T491
T491
    KEMET(基美)
    T491 - LOW PROFILE SURFACE MOUNT CAPACITORS - Kemet Corporation
T491 数据手册
INDEX T491 Series - Industrial Grade . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 - 6 T494 Series - Low ESR, Industrial Grade . . . . . . . . . . . . . . . . . . . . . . . . .7 - 9 T495 Series - Low ESR, Surge Robust . . . . . . . . . . . . . . . . . . . . . . . . . 10 - 11 T520 Series - Low ESR, Organic Polymer . . . . . . . . . . . . . . . . . . . . . . . 12 - 14 T525 Series - High Temperature . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Packaging Information . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 - 18 NOTICE Although the information in this catalog has been carefully checked for accuracy, and is believed to be correct and current, no warranty, either expressed or implied, is made as to either its applicability to, or its compatibility with specific requirements; nor does KEMET Electronics Corporation assume any responsibility for correctness of this information, nor for damages consequent to its use. All design characteristics, specifications, tolerance, and the like are subject to change without notice. The KEMET website (www.kemet.com) should be consulted for the very latest information on design characteristics, specifications, applications, and newly-released products, since previously-issued printed information may not be current. Any capacitors misapplied may fail and thereby damage other circuit components. Please refer to application notes and recommendations in this catalog for a complete description of capacitor characteristics. © KEMET Electronics Corporation • P.O. Box 5928 • Greenville, SC 29606 • www.kemet.com 3 T491 SERIES LOW PROFILE SURFACE MOUNT CAPACITORS Industrial Grade FEATURES Meets or exceeds EIA Standard 535BAAC Taped and Reeled per EIA 481-1 Symmetrical, Compliant Terminations Optional Gold-plated Terminations Laser-marked Case Refer to KEMET F3102 for performance characteristics and page 16 of this catalog component packaging Capacitance: 1.0μF to 330μF Tolerance: ±10%, ±20% Voltage: 2.5 - 50 VDC Halogen Free Epoxy 100% Surge Current test on U, V case sizes RoHS Compliant - Lead Free Terminations (See www.kemet.com for transition information) CAPACITOR OUTLINE DRAWING CATHODE (-) END VIEW W H T X S G S A L E F SIDE VIEW ANODE (+) END VIEW BOTTOM VIEW K DIMENSIONS – Millimeters (inches) Case Size KEMET R S T U V EIA 2012-12 3216-12 3528-12 6032-15 7343-20 L* 2.0 ± 0.2 (.079 ± .008) 3.2 ± 0.2 (.126 ± .008) 3.5 ± 0.2 (.138 ± .008) 6.0 ± 0.3 (.236 ± .012) 7.3 ± 0.3 (.287 ± .012) W* 1.3 ± 0.2 (.051 ± .008) 1.6 ± 0.2 (.063 ± .008) 2.8 ± 0.2 (.110 ± .008) 3.2 ± 0.3 (.126 ± .012) 4.3 ± 0.3 (.169 ± .012) H Max. 1.2 (.047) 1.2 (.047) 1.2 (.047) 1.5 (.059) 2.0 (.079) K Min. 0.3 (.012) 0.3 (.012) 0.3 .012) 0.5 (.020) 0.09 (.035) Component F* ±0.1 0.9 (.035) 1.2 (.047) 2.2 (.087) 2.2 (.087) 2.4 (.094) S* ± 0.3 0.5 (.020) 0.8 (.031) 0.8 (.031) 1.3 (.051) 1.3 .051) X (Ref) 0.05 (.002) 0.05 (.002) 0.05 (.002) 0.05 (.002) 0.05 (.002) T (Ref) 0.13 (.005) 0.13 (.005) 0.13 (.005) 0.13 (.005) 0.13 (.005) A (Min) 0.8 (.031) 1.4 (.055) 2.1 (.083) 3.1 (.122) 3.8 (.150) G (Ref) 0.5 (.020) 1.1 (.043) 1.8 (.071) 2.8 (.110) 3.5 (.138) E (Ref) 0.8 (.031) 1.3 (.051) 2.2 (.087) 2.4 (.094) 3.5 (.138) Notes: 1. Metric dimensions govern. 2. (Ref) Dimensions provided for reference only. KEMET ORDERING INFORMATION T Tantalum Series 491 – Industrial Case Size R,S,T,U,V 491 S 685 K 004 A T Lead Material T = 100% Tin (Sn) Plated* H = Standard Solder Coated (SnPb 5% Pb minimum) S = Not Recommended for New Design Failure Rate A = Not Applicable Capacitance Picofarad Code First two digits represent significant figures. Third digit specifies number of zeros. Voltage As Shown Capacitance Tolerance M = ±20% K = ±10% *Refer to www.kemet.com for lead material transition to Pb free. 4 © KEMET Electronics Corporation • P.O. Box 5928 • Greenville, SC 29606 • www.kemet.com T491 SERIES LOW PROFILE SURFACE MOUNT CAPACITORS Industrial Grade PART NUMBER REFERENCE Capacitance μF Case Size KEMET Part Number DC Leakage μA @ 25ºC Max DF % @ +25ºC 120 Hz Max ESR Ω @ +25°C 100 kHz Max 100.0 #6.8 #10.0 #10.0 15.0 #15.0 #22.0 22.0 33.0 #33.0 47.0 #47.0 #68.0 #100.0 †100.0 150.0 #220.0 †330.0 2.2 #4.7 #6.8 #6.8 10.0 #10.0 #10.0 #15.0 #15.0 22.0 #22.0 33.0 #33.0 #47.0 #47.0 #68.0 100.0 #100.0 #150.0 #220.0 3.3 #3.3 #4.7 #4.7 6.8 #6.8 #10.0 #10.0 T *S *S *R T *S *T *S U *T U *T *U *U *T V *V *V R *S *S *R T *S *R *T *S U *T U *T *U *T *U V *U *V *V S *R *S *R T *S *T *S 