T520
T520
    KEMET(基美)
    T520 - CONDUCTIVE POLYMER CHIP CAPACITORS - Kemet Corporation
T520 数据手册
CONDUCTIVE POLYMER CHIP CAPACITORS T520 Series - KO Cap FEATURES Polymer Cathode Technology • Low ESR • High Frequency Cap Retention • No-Ignition Failure Mode • Use Up to 90% of Rated Voltage (10% Derating) for part types ≤ 10 Volts • Halogen Free Epoxy • 100% Accelerated Steady State Aging • Volumetrically Efficient • Use Up to 80% of Rated Voltage (20% Derating) for part types > 10 Volts • Capacitance 15 to 1000μF (±20%) • Voltage 2V to 25V • EIA Standard Case Sizes • 100% Surge Current Tested • Operating Temperature -55ºC to +105ºC • Self Healing Mechanism • RoHS Compiant & Leadfree Terminations (see www.kemet.com for lead transition) • ANODE (+) END VIEW BOTTOM VIEW OUTLINE DRAWING CATHODE (-) END VIEW W SIDE VIEW B B H K X S T G S R P Termination cutout at KEMET’s Option, either end E A L F DIMENSIONS - MILLIMETERS Case Size KEMET EIA A 3216-18 T 3528-12 M 3528-15 B 3528-21 U 6032-15 L 6032-19 C 6032-28 W 7343-15 V 7343-20 D 7343-31 Y 7343-40 X 7343-43 3.2 3.5 3.5 3.5 6.0 6.0 6.0 7.3 7.3 7.3 7.3 7.3 L ± 0.2 ± 0.2 ± 0.2 ± 0.2 ± 0.3 ± 0.3 ± 0.3 ± 0.3 ± 0.3 ± 0.3 ± 0.3 ± 0.3 1.6 2.8 2.8 2.8 3.2 3.2 3.2 4.3 4.3 4.3 4.3 4.3 W ±02 ±02 ±02 ±02 ±03 ±03 ±03 ±03 ±03 ±03 ±03 ±03 H 1.6 ± 0.2 1.2 max 1.5 max 1.9 ± 0.1 1.5 max 1.9 max 2.5 ± 0.3 1.5 max 1.9 max 2.8 ± 0.3 4.0 max 4.0 ± 0.3 F ± 0.1 1.2 2.2 2.2 2.2 2.2 2.2 2.2 2.4 2.4 2.4 2.4 2.4 S ± 0.3 08 08 08 08 13 13 13 13 13 13 13 13 X(Ref) 0.10 ± 0.10 0.05 0.11 0.10 ± 0.10 0.05 0.10 ± 0.10 0.10 ± 0.10 0.05 0.05 0.10 ± 0.10 0.10 ± 0.10 0.10 ± 0.10 T(Ref) 0.13 0.13 0.13 0.13 0.13 0.13 0.13 0.13 0.13 0.13 0.13 0.13 A(Min) 0.8 1.1 2.1 1.1 3.1 2.5 2.5 3.8 3.8 3.8 3.8 3.8 G(ref) 1.1 1.8 1.8 1.8 2.8 2.8 2.8 3.5 3.5 3.5 3.5 3.5 E(ref) 1.3 2.2 2.2 2.2 2.4 2.4 2.4 3.5 3.5 3.5 3.5 3.5 T520 ORDERING INFORMATION T 520 V 157 M 006 A Tantalum Series T520 - Low ESR Polymer T E015 ESR Lead Material T - 100% Tin (Sn) Plated H - Tin/Lead (SnPb 5% Pb minimum) Case Size A, T, B, C, V, W, D, Y, X Failure Rate A - Not Applicable Capacitance Picofarad Code First two digits represent significant figures. Third digit specifies number of zeros to follow. Voltage Note: 006 = 6.3 volts Capacitance Tolerance M = ± 20% *See www.kemet.com for Pb Free transition information. COMPONENT MARKING KEMET Organic KO Polarity (+) Indicator Picofarad Code KEMET ID PWC Rated Voltage 157 6K 512 512 = 12th week of 2005 50 ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 CONDUCTIVE POLYMER CHIP CAPACITORS T520 Series - KO Cap T520 RATINGS & PART NUMBER REFERENCE Rated Voltage (V) Rated Capacitance (μF) Case Code/ Case Size KEMET Part Number DC Leakage µA @ 20°C max/ 5min DF% @ 20°C 120 Hz Max ESR mΩ @ 20°C 100 kHz Max Maximum allowable ripple current (mArms) 100kHz* MSL Reflow Temp ≤ 260ºC Rated Voltage (V) Rated Capacitance (μF) Case Code/ Case Size KEMET Part Number DC Leakage µA @ 20°C max/ 5min DF% @ 20°C 120 Hz Max ESR mΩ @ 20°C 100 kHz Max Maximum allowable ripple current (mArms) 100kHz* MSL Reflow Temp ≤ 260ºC 2 2.5 470 47 56 56 68 68 100 100 100 100 100 100 150 220 220 220 220 220 220 220 220 220 220 220 220 220 220 220 220 220 220 220 220 330 330 330 330 330 330 330 330 330 330 330 330 330 330 330 330 330 330 330 330 330 330 470 470 470 470 470 470 470 470 470 470 680 680 680 680 680 1000 1000 1000 1000 1000 1000 V/7343-19 A/3216-18 T/3528-12 T/3528-12 A/3216-18 A/3216-18 T/3528-12 T/3528-12 B/3528-20 B/3528-20 B/3528-20 B/3528-20 U/6032-15 B/3528-20 B/3528-20 B/3528-20 B/3528-20 B/3528-20 B/3528-20 B/3528-20 B/3528-20 U/6032-15 C/6032-28 C/6032-28 W/7343-15 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 D/7343-31 D/7343-31 B/3528-20 B/3528-20 C/6032-28 C/6032-28 C/6032-28 C/6032-28 L/6032-20 L/6032-20 L/6032-20 W/7343-15 W/7343-15 W/7343-15 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 