T510
T510
    KEMET(基美)
    T510 - SOLID TANTALUM CHIP CAPACITORS - Kemet Corporation
T510 数据手册
SOLID TANTALUM CHIP CAPACITORS T510 SERIES—High Capacitance-Low ESR • • • • • Ultra Low ESR < 30 mΩ New E/7260 Case with ESR < 18 mΩ Up to 5 Amps ripple current RoHS Compliant & Leadfree Termination (see www. kemet.com for lead transitions) Operating Temperature: -55˚C to +125˚C CATHODE (-) END VIEW W SIDE VIEW FEATURES 100% accelerated steady-state aging 100% Surge current test • Precision - molded, laser-marked case • Symmetrical compliant terminations • Taped and reeled per EIA 481-1 • • OUTLINE DRAWING B B H K X S T G S R P Termination cutout at KEMET’s Option, either end ANODE (+) END VIEW BOTTOM VIEW E A L F DIMENSIONS - Millimeters (Inches) CASE SIZE KEMET X E EIA 7343-43 7260-38 COMPONENT L W H ± 0.20 K ± (.008) 2.3 (.091) 2.3 (.091) ± 0.1 F ± (.004) 2.4 (.094) 4.1 (.161 S ± (.012) 1.3 (.051) 1.3 (.051) ± 0.3 B ± 0.15 (Ref) ± (.006) 0.5 (.020) 0.5 (.020) X (Ref) P (Ref) R (Ref) T (Ref) A (Min) G (Ref) E (Ref) 4.0 ± 0.3 7.3 ± 0.3 4.3 ± 0.3 (.287 ± .012) (.169 ± .012) (.157 ± .012) 7.3 ± 0.3 3.6 ± 0.2 6.0 ± 0.3 (.287 ± .012) (.236 ± .012) (.142 ± .008) 0.10 ± 0.10 0.9 1.0 0.13 3.8 3.5 3.5 (.004 ± .004) (.035) (.039) (.005) (.150) (.138) (.138) 0.13 3.8 3.5 0.10 ± 0.10 0.9 1.0 3.5 (.004 ± .004) (.035) (.039) (.005) (.150) (.138) (.138) Notes: Metric Dimensions govern (Ref) - Dimensions provided for reference only. T510 RATINGS & PART NUMBER REFERENCE Cap Cap µF µF Case Case Size Size KEMET KEMET Part Number Part Number DF % DC Leakage ESR DC ESR DC Capaci- Case % KEMET Ripple Current @ 25°C Ripple Current DF % DF @ 25°C µA @ 25°C Leakage mΩ Number Leakage Size mΩ tance µF Part 100 kHz Arms @ +25°C, Arms @ +25°C, @ +25°C Max Max Cap Case @ +25°C Max µA @ @ +25°C µA @ @ +25°C 100 kHz, max 100 kHz, max 120Hz µF Size 120Hz +25°C 100 kHz 4 Volt Rating at +85°C (2.7 Volt Rating at 125°C) +25°C 100 kHz Max Max Max Max 680.0 X T510X687(1)004A(2)E03085°C 125°C 27.2 6.0 30.0 Max Max 25°C 85°C 125°C 25°C 1000.0 X T510X108(1)004A(2)E018 40.0 6.0 18.0 ESR m Ripple Current A rms @ 25°C 100 kHz, max KEMET 25°C 85°C Part Number 3.0 3.9 2.7 3.5 ESR DC Ripple Current DF % Leakage mΩ Arms @ +25°C, @ +25°C µA @ @ +25°C 125°C 100 kHz, max 120Hz +25°C 100 kHz Max 1.2 Max Max 25°C 85°C 125°C 1.5 680.0 680.0 1000.0 1000.0 1000.0 1000.0 1000.0 1000.0 1000.0 1000.0 470.0 470.0 680.0 680.0 680.0 680.0 680.0 680.0 330.0 330.0 150.0 150.0 150.0 150.0 220.0 220.0 220.0 220.0 X X X X X X E E E E X X X X E E E E X X X X X X X X X X 4 Volt Rating at +85°C (2.7 Volt Rating at 125°C) 20 +85°C (13.4 Volt Rating at 125°C) 4 Volt Rating at +85°C (2.7 Volt RatingT510E108(1)004A(2)E018 at 125°C) 1000.0 E 40.0 6.0 18.0 4.0 Volt Rating at 1.6 3.6 1000.0 E 40.0 6.0 10.0 T510X107(1)020A(2)E035 5.3 4.8 2.1 