2.5 Volt Rating at +85ºC (1.7 Volt Rating at +125ºC) T491T107(1)2R5A(2) 2.5 24.0 4 Volt Rating at +85ºC (2.7 Volt Rating at +125ºC) T491S685(1)004A(2) 0.5 6.0 T491S106(1)004A(2) 0.5 6.0 T491R106(1)004A(2) 0.5 8.0 T491T156(1)004A(2) 0.6 6.0 T491S156(1)004A(2) 0.6 10.0 T491T226(1)004A(2) 0.9 6.0 T491S226(1)004A(2) 0.9 10.0 T491U336(1)004A(2) 1.3 6.0 T491T336(1)004A(2) 1.3 8.0 T491U476(1)004A(2) 1.9 6.0 T491T476M004A(2) 1.9 12.0 T491U686(1)004A(2) 2.7 6.0 T491U107(1)004A(2) 4.0 10.0 T491T107M004A(2) 4.0 30.0 T491V157(1)004AS 6.0 8.0 T491V227(1)004A(2) 8.8 8.0 T491V337(1)004A(2) 13.2 12.0 **6 Volt Rating at +85ºC (4 Volt Rating at +125ºC) T491R225(1)006A(2) 0.5 6.0 T491S475(1)006A(2) 0.5 6.0 T491S685(1)006A(2) 0.5 6.0 T491R685(1)006A(2) 0.5 8.0 T491T106(1)006A(2) 0.6 6.0 T491S106(1)006A(2) 0.6 10.0 T491R106(1)006A(2) 0.6 8.0 T491T156(1)006A(2) 0.9 6.0 T491S156(1)006A(2) 0.9 15.0 T491U226(1)006A(2) 1.4 6.0 T491T226(1)006A(2) 1.4 8.0 T491U336(1)006A(2) 2.0 6.0 T491T336(1)006A(2) 2.0 12.0 T491U476(1)006AS 2.9 6.0 T491T476(1)006A(2) 3.0 24.0 T491U686(1)006A(2) 4.1 10.0 T491V107(1)006A(2) 6.0 8.0 T491U107(1)006A(2) 6.0 10.0 T491V157(1)006A(2) 9.0 8.0 T491V227(1)006A(2) 13.2 12.0 10 Volt Rating at +85ºC (7 Volt Rating at +125ºC) T491S335(1)010A(2) 0.5 6.0 T491R335(1)010A(2) 0.3 8.0 T491S475(1)010A(2) 0.5 6.0 T491R475(1)010A(2) 0.5 8.0 T491T685(1)010A(2) 0.7 6.0 T491S685(1)010A(2) 0.7 10.0 T491T106(1)010A(2) 1.0 6.0 T491S106(1)010A(2) 1.0 10.0 3.9 15.0 15.0 10.0 5.0 15.0 5.0 10.0 1.8 5.0 1.8 6.0 1.8 1.8 5.0 0.7 0.7 0.7 25.0 15.0 15.0 15.0 5.0 15.0 10.0 5.0 10.0 1.8 5.0 1.8 6.0 1.8 4.4 1.8 0.7 1.8 0.7 0.7 15.0 15.0 15.0 10.0 5.0 15.0 5.0 15.0 * Extended Values ** 6 Volt product equivalent to 6.3 volt product (1) To complete KEMET part number, insert M for ±20% tolerance or K for ±10% tolerance. (2) To complete KEMET part number, insert lead material designation from page 4. Higher voltage rating, lower ESR and tighter capacitance tolerance product may be substituted within the same size at KEMET’s option. Voltage substitutions will be marked with the higher voltage rating. # Maximum Capacitance Change @ 125°C = +15% † Maximum Capacitance @ 125°C = +20% © KEMET Electronics Corporation • P.O. Box 5928 • Greenville, SC 29606 • www.kemet.com 5 T491 SERIES LOW PROFILE SURFACE MOUNT CAPACITORS Industrial Grade PART NUMBER REFERENCE Capacitance μF Case Size KEMET Part Number DC Leakage μA @ 25ºC Max DF % @ +25ºC 120 Hz Max ESR Ω @ +25°C 100 kHz Max 15.0 #15.0 22.0 #22.0 33.0 #33.0 47.0 #47.0 68.0 #68.0 #100.0 #150.0 #220.0 2.2 #2.2 4.7 10.0 #10.0 15.0 #22.0 #33.0 47.0 68.0 †100.0 1.0 #1.0 1.5 3.3 6.8 10.0 22.0 †33.0 22.0 #10.0 1.0 10 Volt Rating at +85ºC (7 Volt Rating at +125ºC) cont. U T491U156(1)010A(2) 1.5 6.0 *T T491T156(1)010A(2) 1.5 8.0 U T491U226(1)010A(2) 2.2 6.0 *T T491T226(1)010A(2) 2.2 12.0 V T491V336(1)010A(2) 3.3 6.0 *U T491U336(1)010A(2) 3.3 6.0 V T491V476(1)010A(2) 4.7 6.0 *U T491U476(1)010A(2) 4.7 10.0 V T491V686(1)010A(2) 6.8 6.0 *U T491U686(1)010A(2) 6.8 10.0 *V T491V107(1)010A(2) 10.0 8.0 *V T491V157(1)010A(2) 15.0 8.0 *V T491V227(1)010A(2) 22.0 12.0 16 Volt Rating at +85ºC (10 Volt Rating at +125ºC) *S T491S225(1)016A(2) 0.5 6.0 *R T491R225(1)016A(2) 0.5 8.0 T T491T475(1)016A(2) 0.8 6.0 U T491U106(1)016A(2) 1.6 6.0 *T T491T106(1)016A(2) 1.6 8.0 U T491U156(1)016A(2) 2.4 6.0 *U T491U226(1)016A(2) 3.6 10.0 *U T491U336(1)016A(2) 5.3 12.0 V T491V476(1)016A(2) 7.5 6.0 *V T491V686(1)016A(2) 10.9 6.0 *V T491V107(1)016A(2) 16.0 12.0 20 Volt Rating at +85ºC (13 Volt Rating at + 125ºC) S T491S105(1)020A(2) 0.5 6.0 R T491R105(1)020A(2) 0.5 6.0 S T491S155(1)020A(2) 0.5 6.0 *T T491T335(1)020A(2) 0.7 6.0 U T491U685(1)020A(2) 1.4 6.0 U T491U106(1)020A(2) 2.0 6.0 V T491V226(1)020A(2) 4.4 6.0 *V T491V336(1)020A(2) 6.6 8.0 25 Volt Rating at +85ºC (17 Volt Rating at +125ºC) *V T491V226(1)025A(2) 5.5 6.0 35 Volt Rating at +85ºC (23 Volt Rating at +125ºC) *V *V T491V106(1)035A(2) T491V105(1)050A(2) 3.5 0.5 6.0 4.0 50 Volt Rating at +85ºC (33 Volt Rating at + 125ºC) 1.8 5.0 1.8 8.0 0.7 1.8 0.7 2.2 0.7 1.8 0.7 0.7 0.7 15.0 25.0 5.0 1.8 8.0 1.8 3.0 3.0 0.7 0.7 0.7 18.0 20.0 15.0 5.0 1.9 1.8 0.7 0.7 0.7 2.0 6.0 * Extended Values ** 6 Volt product equivalent to 6.3 volt product (1) To complete KEMET part number, insert M for ±20% tolerance or K for ±10% tolerance. (2) To complete KEMET part number, insert lead material designation from page 4. Higher voltage rating, lower ESR and tighter capacitance tolerance product may be substituted within the same size at KEMET’s option. Voltage substitutions