D/7343-31 D/7343-31 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 C/6032-28 C/6032-28 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 Y/7343-40 Y/7343-40 D/7343-31 D/7343-31 Y/7343-40 Y/7343-40 Y/7343-40 X/7343-43 T520V477M002A(1)E040 T520A476M2R5A(1)E090 T520T566M2R5A(1)E040 T520T566M2R5A(1)E070 T520A686M2R5A(1)E070 T520A686M2R5A(1)E080 T520T107M2R5A(1)E040 T520T107M2R5A(1)E070 T520B107M2R5A(1)E025 T520B107M2R5A(1)E035 T520B107M2R5A(1)E040 T520B107M2R5A(1)E070 T520U157M2R5A(1)E055 T520B227M2R5A(1)E015 T520B227M2R5A(1)E018 T520B227M2R5A(1) E021 T520B227M2R5A(1)E025 T520B227M2R5A(1)E030 T520B227M2R5A(1)E035 T520B227M2R5A(1) E055 T520B227M2R5A(1)E070 T520U227M2R5A(1)E055 T520C227M2R5A(1)E025 T520C227M2R5A(1)E045 T520W227M2R5A(1) E025 T520V227M2R5A(1)E007 T520V227M2R5A(1)E009 T520V227M2R5A(1)E012 T520V227M2R5A(1)E015 T520V227M2R5A(1)E025 T520V227M2R5A(1)E045 T520D227M2R5A(1)E007 T520D227M2R5A(1)E040 T520B337M2R5A(1)E045 T520B337M2R5A(1)E070 T520C337M2R5A(1)E015 T520C337M2R5A(1)E018 T520C337M2R5A(1)E025 T520C337M2R5A(1)E045 T520L337M2R5A(1)E009 T520L337M2R5A(1)E012 T520L337M2R5A(1)E025 T520W337M2R5A(1)E015 T520W337M2R5A(1)E025 T520W337M2R5A(1)E040 T520V337M2R5A(1)E006 T520V337M2R5A(1)E007 T520V337M2R5A(1)E009 T520V337M2R5A(1)E012 T520V337M2R5A(1)E015 T520V337M2R5A(1)E018 T520V337M2R5A(1)E025 T520V337M2R5A(1)E040 T520D337M2R5A(1)E006 T520D337M2R5A(1)E007 T520V477M2R5A(1)E007 T520V477M2R5A(1)E009 T520V477M2R5A(1)E012 T520V477M2R5A(1)E015 T520V477M2R5A(1)E018 T520C477M2R5A(1)E025 T520C477M2R5A(1)E045 T520D477M2R5A(1)E006 T520D477M2R5A(1)E007 T520D477M2R5A(1)E009 T520D687M2R5A(1)E010 T520D687M2R5A(1)E015 T520D687M2R5A(1)E040 T520Y687M2R5A(1)E015 T520Y687M2R5A(1)E025 T520D108M2R5A(1)E015 T520D108M2R5A(1)E030 T520Y108M2R5A(1)E010 T520Y108M2R5A(1)E015 T520Y108M2R5A(1)E025 T520X108M2R5A(1)E010 94 12 14 14 17 17 25 25 25 25 25 25 38 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 83 83 83 83 83 83 83 83 83 83 83 83 83 83 83 83 83 83 83 83 83 83 118 118 118 118 118 118 118 118 118 118 170 170 170 170 170 250 250 250 250 250 250 10 8 6 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 10 10 10 10 10 10 10 10 8 8 8 8 8 8 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 8 8 10 10 10 10 10 10 10 10 8 10 10 10 10 10 40 90 40 70 70 80 40 70 25 35 40 70 55 15 15 21 25 30 35 55 70 55 25 45 25 7 9 12 15 25 45 7 40 45 70 15 18 25 45 9 12 25 15 25 40 6 7 9 12 15 18 25 40 6 7 7 9 12 15 18 25 45 6 7 9 10 15 40 15 25 15 30 10 15 25 10 2200 1100 1600 1200 1300 1200 1600 1200 2300 1900 1800 1300 1600 2900 2900 2500 2300 2100 1900 1500 1300 1600 2600 1900 2200 5200 4600 3900 3500 2700 2000 5700 2400 1700 1300 3300 3000 2600 1900 4100 3500 2400 2800 2200 1700 5600 5200 4600 3900 3500 3200 2700 2200 6100 5700 5200 4600 3900 3500 3200 2600 1900 6100 5700 5000 4700 3900 2400 4000 3100 3900 2700 4900 4000 3100 5000 3 100 100 100 100 150 150 150 3 330 330 330 330 680 680 1000 1000 15 33 33 47 47 47 68 68 68 68 68 68 100 100 100 100 100 100 100 100 150 150 150 B/3528-20 B/3528-20 B/3528-20 B/3528-20 B/3528-20 B/3528-20 B/3528-20 V/7343-19 V/7343-19 V/7343-19 V/7343-19 D/7343-31 D/7343-31 X/7343-43 X/7343-43 T/3528-12 A/3216-18 A/3216-18 A/3216-18 A/3216-18 T/3528-12 T/3528-12 B/3528-20 B/3528-20 B/3528-20 B/3528-20 U/6032-15 A/3216-18 T/3528-12 T/3528-12 B/3528-20 B/3528-20 B/3528-20 B/3528-20 U/6032-15 B/3528-20 B/3528-20 B/3528-20 B/3528-20 B/3528-20 U/6032-15 C/6032-28 C/6032-28 C/6032-28 C/6032-28 T520B107M003A(1)E025 T520B107M003A(1)E035 T520B107M003A(1)E040 T520B107M003A(1)E070 T520B157M003A(1)E035 T520B157M003A(1)E040 T520B157M003A(1)E070 T520V337M003A(1)E009 T520V337M003A(1)E012 T520V337M003A(1)E015 T520V337M003A(1)E025 T520D687M003A(1)E015 T520D687M003A(1)E040 T520X108M003A(1)E015 T520X108M003A(1)E030 T520T156M004A(1)E100 T520A336M004A(1)E070 T520A336M004A(1)E080 T520A476M004A(1)E070 