T510X687(1)004A(2)E030 27.2 6.0 T510E108(1)004A(2)E010 2.7 30 3.0 1.2 100.0 X 20.0 8.0 35.0 T510X687(1)004A(2)E030 27.2 6.0 30 3.0 2.7 1.2 6/6.3 Volt Rating at 1.5 (4 Volt 100.0 at 125°C) T510X107(1)020A(2)E040 +85°C Rating T510X108(1)004A(2)E018 40.0 6.0 18 3.9 X 20.0 6.0 40.0 T510X108(1)004A(2)E018 40.0 6.0 18 3.9 3.5 3.5 1.5 470.0 X 28.2 6.0 30.0 3.0 2.7 1.2 T510X108(1)004A(2)E023 40.0 6.0 T510X477(1)006A(2)E030 3.0 23 3.4 1.3 100.0 X T510X107(1)020A(2)E045 20.0 6.0 45.0 T510X108(1)004A(2)E023 40.0 6.0 T510E687(1)006A(2)E023 3.0 23 3.4 1.3 680.0 E 40.8 6.0 23.0 3.5 3.2 1.4 T510E108(1)004A(2)E018 40.0 6.0 T510E687(1)006A(2)E012 3.6 18 4.0 1.6 25 T510E108(1)004A(2)E018 40.0 6.0 18 4.0 3.6 1.6 680.0 E 40.8 6.0 12.0 4.8 Volt Rating at +85°C (17 Volt Rating at 125°C) 4.3 1.9 T510E108(1)004A(2)E010 40.0 6.0 10 5.3 2.1 10 Volt Rating at +85°C (7 Volt Rating at 125°C) T510E107(1)025A(2)E050 T510E108(1)004A(2)E010 40.0 6.0 10 5.3 4.8 4.8 2.1 100.0 E 25.0 8.0 50 X 33.0 6.0 35.0 2.8 2.5 1.1 6/6.3 Volt Rating at +85°C330.0VoltRatingT510X337(1)010A(2)E035 6/6.3 Volt Rating at +85°C(4 Volt Ratingat 125°C) (4 at 125°C) 35 Volt Rating at +85°C (23 Volt Rating at 125°C) 16 Volt Rating at +85°C (11 Volt Rating at 125°C) T510X477(1)006A(2)E030 28.2 6.0 30 3.0 1.2 T510X477(1)006A(2)E030 28.2 6.0 T510X157(1)016A(2)E040 2.7 30 3.0 2.7 1.2 22.0 X 7.7 6.0 100 150.0 X 24.0 6.0 40.0 T510X226(1)035A(2)E100 2.6 2.3 1.0 T510X687(1)006A(2)E023 42.8 6.0 T510X227(1)016A(2)E040 3.1 23 3.4 1.4 T510X687(1)006A(2)E023 42.8 6.0 23 3.4 3.1 1.4 220.0 X 35.2 10.0 40.0 T510X226(1)035A(2)E080 2.6 2.3 1.0 22.0 X 7.7 6.0 80 T510E687(1)006A(2)E023 40.8 6.0 T510X227(1)016A(2)E025 3.2 23 3.5 1.4 220.0 X 35.2 10.0 25.0 3.3 3.0 1.3 T510E687(1)006A(2)E023 40.8 6.0 23 3.5 3.2 1.4 22.0 X T510X226(1)035A(2)E060 7.7 6.0 60 20 4.8 Rating at +85°C (13.4 Volt Rating at 125°C) Volt T510E687(1)006A(2)E012 40.8 6.0 12 4.8 4.3 1.9 T510E687(1)006A(2)E012 40.8 6.0 12 4.3 1.9 33.0 X T510X336(1)035A(2)E065 11.6 6.0 65 100.0 X T510X107(1)020A(2)E040 20.0 6.0 40.0 2.6 2.3 1.0 10 Volt Rating at +85°C (7 Volt Rating at 125°C) 10 Volt Rating at +85°C (7 Volt Rating at 125°C) 25 Volt Rating at +85°C (17 Volt Rating at 125°C) T510X336(1)035A(2)E050 33.0 X 11.6 6.0 50 T510X337(1)010A(2)E035 33.0 6.0 T510E107(1)025A(2)E050 2.5 35 2.8 1.1 T510X337(1)010A(2)E035 33.0 6.0 35 2.8 2.5 1.1 100.0 E 25.0 8.0 50.0 T510X476(1)035A(2)E055 2.4 2.1 1.0 47.0 X 16.5 8.0 55 16 Volt Rating at +85°C (11 Volt Rating at 125°C) 35 Volt Rating at +85°C (23 Volt Rating at 125°C) T510X476(1)035A(2)E065 16 Volt Rating at +85°C (11 Volt Rating at 125°C) 47.0 X 16.5 8.0 65 22.0 X T510X226(1)035A(2)E080 2.7 7.7 6.0 80.0 1.8 1.7 0.7 T510X157(1)016A(2)E030 24.0 6.0 30 3.0 1.2 T510X157(1)016A(2)E030 24.0 6.0 30 3.0 2.7 1.2 47.0 E T510E476(1)035A(2)E050 16.5 8.0 50 33.0 X