FRCIR06R-40-56S-F80-T112-12 数据手册
Interconnect Solutions
APPLICATION NOTE
www.ittcannon.com
FRCIR Connector with M12 Contacts
Product Features
The Challenge
To
provide
system
December 2008
connections
for
data
transmission in railway applications which group
multiple cables of Ethernet / MVB lines into the
M12 type contacts, copper alloy material
and plastic inserts
Connector type FRCIR size 32
Cables tested and qualified at frequency of
same connector.
1MHz, 10MHz, 100MHz
o
With Ethernet lines 100 Ω
o
With MVB lines 120 Ω
According to VG95234 where applicable
Aluminum allow shells with black epoxy
urethanic varnish (RoHS compliant)
Inserts are Plastic material, UL94-VO and
meets NF F 16-101/16-102 standards
New VEAM M12 contacts within insert of FRCIR
connector, for inter-vehicle application.
Meets IP67 in a mated condition with the
appropriate accessories
The ITT Solution …
ITT ICS answered the challenge with new M12
contacts mounted into a CIR connector series
hardware. The four conductor wires and braid of
shielded cables are integrated into the M12 contact.
The special plastic insert and connector accessories
Operating Temperature of -40° C to 125° C
Benefit to the Customer
Cost effective solution for multiple shielding
Extra sealing
Suitable for harsh very demanding
applications
can regroup multiple M12 contacts and cables in the
same connector.
Applications
Railway system
Transportation interconnects
Data bus network system
For application assistance, please contact:
AMERICAS
Mike Gardiner, +1.860.945.8275, mike.gardiner@itt.com
ASIA
Edward Wong +852.2589.5839, edward.wong@itt.com
EUROPE
Flavio Frascoli, +39 02 93872217 flavio.frascoli@it.itt.com
FRCIR06R-40-56S-F80-T112-12 价格&库存
很抱歉,暂时无法提供与“FRCIR06R-40-56S-F80-T112-12”相匹配的价格&库存,您可以联系我们找货