T520A476M004A(1)E080 T520T476M004A(1)E070 T520T686M004A(1)E070 T520B686M004A(1)EO25 T520B686M004A(1)E035 T520B686M004A(1)E040 T520B686M004A(1)E070 T520U686M004A(1)E055 T520A107M004A(1) E200 T520T107M004A(1)E070 T520T107M004A(1)E150 T520B107M004A(1)E025 T520B107M004A(1)E035 T520B107M004A(1)E040 T520B107M004A(1)E070 T520U107M004A(1)E055 T520B157M004A(1)E015 T520B157M004A(1)E018 T520B157M004A(1)E035 T520B157M004A(1)E040 T520B157M004A(1)E070 T520U157M004A(1)E055 T520C157M004A(1)E015 T520C157M004A(1)E025 T520C157M004A(1)E045 T520C157M004A(1)E100 30 30 30 30 45 45 45 99 99 99 99 204 204 300 300 6 13 13 19 19 19 27 27 27 27 27 27 40 40 40 40 40 40 40 40 60 60 60 60 60 60 60 60 60 60 8 8 8 8 8 8 8 10 10 10 10 10 10 10 10 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 25 35 40 70 35 40 70 9 12 15 25 15 40 15 30 100 70 80 70 80 70 70 25 35 40 70 55 200 70 150 25 35 40 70 55 15 18 35 40 70 55 15 25 45 100 2300 1900 1800 1300 1900 1800 1300 4600 3900 3500 2700 3900 2400 4100 2900 1000 1300 1200 1300 1200 1200 1200 2300 1900 1800 1300 1600 700 1200 800 2300 1900 1800 1300 1600 2900 2700 1900 1800 1300 1600 3300 2600 1900 1300 3 3 3 150 150 150 150 4 150 150 150 150 150 150 150 150 150 220 220 220 220 220 220 220 220 220 220 220 220 220 220 220 220 220 220 220 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 D/7343-31 B/3528-20 B/3528-20 B/3528-20 C/6032-28 C/6032-28 C/6032-28 C/6032-28 C/6032-28 L/6032-20 L/6032-20 W/7343-15 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 T520V157M004A(1)E007 T520V157M004A(1)E009 T520V157M004A(1)E012 T520V157M004A(1)E015 T520V157M004A(1)E025 T520D157M004A(1)E007 T520B227M004A(1)E035 T520B227M004A(1)E045 T520B227M004A(1)E070 T520C227M004A(1)E015 T520C227M004A(1)E018 T520C227M004A(1)E025 T520C227M004A(1)E045 T520C227M004A(1)E055 T520L227M004A(1)E012 T520L227M004A(1)E025 T520W227M004A(1)E040 T520V227M004A(1)E007 T520V227M004A(1)E009 T520V227M004A(1)E012 T520V227M004A(1)E015 T520V227M004A(1)E018 T520V227M004A(1)E025 T520V227M004A(1)E040 T520V227M004A(1)E045 60 60 60 60 60 60 88 88 88 88 88 88 88 88 88 88 88 88 88 88 88 88 88 88 88 10 10 10 10 10 10 8 8 8 8 8 8 8 8 8 10 10 10 10 10 10 10 10 10 10 7 9 12 15 25 7 35 45 70 15 18 25 45 55 12 25 40 7 9 12 15 18 25 40 45 5200 4600 3900 3500 2700 5700 1900 1700 1300 3300 3000 2600 1900 1700 3500 2400 1700 5200 4600 3900 3500 3200 2700 2200 2000 *100kHz to 500kHz, 45º C (1) To complete KEMET part number, insert letter designation for lead material from page 50. Higher voltage ratings and tighter tolerance product may be substituted with the same size at KEMET's option.Voltage substitutions will be marked with the higher voltage rating. *100kHz to 500kHz, 45º C (1) To complete KEMET part number, insert letter designation for lead material from page 50. Higher voltage ratings and tighter tolerance product may be substituted with the same size at KEMET's option.Voltage substitutions will be marked with the higher voltage rating. ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 CONDUCTIVE POLYMER CHIP CAPACITORS T520 Series - KO Cap T520 RATINGS & PART NUMBER REFERENCE Rated Voltage (V) Rated Capacitance (μF) Case Code/ Case Size KEMET Part Number DC Leakage µA @ 20°C max/ 5min DF% @ 20°C 120 Hz Max ESR mΩ @ 20°C 100 kHz Max Maximum allowable ripple current (mArms) 100kHz* MSL Reflow Temp ≤ 260ºC Rated Voltage (V) Rated Capacitance (μF) Case Code/ Case Size KEMET Part Number DC Leakage µA @ 20°C max/ 5min DF% @ 20°C 120 Hz Max ESR mΩ @ 20°C 100 kHz Max Maximum allowable ripple current (mArms) 100kHz* MSL Reflow Temp ≤ 260ºC 4 6.3 220 220 220 220 330 330 330 330 330 330 330 330 330 330 330 330 330 330 470 470 470 470 470 470 680 680 680 680 680 680 680 680 680 15 22 22 33 33 33 33 33 33 33 33 33 47 47 47 47 47 47 68 68 68 68 68 68 68 68 68 100 100 100 100 100 100 100 100 100 100 100 100 100 100 D/7343-31 D/7343-31 D/7343-31 D/7343-31 