will be marked with the higher voltage rating. # Maximum Capacitance Change @ 125°C = +15% † Maximum Capacitance @ 125°C = +20% COMPONENT MARKING Polarity Indicator (+) CONSTRUCTION Rated Voltage 226 20K 532 Picofarad Code Print Week Code 1st Digit = Year 2nd & 3rd Digits = Week “532” = 32nd Week of 2005 6 © KEMET Electronics Corporation • P.O. Box 5928 • Greenville, SC 29606 • www.kemet.com T494 SERIES LOW PROFILE SURFACE MOUNT CAPACITORS Low ESR, Industrial Grade FEATURES Low ESR Values EIA 535BAAC sizes Taped and Reeled per EIA 481-1 Symmetrical, Compliant Terminations Optional Gold-plated Terminations Laser-marked Case Refer to KEMET F3102 for performance characteristics and page 16 of this catalog component packaging Capacitance: 1.0μF to 330μF Tolerance: ±10%, ±20% Voltage: 2.5 - 50 VDC Halogen Free Epoxy 100% Surge Current test on U, V case sizes RoHS Compliant - Lead Free Terminations (See www.kemet.com for transition information) CAPACITOR OUTLINE DRAWING CATHODE (-) END VIEW W H T X S G S A L E F SIDE VIEW ANODE (+) END VIEW BOTTOM VIEW K DIMENSIONS – Millimeters (inches) Case Size KEMET R S T U V EIA 2012-12 3216-12 3528-12 6032-15 7343-20 L* 2.0 ± 0.2 (.079 ± .008) 3.2 ± 0.2 (.126 ± .008) 3.5 ± 0.2 (.138 ± .008) 6.0 ± 0.3 (.236 ± .012) 7.3 ± 0.3 (.287 ± .012) W* 1.3 ± 0.2 (.051 ± .008) 1.6 ± 0.2 (.063 ± .008) 2.8 ± 0.2 (.110 ± .008) 3.2 ± 0.3 (.126 ± .012) 4.3 ± 0.3 (.169 ± .012) H Max. 1.2 (.047) 1.2 (.047) 1.2 (.047) 1.5 (.059) 2.0 (.079) K Min. 0.3 (.012) 0.3 (.012) 0.3 .012) 0.5 (.020) 0.09 (.035) Component F* ±0.1 0.9 (.035) 1.2 (.047) 2.2 (.087) 2.2 (.087) 2.4 (.094) S* ± 0.3 0.5 (.020) 0.8 (.031) 0.8 (.031) 1.3 (.051) 1.3 .051) X (Ref) 0.05 (.002) 0.05 (.002) 0.05 (.002) 0.05 (.002) 0.05 (.002) T (Ref) 0.13 (.005) 0.13 (.005) 0.13 (.005) 0.13 (.005) 0.13 (.005) A (Min) 0.8 (.031) 1.4 (.055) 2.1 (.083) 3.1 (.122) 3.8 (.150) G (Ref) 0.5 (.020) 1.1 (.043) 1.8 (.071) 2.8 (.110) 3.5 (.138) E (Ref) 0.8 (.031) 1.3 (.051) 2.2 (.087) 2.4 (.094) 3.5 (.138) Notes: 1. Metric dimensions govern. 2. (Ref) Dimensions provided for reference only. KEMET ORDERING INFORMATION T Tantalum Series 494 – Low ESR, Industrial Grade Case Size R,S,T,U,V 494 T 336 M 004 A T Lead Material T = 100% Tin (Sn) Plated* H = Standard Solder Coated (SnPb 5% Pb minimum) S = Not Recommended for New Design Failure Rate A = Not Applicable Voltage As Shown Capacitance Tolerance M = ±20% K = ±10% Capacitance Picofarad Code First two digits represent significant figures. Third digit specifies number of zeros. *Refer to www.kemet.com for lead material transition to Pb free. © KEMET Electronics Corporation • P.O. Box 5928 • Greenville, SC 29606 • www.kemet.com 7 T494 SERIES LOW PROFILE SURFACE MOUNT CAPACITORS Low ESR, Industrial Grade PART NUMBER REFERENCE Capacitance μF Case Size KEMET Part Number DC Leakage μA @ 25°C Max DF % @ +25ºC 120 Hz Max ESR Ω @ +25ºC 100 kHz Max 100.0 6.8 #10.0 #10.0 15.0 #15.0 #22.0 #22.0 33.0 #33.0 47.0 #47.0 #68.0 #100.0 †100.0 150.0 #220.0 †330.0 2.2 4.7 #6.8 #6.8 10.0 #10.0 #10.0 #15.0 #15.0 22.0 #22.0 33.0 #33.0 #47.0 47.0 #68.0 100.0 #100.0 #150.0 #220.0 3.3 #3.3 #4.7 #4.7 6.8 #6.8 #10.0 #10.0 2.5 Volt Rating at +85ºC (1.7 Volt Rating at +125ºC) T T494T107(1)2R5A(2) 2.5 24 4 Volt Rating at +85ºC (2.7 Volt Rating at +125ºC) S T494S685(1)004A(2) 0.5 6.0 *S T494S106(1)004A(2) 0.5 6.0 *R T494R106M004A(2) 0.5 8.0 T T494T156(1)004A(2) 0.6 6.0 *S T494S156M004A(2) 0.6 10.0 *S T494S226M004A(2) 0.9 10.0 *T T494T226(1)004A(2) 0.9 6.0 U T494U336(1)004A(2) 1.3 6.0 *T T494T336M004A(2) 1.3 8.0 U T494U476(1)004A(2) 1.9 6.0 T T494T476M004A(2) 1.9 12.0 *U T494U686(1)004A(2) 2.7 6.0 *U T494U107(1)004A(2) 4.0 10.0 *T T494T107M004A(2) 4.0 30.0 V T494V157(1)004A(2) 6.0 8.0 *V T494V227(1)004A(2) 8.8 8.0 *V T494V337(1)004A(2) 13.2 12.0 **6 Volt Rating at +85ºC (4 Volt Rating at +125ºC) R T494R225(1)006A(2) 0.5 6.0 S T494S475(1)006A(2) 0.5 6.0 *S T494S685(1)006A(2) 0.5 6.0 *R T494R685(1)006A(2) 0.5 8.0 T T494T106(1)006A(2) 0.6 6.0 *S T494S106M006A(2) 0.6 10.0 *R T494R106M006A(2) 0.6 8.0 *T T494T156(1)006A(2) 0.9 6.0 S T494S156M006A(2) 0.9 10.0 U T494U226(1)006A(2) 1.4 6.0 *T T494T226M006A(2) 1.4 8.0 U T494U336(1)006A(2) 2.0 6.0 T T494T336M006A(2) 2.0 12.0 *U T494U476(1)006A(2) 2.9 6.0 *T T494T476(1)006A(2) 3.0 24.0 *U T494U686(1)006A(2) 4.1 10.0 V T494V107(1)006A(2) 6.0 8.0 U T494U107M006A(2) 6.0 10.0 *V T494V157(1)006A(2) 9.0 8.0 *V T494V227M006A(2) 13.2 12.0 10 Volt Rating at +85ºC (7 Volt Rating at +125ºC) S T494S335(1)010A(2) 0.5 6.0 *R T494R335(1)010A(2) 0.3 8.0 *S T494S475(1)010A(2) 