Fakra
Features/Benefits
• Robust Connector made of one metal piece • Supports 0 to 4 GHz transferring speed • Available in a variety of Fakra codes
Typical Applications
• • • • • Bluetooth Global positioning satellite Remote vehicle diagnostics Satellite radio Vehicular internet access
Fakra is a standard developed by the DIN group for RF connectors used in “Road Vehicle” applications. RF connectors are fitted with a color coded, and polarized diecast housing. Fakra Connectors are available in 1, 2 and 3 way right-angle PCB versions. They are ideally suited for circuit miniaturization and are offered in a wide range of configurations which includes, black (A), natural (B), blue (C), violet (D), beige (I). The desirable feature of the new 50 ohm Fakra connector is its consistant low mating and unmating forces, extremely low VSWR and insertion loss (IL) values up to 4 GHz.
FAKRA
Performance Specifications
CONNECTOR DURABILITY: CONTACT RESISTANCE, INNER CONDUCTOR: CONTACT RESISTANCE, OUTER CONDUCTOR: CORONA LEVEL: DWV (PIN-TO-CASE): IMPEDANCE: INSERTION LOSS: MATING FORCE: MOUNTING: NUMBER OF CIRCUITS: OPERATING TEMPERATURE: PACKAGING: PEAK SOLDER TEMPERATURE EXPOSURE: RF LEAKAGE: STORAGE TEMPERATURE: VSWR: 50 mating cycles min. 6.0m Ωmax. before environment 8.0m Ωmax. after environment 2.0m Ωmax. 190 V min. 750 VAC rms 50 Ω 0.8 to 2 GHz: 0.35 dB max. 2 to 3 GHz: 0.45 dB min. 1 way: 75 N max. 2 way: 100 N max. 3 way: 100 N max. Thru-hole 1, 2, 3 -40˚C to 105˚C (-40˚F to 221˚F) 1 way: Tape & reel 2 way: Tape & reel 3 way: Tube of 20 pieces 30 s 0.8 to 3 GHz: -40 dB min. -40˚C to 105˚C (-40˚F to 221˚F) 1.2 max. at 3 GHz Zinc alloy, Tin lead plating Brass or beryllium copper, Gold plating High temperature plastic, glass filled Brass, nickel plating Teflon
Materials and Finishes
HOUSING: CONTACT: COLOR BAND: OUTER CONDUCTOR: DIELECTRICS
North America Tel: 800.683.7666
www.ittcannon.com United Kingdom Tel: 44.1256.311200
Hong Kong Tel: 852.2732.2720
Fakra
2 Way, Part Number: T112220-0015
26,6 (1.048)
25,4 (1.000)
9,88 (0.389) 5,0 (0.197) 10,0 (0.394) 3,5 (0.138) 2x ø7,5+0.00/-0.05 (0.2953+0.0000/-0.0019) -D12,7 (0.500)
2,8 (0.111)
FAKRA
1 Way, Part Number: T112220-0007
8,0±0,1 (0.315±0.004) 2,0+0,0/-0,1 (0.0787+0.000/-0.004) 0.10 A A 25,7 REF. (1.012) 3,0±0,1 (0.118±0.004) 1,0±0,1 (0.039±0.004) 4,65±0,1 (0.183±0.004)
4,75+0,0/-0,1 (0.187+0.000/-0.004) 45˚±1˚ 2x R 0,2 (0.008) 1,0+0,0/-0,1 (0.039+0.000/-0.004)
9,36 MIN (0.369) 7,55+0,0/-0.05 (0.297+0.000/-0.001)
7,0 (0.276) B A
11,5 (0.453)
C
6,25±0,1 4,75±0,1 (0.246±0.004) (0.187±0.004)
C 9,13 (0.360)
10,88 (0.429)
C
5,0 (0.197)
0,8±0,1 (0.032±0.004)
A
3,5 MIN (0.138)
8,0 (0.315) B
2,4 (0.095) 3x ø0.97±0.0 (0.038±0.000) 2,54 (0.100) 4x ø1,4 (0.060) A 5,08 (0.200)
4x 2,79 (0.110)
1,0 (0.040)
0,5 (0.020)
5,5 (0.217)
2,54 (0.100) 5,08 (0.200) 11,0 (0.433)
