FRCIR030-28-12P-F80-T112-13
    ITT
    CONNRCPT26POSPNLMNTPIN
FRCIR030-28-12P-F80-T112-13 数据手册
Interconnect Solutions APPLICATION NOTE www.ittcannon.com FRCIR Connector with M12 Contacts Product Features The Challenge To provide system December 2008 connections for data transmission in railway applications which group multiple cables of Ethernet / MVB lines into the M12 type contacts, copper alloy material • and plastic inserts • Connector type FRCIR size 32 • Cables tested and qualified at frequency of same connector. 1MHz, 10MHz, 100MHz o With Ethernet lines 100 Ω o With MVB lines 120 Ω • According to VG95234 where applicable • Aluminum allow shells with black epoxy urethanic varnish (RoHS compliant) Inserts are Plastic material, UL94-VO and • meets NF F 16-101/16-102 standards New VEAM M12 contacts within insert of FRCIR connector, for inter-vehicle application. Meets IP67 in a mated condition with the • appropriate accessories The ITT Solution … ITT ICS answered the challenge with new M12 contacts mounted into a CIR connector series hardware. The four conductor wires and braid of shielded cables are integrated into the M12 contact. The special plastic insert and connector accessories Operating Temperature of -40° C to 125° C • Benefit to the Customer • Cost effective solution for multiple shielding • Extra sealing • Suitable for harsh very demanding applications can regroup multiple M12 contacts and cables in the same connector. Applications • Railway system • Transportation interconnects • Data bus network system For application assistance, please contact: AMERICAS Mike Gardiner, +1.860.945.8275, mike.gardiner@itt.com ASIA Edward Wong +852.2589.5839, edward.wong@itt.com EUROPE Flavio Frascoli, +39 02 93872217 flavio.frascoli@it.itt.com
- 物料型号:FRCIR连接器,M12接触件。 - 器件简介:该连接器设计用于铁路系统中的以太网/MVB线路的多电缆连接。 - 引脚分配:文档未明确提供引脚分配的详细信息。 - 参数特性: - M12型接触件,铜合金材料和塑料插入件。 - FRCIR连接器尺寸为32。 - 电缆在1MHz、10MHz、100MHz频率下经过测试和认证。 - 以太网线路为100欧姆,MVB线路为120欧姆。 - 符合VG95234标准(如适用)。 - 铝合金壳体,黑色环氧聚氨酯漆(符合RoHS)。 - 插入件为塑料材料,UL94-VO等级,符合NF F 16-101/16-102标准。 - 在配合适当配件的情况下,达到IP67防护等级。 - 工作温度范围为-40°C至125°C。 - 功能详解:文档未提供详细的功能解释,但强调了连接器适用于恶劣环境和高要求的应用。 - 应用信息:铁路系统、交通互连、数据总线网络系统。 - 封装信息:连接器和配件的详细封装信息未在文档中明确说明。
FRCIR030-28-12P-F80-T112-13 价格&库存
很抱歉,暂时无法提供与“FRCIR030-28-12P-F80-T112-13”相匹配的价格&库存,您可以联系我们找货