0.5 6.0 *R T494R475M010A(2) 0.5 8.0 T T494T685(1)010A(2) 0.7 6.0 *S T494S685M010A(2) 0.7 10.0 *T T494T106(1)010A(2) 1.0 6.0 S T494S106M010A(2) 1.0 10.0 3.5 7.0 9.0 6.0 2.0 9.0 8.0 2.5 0.6 3.5 0.6 4.0 0.6 1.0 4.5 0.2 0.3 0.3 20.0 8.0 9.0 10.0 1.2 9.0 6.0 2.5 10.0 0.8 3.5 0.6 4.0 0.6 4.0 1.0 0.2 1.2 0.3 0.3 9.0 10.0 9.0 8.0 2.0 9.0 3.5 12.0 * Extended Values ** 6 Volt product equivalent to 6.3 volt product (1) To complete KEMET part number, insert M for ±20% tolerance or K for ±10% tolerance. (2) To complete KEMET part number, insert lead material designation from page 7. Higher voltage rating, lower ESR and tighter capacitance tolerance product may be substituted within the same size at KEMET’s option. Voltage substitutions will be marked with the higher voltage rating. # Maximum Capacitance Change @ 125°C = +15% † Maximum Capacitance @ 125°C = +20% 8 © KEMET Electronics Corporation • P.O. Box 5928 • Greenville, SC 29606 • www.kemet.com T494 SERIES LOW PROFILE SURFACE MOUNT CAPACITORS Low ESR, Industrial Grade PART NUMBER REFERENCE Capacitance μF Case Size KEMET Part Number DC Leakage μA @ 25°C Max DF % @ +25ºC 120 Hz Max ESR Ω @ +25ºC 100 kHz Max 15.0 #15.0 22.0 22.0 33.0 #33.0 47.0 #47.0 68.0 #68.0 #100.0 #150.0 #220.0 2.2 #2.2 4.7 10.0 #10.0 15.0 #22.0 #33.0 47.0 #68.0 †100.0 1.0 †1.0 1.5 3.3 6.8 10.0 22.0 †33.0 22.0 #10.0 #1.0 10 Volt Rating at +85ºC (7 Volt Rating at +125ºC) cont. U T494U156(1)010A(2) 1.5 6.0 *T T494T156M010A(2) 1.5 8.0 U T494U226(1)010A(2) 2.2 6.0 T T494T226(1)010A(2) 2.2 12.0 V T494V336(1)010A(2) 3.3 6.0 *U T494U336(1)010A(2) 3.3 6.0 V T494V476(1)010A(2) 4.7 6.0 *U T494U476(1)010A(2) 4.7 10.0 V T494V686(1)010A(2) 6.8 6.0 U T494U686M010A(2) 6.8 10.0 *V T494V107(1)010A(2) 10.0 8.0 V T494V157M010A(2) 15.0 8.0 *V T494V227(1)010A(2) 22.0 12.0 16 Volt Rating at +85ºC (10 Volt Rating at + 125ºC) *S T494S225(1)016A(2) 0.5 6.0 *R T494R225M016A(2) 0.5 8.0 T T494T475(1)016A(2) 0.8 6.0 U T494U106(1)016A(2) 1.6 6.0 *T T494T106(1)016A(2) 1.6 8.0 U T494U156(1)016A(2) 2.4 6.0 *U T494U226(1)016A(2) 3.6 10.0 *U T494U336(1)016A(2) 5.3 12.0 V T494V476(1)016A(2) 7.5 6.0 *V T494V686(1)016A(2) 10.9 6.0 *V T494V107(1)016A(2) 16.0 12.0 20 Volt Rating at +85ºC (13 Volt Rating at +125ºC) S T494S105(1)020A(2) 0.5 6.0 R T494R105(1)020A(2) 0.2 6.0 S T494S155(1)020A(2) 0.5 6.0 *T T494T335(1)020A(2) 0.7 6.0 U T494U685(1)020A(2) 1.4 6.0 U T494U106(1)020A(2) 2.0 6.0 V T494V226(1)020A(2) 4.4 6.0 V T494V336(1)020A(2) 6.6 8.0 25 Volt Rating at +85ºC (17 Volt Rating at +125ºC) *V *V *V T494V226(1)025A(2) T494V106(1)035A(2) T494V105M050A(2) 5.5 3.5 0.5 6.0 6.0 4.0 0.8 3.5 0.8 6.0 0.30 0.60 0.30 1.20 0.30 1.20 0.40 0.30 0.50 10.0 20.0 3.0 1.0 6.0 0.8 1.8 2.2 0.3 0.5 0.5 10.0 15.0 9.0 4.0 1.4 0.8 0.4 0.4 0.5 0.8 4.0 35 Volt Rating at +85ºC (23 Volt Rating at +125ºC) 50 Volt Rating at +85ºC (33 Volt Rating at +125ºC) * Extended Values ** 6 Volt product equivalent to 6.3 volt product (1) To complete KEMET part number, insert M for ±20% tolerance or K for ±10% tolerance. (2) To complete KEMET part number, insert lead material designation from page 7. Higher voltage rating, lower ESR and tighter capacitance tolerance product may be substituted within the same size at KEMET’s option. Voltage substitutions will be marked with the higher voltage rating. # Maximum Capacitance Change @ 125°C = +15% † Maximum Capacitance @ 125°C = +20% COMPONENT MARKING Polarity Indicator (+) CONSTRUCTION Rated Voltage 107 10K 527 Picofarad Code Print Week Code 1st Digit = Year 2nd & 3rd Digits = Week “527” = 27nd Week of 2005 © KEMET Electronics Corporation • P.O. Box 5928 • Greenville, SC 29606 • www.kemet.com 9 T495 SERIES LOW PROFILE SURFACE MOUNT CAPACITORS Low ESR, Surge Robust FEATURES Meets or Exceeds EIA Standard 535BAAC Taped and Reeled per EIA 481-1 Symmetrical, Compliant Terminations 100% accelerated steady-state aging 100% Surge Current test Refer to KEMET F3102 for performance characteristics and page 16 of this catalog for component packaging Capacitance: 10.0μF to 220.0μF Tolerance: ±10%, ±20% Voltage: 2.5 - 16 VDC Low Equivalent Series Inductance ( 10 volts RoHS Compliant - Lead Free Terminations (See www.kemet.com for transition information) CAPACITOR OUTLINE DRAWING CATHODE (-) END VIEW W H T X S G S A L E F SIDE VIEW ANODE (+) END VIEW BOTTOM VIEW K DIMENSIONS – Millimeters (inches) Case Size KEMET T W V EIA 3528-12 7343-15 7343-19 L* 3.5 ± 0.2 (.138 ± .008) 7.3 ± 0.3 (.287 ± .012) 7.3 ± 0.3 (.287 ± .012) W* 2.8 ± 0.2 (.110 ± .008) 4.3 ± 0.3 (.169 ± .012) 4.3 ± 0.3 (.169 ± .012) H Max. 1.2 (.047) 1.5 (.059) 1.9 (.079) K Min. 0.3 .012) 0.6 .024) 0.09 (.035) Component F* ±0.1 2.2 (.087) 2.4 (.094) 2.4 (.094) S* ± 0.3 0.8 (.031) 1.3 .051) 1.3 .051) X (Ref) 0.05 (.002) 0.05 (.002) 0.05 (.002) T (Ref) 0.13 (.005) 0.13 (.005) 0.13 (.005) A (Min) 1.1 (.043) 3.8 (.150) 3.8 (.150) G (Ref) 1.8 (.071) 3.5 (.138) 3.5 (.138) E (Ref) 2.2 (.087) 3.5 (.138) 3.5 (.138) Notes: 1. Metric dimensions govern. 