C/6032-28 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 Y/7343-40 Y/7343-40 Y/7343-40 X/7343-43 X/7343-43 X/7343-43 T/3528-12 A/3216-18 A/3216-18 A/3216-18 A/3216-18 A/3216-18 T/3528-12 B/3528-20 B/3528-20 B/3528-20 B/3528-20 C/6032-28 T/3528-12 T/3528-12 B/3528-20 B/3528-20 B/3528-20 B/3528-20 T/3528-12 T/3528-12 B/3528-20 B/3528-20 B/3528-20 B/3528-20 U/6032-15 U/6032-15 C/6032-28 B/3528-20 B/3528-20 B/3528-20 B/3528-20 B/3528-20 U/6032-15 W/7343-15 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 C/6032-28 C/6032-28 T520D227M004A(1)E006 T520D227M004A(1)E007 T520D227M004A(1)E012 T520D227M004A(1)E065 T520C337M004A(1)E025 T520V337M004A(1)E007 T520V337M004A(1)E009 T520V337M004A(1)E012 T520V337M004A(1)E018 T520V337M004A(1)E025 T520V337M004A(1)E040 T520D337M004A(1)E006 T520D337M004A(1)E007 T520D337M004A(1)E009 T520D337M004A(1)E012 T520D337M004A(1)E015 T520D337M004A(1)E040 T520D337M004A(1)E045 T520D477M004A(1)E010 T520D477M004A(1)E012 T520D477M004A(1)E015 T520D477M004A(1)E018 T520D477M004A(1)E025 T520D477M004A(1)E040 T520D687M004A(1)E012 T520D687M004A(1)E015 T520D687M004A(1)E025 T520Y687M004A(1)E010 T520Y687M004A(1)E015 T520Y687M004A(1)E025 T520X687M004A(1)E010 T520X687M004A(1)E015 T520X687M004A(1)E035 T520T156M006A(1)E100 T520A226M006A(1)E090 T520A226M006A(1)E100 T520A336M006A(1)E070 T520A336M006A(1)E080 T520A336M006A(1)E120 T520T336M006A(1)E070 T520B336M006A(1)E025 T520B336M006A(1)E035 T520B336M006A(1)E040 T520B336M006A(1)E070 T520C336M006A(1)E100 T520T476M006A(1)E040 T520T476M006A(1)E070 T520B476M006A(1)E025 T520B476M006A(1)E035 T520B476M006A(1)E040 T520B476M006A(1)E070 T520T686M006A(1)E070 T520T686M006A(1)E150 T520B686M006A(1)E025 T520B686M006A(1)E035 T520B686M006A(1)E040 T520B686M006A(1)E070 T520U686M006A(1)E055 T520U686M006A(1)E070 T520C686M006A(1) E100 T520B107M006A(1)E015 T520B107M006A(1)E018 T520B107M006A(1)E040 T520B107M006A(1)E045 T520B107M006A(1)E070 T520U107M006A(1)E055 T520W107M006A(1)E040 T520V107M006A(1)E007 T520V107M006A(1)E009 T520V107M006A(1)E012 T520V107M006A(1)E015 T520V107M006A(1)E045 T520C107M006A(1)E025 T520C107M006A(1)E045 88 88 88 88 132 132 132 132 132 132 132 132 132 132 132 132 132 132 188 188 188 188 188 188 272 272 272 272 272 272 272 272 272 9.5 14 14 21 21 21 21 21 21 21 21 21 30 30 30 30 30 30 43 43 43 43 43 43 43 43 43 63 63 63 63 63 63 63 63 63 63 63 63 63 63 10 10 10 10 8 10 10 10 10 10 10 10 10 10 10 10 10 8 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 10 10 10 10 10 10 8 8 6 7 12 65 25 7 9 12 18 25 40 6 7 9 12 15 40 45 10 12 15 18 25 40 12 15 25 10 15 25 10 15 35 100 90 100 70 80 120 70 25 35 40 70 100 40 70 25 35 40 70 70 150 25 35 40 70 55 70 100 15 18 40 45 70 55 40 7 9 12 15 45 25 45 6100 5700 4300 1900 2600 5200 4600 3900 3200 2700 2200 6100 5700 5000 4300 3900 2400 2200 4700 4300 3900 3500 3000 2400 4300 3900 3000 4900 4000 3100 5000 4100 2700 1000 1100 1100 1300 1200 1000 1200 2300 1900 1800 1300 1300 1600 1200 2300 1900 1800 1300 1200 800 2300 1900 1800 1300 1600 1400 1300 2900 2700 1800 1700 1300 1600 1700 5200 4600 3900 3500 2000 2600 1900 3 6.3 3 120 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 150 220 220 220 220 220 220 220 220 220 220 220 220 220 220 220 220 220 220 330 330 330 330 330 330 330 330 330 330 330 330 330 330 330 470 470 470 470 470 470 470 470 470 470 470 B/3528-20 B/3528-20 B/3528-20 B/3528-20 B/3528-20 M/3528-15 M/3528-15 C/6032-28 C/6032-28 U/6032-15 U/6032-15 L/6032-20 L/6032-20 W/7343-15 W/7343-15 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 C/6032-28 C/6032-28 C/6032-28 C/6032-28 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 Y/7343-40 Y/7343-40 Y/7343-40 Y/7343-40 Y/7343-40 Y/7343-40 Y/7343-40 Y/7343-40 D/7343-31 D/7343-31 X/7343-43 X/7343-43 X/7343-43 X/7343-43 T520B127M006A(1)E035 T520B157M006A(1)E025 T520B157M006A(1)E035 T520B157M006A(1)E045 T520B157M006A(1)E070 T520M157M006A(1)E150 