T4161420003-003
T4161420003-003
    HUMIREL(泰科)
    TE CONNECTIVITY - T4161420003-003 - SENSOR CORD, 3P, M12 RCPT-FREE END, 1.5M
T4161420003-003 数据手册
T4161420003-003 M8/M12 Cable Assemblies, Sensor/Actuator, 3 Positions, A M8/M12 Cable Assembly Keying, Receptacle, M12 Pigtail, Right Angle T4161420003-003  ACTIVE TE Internal #: T4161420003-003 M8/M12 Cable Assemblies, Sensor/Actuator, 3 Positions, A M8 /M12 Cable Assembly Keying, Receptacle, M12 Pigtail, Right Angle View on TE.com > Cable Assemblies > Copper Cable Assemblies > M8/M12 Cable Assemblies > M12 A-CODE FEMALE R/A SINGLE ENDED CABL M8/M12 Application Type: Sensor/Actuator Number of M8/M12 Cable Assembly Positions: 3 M8/M12 Cable Assembly Keying: A M8/M12 Cable Assembly Connector Type: Receptacle M8/M12 Cable Assembly Type: M12 Pigtail All M12 A-CODE FEMALE R/A SINGLE ENDED CABL (140) Features Product Type Features LED Without Cable Type PUR Product Type Cable Assembly Assembly Type Pigtail M8/M12 Cable Assembly Connector Type Receptacle M8/M12 Cable Assembly Type M12 Pigtail M8/M12 Cable Assembly Shielded Yes Configuration Features Number of M8/M12 Cable Assembly Positions 3 M8/M12 Cable Assembly Keying A M8/M12 Cable Assembly Configuration Single Ended Electrical Characteristics Operating Voltage  Body Features For support call+1 800 522 6752 250 VDC 02/18/2021 07:30PM | Page 1 T4161420003-003 M8/M12 Cable Assemblies, Sensor/Actuator, 3 Positions, A M8/M12 Cable Assembly Keying, Receptacle, M12 Pigtail, Right Angle Body Features Connector Color Blue Cable Exit Angle Right Angle Environmental Protection With Conductor Material Copper Alloy Cable Jacket Color Gray Contact Features Contact Current Rating 4A Mechanical Attachment Screw & Hole Thread Size M12 M8/M12 Cable Assembly Mounting Angle Right Angle Housing Features M8/M12 Cable Assembly Housing Material GF Nylon Dimensions Wire Size 22 AWG Cable Assembly Length 1500 mm Operation/Application M8/M12 Application Type Sensor/Actuator Packaging Features Packaging Method Bag Other Field Serviceable Yes Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Compliant with Exemptions China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUN 2020 (209) Candidate List Declared Against: JAN 2020 (205) SVHC > Threshold: Pb (1.9% in Pb-Alloy in Copper) Article Safe Usage Statements:  For support call+1 800 522 6752 02/18/2021 07:30PM | Page 2 T4161420003-003 M8/M12 Cable Assemblies, Sensor/Actuator, 3 Positions, A M8/M12 Cable Assembly Keying, Receptacle, M12 Pigtail, Right Angle Pb (1.9% in Pb-Alloy in Copper) Article Safe Usage Statements: Do not eat, drink or smoke when using this product. Wash thoroughly after handling. Recycle if possible and dispose of the article by following all applicable governmental regulations relevant to your geographic location. Halogen Content Not Yet Reviewed for halogen content Solder Process Capability Not applicable for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach Compatible Parts TE Part # CAT-SE594-M1EE TE Part # CAT-SE594-M1DD M12 A-CODE MALE R/A PIGTAIL M12 A-CODE MALE R/A SINGLE ENDED CABLE Customers Also Bought  TE Part #1-2273047-4 TE Part #1-2273101-4 TE Part #2317655-2 TE Part #T4171110502-001 M12 A-CODE FEMALE STRAIGHT PIGTAIL M12 A-CODE FEMALE R/A PIGTAIL AV25 SPL 3A NO LED FL M12 Panel Mount Wire TE Part #TAA753A5501-040 TE Part #4-603225-0 TE Part #2325098-4 TE Part #1-1318954-1 Fieldbus, DeviceNet M12 A-Code 5p PUR AMP-TY HD BLK TY2HDB MNTG CLIP,ENETSEAL PLUS PL EXII 250 REC HSG 1P NYLON NAT For support call+1 800 522 6752 02/18/2021 07:30PM | Page 3 T4161420003-003 M8/M12 Cable Assemblies, Sensor/Actuator, 3 Positions, A M8/M12 Cable Assembly Keying, Receptacle, M12 Pigtail, Right Angle TE Part #5414265-3 PLUG, TWIST ON, COML BNC Documents Product Drawings RPC-M12-FR-3CON-PUR-1.5SH English CAD Files 3D PDF 3D Customer View Model ENG_CVM_CVM_T4161420003-003_A.2d_dxf.zip English Customer View Model ENG_CVM_CVM_T4161420003-003_A.3d_igs.zip English Customer View Model ENG_CVM_CVM_T4161420003-003_A.3d_stp.zip English By downloading the CAD file I accept and agree to the Terms and Conditions of use. Datasheets & Catalog Pages M8 / M12 Connector System Catalog English Product Specifications Application Specification English  For support call+1 800 522 6752 02/18/2021 07:30PM | Page 4
T4161420003-003 价格&库存
很抱歉,暂时无法提供与“T4161420003-003”相匹配的价格&库存,您可以联系我们找货