2. (Ref) Dimensions provided for reference only. T Tantalum 520 KEMET ORDERING INFORMATION V 227 M 004 A T E009 ESR 009 = 9 mOhms Lead Material T = 100% Tin (Sn) Plated* H = Standard Solder Coated (SnPb – 5% Pb minimum) S = Not Recommended for New Design Failure Rate A = Not Applicable Voltage As Shown Series 520 – Low ESR Polymer Case Size T, W, V Capacitance Picofarad Code First two digits represent significant figures. Third digit specifies number of zeros. Capacitance Tolerance M = ±20%; K = ±10% *Refer to www.kemet.com for lead material transition to Pb free. 12 © KEMET Electronics Corporation • P.O. Box 5928 • Greenville, SC 29606 • www.kemet.com T520 SERIES LOW PROFILE SURFACE MOUNT CAPACITORS Low ESR, Organic Polymer PART NUMBER REFERENCE Capacitance μF Case Size DC Leakage μA @ 25°C Max DF% @ 25°C 120 Hz Max ESR mΩ @ 25°C 100 kHz Max Ripple Current A rms @ 25°C, 100 kHz Max w/ΔT=20°C @ -55°C to 85°C w/ΔT=2°C @ 105°C KEMET Part Number 2 Volt Rating @ 105°C T520V477M002A(1)E040 94.0 10.0 40.0 1.8 0.6 2.5 Volt Rating @ 105°C 220.0 V T520V227M2R5A(1)E007 55.0 10.0 7.0 4.2 1.3 220.0 V T520V227M2R5A(1)E009 55.0 10.0 9.0 3.7 1.2 220.0 V T520V227M2R5A(1)E012 55.0 10.0 12.0 3.2 1.0 220.0 V T520V227M2R5A(1)E015 55.0 10.0 15.0 2.9 0.9 220.0 V T520V227M2R5A(1)E025 55.0 10.0 25.0 2.2 0.7 220.0 V T520V227M2R5A(1)E045 55.0 10.0 45.0 1.7 0.5 330.0 V T520V337M2R5A(1)E007 83.0 10.0 7.0 4.2 1.3 330.0 V T520V337M2R5A(1)E009 83.0 10.0 9.0 3.7 1.2 330.0 V T520V337M2R5A(1)E015 83.0 10.0 15.0 2.9 0.9 330.0 V T520V337M2R5A(1)E025 83.0 10.0 25.0 2.2 0.7 330.0 V T520V337M2R5A(1)E040 83.0 10.0 40.0 1.8 0.6 470.0 V T520V477M2R5A(1)E007 118.0 10.0 7.0 4.2 1.3 470.0 V T520V477M2R5A(1)E009 118.0 10.0 9.0 3.7 1.2 470.0 V T520V477M2R5A(1)E012 118.0 10.0 12.0 3.2 1.0 470.0 V T520V477M2R5A(1)E015 118.0 10.0 15.0 2.9 0.9 3 Volt Rating at 105°C 330.0 V T520V337M003A(1)E009 99.0 10.0 9.0 3.7 1.2 330.0 V T520V337M003A(1)E012 99.0 10.0 12.0 3.2 1.0 330.0 V T520V337M003A(1)E015 99.0 10.0 15.0 2.9 0.9 330.0 V T520V337M003A(1)E025 99.0 10.0 25.0 2.2 0.7 4 Volt Rating @ 105°C 15.0 T T520T156M004A(1)E100 6.0 8.0 100.0 0.8 0.3 47.0 T T520T476M004A(1)E070 19.0 8.0 70.0 1.0 0.3 68.0 T T520T686M004A(1)E070 27.0 8.0 70.0 1.0 0.3 150.0 v T520V157M004A(1)E007 60.0 10.0 7.0 4.2 1.3 150.0 V T520V157M004A(1)E009 60.0 10.0 9.0 3.7 1.2 150.0 V T520V157M004A(1)E012 60.0 10.0 12.0 3.2 1.0 150.0 V T520V157M004A(1)E015 60.0 10.0 15.0 2.9 0.9 150.0 V T520V157M004A(1)E025 60.0 10.0 25.0 2.2 0.7 220.0 V T520V227M004A(1)E007 88.0 10.0 7.0 4.2 1.3 220.0 V T520V227M004A(1)E009 88.0 10.0 9.0 3.7 1.2 220.0 V T520V227M004A(1)E012 88.0 10.0 12.0 3.2 1.0 220.0 V T520V227M004A(1)E015 88.0 10.0 15.0 2.9 0.9 220.0 V T520V227M004A(1)E025 88.0 10.0 25.0 2.2 0.7 220.0 V T520V227M004A(1)E040 88.0 10.0 40.0 1.8 0.6 220.0 V T520V227M004A(1)E045 88.0 10.0 45.0 1.7 0.5 330.0 V T520V337M004A(1)E007 132.0 10.0 7.0 4.2 1.3 330.0 V T520V337M004A(1)E009 132.0 10.0 9.0 3.7 1.2 330.0 V T520V337M004A(1)E012 132.0 10.0 12.0 3.2 1.0 330.0 V T520V337M004A(1)E025 132.0 10.0 25.0 2.2 0.7 330.0 V T520V337M004A(1)E040 132.0 10.0 40.0 1.8 0.6 6/6.3 Volt Rating @ 105°C 15.0 T T520T156M006A(1)E100 9.5 8.0 100.0 0.8 0.3 33.0 T T520T336M006A(1)E070 21.0 8.0 70.0 0.9 0.4 47.0 T T520T476M006A(1)E070 30.0 8.0 70.0 1.0 0.3 100.0 W T520W107M006A(1)E040 63.0 10.0 40.0 1.7 0.5 100.0 V T520V107M006A(1)E007 63.0 10.0 7.0 4.2 1.3 100.0 V T520V107M006A(1)E009 63.0 10.0 9.0 3.7 1.2 100.0 V T520V107M006A(1)E012 63.0 10.0 12.0 3.2 1.0 (1) To complete KEMET part number, insert lead material designation from page 12. Higher voltage rating, lower ESR and tighter capacitance tolerance product may be substituted within the same size at KEMET’s option. Voltage substitutions will be marked with the higher voltage rating. 