Dimensions are shown: mm (inch) Dimensions subject to change
Fakra
1 Way, Part Number: T112220-0008
8,0±0,1 (0.315±0.004) 2,0+0,1/-0,1 (0.0787+0.004/-0.004) 0.10 A A 4,75+0,0/-0,1 (0.187+0.000/-0.004) 1,7+0,0/-0,1 (0.070+0.000/-0.004) 45˚±1˚ 2x R 0,2 (0.008) 1,0+0,0/-0,1 (0.039+0.000/-0.004) 25,7 REF (1.012)
9,36 MIN (0.369) 7,55+0,0/-0.05 (0.297+0.000/-0.001) 0,5+0,0/-0,05 (0.020+0.000/-0.000) 6,25±0,1 (0.246±0.004) 4,75±0,1 (0.187±0.004)
3,0±0,1 (0.118±0.004) 7,0 1,0±0,1 (0.280) (0.039±0.004) B 4,65±0,1 (0.183±0.004) C 9,13 (0.360) 10,88 (0.429)
11,5 (0.453) A
C
5,0 (0.197)
C
A
4,75+0,0/-0,1 (0.187+0.000/-0.004) 0,5 (0.020) B
8,0 (0.315)
FAKRA
1,0 (0.040)
2,54 (0.100) 4x ø1,4 (0.056) A
2,40 3x ø0.97±0,0 (0.095) (0.038±0.000)
4x 2,79 (0.110)
5,08 (0.200)
2,54 (0.100) 5,5 (0.217) 5,08 (0.200) 11,0 (0.433)
1 Way, Part Number: T112220-0009
8±0,1 (0.315±0.004) 2+0,0/-0,1 (0.0787+0.000/-0.004) 0.10 A A 25,7 REF (1.012) 3,0±0,1 (0.118±0.004) 7,0 1,0±0,1 (0.276) (0.039±0.004) B 4,65±0,1 (0.183±0.004) C 10,88 9,13 (0.429) (0.360)
4,75+0,0/-0,1 (0.187+0.000/-0.004) 45˚±1˚ 2x 0,2 (0.008) 1,0+0,0/-0,1 (0.039+0.000/-0.004)
9,36 MIN (0.369) 7,55+0/-0,05 (0.298+0.000/-.001) 2,7 0,5+0,1/-0.05 (0.020+0.004/-0.000) (0.107) 6,25±0,1 4,75±0,1 (0.246±0.004) (0.187±0.004) C 1,7+0,1/-0,1 (0.067+0.004/-0.004)
11,5 (0.453) A
C
5,0 (0.197)
A
4,75+0,0/-0,1 (0.187+0.000/-0.004) 0,5 (0.020) 1,0 (0.040) B
8,0 (0.315)
2,54 (0.100) 4x ø1,4 (0.06) A
2,40 (0.095) 3x ø0.97±0,0 (0.038±0.000)
4x 2,79 (0.110)
5,08 (0.200)
Fakra
1 Way, Part Number: T11220-0010
2x 2,7+0,1/-0,0 (0.107+0.004/-0.000) 2,0+0,0/-0,1 (0.0787+0.000/-0.004) 0.10 A A 8,0±0,1 (0.315±0.004)
4,75+0,0/-0,1 (0.187+0.000/-0.004) 45˚±1˚ 2x R 0,2 (0.008) 1,0+0,0/-0,1 (0,039+0.000/-0.004) 90˚
9,36 MIN (0.369) 7,55+0,1/-0,05 (0.297+0.004/-0.001)
25,7 REF (1.012) 3,0±0,1 (0.118±0.004) 7,0 1,0±0,1 (0.276) (0.039±0.004) B 4,65±0,1 (0.183±0.004) C 9,13 (0.360) 10,88 (0.429)
11,5 (0.453) A
C
C
5,0 (0.197)
A
8,0 (0.315) B
2.40 (0.095) 3x ø0.97±0,0 (0.038±0.000) 2,54 (0.100) 4x ø1,4 (0.056)
4x 2,79 (0.110)
FAKRA
A
5,08 (0.200)
3 Way, Part Number: T112220-0012
23,9 (0.941) 2,0 (0.079)
3x 45˚x0,1 (45˚x.004)
3,95 (0.156) 2,65±0,1 (0.104±0.004)
3x ø7,9+0,0/-0,05 (0.311+0.000/-0.001) -A3,95 (0.156) 2,65±0,1 (0.104±0.004) 3,95 (0.156) 3x ø0.97±0,0 (0.038±0.000) 2,65±0,1 (0.104±0.004)
7,55+0,0/-0,05 (0.297+0.000/-0.001)
6,55±0,1 (0.258±0.004)
12,5 (0.493) 28,5 (1.122) 9,36+0,2/-0,0 (0.369+0.007/-0.000) 3,1±0,1 (0.118±0.004) 1,0±0,1 (0.039±0.004) 8,75±0,1 9,25±0,1 (0.344±0.004) (0.365±0.004) 5,0 (0.197) 8x 3,0 (0.119) 3x 8,27±0,1 (0.326±0.004) 14,55 (0.573)
3,95 (0.156) 2,65 (0.105) 8,0±0,1 (0.315±0.004)
5,05+0,0/-0,1 (0.199+0.000/-0.004) 0,8 (0.032) 5,0 (0.197)
8x ø1,5±0,05 (0.059±0.001)
16,0±0,1 (0.630±0.004)
22,5±0,1 (0.886±0.004) 8,0±0,1 27,5 (0.315±0.004) (1.083) 7,25±0,1 (0.285±0.004) 3,25 (0.128) 10,25 (0.404) 2,5 1,02 (0.041) (0.099)
