P PUR CABLE 0.5M T4052224004-001 M8 MR 4P – M8 FR 3P PUR CABLE 0.5M SH T4062214004-001 M8 MR 4P – M8 FR 3P PVC CABLE 0.5M T4052214004-001 M8 MR 4P – M8 FR 3P PVC CABLE 0.5M SH Pos Type Cable Materials MR-FR PUR 3 PVC PUR 4 PVC Shield/ Unshielded Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield M8 MALE R/A – FEMALE STR DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4062223003-001 M8 MR 3P – M8 FS 3P PUR CABLE 0.5M T4052223003-001 M8 MR 3P – M8 FS 3P PUR CABLE 0.5M SH T4062213003-001 M8 MR 3P – M8 FS 3P PVC CABLE 0.5M T4052213003-001 M8 MR 3P – M8 FS 3P PVC CABLE 0.5M SH T4052223004-001 M8 MR 4P – M8 FS 3P PUR CABLE 0.5M T4062223004-001 M8 MR 4P – M8 FS 3P PUR CABLE 0.5M SH T4052213004-001 M8 MR 4P – M8 FS 3P PVC CABLE 0.5M T4062213004-001 M8 MR 4P – M8 FS 3P PVC CABLE 0.5M SH INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM Pos Type Cable Materials MR-FS PUR 3 PVC PUR 4 PVC Shield/ Unshielded Unshield Shielded Unshield Shielded Unshielded Shield Unshielded Shield PAGE 42 M8/M12 CONNECTOR SYSTEM PRODUCT OFFERINGS - M12 to M12 A-Code Double Ended Cable Assembly M12 A-CODE MALE STR – FEMALE STR DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4152123002-001 M12 MS 2P – M12 FS 2P PUR CABLE 0.5M T4162123002-001 M12 MS 2P – M12 FS 2P PUR CABLE 0.5M SH T4152113002-001 M12 MS 2P – M12 FS 2P PVC CABLE 0.5M T4162113002-001 M12 MS 2P – M12 FS 2P PVC CABLE 0.5M SH T4152123003-001 M12 MS 3P – M12 FS 3P PUR CABLE 0.5M T4162123003-001 M12 MS 3P – M12 FS 3P PUR CABLE 0.5M SH T4152113003-001 M12 MS 3P – M12 FS 3P PVC CABLE 0.5M T4162113003-001 M12 MS 3P – M12 FS 3P PVC CABLE 0.5M SH T4152123004-001 M12 MS 4P – M12 FS 4P PUR CABLE 0.5M T4162123004-001 M12 MS 4P – M12 FS 4P PUR CABLE 0.5M SH T4152113004-001 M12 MS 4P – M12 FS 4P PVC CABLE 0.5M T4162113004-001 M12 MS 4P – M12 FS 4P PVC CABLE 0.5M SH T4152123005-001 M12 MS 5P – M12 FS 5P PUR CABLE 0.5M T4162123005-001 M12 MS 5P – M12 FS 5P PUR CABLE 0.5M SH T4152113005-001 M12 MS 5P – M12 FS 5P PVC CABLE 0.5M T4162113005-001 M12 MS 5P – M12 FS 5P PVC CABLE 0.5M SH Pos Type Code Cable Materials PUR 2 PVC PUR 3 MS-FS PVC A PUR 4 PVC PUR 5 PVC Shield/ Unshielded Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield M12 A-CODE MALE R/A – FEMALE R/A DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4152224002-001 M12 MR 2P – M12 FR 2P PUR CABLE 0.5M T4162224002-001 M12 MR 2P – M12 FR 2P PUR CABLE 0.5M SH T4152214002-001 M12 MR 2P – M12 FR 2P PVC CABLE 0.5M T4162214002-001 M12 MR 2P – M12 FR 2P PVC CABLE 0.5M SH T4152224003-001 M12 MR 3P – M12 FR 3P PUR CABLE 0.5M T4162224003-001 M12 MR 3P – M12 FR 3P PUR CABLE 0.5M SH T4152214003-001 M12 MR 3P – M12 FR 3P PVC CABLE 0.5M T4162214003-001 M12 MR 3P – M12 FR 3P PVC CABLE 0.5M SH T4152224004-001 M12 MR 4P – M12 FR 4P PUR CABLE 0.5M T4162224004-001 M12 MR 4P – M12 FR 4P PUR CABLE 0.5M SH T4152214004-001 M12 MR 4P – M12 FR 4P PVC CABLE 0.5M T4162214004-001 M12 MR 4P – M12 FR 4P PVC CABLE 0.5M SH T4152224005-001 M12 MR 5P – M12 FR 5P PUR CABLE 0.5M T4162224005-001 M12 MR 5P – M12 FR 5P PUR CABLE 0.5M SH T4152214005-001 M12 MR 5P – M12 FR 5P PVC CABLE 0.5M T4162214005-001 M12 MR 5P – M12 FR 5P PVC CABLE 0.5M SH INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM Pos Type Code Cable Materials PUR 2 PVC 3 PUR MS-FS PVC A PUR 4 PVC PUR 5 PVC Shield/ Unshielded Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield PAGE 43 M8/M12 CONNECTOR SYSTEM PRODUCT OFFERINGS - M12 to M12 A-Code Double Ended Cable Assembly M12 A-CODE MALE STR – FEMALE R/A DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4152124002-001 M12 MS 2P – M12 FR 2P PUR CABLE 0.5M T4162124002-001 M12 MS 2P – M12 FR 2P PUR CABLE 0.5M SH T4152114002-001 M12 MS 2P – M12 FR 2P PVC CABLE 0.5M T4162114002-001 M12 MS 2P – M12 FR 2P PVC CABLE 0.5M SH T4152124003-001 M12 MS 3P – M12 FR 3P PUR CABLE 0.5M T4162124003-001 M12 MS 3P – M12 FR 3P PUR CABLE 0.5M SH T4152114003-001 M12 MS 3P – M12 FR 3P PVC CABLE 0.5M T4162114003-001 M12 MS 3P – M12 FR 3P PVC CABLE 