470.0 V © KEMET Electronics Corporation • P.O. Box 5928 • Greenville, SC 29606 • www.kemet.com 13 T520 SERIES LOW PROFILE SURFACE MOUNT CAPACITORS Low ESR, Organic Polymer PART NUMBER REFERENCE Capacitance μF Case Size KEMET Part Number DC Leakage μA @ 25°C Max DF% @ 25°C 120 Hz Max ESR mΩ @ 25°C 100 kHz Max Ripple Current A rms @ 25°C, 100 kHz Max w/ΔT=20°C @ -55°C to 85°C w/ΔT=2°C @ 105°C 6/6.3 Volt Rating @ 105°C cont. 150.0 150.0 150.0 150.0 150.0 150.0 220.0 220.0 220.0 220.0 220.0 220.0 330.0 330.0 68.0 68.0 68.0 68.0 100.0 100.0 100.0 100.0 33.0 33.0 33.0 47.0 47.0 22.0 22.0 15.0 V V V V V V V V V V V V V V V V V W V V V V W V V W V V V V T520V157M006A(1)E009 T520V157M006A(1)E012 T520V157M006A(1)E015 T520V157M006A(1)E025 T520V157M006A(1)E040 T520V157M006A(1)E045 95.0 95.0 95.0 95.0 95.0 95.0 10.0 10.0 10.0 10.0 10.0 10.0 9.0 12.0 15.0 25.0 40.0 45.0 7.0 9.0 12.0 15.0 25.0 40.0 25.0 40.0 25.0 45.0 60.0 40.0 18.0 25.0 45.0 50.0 60.0 45.0 60.0 45.0 45.0 40.0 90.0 90.0 3.7 3.2 2.9 2.2 1.8 1.7 4.2 3.7 3.2 2.9 2.2 1.8 2.2 1.8 2.2 1.7 1.4 1.7 2.6 2.2 1.7 1.6 1.6 1.7 1.4 1.6 1.7 1.8 1.2 1.2 1.2 1.0 0.9 0.7 0.6 0.5 1.3 1.2 1.0 0.9 0.7 0.6 0.7 0.6 0.7 0.5 0.5 0.5 0.8 0.7 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.6 0.4 0.4 T520V227M006A(1)E007 139.0 10.0 T520V227M006A(1)E009 139.0 10.0 T520V227M006A(1)E012 139.0 10.0 T520V227M006A(1)E015 139.0 10.0 T520V227M006A(1)E025 139.0 10.0 T520V227M006A(1)E040 139.0 10.0 T520V337M006A(1)E025 208.0 10.0 T520V337M006A(1)E040 208.0 10.0 10 Volt Rating @ 105°C T520V686M010A(1)E025 68.0 10.0 T520V686M010A(1)E045 68.0 10.0 T520V686M010A(1)E060 68.0 10.0 T520W686M010A(1)E040 68.0 10.0 T520V107M010A(1)E018 100.0 10.0 T520V107M010A(1)E025 100.0 10.0 T520V107M010A(1)E045 100.0 10.0 T520V107M010A(1)E050 100.0 10.0 16 Volt Rating @ 105°C T520W336M016A(1)E060 53.0 10.0 T520V336M016A(1)E045 53.0 10.0 T520V336M016A(1)E060 53.0 10.0 T520W476M016A(1)E045 75.0 10.0 T520V476M016A(1)E045 75.0 10.0 20 Volt Rating @ 105°C T520V226M020A(1)E040 44.0 10.0 T520V226M016A(1)E090 44.0 10.0 25 Volt Rating @ 105°C T520V156M016A(1)E090 38.0 10.0 (1) To complete KEMET part number, insert lead material designation from page 12. Higher voltage rating, lower ESR and tighter capacitance tolerance product may be substituted within the same size at KEMET’s option. Voltage substitutions will be marked with the higher voltage rating. COMPONENT MARKING CONSTRUCTION KO Rated Voltage Polarity Indicator (+) Picofarad Code Print Week Code 1st Digit = Year 2nd & 3rd Digits = Week “527” = 27nd Week of 2005 157 4K 527 14 © KEMET Electronics Corporation • P.O. Box 5928 • Greenville, SC 29606 • www.kemet.com T525 SERIES LOW PROFILE SURFACE MOUNT CAPACITORS High Temperature FEATURES Polymer Cathode Technology 125°C Maximum Temperature Capability High Frequency Cap Retention No-ignition Failure Mode 100% Surge Current test 100% Accelerated Steady State Aging Operating Temperature -55°C to +125°C Refer to KEMET F3102 for performance characteristics and page 16 of this catalog for component packaging Capacitance: 47.0μF to 100.0μF Tolerance: ±20% Voltage: 2.5 - 6 VDC Use up to 90% of rated voltage (10% derating) for part types ≤ 10 volts Use up to 80% of rated voltage (20% derating) for part types > 10 volts Self-Healing Mechanism Extremely Stable ESR at 125°C RoHS Compliant - Lead Free Terminations (See www.kemet.com for transition information) CAPACITOR OUTLINE DRAWING CATHODE (-) END VIEW W H T X S G S A L E F SIDE VIEW ANODE (+) END VIEW BOTTOM VIEW K DIMENSIONS – Millimeters (inches) Case Size KEMET T EIA 3528-12 L* 3.5 ± 0.2 (.138 ± .008) W* 2.8 ± 0.2 (.110 ± .008) H Max. 1.2 (.047) K Min. 0.3 .012) Component F* ±0.1 2.2 (.087) S* ± 0.3 0.8 (.031) X (Ref) 0.05 (.002) T (Ref) 0.13 (.005) A (Min) 2.1 (.083) G (Ref) 1.8 (.071) E (Ref) 2.2 (.087) Notes: 1. Metric dimensions govern. 2. (Ref) Dimensions provided for reference only. T 525 KEMET ORDERING INFORMATION T 107 M 2R5 A T E080 ESR 080 = 80 mOhms Lead Material T = 100% Tin (Sn) Plated* H = Standard Solder Coated (SnPb – 5% Pb minimum) Failure Rate A = Not Applicable Voltage As Shown Tantalum Series 525 – High Temperature Case Size T Capacitance Picofarad Code First two digits represent significant figures. Third digit specifies number of zeros. Capacitance Tolerance M = ±20% *Refer to www.kemet.com for lead material transition to Pb free. PART NUMBER REFERENCE Capacitance μF Case Size KEMET Part Number DC Leakage μA @ 25°C Max DF% @ 25°C 120 Hz Max ESR mΩ @ 25°C 100 kHz Max Ripple Current A rms @ 25°C, 100 kHz Max w/ΔT=20°C @ -55°C to 105°C w/ΔT=2°C @ 125°C 2.5 Volt Rating @ +105°C (1.7 Volt Rating at 125°C) 100.0 68.0 47.0 T T T T525T107M2R5A(1)E080 T525T686M004A(1)E080 T525T476M006A(1)E080 25.0 27.0 30.0 8.0 8.0 8.0 80.0 80.0 80.0 0.9 0.9 0.9 0.3 0.3 0.3 4 Volt Rating @ 105°C (2.7 Volt Rating at 125°C) 6.3 Volt Rating @ 105°C (4.2 Volt Rating at 125°C) (1) To complete KEMET