B0515LM-1W
B0515LM-1W
    MORNSUN(金升阳)
    B0515LM-1W - DUAL/SINGLE OUTPUT,SUPERMINIATURE SIP PACKAGE - MORNSUN Science& Technology Ltd.
B0515LM-1W 数据手册
A_M-1W & B_LM-1W Series 1W, FIXED INPUT, ISOLATED & UNREGULATED DUAL/SINGLE OUTPUT,SUPERMINIATURE SIP PACKAGE m ulti-country patent protection RoHS FEATURES Efficiency up to 80% Miniature SIP Package Style Temperature Range: -40°C to+85°C Internal SMD Construction Industry Standard Pinout No Heat sink Required No External Component Required RoHS Compliance PRODUCT PROGRAM Input P art Number A0505M-1W A0509M-1W A0512M-1W A0515M-1W A1205M-1W A1209M-1W A1212M-1W A1215M-1W B0505LM-1W B0509LM-1W B0512LM-1W B0515LM-1W B1205LM-1W B1209LM-1W B1212LM-1W B1215LM-1W B2405LM-1W B2409LM-1W B2412LM-1W B2415LM-1W B2424LM-1W 24 21.6-26.4 12 10.8-13.2 5 4.5-5.5 12 10.8-13.2 5 4.5-5.5 Voltage (VDC) Nominal Range Voltage (VDC) ±5 ±9 ±12 ±15 ±5 ±9 ±12 ±15 5 9 12 15 5 9 12 15 5 9 12 15 24 Output Current (mA) Max ±100 ±56 ±42 ±33 ±100 ±56 ±42 ±33 200 111 83 67 200 111 83 67 200 111 83 67 42 Min ±10 ±6 ±5 ±4 ±10 ±6 ±5 ±4 20 12 9 7 20 12 9 7 20 12 9 7 5 70 75 78 79 72 75 77 79 70 75 79 80 72 75 77 79 70 73 75 78 77 Efficiency (%, Typ) APPLICATIONS The A_M-1W & B_LM-1W Series are specially designed for applications where a group of polar power supplies are isolated from the input power supply in a distributed power supply system on a circuit board. These products apply to: 1) W here the voltage of the input power supply is fixed (voltage variation ≤ ±10%); 2) W here isolation is necessary between input and output (isolation voltage ≤1000VDC); 3) W here the regulation of the output voltage and the output ripple noise are not demanding. Such as: purely digital circuits, ordinary low frequency analog circuits, and IGBT power device driving circuits. ISOLATION SPECIFICATIONS Item Isolation voltage Isolation resistance Test conditions Tested for 1 minute and 1mA max Test at 500VDC Min 1000 1000 Typ Max Units VDC MΩ OUTPUT SPECIFICATION MODEL SELECTION B0505LM-1W Rated Pow er Package Style Output Voltage Input Voltage Product Series Item Output power Line regulation For Vin change of 1% 10% to 100% full load(5V output) 10% to 100% full load(9V output) Load regulation 10% to 100% full load(12V output) 10% to 100% full load(15V output) 10% to 100% full load(24V output) Temperature drift MORNSUN Science& Technology co.,Ltd. Address: 2th floor 6th building, Hangzhou Industrial District, Guangzhou, China Tel: 86-20-38601850 Fax: 86-20-38601272 http://www.mornsun-power.com Test Conditions Min 0.1 Typ M ax 1 1.2 Units W 10 8.3 6.8 6.3 5 15 10 10 10 10 0.03 %/°C % 100% full load 20MHz Bandwidth(AXXXXM-1W) 20MHz Bandwidth(BXXXXLM-1W) 100% load, nominal input(5V,12V) 100% load, nominal input(24V) 50 75 100 500 Output voltage accuracy Ripple & Noise* Switching frequency Converter section, application notes. S ee tolerance envelope graph 75 100 mVp-p KHz *Test ripple and noise by “parallel cable” method. See detailed operat ion instructions at Testing of Power MORNSUN reserves the copyright Specifications subject to change without notice. A_M-1W & B_LM-1W A/1-2008 Page 1 of 2 COMMON SPECIFICATION Item Storage humidity Operating temperature Storage temperature Lead temperature Temp. rise at full load Cooling Case material Short circuit protection* MTBF W eight *Supply voltage must be discontinued at the end of short circuit duration. Note: 1.All specifications measured at TA=25° C, humidity
B0515LM-1W 价格&库存
很抱歉,暂时无法提供与“B0515LM-1W”相匹配的价格&库存,您可以联系我们找货