0.5M SH T4152124004-001 M12 MS 4P – M12 FR 4P PUR CABLE 0.5M T4162124004-001 M12 MS 4P – M12 FR 4P PUR CABLE 0.5M SH T4152114004-001 M12 MS 4P – M12 FR 4P PVC CABLE 0.5M T4162114004-001 M12 MS 4P – M12 FR 4P PVC CABLE 0.5M SH T4152124005-001 M12 MS 5P – M12 FR 5P PUR CABLE 0.5M T4162124005-001 M12 MS 5P – M12 FR 5P PUR CABLE 0.5M SH T4152114005-001 M12 MS 5P – M12 FR 5P PVC CABLE 0.5M T4162114005-001 M12 MS 5P – M12 FR 5P PVC CABLE 0.5M SH Pos Type Code Cable Materials PUR 2 PVC 3 PUR MS-FR PVC A PUR 4 PVC PUR 5 PVC Shield/ Unshielded Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield M12 A-CODE MALE R/A – FEMALE STR DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4152223002-001 M12 MR 2P – M12 FS 2P PUR CABLE 0.5M T4162223002-001 M12 MR 2P – M12 FS 2P PUR CABLE 0.5M SH T4152213002-001 M12 MR 2P – M12 FS 2P PVC CABLE 0.5M T4162213002-001 M12 MR 2P – M12 FS 2P PVC CABLE 0.5M SH T4152223003-001 M12 MR 3P – M12 FS 3P PUR CABLE 0.5M T4162223003-001 M12 MR 3P – M12 FS 3P PUR CABLE 0.5M SH T4152213003-001 M12 MR 3P – M12 FS 3P PVC CABLE 0.5M T4162213003-001 M12 MR 3P – M12 FS 3P PVC CABLE 0.5M SH T4152223004-001 M12 MR 4P – M12 FS 4P PUR CABLE 0.5M T4162223004-001 M12 MR 4P – M12 FS 4P PUR CABLE 0.5M SH T4152213004-001 M12 MR 4P – M12 FS 4P PVC CABLE 0.5M T4162213004-001 M12 MR 4P – M12 FS 4P PVC CABLE 0.5M SH T4152223005-001 M12 MR 5P – M12 FS 5P PUR CABLE 0.5M T4162223005-001 M12 MR 5P – M12 FS 5P PUR CABLE 0.5M SH T4152213005-001 M12 MR 5P – M12 FS 5P PVC CABLE 0.5M T4162213005-001 M12 MR 5P – M12 FS 5P PVC CABLE 0.5M SH INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM Pos Type Code Cable Materials PUR 2 PVC 3 PUR MR-FS PVC A PUR 4 PVC PUR 5 PVC Shield/ Unshielded Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield Unshielded Shield PAGE 44 M8/M12 CONNECTOR SYSTEM PRODUCT OFFERINGS - M8 to M12 Double Ended Cable Assembly M8 FEMALE STR – M12 MALE STR DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4052325003-001 M8 3P FS – M12 3P MS PUR CABLE 0.5M Pos 3 Type M8 FS - M12 MS Cable Materials Shield/Unshielded PUR T4052315003-001 M8 3P FS – M12 3P MS PVC CABLE 0.5M PVC T4052325004-001 M8 4P FS – M12 4P MS PUR CABLE 0.5M PUR T4052315004-001 M8 4P FS – M12 4P MS PVC CABLE 0.5M Unshielded 4 PVC M8 FEMALE STR – M12 MALE R/A DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4052326003-001 M8 3P FS – M12 3P MR PUR CABLE 0.5M Pos Type M8 FS -M12 MR Cable Materials Shield/Unshielded PUR 3 T4052316003-001 M8 3P FS – M12 3P MR PVC CABLE 0.5M PVC T4052326004-001 M8 4P FS – M12 4P MR PUR CABLE 0.5M PUR T4052316004-001 M8 4P FS – M12 4P MR PVC CABLE 0.5M Unshielded 4 PVC M8 FEMALE R/A – M12 MALE STR DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4052425003-001 M8 3P FR – M12 3P MS PUR CABLE 0.5M Pos Type M8 FR -M12 MS Cable Materials Shield/Unshielded PUR 3 T4052415003-001 M8 3P FR – M12 3P MS PVC CABLE 0.5M PVC T4052425004-001 M8 4P FR – M12 4P MS PUR CABLE 0.5M PUR T4052415004-001 M8 4P FR – M12 4P MS PVC CABLE 0.5M Unshielded 4 PVC M8 FEMALE R/A – M12 MALE R/A DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4052426003-001 M8 3P FR – M12 3P MR PUR CABLE 0.5M Pos Type M8 FR -M12 MR Cable Materials Shield/Unshielded PUR 3 T4052416003-001 M8 3P FR – M12 3P MR PVC CABLE 0.5M PVC T4052426004-001 M8 4P FR – M12 4P MR PUR CABLE 0.5M PUR T4052416004-001 M8 4P FR – M12 4P MR PVC CABLE 0.5M Unshielded 4 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PVC PAGE 45 M8/M12 CONNECTOR SYSTEM PRODUCT OFFERINGS - M8 to M12 Double Ended Cable Assembly M8 MALE STR – M12 FEMALE STR DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4052127003-001 M8 3P MS – M12 3P FS PUR CABLE 0.5M Pos 3 Type M8 MS -M12 FS Cable Materials Shield/Unshielded PUR T4052117003-001 M8 3P MS – M12 3P FS PVC CABLE 0.5M PVC T4052127004-001 M8 4P MS – M12 4P FS PUR CABLE 0.5M PUR T4052117004-001 M8 4P MS – M12 4P FS PVC CABLE 0.5M Unshielded 4 PVC M8 MALE STR – M12 FEMALE R/A DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4052128003-001 