T520M157M006A(1)E200 T520C157M006A(1)E025 T520C157M006A(1)E045 T520U157M006A(1)E045 T520U157M006A(1)E055 T520L157M006A(1)E012 T520L157M006A(1)E025 T520W157M006A(1)E025 T520W157M006A(1)E040 T520V157M006A(1)E007 T520V157M006A(1)E009 T520V157M006A(1)E012 T520V157M006A(1)E015 T520V157M006A(1)E025 T520V157M006A(1)E040 T520V157M006A(1)E045 T520D157M006A(1)E006 T520D157M006A(1)E007 T520D157M006A(1)E015 T520D157M006A(1)E025 T520D157M006A(1)E055 T520C227M006A(1)E015 T520C227M006A(1)E018 T520C227M006A(1)E025 T520C227M006A(1)E045 T520V227M006A(1)E007 T520V227M006A(1)E009 T520V227M006A(1)E012 T520V227M006A(1)E015 T520V227M006A(1)E025 T520V227M006A(1)E040 T520D227M006A(1)E006 T520D227M006A(1)E007 T520D227M006A(1)E009 T520D227M006A(1)E015 T520D227M006A(1)E018 T520D227M006A(1)E025 T520D227M006A(1)E040 T520D227M006A(1)E050 T520V337M006A(1)E015 T520V337M006A(1)E018 T520V337M006A(1)E025 T520V337M006A(1)E040 T520V337M006A(1)E045 T520D337M006A(1)E009 T520D337M006A(1)E010 T520D337M006A(1)E015 T520D337M006A(1)E018 T520D337M006A(1)E025 T520D337M006A(1)E040 T520D337M006A(1)E045 T520Y337M006A(1)E015 T520Y337M006A(1)E025 T520Y337M006A(1)E040 T520Y477M006A(1)E010 T520Y477M006A(1)E015 T520Y477M006A(1)E018 T520Y477M006A(1)E025 T520Y477M006A(1)E035 T520D477M006A(1)E025 T520D477M006A(1)E030 T520X477M006A(1)E010 T520X477M006A(1)E018 T520X477M006A(1)E035 T520X477M006A(1)E040 76 95 95 95 95 95 95 95 95 95 95 95 95 95 95 95 95 95 95 95 95 95 95 95 95 95 95 139 139 139 139 139 139 139 139 139 139 139 139 139 139 139 139 139 139 208 208 208 208 208 208 208 208 208 208 208 208 208 208 208 296 296 296 296 296 296 296 296 296 296 296 8 8 8 8 8 10 8 8 8 8 8 8 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 8 8 8 8 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 35 25 35 45 70 150 200 25 45 45 55 12 25 25 40 7 9 12 15 25 40 45 6 7 15 25 55 15 18 25 45 7 9 12 15 25 40 6 7 9 15 18 25 40 50 15 18 25 40 45 9 10 15 18 25 40 45 15 25 40 10 15 18 25 35 25 30 10 18 35 40 1900 2300 1900 1700 1300 700 600 2600 1900 1700 1600 3500 2400 2200 1700 5200 4600 3900 3500 2700 2200 2000 6100 5700 3900 3000 2000 3300 3000 2600 1900 5200 4600 3900 3500 2700 2200 6100 5700 5000 3900 3500 3000 2400 2100 3500 3200 2700 2200 2000 5000 4700 3900 3500 3000 2400 2200 4000 3100 2500 4900 4000 3700 3100 2600 3000 2700 5000 3700 2700 2500 3 *100kHz to 500kHz, 45º C (1) To complete KEMET part number, insert letter designation for lead material from page 50. Higher voltage ratings and tighter tolerance product may be substituted with the same size at KEMET's option.Voltage substitutions will be marked with the higher voltage rating. *100kHz to 500kHz, 45º C (1) To complete KEMET part number, insert letter designation for lead material from page 50. Higher voltage ratings and tighter tolerance product may be substituted with the same size at KEMET's option.Voltage substitutions will be marked with the higher voltage rating. ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 CONDUCTIVE POLYMER CHIP CAPACITORS T520 Series - KO Cap T520 RATINGS & PART NUMBER REFERENCE Rated Voltage (V) Rated Capacitance (μF) Case Code/ Case Size DC Leakage µA @ 20°C max/ 5min DF% @ 20°C 120 Hz Max ESR mΩ @ 20°C 100 kHz Max Maximum allowable ripple current (mArms) 100kHz* MSL Reflow Temp ≤ 260ºC Rated Voltage (V) Rated Capacitance (μF) Case Code/ Case Size KEMET Part Number DC Leakage µA @ 20°C max/ 5min DF% @ 20°C 120 Hz Max ESR mΩ @ 20°C 100 kHz Max Maximum allowable ripple current (mArms) 100kHz* MSL Reflow Temp ≤ 260ºC KEMET Part Number 8 10 33 33 33 33 33 33 33 47 47 82 82 150 150 150 150 10 15 22 33 33 33 33 33 33 33 33 47 47 47 47 68 68 68 68 68 68 68 68 68 68 100 100 100 100 100 100 100 100 100 100 100 150 150 150 150 150 150 150 150 150 150 150 150 220 220 220 220 220 330 330 330 330 330 T/3528-12 T/3528-12 B/3528-20 B/3528-20 B/3528-20 B/3528-20 U/6032-15 B/3528-20 B/3528-20 