T510X336(1)035A(2)E065 11.6 6.0 65.0 2.0 1.8 0.8 T510X157(1)016A(2)E040 24.0 6.0 T510X336(1)035A(2)E050 2.3 40 2.6 1.0 T510X157(1)016A(2)E040 24.0 6.0 40 2.6 2.3 1.0 50 33.0 X 11.6 6.0 50.0 2.3 Volt Rating at +85°C (33 Volt Rating at 125°C) 2.1 0.9 T510X227(1)016A(2)E040 35.2 10.0 T510X476(1)035A(2)E055 2.3 40 2.6 1.0 47.0 X 16.5 8.0 55.0 T510X106(1)050A(2)E120 2.2 2.0 0.9 T510X227(1)016A(2)E040 35.2 10.0 40 2.6 2.3 1.0 10.0 X 5.0 8.0 120 47.0 E 16.5 8.0 50.0 2.4 2.1 1.0 T510X227(1)016A(2)E025 35.2 10.0 T510E476(1)035A(2)E050 3.0 25 3.3 1.3 T510X227(1)016A(2)E025 35.2 10.0 25 3.3 3.0 1.3 10.0 X T510X106(1)050A(2)E090 5.0 8.0 90 10.0 50 Volt Rating at +85°C (33 Volt Rating at 125°C) or "M"T510X106(1)050A(2)E120 tolerance. (2) To 8.0 - ±20% capacitance complete KEMET X 5.0 120.0 X T510X106(1)050A(2)E090 5.0 8.0 90.0 7.7 2.6 2.4 2.4 1.6 1.8 2.1 2.0 2.3 2.2 2.0 2.4 1.5 1.7 6.9 2.3 2.2 2.1 1.4 1.7 1.9 1.8 2.1 2.0 1.8 2.1 1.3 1.6 3.1 1.0 0.9 1.0 0.6 0.7 0.8 0.8 0.9 0.9 0.8 1.0 0.6 0.7 (1) To complete KEMET part number insert "K" -10.0 ±10% part number, insert0.6 (SnPb) or T - 100% tin. H 1.5 1.3 1.7 1.6 0.7 (1) To complete KEMET part number insert "K" - ±10% or "M" - ±20% capacitance tolerance. (2) To complete KEMET part number, insert H (SnPb) or T 100% tin. T510 ORDERING INFORMATION T Tantalum Series T510 - High Capacitance, Low ESR 510 X 477 M 006 A T 030 ESR E030 = ESR in Milliohmns = 30 mOhms Lead Material T = 100% Tin (Sn) Plated H = (Sn) Solder-Coated (90% Sn/10% Pb) G = Gold Plated S = Not Recommended for new design Case Size E, X Capacitance Picofarad Code First two digits represent significant figures. Third digit specifies number of zeros to follow. *PartM = ±20%, K = ±10% number example: T510X477M006AT (14 digits - no spaces).*Pb-free supply is not Pb Free transition. See www.kemet.com for guaranteed with ** “S” Termination codes are converting from 90 Sn/10 Pb to 100% tin finishes. Orders including “S” suffix the ‘S’ termination code. termination codes do not quarantee Pb-free product. This termination code not available Failure Rate A = Not Applicable Capacitance Tolerance VOLTAGE effective 15 July 2007. ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 41 Solid Tantalum Surface Mount SOLID TANTALUM CHIP CAPACITORS T510 SERIES—High Capacitance TYPICAL CAP FREQUENCY SCAN @25˚C T510X477M006AS 500 450 400 ) ( Ω) ) .1 TYPICAL ESR/Z FREQUENCY SCAN @25˚C T510X477M006AS 10 Capacitance (μF) 350 300 250 200 150 100 50 0 100Hz 1kHz 10kHz 100kHz 1MHz 1 ESR ( .01 100Hz Z( 1kHz 10kHz 100kHz 1MHz TYPICAL CAP FREQUENCY SCAN @ 25°C T510E108M004AS 1500 1400 TYPICAL ESR/Z FREQUENCY SCAN @ 25°C T510E108M004AS 10 1200 ) (Ω) ) Z( 1300 Capacitance (μF) 1 1100 1000 900 800 700 600 500 100Hz 1kHz 10kHz 100kHz 1MHz .01 100Hz 1kHz 10kHz 100kHz 1MHz ESR ( .1 CAPACITOR ALTERNATE MARKINGS Date