M8 3P MS – M12 3P FR PUR CABLE 0.5M Pos 3 Type M8 MS -M12 FR Cable Materials Shield/Unshielded PUR T4052118003-001 M8 3P MS – M12 3P FR PVC CABLE 0.5M PVC T4052128004-001 M8 4P MS – M12 4P FR PUR CABLE 0.5M PUR T4052118004-001 M8 4P MS – M12 4P FR PVC CABLE 0.5M Unshielded 4 PVC M8 MALE R/A – M12 FEMALE STR DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4052227003-001 M8 3P MR – M12 3P FS PUR CABLE 0.5M Pos 3 Type M8 MR -M12 FS Cable Materials Shield/Unshielded PUR T4052217003-001 M8 3P MR – M12 3P FS PVC CABLE 0.5M PVC T4052227004-001 M8 4P MR – M12 4P FS PUR CABLE 0.5M PUR T4052217004-001 M8 4P MR – M12 4P FS PVC CABLE 0.5M Unshielded 4 PVC M8 MALE R/A – M12 FEMALE R/A DOUBLE ENDED CABLE ASSEMBLY PN Part Description T4052228003-001 M8 3P MR – M12 3P FR PUR CABLE 0.5M Pos 3 Type M8 MR - M12 FR Cable Materials Shield/Unshielded PUR T4052218003-001 M8 3P MR – M12 3P FR PVC CABLE 0.5M PVC T4052228004-001 M8 4P MR – M12 4P FR PUR CABLE 0.5M PUR T4052218004-001 M8 4P MR – M12 4P FR PVC CABLE 0.5M Unshielded 4 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PVC PAGE 46 M8/M12 CONNECTOR SYSTEM Cable Specifications M8 UNSHIELDED CABLE ASSEMBLIES M8 cable assembly unshielded PVC series M8 cable assembly unshielded PUR series PVC PUR Image No. of conductors 3 4 3 4 Jacket material PVC PUR Jacket color Black Gray Cross section 24AWG 24AWG Contruction 32/0.10mm 32/0.10mm Temp range-Fixed -10°C-80°C -40°C-80°C Temp range-Flexible -5°C-80°C -25°C-80°C Features Flame Retardant, Rohs Flame Retardant, oil resistant, Rohs Standards UL758, UL1581, UL2464 UL758, UL1581, UL20549 M8 SHIELDED CABLE ASSEMBLIES M8 cable assembly shielded PVC series M8 cable assembly shielded PUR series PUR PVC Image No. of conductors 3 4 3 4 Jacket material PVC PUR Jacket color Black Gray Cross section 24AWG 24AWG Construction: 32/0.10mm Shield1: AL/Mylar Shield2: Tinned copper braid Construction: 32/0.10mm Shield1: AL/Mylar Shield2: Tinned copper braid -10°C-80°C -40°C-80°C Contruction Temp range-Fixed -5°C-80°C -25°C-80°C Features Temp range-Flexible Flame Retardant, Rohs Flame Retardant, oil resistant, Rohs Standards UL758, UL1581, UL2464 UL758, UL1581, UL20549 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 47 M8/M12 CONNECTOR SYSTEM M12 UNSHIELDED CABLE ASSEMBLIES M12 PVC cable assembly unshielded series M12 PUR cable assembly unshielded series PVC PUR Image No. of conductors 2 3 4 Jacket material 5 2 3 4 PVC 5 8 22AWG 24AWG PUR Jacket color Black Cross section 22AWG Contruction 8 Gray 22AWG 22AWG 22AWG 43/0.10mm 43/0.10mm 43/0.10mm 43/0.10mm 32/0.10mm 43/0.10mm 43/0.10mm 43/0.10mm 43/0.10mm 32/0.10mm Temp range-Fixed -10°C-80°C -40°C-80°C Temp rangeFlexible -5°C-80°C -25°C-80°C Features Flame Retardant, Rohs Flame Retardant, oil resistant, Rohs Standards UL758, UL1581, UL2464 UL758, UL1581, UL20549 M12 SHIELDED CABLE ASSEMBLIES M12 cable assembly shielded series M12 cable assembly shielded series PVC PUR Image No. of conductors 2 3 4 5 Jacket material Jacket color 8 3 4 5 8 PVC PUR Black Gray Cross section 22AWG 22AWG 22AWG 22AWG Contruction 2 Construction: 43/0.10mm Shield1: AL/Mylar Shield2: Tinned copper braid 24AWG 22AWG 22AWG 22AWG 22AWG 24AWG Construction: 32/0.10mm Shield1: AL/Mylar Shield2: Tinned copper braid Construction: 43/0.10mm Shield1: AL/Mylar Shield2: Tinned copper braid Construction: 2/0.10mm Shield1: AL/Mylar Shield2: Tinned copper braid Temp range-Fixed -10°C-80°C -40°C-80°C Temp rangeFlexible -5°C-80°C -25°C-80°C Features Flame Retardant, Rohs Flame Retardant, oil resistant, Rohs Standards UL758, UL1581, UL2464 UL758, UL1581, UL20549 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 48 M8/M12 CONNECTOR SYSTEM M12 FIELDBUS CABLE ASSEMBLY SOLUTIONS TE now complements its’ Sensor/Actuator cable assemblies with Data Communication solutions by introducing the Fieldbus cable assemblies. First developed more than two decades ago, many different field networks still continue to dominate Industrial