C/6032-28 C/6032-28 D/7343-31 D/7343-31 D/7343-31 V/7343-19 A/3216-18 A/3216-18 A/3216-18 T/3528-12 T/3528-12 T/3528-12 B/3528-20 B/3528-20 B/3528-20 B/3528-20 U/6032-15 B/3528-20 B/3528-20 U/6032-15 C/6032-28 U/6032-15 W/7343-15 W/7343-15 C/6032-28 V/7343-19 V/7343-19 V/7343-19 V/7343-19 V/7343-19 D/7343-31 C/6032-28 C/6032-28 L/6032-20 W/7343-15 V/7343-19 V/7343-19 V/7343-19 V/7343-19 D/7343-31 D/7343-31 D/7343-31 C/6032-28 V/7343-19 V/7343-19 V/7343-19 D/7343-31 D/7343-31 D/7343-31 D/7343-31 D/7343-31 Y/7343-40 Y/7343-40 Y/7343-40 V/7343-19 Y/7343-40 D/7343-31 D/7343-31 D/7343-31 Y/7343-40 Y/7343-40 X/7343-43 X/7343-43 X/7343-43 T520T336M008A(1)E070 T520T336M008A(1)E080 T520B336M008A(1)E025 T520B336M008A(1)E035 T520B336M008A(1)E040 T520B336M008A(1)E070 T520U336M008A(1)E070 T520B476M008A(1)E035 T520B476M008A(1)E070 T520C826M008A(1)E025 T520C826M008A(1)E045 T520D157M008A(1)E025 T520D157M008A(1)E040 T520D157M008A(1)E055 T520V157M008A(1)E040 T520A106M010A(1)E080 T520A156M010A(1)E080 T520A226M010A(1)E080 T520T336M010A(1)E040 T520T336M010A(1)E070 T520T336M010A(1)E080 T520B336M010A(1)E025 T520B336M010A(1)E035 T520B336M010A(1)E040 T520B336M010A(1)E070 T520U336M010A(1)E070 T520B476M010A(1)E035 T520B476M010A(1)E070 T520U476M010A(1)E055 T520C476M010A(1)E100 T520U686M010A(1)E055 T520W686M010A(1)E025 T520W686M010A(1)E040 T520C686M010A(1)E045 T520V686M010A(1)E025 T520V686M010A(1)E040 T520V686M010A(1)E045 T520V686M010A(1)E060 T520V686M010A(1)E100 T520D686M010A(1)E100 T520C107M010A(1)E025 T520C107M010A(1)E045 T520L107M010A(1)E025 T520W107M010A(1)E040 T520V107M010A(1)E018 T520V107M010A(1)E025 T520V107M010A(1)E045 T520V107M010A(1)E050 T520D107M010A(1)E018 T520D107M010A(1)E055 T520D107M010A(1)E080 T520C157M010A(1)E055 T520V157M010A(1)E018 T520V157M010A(1)E025 T520V157M010A(1)E040 T520D157M010A(1) E015 T520D157M010A(1) E018 T520D157M010A(1)E025 T520D157M010A(1)E040 T520D157M010A(1)E055 T520Y157M010A(1) E015 T520Y157M010A(1) E018 T520Y157M010A(1) E025 T520V227M010A(1) E045 T520Y227M010A(1)E040 T520D227M010A(1)E018 T520D227M010A(1)E025 T520D227M010A(1)E040 T520Y337M010A(1)E015 T520Y337M010A(1)E035 T520X337M010A(1)E010 T520X337M010A(1)E025 T520X337M010A(1)E040 26 26 26 26 26 26 26 38 38 82 82 120 120 120 120 10 15 22 33 33 33 33 33 33 33 33 47 47 47 47 68 68 68 68 68 68 68 68 68 68 100 100 100 100 100 100 100 100 100 100 100 150 150 150 150 150 150 150 150 150 150 150 150 220 220 220 220 220 330 330 330 330 330 8 8 8 15 8 8 8 8 8 8 8 10 10 10 10 8 8 8 8 8 8 10 8 8 8 8 8 8 8 8 8 10 10 8 10 10 10 10 10 10 8 8 10 10 10 10 10 10 10 10 10 8 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 70 80 25 35 40 70 70 35 70 66 66 25 40 55 40 80 80 80 40 70 80 25 35 40 70 70 35 70 55 100 55 25 40 45 25 40 45 60 100 100 25 45 25 40 18 25 45 50 18 55 80 55 18 25 40 15 18 25 40 55 15 18 25 45 40 18 25 40 15 35 10 25 40 1200 1100 2300 1900 1800 1300 1400 1900 1300 1600 1600 3000 2400 2000 2200 1200 1200 1200 1600 1200 1100 2300 1900 1800 1300 1400 1900 1300 1600 1300 1600 2200 1700 1900 2700 2200 2000 1800 1400 1500 2600 1900 2400 1700 3200 2700 2000 1900 3500 2000 1700 1700 3200 2700 2200 3900 3500 3000 2400 2000 4000 3700 3100 2000 2500 3500 3000 2400 4000 2600 5000 3100 2500 12.5 10 15 10 22 33 33 33 33 47 47 47 47 47 68 150 22 22 22 15 15 15 T/3528-12 T520T106M12RA(1)E150 T/3528-12 B/3528-20 C/6032-28 W/7343-15 V/7343-19 V/7343-19 V/7343-19 W/7343-15 V/7343-19 V/7343-19 D/7343-31 D/7343-31 D/7343-31 X/7343-43 V/7343-19 V/7343-19 V/7343-19 V/7343-19 D/7343-31 D/7343-31 T520T156M12RA(1)E080 T520B106M016A(1)E100 T520C226M016A(1)E080 T520W336M016A(1)E045 T520V336M016A(1)E045 T520V336M016A(1)E060 T520V336M016A(1)E070 T520W476M016A(1)E045 T520V476M016A(1)E045 T520V476M016A(1)E070 T520D476M016A(1)E035 T520D476M016A(1)E070 T520D686M016A(1)E050 T520X157M016A(1)E040 T520V226M020A(1)E040 T520V226M020A(1)E045 T520V226M020A(1)E090 