IA2415KP-1W
IA2415KP-1W
    MORNSUN(金升阳)
    IA2415KP-1W - DUAL OUTPUT DC-DC CONVERTER - MORNSUN Science& Technology Ltd.
IA2415KP-1W 数据手册
IA_KP-*W Series 1W/2W/3W, FIXED INPUT, ISOLATED & REGULATED DUAL OUTPUT DC-DC CONVERTER multi-country patent protection FEATURES Low ripple Good dynamic feature 1KVDC Isolation DIP Package Temperature Range: -40°C to +85°C UL94-V0 Package No Heatsink Required No External Component Required Internal SMD construction RoHS Compliance RoHS Efficiency (%, Typ) 64 65 62 63 64 64 62 64 65 63 65 66 65 68 64 65 63 66 67 68 69 PRODUCT PROGRAM I nput Part Number IA0512KP-1W IA0515KP-1W IA0509KP-2W * IA0512KP-2W IA0515KP-2W IA0512KP-3W IA0515KP-3W IA1212KP-1W * IA1215KP-1W * IA1209KP-2W 5 4.75-5.25 Voltage (VDC) Nominal Range Voltage (VDC) ±12 ±15 ±9 ±12 ±15 ±12 ±15 ±12 ±15 ±9 12 11.4-12.6 ±12 ±15 ±12 ±15 ±12 ±15 ±9 24 22.8-25.2 ±12 ±15 ±12 ±15 Output Current (mA) Max ±42 ±33 ±100 ±83 ±67 ±100 ±100 ±42 ±33 ±100 ±83 ±67 ±100 ±100 ±42 ±33 ±100 ±83 ±67 ±100 ±100 Min ±5 ±4 ±10 ±9 ±7 ±10 ±10 ±5 ±4 ±10 ±9 ±7 ±10 ±10 ±5 ±4 ±10 ±9 ±7 ±10 ±10 APPLICATIONS The IA_KP-3W & IA_KP-2W & IA_KP-1W S eries are specially designed for applications where a group of polar power supplies are isolated from the input power supply in a distributed power supply system on a circuit board. These products apply to: 1) W here the voltage of the input power supply is fixed (voltage variation ≤±5%); 2) Where isolation is necessary between input and output (isolation voltage ≤1000VDC); 3) W here the regulation of the output voltage and the output ripple noise are demanded. IA1212KP-2W IA1215KP-2W * IA1212KP-3W * IA1215KP-3W IA2412KP-1W * IA2415KP-1W IA2409KP-2W * IA2412KP-2W IA2415KP-2W IA2412KP-3W IA2415KP-3W * * Designing. ISOLATION SPECIFICATIONS Item Isolation voltage Isolation resistance Test conditions Tested for 1 minute and 1mA max Test at 500VDC Min 1000 1000 Typ Max Units VDC MΩ OUTPUT SPECIFICATIONS MODEL SELECTION Item Line regulation Output voltage accuracy Temperature drift Output ripple* Output Noise* Test Conditions F or Vin change of ± 5%(1W&2W) F or Vin change of ± 5%(3W) 10% to 100% full load 100% full load 100% full load 20MHz Bandwidth(1W) 20MHz Bandwidth(2W&3W) 20MHz Bandwidth(1W&2W) 20MHz Bandwidth(3W) Full load, nominal input Min Typ Max ±0.25 ±0.3 ±1 ±3 0.03 Units IA0 512KP-3W Rated Powe r Pac ka ge St yle Out put Vol ta ge Inp ut Voltag e Product Ser ies % %/°C 10 20 50 150 75 20 40 150 300 KHz mVp-p MORNSUN Science& Technology co.,Ltd. Address: 2th floor 6th building, Hangzhou Industrial District, Guangzhou, China Tel: 86-20-38601850 Fax: 86-20-38601272 http://www.mornsun-power.com Switching frequency *Test ripple and noise by “parallel cable” method. See detailed operation instructions at Testing of Power Converter section, application notes. Note: 1. All specifications measured at TA=25°C, humidity
IA2415KP-1W 价格&库存
很抱歉,暂时无法提供与“IA2415KP-1W”相匹配的价格&库存,您可以联系我们找货