automation and process control. Fieldbus networks seems to be very practical at the lowest level of the automation pyramid and are critical element of Industry 4.0, IIoT and beyond for end devices that do not require the bandwidth but do need the ability to have power and signal in the same cable. The new A and B-coded M12 cable assemblies comply with Profibus, DeviceNet and CC-link protocols, offering multiple options for a variety of needs that makes TE an one-stop shop. They have 360-degree shielding against EMI for complete protection for signal and data transmission, and are rated IP67 for resistance to dust and water. The assemblies are overmolded in either PVC or halogen-free polyurethane (PUR) cables, suitable for drag chain applications or torsional stress, depending on customer performance requirements. Assemblies are produced in many customer-specific plug-and-play configurations to enable design flexibility and quick installation in most industrial environments. Applications for the new assemblies lie in numerous areas of industry, including process control systems, robotics and automation, production equipment, machine tools and material handling. TE’s Fieldbus M12 cable assemblies are available as single-ended or double-ended, in straight and angled versions, all shielded variants. Various cable types are offered depending on the application requirements. The predefined offering in length of 0.5, to 15 meters covers a vast range of customer needs on the market, while customized cable assemblies in different lengths provide a solution for specific needs. All can be used in combination with TE’s male/female connectors. KEY FEATURES BENEFITS • IP67 rated: dust and waterproof • Maximum signal transmission • Overmolded PVC or PUR cable assemblies/Shielded • Reduced noise and interference • Key options: A, B coded • Maximum installation versatility • M12 Positions: 2, 4, 5 pos • Cable types variations for drag chain and torsion • M12 B-coded 5-pole for Profibus applications • M12 A-code 5pos for DeviceNet applications • M12 A-code 4pos for CC-link applications • Cable length options: 0.5 m, 1 m, 2m, 4m, 6m, 8m, 10m and 15m. INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 49 M8/M12 CONNECTOR SYSTEM APPLICATIONS MATERIALS • Industrial communications • Contact: Brass, Gold plating • Industrial machinery • Nut & Shells: Brass, Nickel plating • Industrial automation • O-ring: Silicon rubber • Machine tools • Over-molding: TPU/PVC • Robotics • Housing: PA • Material handling • PROFIBUS® M12 Cable Assy B-code 2-pole 1x2x22AWG PUR Drag Chain • Process control systems ELECTRICAL • Voltage and current rating: • M12 A code 4 poles: 250V/4A • M12 A code 5 poles: 60V/4A • M12 B code 2 poles: 250V/4A • PROFIBUS®M12 Cable Assy B-code 2-pole 1x2x24AWG PUR Torsion • DeviceNet™ M12 Cable Assy A-code 5-pole 2x24AWG+2x22AWG Thin Violet PUR • DeviceNet™ M12 Cable Assy A-code 5-pole 2x24AWG+2x22AWG Thin Gray PVC • CC-Link® M12 Cable Assy A-code 4pos 3 conductor 20AWG Red PVC MECHANICAL • Durability: 100 cycles SPECIFICATIONS • Degree of protection: IP67 • Product specification: 108-106140 • Temperature ratings: - Profibus PUR: Fixed: -40°C to +80°C Flexible: -40°C to +75°C • Application specification: 114-137144 • Profibus PUR torsion: Operating temperature -25°C to +75°C • DeviceNet PVC: Operating temperature -20°C to +75°C • DeviceNet PUR: Operating temperature -40°C to +80°C • UL standard: UL2238 • IEC 61076-2-101: Detail specification for M12 connectors with screw-locking • IEC 60512: Electromechanical components for electronic equipment; basic testing procedure and measuring methods • IEC-60529: Degree of protection provided by enclosures (IP Code) • CC-Link PVC: Operating temperature -30°C to +60°C INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 50 M8/M12 CONNECTOR SYSTEM PRODUCT OFFERINGS - CC-LINK M12 A-CODE 4POS CABLE ASSEMBLIES SINGLE ENDED Part Number Part Description TAA541B1411-001 M12A4-MS-PVC-0.5M