T520V156M025A(1)E090 T520D156M025A(1)E060 T520D156M025A(1)E080 13 19 16 35 53 53 53 53 75 75 76 75 75 109 240 44 44 44 38 38 38 8 8 8 8 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 150 80 100 80 60 45 60 70 45 45 70 35 70 50 40 40 45 90 90 60 80 800 1100 1100 1400 1400 2000 1800 1600 1600 2000 1600 2500 1800 2100 2500 2200 2000 1400 1400 1900 1700 3 16 3 3 16 3 20 3 25 3 *100kHz to 500kHz, 45º C (1) To complete KEMET part number, insert letter designation for lead material from page 50. Higher voltage ratings and tighter tolerance product may be substituted with the same size at KEMET's option.Voltage substitutions will be marked with the higher voltage rating. 3 *100kHz to 500kHz, 45º C (1) To complete KEMET part number, insert letter designation for lead material from page 50. Higher voltage ratings and tighter tolerance product may be substituted with the same size at KEMET's option.Voltage substitutions will be marked with the higher voltage rating. ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 TANTALUM AND ALUMINUM CHIP CAPACITORS Packaging Information Tape & Reel Packaging KEMET’s Molded Tantalum and Aluminum Chip Capacitor families are packaged in 8 mm and 12 mm plastic tape on 7" and 13" reels, in accordance with EIA Standard 481-1: Taping of Surface Mount Components for Automatic Handling. This packaging system is compatible with all tape fed automatic pick and place systems. Right Hand Orientation Only Embossed Carrier (+) (–) Embossment 8mm (0.315") or 12mm (0.472") Top Tape Thickness .10mm (.004") Max Thickness 180mm (7.0") or 330mm (13.0") Labeling: Bar code labeling (standard or custom) shall be on the side of the reel opposite the sprocket holes. Refer to EIA-556. QUANTITIES PACKAGED PER REEL Case Code KEMET R I S T M U L W Z V A B C D Y X E EIA 2012 12 3216 10 3216 12 3528 12 3528 15 6032 15 6032 19 7343 15 7343 17 7343 20 3216 18 3528 21 6032 28 7343 31 7343 40 7343 43 7260 38 Tape Width-mm 8 8 8 8 8 12 12 12 12 12 8 8 12 12 12 12 12 7" Reel* 2,500 3,000 2,500 2,500 2,000 1,000 1,000 1,000 1,000 1,000 2,000 2,000 500 500 500 500 500 13" Reel 10,000 12,000 10,000 10,000 8,000 5,000 5,000 3,000 3,000 3,000 9,000 8,000 3,000 2,500 2,000 2,000 2,000 * No c-spec required for 7" reel packaging. C-7280 required for 13" reel packaging. 92 ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 TANTALUM, CERAMIC AND ALUMINUM CHIP CAPACITORS Packaging Information Performance Notes 1. Cover Tape Break Force: 1.0 Kg Minimum. 2. Cover Tape Peel Strength: The total peel strength of the cover tape from the carrier tape shall be: Tape Width Peel Strength 8 mm 0.1 Newton to 1.0 Newton (10g to 100g) 12 mm 0.1 Newton to 1.3 Newton (10g to 130g) The direction of the pull shall be opposite the direction of the carrier tape travel. The pull angle of the carrier tape shall be 165 to 180 from the plane of the carrier tape. During peeling, the carrier and/or cover tape shall be pulled at a velocity of 300 ±10 mm/minute. 3. Reel Sizes: Molded tantalum capacitors are available on either 180 mm (7") reels (standard) or 330 mm (13") reels (with C-7280). Note that 13” reels are preferred. 4. Labeling: Bar code labeling (standard or custom) shall be on the side of the reel opposite the sprocket holes. Refer to EIA-556. Embossed Carrier Tape Configuration: Figure 1 Table 1 — EMBOSSED TAPE DIMENSIONS (Metric will govern) Constant Dimensions — Millimeters (Inches) Tape Size 8 mm and 12 mm D0 E P0 4.0 ±0.10 (0.157 ±0.004) P2 2.0 ±0.05 (0.079 ±0.002) T Max 0.600 (0.024) T1 Max 0.100 (0.004) 1.5 1.75 ±0.10 +0.10 -0.0 (0.059 (0.069 ±0.004) +0.004, -0.0) Pitch Single (4 mm) B1 Max. Note 1 4.4 (0.173) 12 mm Double (8 mm) 8.2 (0.323) D1 Min. Note 2 1.0 Variable Dimensions — Millimeters (Inches) Tape Size 8 mm F 3.5 ±0.05 P1 4.0 ±0.10 R Min. Note 3 25.0 T2 Max 2.5 (0.098) W 8.0 ±0.30 (.315 ±0.012) A0B0K0 Note 4 (0.039) (0.138 ±0.002) 1.5 5.5 ±0.05 (0.059) (0.217 ±0.002) (0.157 ±0.004) (0.984) 8.0 ±0.10 30.0 (0.315 ±0.004) (1.181) 4.6 12.0 ±0.30 (0.181) (0.472 ±0.012) NOTES 1. B1 dimension is a reference dimension for tape feeder clearance only. 2. The embossment hole location shall be measured from the sprocket hole controlling the location of the embossment. Dimensions of embossment location and hole location shall be applied independent of each other. 