A1215D-W25
A1215D-W25
    MORNSUN(金升阳)
    A1215D-W25 - DUAL/SINGLE OUTPUT DC-DC CONVERTER - MORNSUN Science& Technology Ltd.
A1215D-W25 数据手册
A_D-W25 & B_LD-W25 Series 0.25W, FIXED INPUT, ISOLATED & UNREGULATED DUAL/SINGLE OUTPUT DC-DC CONVERTER m ulti-country patent protection RoHS FEATURES 1KVDC Isolation DIP Package Internal SMD Construction Temperature Range: -40°C to +85°C No Heat sink Required No External Component Required Industry Standard Pinout RoHS Compliance PRODUCT PROGRAM I nput P art Number B0303LD-W25* B0305LD-W25* A0505D- W25 A0509D- W25* A0512D- W25* A0515D- W25* B0505LD- W25 B0509 LD- W25* B0512 LD- W25 B0515 LD- W25 A1205D- W25* A1209D- W25* A1212D- W25* A1215D- W25* B1203 LD- W25* B1205 LD- W25 B1209 LD- W25* B1212 LD- W25 B1215 LD- W25* A2405D- W25* A2409D- W25* A2412D- W25* A2415D- W25* B2405 LD- W25 B2409 LD- W25* B2412 LD- W25* B2415 LD- W25* B2424LD- W25* *Designing Output Range 3.0-3.6 Voltage (VDC) 3.3 5 ±5 ±9 ±12 ±15 5 9 12 15 ±5 ±9 ±12 ±15 Current (mA) Max 75.8 50 ±25 ±13.8 ±10.4 ±8.3 50 27.8 20.8 16.7 ±25 ±13.8 ±10.4 ±8.3 75.8 50 27.8 20.8 16.7 ±25 ±13.8 ±10.4 ±8.3 50 27.8 20.8 16.7 10.4 62 65 62 64 66 65 64 65 67 65 62 63 64 65 62 65 66 67 66 63 64 65 65 63 63 65 65 64 Efficiency (%, Typ) Voltage (VDC) Nominal 3.3 5 4.5-5.5 APPLICATIONS The A_D-W25 & B_LD-W25 Series are specially designed for applications where a group of polar power supplies are isolated from the input power supply in a distributed power supply system on a circuit board. These products apply to: 1) W here the voltage of the input power supply is fixed (voltage variation ≤ ±10%); 2) Where isolation is necessary between input and output (isolation voltage ≤1000VDC); 3) W here the regulation of the output voltage and the output ripple noise are not demanding. Such as: purely digital circuits, ordinary low frequency analog circuits, and IGBT power device driving circuits. 12 10.8-13.2 3.3 5 9 12 15 ±5 ±9 ±12 ±15 24 21.6-26.4 5 9 12 15 24 MODEL SELECTION B 0505 LD -W25 Rated Pow er Pack age S ty le O utpu t Volt age Input Volta ge Produ ct Se ries COMMON SPECIFICATIONS Item Operating Temp. Range Storage Temp. Range Storage humidity range Cooling Test conditions Min -40 -55 Typ Max 85 125 95 Free air convection 15 1.5mm from case for 10 seconds 25 300 1 Plastic (UL94-V0) 3500 2.1 K hours g °C s Units °C % MORNSUN Science & Technology co.,Ltd. Address: 2th floor 6th building, Hangzhou Industrial District, Guangzhou, China Tel: 86-20-38601850 Fax: 86-20-38601272 http://www.mornsun-power.com Temp. rise at full load Lead temperature Short circuit protection* Case material MTBF W eight * Supply voltage must be discontinued at the end of short circuit duration. MORNSUN reserves the copyright Specifications subject to change without notice. A_D-W 25 & B_LD-W25 A/1-2008 Page 1 of 2 ISOLATION SPECIFICATIONS Item I solation voltage I solation resistance Test conditions Tested for 1 minute and 1 mA max Test at 500VDC Min 1000 1000 Typ Max Units VDC MΩ APPLICATION NOTE Requirement on output load To ensure this module can operate efficiently and reliably, During operation, the minimum output load is n ot less than 10% of the full load, and that Min Typ Max 0.25 ±1.5 ±1.2 12 10.5 8.3 6.8 6.3 20 15 10 10 10 0.03 50 100 75 %/°C mVp-p KHz Recommended circuit If you want to further decrease the input/output ripple, an “LC” filtering network may be connected to the input and output ends of the DC/DC converter, see (Figure 1). D u al O utpu t L Vin Cin GND Sin g le O utpu t L Vin Cin GND OUTPUT SPECIFICATIONS Item Output power Line regulation For Vin change of 1% (3.3output) (others output) (3.3 output) (5V output) Load regulation 10% to 100% load (9V output) (12V output) (15V output) Output voltage accuracy Temperature drift Ripple & Noise* Switching frequency 100% full load 20MHz Bandwidth Full load, nominal input Test conditions Units W this product should never be operated under no load! If the actual output p ower is very small, please connect a resistor with proper resistance at the output end in p arallel to increase the load. % Overload Protection Under normal operating conditions, the output circuit of these products has no protection against overload. The simplest method is to connect a self-recovery fuse in series at the input end or add a circuit breaker to the circuit. See tolerance envelope graph *Test ripple and noise by “parallel cable” method. See detailed operation instructions at Testing of Power Converter section, application notes. Note: 1.All specifications measured at TA=25°C, humidity
A1215D-W25
### 物料型号 - 单输出型号:B0303LD-W25, B0305LD-W25, A0505D-W25, A0509D-W25, A0512D-W25, A0515D-W25等。 - 双输出型号:A1205D-W25, A1209D-W25, A1212D-W25, A1215D-W25, B1203LD-W25, B1205LD-W25等。
### 器件简介 Mornsun A_D-W25 & B_LD-W25系列是隔离和非隔离的固定输入双/单输出DC-DC转换器,具有1kVDC隔离,DIP封装内部SMD结构,工作温度范围为-40°C至+85°C,无需散热片,无需外部组件,符合行业标准引脚排列,符合RoHS标准。
### 引脚分配 - 单输出:1号引脚为GND,8号引脚为+Vo,9号引脚为OV(过压保护),14号引脚为Vin。 - 双输出:1号引脚为GND,8号引脚为+Vo,11号引脚为-Vo,14号引脚为Vin。
### 参数特性 - 输入电压范围:从3.0-3.6VDC到24VDC不等。 - 输出电压和电流:输出电压从3.3VDC到24VDC,最大电流从62mA到75.8mA。 - 效率:典型效率从62%到67%。 - 隔离电压:1000VDC。 - 隔离电阻:最小1000MΩ。
### 功能详解 这些产品专为分布式电源系统中从输入电源隔离一组极性电源的应用而设计。适用于输入电源电压固定(电压变化≤±10%)、输入和输出之间需要隔离(隔离电压≤1000VDC)、输出电压和输出纹波噪声调节要求不高的场合。
### 应用信息 适用于纯数字电路、普通低频模拟电路和IGBT功率器件驱动电路。
### 封装信息 封装为DIP形式,具体尺寸和引脚布局在文档中有详细描述,包括第一视角投影图和推荐足迹。
A1215D-W25 价格&库存
很抱歉,暂时无法提供与“A1215D-W25”相匹配的价格&库存,您可以联系我们找货