Code Year S = 2004 T = 2005 U = 2006 V = 2007 W = 2008 X = 2009 Date Code Month 1 = Jan 2 = Feb 3 = Mar 4 = Apr 7 = Jul 8= Aug 9 = Sep 10 = Oct Voltage Date Code KEMET Organic T510 CAPACITOR MARKINGS Polarity Indicator (+) M+ K Ultra-Low ESR Device 5 = May 11 = Nov 6 = Jun 12 = Dec Picofarad Code Lot Code Rated Voltage 1st Digit =Year V5 49 M+ 477 6K 514 “514” = The 14th week of 2005. Polarity Indicator (+) (Solid Stripe) Picofarad Code KEMET I. D. Symbol 2nd & 3rd Digits = Week 477 6V 42 ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 TANTALUM AND ALUMINUM CHIP CAPACITORS Packaging Information Tape & Reel Packaging KEMET’s Molded Tantalum and Aluminum Chip Capacitor families are packaged in 8 mm and 12 mm plastic tape on 7" and 13" reels, in accordance with EIA Standard 481-1: Taping of Surface Mount Components for Automatic Handling. This packaging system is compatible with all tape fed automatic pick and place systems. Right Hand Orientation Only Embossed Carrier (+) (–) Embossment Top Tape Thickness .10mm (.004") Max Thickness 8mm ±.30 8mm (0.315") (.315 ±.012") or or 12mm (0.472") 12mm ±.30 (.472 ±.012") 178mm (7.00") 180mm (7.0") oror 330mm (13.00") 330mm (13.0") Labeling: Bar code labeling (standard or custom) shall be on the side of the reel opposite the sprocket holes. Refer to EIA-556. QUANTITIES PACKAGED PER REEL Case Code KEMET EIA R 2012-12 S 3216-12 T 3528-12 U 6032-15 W 7343-15 V 7343-20 A 3216-18 B 3528-21 C 6032-28 D 7343-31 Y 7343-40 X 7343-43 E 7260-38 Tape Width-mm 8 8 8 12 12 12 8 8 12 12 12 12 12 7" Reel* 2,500 2,500 2,500 1,000 1,000 1,000 2,000 2,000 500 500 500 500 500 13" Reel* 10,000 10,000 10,000 5,000 3,000 3,000 9,000 8,000 3,000 2,500 2,000 2,000 2,000 * No c-spec required for 7" reel packaging. C-7280 required for 13" reel packaging. * Standard reel packaging is not mandatory. * Bulk packaging also available using C-7610. 92 ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 Packaging TANTALUM, CERAMIC AND ALUMINUM CHIP CAPACITORS Packaging Information Performance Notes 1. Cover Tape Break Force: 1.0 Kg Minimum. 2. Cover Tape Peel Strength: The total peel strength of the cover tape from the carrier tape shall be: Tape Width Peel Strength 8 mm 0.1 Newton to 1.0 Newton (10g to 100g) 12 mm 0.1 Newton to 1.3 Newton (10g to 130g) The direction of the pull shall be opposite the direction of the carrier tape travel. The pull angle of the carrier tape shall be 165 to 180 from the plane of the carrier tape. During peeling, the carrier and/or cover tape shall be pulled at a velocity of 300 ±10 mm/minute. 3. Reel Sizes: Molded tantalum capacitors are available on either 180 mm (7") reels (standard) or 330 mm (13") reels (with C-7280). Note that 13” reels are preferred. 