TAA543B1411-001 M12A4-FS-PVC-0.5M Application CC-Link (10Mbs) TAA544B1411-001 M12A4-FR-PVC-0.5M TAA542B1411-001 M12A4-MR-PVC-0.5M Code A POS 4 Type Cable Material Male / Female Straight PVC Red 20AWG Shielded Yes Male / Female R/A PRODUCT OFFERINGS - CC-LINK M12 A-CODE 4POS CABLE ASSEMBLIES DOUBLE ENDED Part Number Part Description TAA545B1411-001 M12A4-MS-FSPVC-0.5M TAA54AB1411-001 M12A4-MR-FSPVC-0.5M TAA546B1411-001 M12A4-MS-FRPVC-0.5M Application CC-Link (10Mbs) Code A POS 4 Type Cable Material MS-FS PVC Red 20AWG Shielded Yes MR-FS / MS-FR PRODUCT OFFERINGS - DEVICENET M12 A-CODE 5POS CABLE ASSEMBLIES SINGLE ENDED PUR Part Number Part Description TAA751A5501-001 M12A5-MS-PUR-0.5M TAA753A5501-001 M12A5-FS-PUR-0.5M Application M12A5-FR-PUR-0.5M TAA752A5501-001 M12A5-MR-PUR-0.5M INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM POS Type Male / Female Straight DeviceNet (500Kbs) TAA754A5501-001 Code A 5 Male / Female R/A Cable Material Shielded PUR Violet 2x24AWG+2x22 AWG Yes PAGE 51 M8/M12 CONNECTOR SYSTEM PRODUCT OFFERINGS - DEVICENET M12 A-CODE 5POS CABLE ASSEMBLIES DOUBLE ENDED PUR Part Number Part Description Application Code POS Type MS-FS TAA755A5501-001 M12A5-MS-FS-PUR-0.5M TAA75AA5501-001 M12A5-MR-FS-PUR-0.5M TAA756A5501-001 M12A5-MS-FR-PUR-0.5M DeviceNet (500Kbs) A 5 Cable Material Shielded PUR Violet 2x24AWG+2x 22AWG MR-FS / MS-FR Yes PRODUCT OFFERINGS - DEVICENET M12 A-CODE 5POS CABLE ASSEMBLIES SINGLE ENDED PVC Part Number Part Description TAA751A1611-001 M12A5-MS-PVC-0.5M TAA753A1611-001 M12A5-FS-PVC-0.5M Application DeviceNet (500Kbs) TAA754A1611-001 M12A5-FR-PVC-0.5M TAA752A1611-001 M12A5-MR-PVC-0.5M Code POS A 5 Type Cable Material Male / Female Straight PVC Gray 2x24AWG+2x22AWG Shielded Yes Male / Female R/A PRODUCT OFFERINGS - DEVICENET M12 A-CODE 5POS CABLE ASSEMBLIES DOUBLE ENDED PVC Part Number Part Description Application Code POS Type MS-FS TAA755A1611-001 M12A5-MS-FS-PVC-0.5M TAA75AA1611-001 M12A5-MR-FS-PVC-0.5M TAA756A1611-001 M12A5-MS-FR-PVC-0.5M INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM DeviceNet (500Kbs) A 5 MR-FS / MS-FR Cable Material Shielded PVC Gray 2x24AWG+2x22 AWG Yes PAGE 52 M8/M12 CONNECTOR SYSTEM PRODUCT OFFERINGS - PROFIBUS M12 B-CODE 2-POS CABLE ASSEMBLIES SINGLE ENDED PUR TORSION Part Number Part Description TAB62146501-001 M12B2-MS-PUR TORS-0.5M TAB62346501-001 M12B2-FS-PUR TORS-0.5M Application Code M12B2-FR-PUR TORS-0.5M TAB62246501-001 M12B2-MR-PUR TORS-0.5M Type Cable Material 2 B Shielded PUR Torsion 22AWG Violet Male / Female Straight Profibus DP (12Mbs) TAB62446501-001 POS Yes Male / Female R/A PRODUCT OFFERINGS - PROFIBUS M12 B-CODE 2-POS CABLE ASSEMBLIES DOUBLE ENDED PUR TORSION Part Number Part Description TAB62546501-001 M12B2-MS-FS-PUR/T-0.5M TAB62A46501-001 M12B2-MR-FS-PUR/T-0.5M TAB62646501-001 M12B2-MS-FR-PUR/T-0.5M Application Code Profibus DP (12Mbs) POS B 2 Type Cable Material MS-FS PUR Torsion 22AWG Violet MR-FS / MS-FR Shielded Yes PRODUCT OFFERINGS - PROFIBUS M12 B-CODE 2-POS CABLE ASSEMBLIES SINGLE ENDED PUR FLEX/ DRAG CHAIN Part Number Part Description TAB62135501-001 M12B2-MS-PUR Flex-0.5M TAB62335501-001 M12B2-FS-PUR Flex-0.5M Application Profibus DP (12Mbs) TAB62435501-001 M12B2-FR-PUR Flex-0.5M TAB62235501-001 M12B2-MR-PUR Flex-0.5M INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM Code B POS 2 Type Cable Material Male / Female Straight PUR Flex/Drag Chain 24AWG Violet Male / Female R/A Shielded Yes PAGE 53 M8/M12 CONNECTOR SYSTEM PRODUCT OFFERINGS - PROFIBUS M12 B-CODE 2-POS CABLE ASSEMBLIES DOUBLE ENDED PUR FLEX/DRAG CHAIN Part Number Part Description TAB62535501-001 M12B2-MS-FSPURFlex-0.5M TAB62A35501-001 M12B2-MR-FSPURFlex0.5M TAB62635501-001 M12B2-MS-FRPURFlex-0.5M Application Profibus DP (12Mbs) 00L Cable Length -001 0.5M -002 1.0M -020 2.0M -040 4.0M -060 6.0M -080 8.0M -007 10.0M -150 15.0M -XXX Customized Cable Length -XX0 XXM -XX5 XX.5M INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM Code B POS 2 