3. Tape with components shall pass around radius “R” without damage (see sketch A). The minimum trailer length (Fig. 2) may require additional length to provide R min. for 12 mm embossed tape for reels with hub diameters approaching N min. (Table 2) 4. The cavity defined by A0, B0, and K0 shall be configured to surround the part with sufficient clearance such that the chip does not protrude beyond the sealing plane of the cover tape, the chip can be removed from the cavity in a vertical direction without mechanical restriction, rotation of the chip is limited to 20 degrees maximum in all 3 planes, and lateral movement of the chip is restricted to 0.5 mm maximum in the pocket (not applicable to vertical clearance.) 94 ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 TANTALUM, CERAMIC AND ALUMINUM CHIP CAPACITORS Packaging Information Embossed Carrier Tape Configuration (cont.) 20° Sketch D: Tape Camber (Top View) 1mm (0.039) Max. 250mm (9.843) Allowable camber to be 1 mm/250 mm. 1mm (0.039) Max. 400mm (15.75) Min. Figure 2: Tape Leader & Trailer Dimensions (Metric Dimensions Will Govern) Figure 3: Reel Dimensions (Metric Dimensions will govern) Table 2 – REEL DIMENSIONS (Metric will govern) Tape Size 8 mm A Max 330.0 (12.992) B* Min 1.5 (0.059) C 13.0 ± 0.20 (0.512 ± 0.008) D* Min 20.2 (0.795) N Min 50.0 (1.969) See Note 3 Table 1 W1 8.4 +1.5, -0.0 (0.331 +0.059, -0.0) 12.4 +2.0, -0.0 (0.488 +0.078, -0.0) W2 Max 14.4 (0.567) W3 7.9 Min (0.311) 10.9 Max (0.429) 11.9 Min (0.469) 15.4 Max (0.606) 12 mm 330.0 (12.992) 1.5 (0.059) 13.0 ± 0.20 (0.512 ± 0.008) 20.2 (0.795) 18.4 (0.724) ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 95 Packaging World Sales Headquarters KEMET Electronics Corporation P.O. Box 5928 Greenville, SC 29606 Phone: 864-963-6300 Europe KEMET Electronics S.A. 15bis Chemin des Mines 1202 Geneva, Switzerland Phone: 41-22-715-0100 Asia KEMET Electronics Marketing PTE Ltd. 73 Bukit Timah Road #05-01 Rex House Singapore, 229832, Singapore Phone: 65-6386-1900 KEMET Electronics Asia Ltd. 30 Canton Road, Room 1512 SilverCord Tower II Tsimshatshui, Kowloon Hong Kong Phone: 852-2305-1168 KEMET reserves the right to modify minor details of internal and external construction at any time in the interest of product improvement. KEMET does not assume any responsibility for infringement that might result from the use of KEMET capacitors in potential circuit designs. KEMET Electronics Corporation • P.O. Box 5928 • Greenville, SC 29606 (864) 963-6300 • www.kemet.com
很抱歉,暂时无法提供与“T520”相匹配的价格&库存,您可以联系我们找货
T520A107M006ATE045
  • 1+2.145
  • 10+2.015
  • 50+1.82
  • 150+1.69
  • 300+1.599
  • 500+1.56
库存:1000
T520B107M010ATE070
  • 5+3.038
  • 50+2.1756
  • 400+1.715
  • 800+1.6268
  • 2000+1.61053
库存:1490
T520D477M004ATE010
  • 1+2.79721
T520B337M2R5ATE009
  • 1+1.8221
  • 10+1.7536
  • 100+1.5481
  • 500+1.507
T520B107M006ATE018
  • 1+1.93792
  • 30+1.8711
  • 100+1.73745
  • 500+1.6038
  • 1000+1.53697
T520B227M006ATE045
  • 1+3.8511
  • 10+3.1878
  • 400+2.2077
  • 800+2.1087
  • 2000+2.08761
库存:1928
T520V337M2R5ATE025
  • 1+3.293
  • 10+3.115
  • 30+2.759
  • 100+2.492
  • 500+2.314
  • 1000+2.1894
T520V477M2R5ATE007
  • 1+5.0589
  • 10+4.0986
  • 200+4.05761
  • 400+3.97646
  • 1000+3.85717
库存:590
T520V337M2R5ATE006
  • 1+2.76792
  • 10+2.49656
  • 50+2.27947
  • 150+2.13474
  • 300+2.04428
库存:165
T520T476M006ATE070
  • 1+1.18171
  • 10+1.08071
  • 30+1.06051