part number, insert lead material designation as shown above. Higher voltage ratings and tighter tolerance product may be substituted within the same size at KEMET’s option. Voltage substitutions will be marked with the higher voltage rating. © KEMET Electronics Corporation • P.O. Box 5928 • Greenville, SC 29606 • www.kemet.com 15 PACKAGING INFORMATION Tape & Reel Packaging KEMET’s Molded Tantalum Chip Capacitor families are packaged in 8 mm and 12 mm plastic tape on 7" and 13" reels, in accordance with EIA Standard 481-1: Taping of Surface Mount Components for Automatic Handling. This packaging system is compatible with all tape fed automatic pick and place systems. Right Hand Orientation Only Embossed Carrier (+) (–) Embossment Top Tape Thickness .10mm (.004") Max Thickness 8mm ±.30 8mm (0.315") (.315 ±.012") or or 12mm (0.472") 12mm ±.30 (.472 ±.012") 178mm (7.00") 180mm (7.0") oror 330mm (13.00") 330mm (13.0") Labeling: Bar code labeling (standard or custom) shall be on the side of the reel opposite the sprocket holes. Refer to EIA-556. QUANTITIES PACKAGED PER REEL Case Code KEMET R S T U W V EIA 2012-12 3216-12 3528-12 6032-15 7343-15 7343-20 Tape Width - mm 8 8 8 12 12 12 7” Reel 2,500 2,500 2,500 1,000 1,000 1,000 13” Reel 10,000 10,000 10,000 5,000 3,000 3,000 16 © KEMET Electronics Corporation • P.O. Box 5928 • Greenville, SC 29606 • www.kemet.com PACKAGING INFORMATION Performance Notes 1. Cover Tape Break Force: 1.0 Kg Minimum. 2. Cover Tape Peel Strength: The total peel strength of the cover tape from the carrier tape shall be: Tape Width Peel Strength 8 mm 0.1 Newton to 1.0 Newton (10g to 100g) 12 mm 0.1 Newton to 1.3 Newton (10g to 130g) The direction of the pull shall be opposite the direction of the carrier tape travel. The pull angle of the carrier tape shall be 165 to 180 from the plane of the carrier tape. During peeling, the carrier and/or cover tape shall be pulled at a velocity of 300 ±10 mm/minute. 3. Reel Sizes: Molded tantalum capacitors are available on either 180 mm (7") reels (standard) or 330 mm (13") reels (with C-7280). Note that 13” reels are preferred. 4. Labeling: Bar code labeling (standard or custom) shall be on the side of the reel opposite the sprocket holes. Refer to EIA-556. Embossed Carrier Tape Configuration: Figure 1 Table 1 — EMBOSSED TAPE DIMENSIONS (Metric will govern) Constant Dimensions — Millimeters (Inches) Tape Size 8 mm and 12 mm D0 E P0 4.0 ±0.10 (0.157 ±0.004) P2 2.0 ±0.05 (0.079 ±0.002) T Max 0.600 (0.024) T1 Max 0.100 (0.004) 1.5 1.75 ±0.10 +0.10 -0.0 (0.059 (0.069 ±0.004) +0.004, -0.0) Pitch Single (4 mm) B1 Max. Note 1 4.4 (0.173) 12 mm Double (8 mm) 8.2 (0.323) D1 Min. Note 2 1.0 Variable Dimensions — Millimeters (Inches) Tape Size 8 mm F 3.5 ±0.05 P1 4.0 ±0.10 R Min. Note 3 25.0 T2 Max 2.5 (0.098) W 8.0 ±0.30 (.315 ±0.012) A0B0K0 Note 4 (0.039) (0.138 ±0.002) 1.5 5.5 ±0.05 (0.059) (0.217 ±0.002) (0.157 ±0.004) (0.984) 8.0 ±0.10 30.0 (0.315 ±0.004) (1.181) 4.6 12.0 ±0.30 (0.181) (0.472 ±0.012) NOTES 1. B1 dimension is a reference dimension for tape feeder clearance only. 2. The embossment hole location shall be measured from the sprocket hole controlling the location of the embossment. Dimensions of embossment location and hole location shall be applied independent of each other. 3. Tape with components shall pass around radius “R” without damage (see sketch A). The minimum trailer length (Fig. 2) may require additional length to provide R min. for 12 mm embossed tape for reels with hub diameters approaching N min. (Table 2) 4. The cavity defined by A0, B0, and K0 shall be configured to surround the part with sufficient clearance such that the chip does not protrude beyond the sealing plane of the cover tape, the chip can be removed from the cavity in a vertical direction without mechanical restriction, rotation of the chip is limited to 20 degrees maximum in all 3 planes, and lateral movement of the chip is restricted to 0.5 mm maximum in the pocket (not applicable to vertical clearance.) © KEMET Electronics Corporation • P.O. Box 5928 • Greenville, SC 29606 • www.kemet.com 17 PACKAGING INFORMATION Embossed Carrier Tape Configuration (cont.) Sketch D: Tape Camber (Top View) 1mm (0.039) Max. 1mm (0.039) Max. 250mm (9.843) Allowable camber to be 1 mm/250 mm. 400mm (15.75) Min. Figure 2: Tape Leader & Trailer Dimensions (Metric Dimensions Will Govern) Figure 3: Reel Dimensions (Metric Dimensions will govern) Table 2 – REEL DIMENSIONS (Metric will govern) Tape Size 8 mm A Max 330.0 (12.992) B* Min 1.5 (0.059) C 