T112220-0012
T112220-0012
    ITT
    T112220-0012 - Fakra - ITT Industries
T112220-0012 数据手册
Fakra Features/Benefits • Robust Connector made of one metal piece • Supports 0 to 4 GHz transferring speed • Available in a variety of Fakra codes Typical Applications • • • • • Bluetooth Global positioning satellite Remote vehicle diagnostics Satellite radio Vehicular internet access Fakra is a standard developed by the DIN group for RF connectors used in “Road Vehicle” applications. RF connectors are fitted with a color coded, and polarized diecast housing. Fakra Connectors are available in 1, 2 and 3 way right-angle PCB versions. They are ideally suited for circuit miniaturization and are offered in a wide range of configurations which includes, black (A), natural (B), blue (C), violet (D), beige (I). The desirable feature of the new 50 ohm Fakra connector is its consistant low mating and unmating forces, extremely low VSWR and insertion loss (IL) values up to 4 GHz. FAKRA Performance Specifications CONNECTOR DURABILITY: CONTACT RESISTANCE, INNER CONDUCTOR: CONTACT RESISTANCE, OUTER CONDUCTOR: CORONA LEVEL: DWV (PIN-TO-CASE): IMPEDANCE: INSERTION LOSS: MATING FORCE: MOUNTING: NUMBER OF CIRCUITS: OPERATING TEMPERATURE: PACKAGING: PEAK SOLDER TEMPERATURE EXPOSURE: RF LEAKAGE: STORAGE TEMPERATURE: VSWR: 50 mating cycles min. 6.0m Ωmax. before environment 8.0m Ωmax. after environment 2.0m Ωmax. 190 V min. 750 VAC rms 50 Ω 0.8 to 2 GHz: 0.35 dB max. 2 to 3 GHz: 0.45 dB min. 1 way: 75 N max. 2 way: 100 N max. 3 way: 100 N max. Thru-hole 1, 2, 3 -40˚C to 105˚C (-40˚F to 221˚F) 1 way: Tape & reel 2 way: Tape & reel 3 way: Tube of 20 pieces 30 s 0.8 to 3 GHz: -40 dB min. -40˚C to 105˚C (-40˚F to 221˚F) 1.2 max. at 3 GHz Zinc alloy, Tin lead plating Brass or beryllium copper, Gold plating High temperature plastic, glass filled Brass, nickel plating Teflon Materials and Finishes HOUSING: CONTACT: COLOR BAND: OUTER CONDUCTOR: DIELECTRICS North America Tel: 800.683.7666 www.ittcannon.com United Kingdom Tel: 44.1256.311200 Hong Kong Tel: 852.2732.2720 Fakra 2 Way, Part Number: T112220-0015 26,6 (1.048) 25,4 (1.000) 9,88 (0.389) 5,0 (0.197) 10,0 (0.394) 3,5 (0.138) 2x ø7,5+0.00/-0.05 (0.2953+0.0000/-0.0019) -D12,7 (0.500) 2,8 (0.111) FAKRA 1 Way, Part Number: T112220-0007 8,0±0,1 (0.315±0.004) 2,0+0,0/-0,1 (0.0787+0.000/-0.004) 0.10 A A 25,7 REF. (1.012) 3,0±0,1 (0.118±0.004) 1,0±0,1 (0.039±0.004) 4,65±0,1 (0.183±0.004) 4,75+0,0/-0,1 (0.187+0.000/-0.004) 45˚±1˚ 2x R 0,2 (0.008) 1,0+0,0/-0,1 (0.039+0.000/-0.004) 9,36 MIN (0.369) 7,55+0,0/-0.05 (0.297+0.000/-0.001) 7,0 (0.276) B A 11,5 (0.453) C 6,25±0,1 4,75±0,1 (0.246±0.004) (0.187±0.004) C 9,13 (0.360) 10,88 (0.429) C 5,0 (0.197) 0,8±0,1 (0.032±0.004) A 3,5 MIN (0.138) 8,0 (0.315) B 2,4 (0.095) 3x ø0.97±0.0 (0.038±0.000) 2,54 (0.100) 4x ø1,4 (0.060) A 5,08 (0.200) 4x 2,79 (0.110) 1,0 (0.040) 0,5 (0.020) 5,5 (0.217) 2,54 (0.100) 5,08 (0.200) 11,0 (0.433) Dimensions are shown: mm (inch) Dimensions subject to change North America Tel: 800.683.7666 www.ittcannon.com United Kingdom Tel: 44.1256.311200 Hong Kong Tel: 852.2732.2720 Fakra 1 Way, Part Number: T112220-0008 8,0±0,1 (0.315±0.004) 2,0+0,1/-0,1 (0.0787+0.004/-0.004) 0.10 A A 4,75+0,0/-0,1 (0.187+0.000/-0.004) 1,7+0,0/-0,1 (0.070+0.000/-0.004) 45˚±1˚ 2x R 0,2 (0.008) 1,0+0,0/-0,1 (0.039+0.000/-0.004) 25,7 REF (1.012) 9,36 MIN (0.369) 7,55+0,0/-0.05 (0.297+0.000/-0.001) 0,5+0,0/-0,05 (0.020+0.000/-0.000) 6,25±0,1 (0.246±0.004) 4,75±0,1 (0.187±0.004) 3,0±0,1 (0.118±0.004) 7,0 1,0±0,1 (0.280) (0.039±0.004) B 4,65±0,1 (0.183±0.004) C 9,13 (0.360) 10,88 (0.429) 11,5 (0.453) A C 5,0 (0.197) C A 4,75+0,0/-0,1 (0.187+0.000/-0.004) 0,5 (0.020) B 8,0 (0.315) FAKRA 1,0 (0.040) 2,54 (0.100) 4x ø1,4 (0.056) A 2,40 3x ø0.97±0,0 (0.095) (0.038±0.000) 4x 2,79 (0.110) 5,08 (0.200) 2,54 (0.100) 5,5 (0.217) 5,08 (0.200) 11,0 (0.433) 1 Way, Part Number: T112220-0009 8±0,1 (0.315±0.004) 2+0,0/-0,1 (0.0787+0.000/-0.004) 0.10 A A 25,7 REF (1.012) 3,0±0,1 (0.118±0.004) 7,0 1,0±0,1 (0.276) (0.039±0.004) B 4,65±0,1 (0.183±0.004) C 10,88 9,13 (0.429) (0.360) 4,75+0,0/-0,1 (0.187+0.000/-0.004) 45˚±1˚ 2x 0,2 (0.008) 1,0+0,0/-0,1 (0.039+0.000/-0.004) 9,36 MIN (0.369) 7,55+0/-0,05 (0.298+0.000/-.001) 2,7 0,5+0,1/-0.05 (0.020+0.004/-0.000) (0.107) 6,25±0,1 4,75±0,1 (0.246±0.004) (0.187±0.004) C 1,7+0,1/-0,1 (0.067+0.004/-0.004) 11,5 (0.453) A C 5,0 (0.197) A 4,75+0,0/-0,1 (0.187+0.000/-0.004) 0,5 (0.020) 1,0 (0.040) B 8,0 (0.315) 2,54 (0.100) 4x ø1,4 (0.06) A 2,40 (0.095) 3x ø0.97±0,0 (0.038±0.000) 4x 2,79 (0.110) 5,08 (0.200) 2,54 (0.100) 5,5 (0.217) 5,08 (0.200) 11,0 (0.433) Dimensions are shown: mm (inch) Dimensions subject to change North America Tel: 800.683.7666 www.ittcannon.com United Kingdom Tel: 44.1256.311200 Hong Kong Tel: 852.2732.2720 Fakra 1 Way, Part Number: T11220-0010 2x 2,7+0,1/-0,0 (0.107+0.004/-0.000) 2,0+0,0/-0,1 (0.0787+0.000/-0.004) 0.10 A A 8,0±0,1 (0.315±0.004) 4,75+0,0/-0,1 (0.187+0.000/-0.004) 45˚±1˚ 2x R 0,2 (0.008) 1,0+0,0/-0,1 (0,039+0.000/-0.004) 90˚ 9,36 MIN (0.369) 7,55+0,1/-0,05 (0.297+0.004/-0.001) 25,7 REF (1.012) 3,0±0,1 (0.118±0.004) 7,0 1,0±0,1 (0.276) (0.039±0.004) B 4,65±0,1 (0.183±0.004) C 9,13 (0.360) 10,88 (0.429) 11,5 (0.453) A C 6,25±0,1 4,75±0,1 (0.246±0.004) (0.187±0.004) C 5,0 (0.197) A 8,0 (0.315) B 2.40 (0.095) 3x ø0.97±0,0 (0.038±0.000) 2,54 (0.100) 4x ø1,4 (0.056) 4x 2,79 (0.110) 0,5 (0.020) 1,0 (0.040) FAKRA A 5,08 (0.200) 2,54 (0.100) 5,5 (0.217) 5,08 (0.200) 11,0 (0.433) 3 Way, Part Number: T112220-0012 23,9 (0.941) 2,0 (0.079) 3x 45˚x0,1 (45˚x.004) 3,95 (0.156) 2,65±0,1 (0.104±0.004) 3x ø7,9+0,0/-0,05 (0.311+0.000/-0.001) -A3,95 (0.156) 2,65±0,1 (0.104±0.004) 3,95 (0.156) 3x ø0.97±0,0 (0.038±0.000) 2,65±0,1 (0.104±0.004) 7,55+0,0/-0,05 (0.297+0.000/-0.001) 6,55±0,1 (0.258±0.004) 12,5 (0.493) 28,5 (1.122) 9,36+0,2/-0,0 (0.369+0.007/-0.000) 3,1±0,1 (0.118±0.004) 1,0±0,1 (0.039±0.004) 8,75±0,1 9,25±0,1 (0.344±0.004) (0.365±0.004) 5,0 (0.197) 8x 3,0 (0.119) 3x 8,27±0,1 (0.326±0.004) 14,55 (0.573) 3,95 (0.156) 2,65 (0.105) 8,0±0,1 (0.315±0.004) 5,05+0,0/-0,1 (0.199+0.000/-0.004) 0,8 (0.032) 5,0 (0.197) 8x ø1,5±0,05 (0.059±0.001) 16,0±0,1 (0.630±0.004) 22,5±0,1 (0.886±0.004) 8,0±0,1 27,5 (0.315±0.004) (1.083) 7,25±0,1 (0.285±0.004) 3,25 (0.128) 10,25 (0.404) 2,5 1,02 (0.041) (0.099) Dimensions are shown: mm (inch) Dimensions subject to change North America Tel: 800.683.7666 www.ittcannon.com United Kingdom Tel: 44.1256.311200 Hong Kong Tel: 852.2732.2720
T112220-0012 价格&库存
很抱歉,暂时无法提供与“T112220-0012”相匹配的价格&库存,您可以联系我们找货