4. Labeling: Bar code labeling (standard or custom) shall be on the side of the reel opposite the sprocket holes. Refer to EIA-556. Embossed Carrier Tape Configuration: Figure 1 Table 1 — EMBOSSED TAPE DIMENSIONS (Metric will govern) Constant Dimensions — Millimeters (Inches) Tape Size 8 mm and 12 mm D0 E P0 4.0 ±0.10 (0.157 ±0.004) P2 2.0 ±0.05 (0.079 ±0.002) T Max 0.600 (0.024) T1 Max 0.100 (0.004) 1.5 1.75 ±0.10 +0.10 -0.0 (0.059 (0.069 ±0.004) +0.004, -0.0) Pitch Single (4 mm) B1 Max. Note 1 4.4 (0.173) 12 mm Double (8 mm) 8.2 (0.323) D1 Min. Note 2 1.0 Variable Dimensions — Millimeters (Inches) Tape Size 8 mm F 3.5 ±0.05 P1 4.0 ±0.10 R Min. Note 3 25.0 T2 Max 2.5 (0.098) W 8.0 ±0.30 (.315 ±0.012) A0B0K0 Note 4 (0.039) (0.138 ±0.002) 1.5 5.5 ±0.05 (0.059) (0.217 ±0.002) (0.157 ±0.004) (0.984) 8.0 ±0.10 30.0 (0.315 ±0.004) (1.181) 4.6 12.0 ±0.30 (0.181) (0.472 ±0.012) NOTES 1. B1 dimension is a reference dimension for tape feeder clearance only. 2. The embossment hole location shall be measured from the sprocket hole controlling the location of the embossment. Dimensions of embossment location and hole location shall be applied independent of each other. 3. Tape with components shall pass around radius “R” without damage (see sketch A). The minimum trailer length (Fig. 2) may require additional length to provide R min. for 12 mm embossed tape for reels with hub diameters approaching N min. (Table 2) 4. The cavity defined by A0, B0, and K0 shall be configured to surround the part with sufficient clearance such that the chip does not protrude beyond the sealing plane of the cover tape, the chip can be removed from the cavity in a vertical direction without mechanical restriction, rotation of the chip is limited to 20 degrees maximum in all 3 planes, and lateral movement of the chip is restricted to 0.5 mm maximum in the pocket (not applicable to vertical clearance.) 94 ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 TANTALUM, CERAMIC AND ALUMINUM CHIP CAPACITORS Packaging Information Embossed Carrier Tape Configuration (cont.) 20° Sketch D: Tape Camber (Top View) 1mm (0.039) Max. 250mm (9.843) Allowable camber to be 1 mm/250 mm. 1mm (0.039) Max. 400mm (15.75) Min. Figure 2: Tape Leader & Trailer Dimensions (Metric Dimensions Will Govern) Figure 3: Reel Dimensions (Metric Dimensions will govern) Table 2 – REEL DIMENSIONS (Metric will govern) Tape Size 8 mm A Max 330.0 (12.992) B* Min 1.5 (0.059) C 13.0 ± 0.20 (0.512 ± 0.008) D* Min 20.2 (0.795) N Min 50.0 (1.969) See Note 3 Table 1 W1 8.4 +1.5, -0.0 (0.331 +0.059, -0.0) 12.4 +2.0, -0.0 (0.488 +0.078, -0.0) W2 Max 14.4 (0.567) W3 7.9 Min (0.311) 10.9 Max (0.429) 11.9 Min (0.469) 15.4 Max (0.606) 12 mm 330.0 (12.992) 1.5 (0.059) 13.0 ± 0.20 (0.512 ± 0.008) 20.2 (0.795) 18.4 (0.724) ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 95 Packaging
很抱歉,暂时无法提供与“T510”相匹配的价格&库存,您可以联系我们找货