13.0 ± 0.20 (0.512 ± 0.008) D* Min 20.2 (0.795) N Min 50.0 (1.969) See Note 3 Table 1 W1 8.4 +1.5, -0.0 (0.331 +0.059, -0.0) 12.4 +2.0, -0.0 (0.488 +0.078, -0.0) W2 Max 14.4 (0.567) W3 7.9 Min (0.311) 10.9 Max (0.429) 11.9 Min (0.469) 15.4 Max (0.606) 12 mm 330.0 (12.992) 1.5 (0.059) 13.0 ± 0.20 (0.512 ± 0.008) 20.2 (0.795) 18.4 (0.724) 18 © KEMET Electronics Corporation • P.O. Box 5928 • Greenville, SC 29606 • www.kemet.com World Sales Headquarters P.O. Box 5928 • Greenville, SC 29606 • www.kemet.com Phone: (864) 963-6300 • Fax: (864) 963-6521 USA/Canada Locations KEMET Electronics Corporation 2350 Mission College Blvd., Suite 972 Santa Clara, CA 95054 Phone: 408-986-0424 Fax: 408-986-1442 KEMET Electronics Corporation Schaumburg Corporate Center Suite 350, 1515 Woodfield Road Schaumburg, IL 60173 Phone: 847-517-1030 Fax: 847-517-1037 KEMET Electronics Corporation 66 Concord St., Suite Z Wilmington, MA 01887 Phone: 978-658-1663 Fax: 978-658-1790 KEMET Electronics Corporation 8445 Freeport Parkway, Suite 320 Irving, TX 75063 Phone: 972-870-9530 Fax: 972-870-9537 KEMET Electronics Canada Ltd. 10 Kensington Road, Suite 1107 Brampton, L6T 3V4 Ontario Canada Phone: 905-595-0893 Fax: 905-595-0894 KEMET Electronics Canada Ltd. 6001 35th Avenue LavaL West, Quebec, Canada H7R 3P7 Phone: 450-962-0806 Fax: 450-962-6462 Europe/Africa Locations KEMET Electronics S.A. 1-3, Avenue de la Paix P.O.B. 76 CH-1211 Geneva 20, Switzerland Phone: 41-22-715-0100 Fax: 41-22-715-0170 KEMET Electronics Ltd. Waterfront House, 55/61 South St. Bishop’s Stortford Hertfordshire, CM23 3AL United Kingdom Phone: 44-1279-757201 Fax: 44-1279-757188 KEMETElectronics GmbH Elisabethstrasse 89-91 D-80797 Munich, Germany Phone: 49-89-456-4200 Fax: 49-56-5908-1303 KEMET Electronics S.A.R.L. ZAC Paris Rive Gauche 118-122, avenue de France 75013 Paris, France Phone: 01-33-01-4646-1009 Fax: 01-33-01-4646-1599 Asia Locations KEMET Electronics (Shanghai) Co., Ltd. 2/F, No. 7 Bldg., 330 Xiya Rd. Waigaoqiao Free Trade Zone Pudong, Shanghai 200131, China Phone: 86-21-5046-0983 Fax: 86-21-5046-0981 KEMET Electronics Asia Ltd. Rm 605, Citic Bldg. No. 19 Jian Guo Men Wai Da Jie Beijing, 100004, China Phone: 8610-8526-3628 Fax: 8610-8526-3626 KEMET Electronics Marketing PTE Ltd. 8-2-04, Sunny Point Kompleks Jalan Batu Uban, 11700 Penang Penang, Malaysia Phone: 60-4-6595200 Fax: 60-4-6595220 KEMET Electronics Marketing PTE Ltd. 101 Thomson Road, #23-03 United Square Singapore, 307591, Singapore Phone: 65-6353-6636 Fax: 65-6353-6656 KEMET Electronics Asia Ltd. Rm. 825 & 826, 8/F, Renminan Road Kerry Center Shenzhen 518001 China Phone: 867-55-25181306 Fax: 867-55-25181307 NOTICE: Place 011 in front of the above Phone and Fax numbers for Europe and Asia, when dialing from a United States exchange. Note: KEMET reserves the right to modify minor details of internal and external construction at any time in the interest of product improvement. KEMET does not assume any responsibility for infringement that might result from the use of KEMET Capacitors in potential circuit designs. © “KEMET” is a registered trademark of KEMET Electronics Corporation. © KEMET Electronics Corporation KEMET Electronics Asia Ltd. 30 Canton Rd., Room 1512 Silvercord Tower II Tsimshatshui, Kowloon Bay, Hong Kong Phone: 852-2305-1168 Fax: 852-2759-0345 KEMET Electronics Corporation Taiwan Branch, 3-4F, No. 148, Section 4 Chung-Hsaio E. Rd. Taipei, Taiwan ROC Phone: 886-2-27528585 Fax: 886-2-27213129 7/05
很抱歉,暂时无法提供与“T491”相匹配的价格&库存,您可以联系我们找货
FMMT491
  • 20+0.12284
  • 200+0.11454
  • 500+0.10624
  • 1000+0.09794
  • 3000+0.09379
  • 6000+0.08798
库存:1038
FMMT491
  • 1+0.15001
  • 100+0.14001
  • 300+0.13001
  • 500+0.12001
  • 2000+0.11501
  • 5000+0.11201
库存:1910
FMMT491
  • 50+0.1406
  • 500+0.12635
  • 5000+0.11685
  • 10000+0.1121
  • 30000+0.10735
  • 50000+0.1045
库存:2950
FMMT491TA
  • 10+0.37
  • 50+0.34
  • 200+0.315
  • 600+0.29
  • 1500+0.27
  • 3000+0.2575
库存:10
FMMT491QTA
  • 1+0.72541
  • 10+0.66961
  • 30+0.65845
  • 100+0.62497
库存:500
FMMT491ATA
  • 1+0.54131
  • 10+0.48901
  • 30+0.45414
  • 100+0.40184
  • 500+0.37743
  • 1000+0.36
库存:1678
FMMT491 100-300
  • 1+0.16094
  • 100+0.14952
  • 300+0.13811
  • 500+0.1267
  • 2000+0.12099
  • 5000+0.11757
库存:11412
T491A475K010AT
  • 5+0.832
  • 20+0.754
  • 100+0.676
  • 500+0.598
  • 1000+0.5616
  • 2000+0.5356
库存:2724
T491B225K035AT
  • 5+1.2096
  • 20+1.1016
  • 100+0.9936
  • 500+0.8856
  • 1000+0.8352
  • 2000+0.7992
库存:11
T491D226K025AT
  • 1+2.45
  • 10+2.3625
  • 100+2.1
  • 500+2.0475
库存:24