Type Cable Material MS-FS PUR Flex/Drag Chain 24AWG Violet MR-FS / MS-FR Shielded Yes PAGE 54 M8/M12 CONNECTOR SYSTEM M12 INDUSTRIAL ETHERNET D-CODE CABLE ASSEMBLIES TE Connectivity offers M12 data cable assemblies with D-code interfaces that support Ethernet protocols as part of its package of Industrial Ethernet and Fieldbus solutions. The Cat5e cable jackets vary between PVC, PUR and TPE offer a unique solution toward satisfying the stringent needs of motion systems supporting both flexing and stationary industrial Ethernet requirements. TE’s portfolio is further complemented with overmolded M12 D-code to RJ45 configurations which are key components to an overall Industrial Ethernet application and designed for connection within control cabinets, machinery and in-the-field operations. This makes it the one-stop shop for M8/M12 cable assemblies for Industrial Network communications. TE has enriched its already large offering in Fieldbus connectivity solutions (based on Profibus, DeviceNet, CanOpen and CC-link) with Industrial Ethernet protocols such as Profinet, EtherCAT, Ethernet/IP and SERCOS-III. FEATURES FEATURES • Jacketing is in halogen-free flame-retardant thermoplastic polyurethane (PUR) high flex TPE, PVC or FRNC (flame retardant, non-corrosive) materials and TPE high-flex cables • Category 5e cables can realize transmission rates of 100Mbps to meet network requirements in the field and at supervisory management levels • PVC provides a competitive and economic solution for occasional movement or vibration, but PUR is more suited to more demanding applications in for example, drag chains and harsh environments where operational reliability is crucial • Category 5e cables can realize transmission rates of 100Mbps to meet network requirements in the field and at supervisory management levels • The new assemblies are available with several standard cable length options from 0.5m through to 30m • Enclosure rating of IP67 rating for dust-tight and waterproof applications ensure efficient, high-quality and reliable connectivity and high integrity signal transmission • The new assemblies are available with several standard cable length options from 0.5m through to 30m BENEFITS • Unit remains protected and fully operational in most industrial applications • Secured signal connections and data trasnmission • Ensure the application of cable assembly in flexible installation environment • Ensure the application of cable assembly in torsion application environment • Oil-resistant for in oil industrial applications • Application of UV-resistant environment • 360 degrees shielding • Depending on the material, the assemblies withstand up to 3 million flexes, machine oils, abrasion and UV • Our TPE cables can withstand 5M cycles for C-track applications INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 55 M8/M12 CONNECTOR SYSTEM APPLICATIONS MECHANICAL • Industrial communications Waterproof: • Process control systems • IP67 rating for D code M12 cable side: IP20 for RJ45 male side • Industrial machinery • Mating / Un-mating force: 15N/15N max. • Industrial automation • Sinusoidal vibration meet IEC60512, test 6d • Machine tools • Mechanical shock meet EIA364-27 • Robotics Durability: • Material handling • 1M for PUR drag chain cable MATERIALS • 3M for TPE torsion cable • 5M for TPE C-track • Contact: Brass, Gold Plating 30um Temperature Ratings: • Nut & Shells: Brass, Nickel plating • Industrial Ethernet Profinet/SERCOS III Type B PVC: Cat5e 22AWG • O-ring: Silicon rubber • Over-molding: PUR/PVC • Housing: PA • PA66 for M12 connector housing • TPU or PVC material for cable assembly over-molding depending cable jacket type • PP for inner over-molding • Cable Jacket materials: PUR, PVC, FRNC and TPE ELECTRICAL • Operating temperature -40°C to +80°C (fixed) -20°C to +60°C (flexible) • Industrial Ethernet Profinet Type C PUR: PUR Cat5e 22AWG • Operating temperature -30°C to +70°C (fixed) -20°C to +60°C (flexible) • Industrial Ethernet/IP Hi-Flex Cat5e TPE SF/UTP 24AWG • Industrial Ethernet/IP Hi-Flex Cat5e TPE U/UTP 24AWG • Operating temperature: -20°C to +80°C (fixed) -40°C to +80°C (flexible) • M12 D code 4 poles: 30V/1.5A SPECIFICATIONS • Voltage proof: 1400V • UL1863 • Insulation resistance: 100MΩ min • IEC 61076-2-101: Detail specification for M12 connectors with screw-locking (but True Position 0.1mm requirement for male side is not required) • 30° C max under loaded rating current • 2pair is for D-Code CAT5E performance, which is based on channel level • IEC 60512: Electromechanical Components For Electronic Equipment; Basic testing procedure and measuring methods • IEC-60529: Degree of protection provided by enclosures (IP Code) • ISO/IEC 11801 category 5e INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 56 M8/M12 CONNECTOR SYSTEM PART NUMBER LIST M12 ETHERNET D-CODE 4POS CABLE ASSEMBLIES DOUBLE ENDED TYPE C PUR & TPE Part Number TAD14545101-001 TAD14541111-001 TAD1453A201-001 TAD2453A201-001 Part Description Application Code POS Type Cable Material M12 MS-FS CAT5E TYPE C, PUR, 22AWG, GREEN M12 MS-FS CAT5E TYPE B, PVC, 22AWG, GREEN M12D4-MS-FS-PUR22SH-TYPE C-0.5M M12D4-MS-FS-PVC22SH-TYPE B-0.5M M12D4-MS-FSTPE-24SH-0.5M Profinet, EtherCAT, Ethernet/IP (up to 100Mbs) D 4 M12 MS-FS CAT5E TPE, SF/ UTP 24AWG TEAL M12 MS-FS CAT5E TPE, U/UTP 24AWG, TEAL M12D4-MS-FS-TPE24UNSH-0.5M Shielded Yes No M12 ETHERNET D-CODE 4POS CABLE ASSEMBLIES DOUBLE ENDED TO RJ45 TYPE C PUR & TPE Part Number TCD14745101-001 TCD14741111-001 TCD1473A201-001 TAD2473A201-001 Part Description Application Code POS Type M12 MS - RJ45 CAT5E TYPE C, PUR, 22AWG, GREEN M12 MS - RJ45 CAT5E TYPE B, PVC, 22AWG, GREEN M12D4-MS-RJ45-PUR22SH-TYPE C-0.5M M12D4-MS-RJ45-PVC22SH-TYPE B-0.5M M12D4-MS-RJ45TPE-24SH-0.5M M12D4-MS-RJ45TPE-24UNSH-0.5M INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM Profinet, EtherCAT, Ethernet/IP (up to 100Mbs) D 4 Cable Material M12 MS - RJ45 CAT5E TPE, SF/ UTP 24AWG TEAL M12 MS - RJ45 CAT5E TPE, U/UTP 24AWG, TEAL Shielded Yes No PAGE 57 M8/M12 CONNECTOR SYSTEM M12 ETHERNET D-CODE 4POS CABLE ASSEMBLIES SINGLE ENDED TPE (Extended to TPE jacketed cables; for PUR and PVC refer to original M8M12 Cordset catalog) Part Number TAD2413A201-001 Part Description Application Code POS Type Cable Material Male Straight (MS) CAT5E TPE SF/UTP 24AWG, TEAL M12D4-MS-TPE USH-0.5M Yes Male Right Angle (MR) TAD2423A201-001 TAD1413A201-001 M12D4-MR-TPE USH-0.5M M12D4-MS-TPE SH-0.5M Profinet, EtherCAT, Ethernet/IP (up to 100Mbs) D 4 Male Straight (MS) CAT5E TPE U/UTP 24AWG, TEAL No Male Right Angle (MR) TAD1423A201-001 Shielded M12D4-MR-TPE SH-0.5M M12 ETHERNET D-CODE 4POS CABLE ASSEMBLIES DOUBLE ENDED TPE (Extended to TPE jacketed cables; for PUR and PVC refer to original M8M12 Cordset catalog) Part Number TAD1473A201-001 Part Description Application Code POS Type Cable Material MS-MS CAT5E TPE SF/UTP 24AWG, TEAL M12D4-MS-MSTPE SH-0.5M Yes MS-MR TAD1483A201-001 TAD2473A201-001 M12D4-MS-MRTPE SH-0.5M M12D4-MS-MSTPE USH-0.5M Profinet, EtherCAT, Ethernet/IP (up to 100Mbs) D 4 MS-MS MS-MR TAD2483A201-001 Shielded CAT5E TPE U/UTP 24AWG, TEAL No M12D4-MS-MRTPE USH-0.5M INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 58 M8/M12 CONNECTOR SYSTEM PRODUCT OFFERINGS - M12 ETHERNET D-CODE 4-POS CABLE ASSEMBLIES SINGLE ENDED TYPE C PUR Part Number Part Description Application Code POS Type Male Straight TAD14145101-001 M12D4-MS-PUR TYPE C GREEN-0.5M Profinet, EtherCAT , Ethernet/IP D Shielded CAT5E TYPE C, PUR, 22AWG, GREEN 4 Yes Male R/A (up to 100Mbs) TAD14245101-001 Cable Material M12D4-MR-PUR TYPE C GREEN-0.5M PRODUCT OFFERINGS - M12 ETHERNET D-CODE 4-POS CABLE ASSEMBLIES DOUBLE ENDED TYPE C PUR Part Number Part Description Application Code POS Type MS-MS TAD14745101-001 M12D4-MS-MS-PUR TYPE C GREEN-0.5M Profinet, EtherCAT , Ethernet/IP D 4 (up to 100Mbs) TAD14845101-001 Cable Material Shielded CAT5E TYPE C, PUR, 22AWG, GREEN Yes MS-MR M12D4-MS-MR-PUR TYPE C GREEN-0.5M PRODUCT OFFERINGS - M12 ETHERNET D-CODE 4-POS CABLE ASSEMBLIES SINGLE ENDED TYPE B FRNC Part Number Part Description Application Code POS Type Male Straight TAD14147101-001 M12D4-MS-FRNC TYPE B GREEN-0.5M Profinet, EtherCAT , Ethernet/IP (up to 100Mbs) TAD14247101-001 D 4 Cable Material Shielded CAT5E TYPE B, FRNC, 22AWG, GREEN Yes Male R/A M12D4-MR-FRNC TYPE B GREEN-0.5M INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 59 M8/M12 CONNECTOR SYSTEM PRODUCT OFFERINGS - M12 ETHERNET D-CODE 4-POS CABLE ASSEMBLIES DOUBLE ENDED TYPE B FRNC Part Number TAD14747101-001 TAD14847101-001 Part Description M12D4-MS-MS-FRNC TYPE B GREEN-0.5M M12D4-MS-MR-FRNC TYPE B GREEN-0.5M Application Profinet, EtherCAT , Ethernet/IP Code D POS 4 (up to 100Mbs) Type Cable Material MS-MS CAT5E TYPE B, FRNC, 22AWG, GREEN Shielded Yes MS-MR PRODUCT OFFERINGS - M12 ETHERNET D-CODE 4-POS CABLE ASSEMBLIES SINGLE ENDED TYPE B PVC Part Number TAD14141111-001 TAD14241111-001 Part Description M12D4-MS-PVC TYPE B-0.5M M12D4-MR-PVC TYPE B-0.5M Application Profinet, EtherCAT , Ethernet/IP Code D POS 4 Type Cable Material Male Straight CAT5E TYPE B, PVC, 22AWG, GREEN Shielded Yes Male R/A (up to 100Mbs) PRODUCT OFFERINGS - M12 ETHERNET D-CODE 4-POS CABLE ASSEMBLIES DOUBLE ENDED TYPE B PVC Part Number Part Description Application Code POS Type MS-MS TAD14741111-001 M12D4-MS-MS-PVC TYPE B-0.5M Profinet, EtherCAT , Ethernet/IP (up to 100Mbs) TAD14841111-001 D 4 Cable Material Shielded CAT5E TYPE B, PVC, 22AWG, GREEN Yes MS-MR M12D4-MS-MR-PVC TYPE B-0.5M INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 60 M8/M12 CONNECTOR SYSTEM PRODUCT OFFERINGS - M12 ETHERNET D-CODE 4-POS CABLE ASSEMBLIES SINGLE ENDED TYPE B PVC RED Part Number TAD14141311-001 Part Description Application Code POS Type Cable Material Male Straight CAT5E TYPE B, PVC, 22AWG, RED Shielded M12D4-MS-PVC TYPE B RED-0.5M SERCOS-III (up to 100Mbs) TAD14241311-001 D 4 Male R/A Yes M12D4-MR-PVC TYPE B RED-0.5M PRODUCT OFFERINGS - M12 ETHERNET D-CODE 4-POS CABLE ASSEMBLIES DOUBLE ENDED TYPE B PVC RED Part Number TAD14741311-001 Part Description M12D4-MS-MS-PVC TYPE B RED-0.5M Application POS Type Cable Material MS-MS CAT5E TYPE B, PVC, 22AWG, RED Shielded SERCOS-III (up to 100Mbs) TAD14841311-001 Code D 4 MS-MR Yes M12D4-MS-MR-PVC TYPE B RED-0.5M 00L Cable Length -XXX Customized Cable Length -001 0.5M -XX0 XXM -002 1.0M -XX5 XX.5M -020 2.0M -040 4.0M -060 6.0M -080 8.0M -007 10.0M -150 15.0M -200 20.0M -250 25.0M -300 30.0M INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 61 M8/M12 CONNECTOR SYSTEM Application Code Pin Assignment M12 D Code Male RJ45 Plug Shielding (For Profinet/EtherCAT PUR, PVC jacketed cables) M12 D code TO RJ45 Ethernet D code Pin1 TD+ Yellow Pin1 Pin3 TD- Orange Pin2 Pin2 RD+ White Pin3 Pin4 RD- Blue Pin6 Option on metal nut (For EtherNET/IP TPE jacketed cable) M12 D code TO RJ45 Pin1 TD+ White-Orange Pin1 Pin3 TD- Orange Pin2 Pin2 RD+ White-Green Pin3 Pin4 RD- Green Pin6 INDUSTRIAL / M8 / M12 CONNECTOR SYSTEM PAGE 62 M8/M12 CONNECTOR SYSTEM PART NUMBER GUIDE FOR M12 D-CODE CORDSETS T A D S B X W Y O M N -XXX T TE Brand W Wire Gauge A M12 series 3 24 AWG (*for TPE) D D code 4 22 AWG (*for PUR, PVC) Y Cable Jacket S Application Type 1 Shielding industrial ethernet Cate5e Unshielding industrial ethernet Cate5e *only with TPE 2 N Other Standard screw nut with nickel plated 1 Stamping contact 30u” AU plated 1 PVC Moderate flexible -00L Cable Length 5 PUR high flex -001 0.5M A TPE Extreme high flex -002 1.0M -003 1.5M Cable Color -020 2.0M B Poles No. O 4 4 Poles 1 Green -004 3.0M 2 Teal -005 5.0M 3 Red -006 7.0M -007 10.0M X Interface Type 1 Male straight 2 Male angled 5 Male straight to female straight 7 Male straight to male straight 8 Male straight to male angled M Over-Molding -XXX Customized Cable Length 0 Black TPU Over-molding (*for PUR and TPE) -XX0 XX.0M -XX5 XX.5M -99X (
T4151320004-007 价格&库存
很抱歉,暂时无法提供与“T4151320004-007”相匹配的价格&库存,您可以联系我们找货
