WRA2409N-2W
WRA2409N-2W
    MORNSUN(金升阳)
    WRA2409N-2W - DUAL/SINGLE OUTPUT DIP DC-DC CONVERTER - MORNSUN Science& Technology Ltd.
WRA2409N-2W 数据手册
WRA_N-2W & WRB_N-2W Series 2W, WIDE INPUT, ISOLATED®ULATED DUAL/SINGLE OUTPUT DIP DC-DC CONVERTER m ulti-country patent protection RoHS FEATURES Miniature DIP Package Wide (2:1) Input Range Operating Temperature: -40°C to +85°C 1500VDC Isolation No Heat Sink Required No External Component Required Industry Standard Pinout Internal SMD construction Short circuit protection(automatic recovery) RoHS Compliance PRODUCT PROGRAM Input P art Number W RA1205N-2W W RA1209N-2W W RA1212N-2W W RA1215N-2W W RB1203N-1W6 W RB1205N-2W W RB1209N-2W W RB1212N-2W W RB1215N-2W 12 9-18 22 Voltage (VDC) Nominal Range Max* Voltage (VDC) ±5 ±9 ±12 ±15 3.3 5 9 12 15 ±5 ±9 ±12 ±15 24 18-36 40 3.3 5 9 12 15 Output Current (mA) Max ±200 ±111 ±83 ±67 500 400 222 167 133 ±200 ±111 ±83 ±67 500 400 222 167 133 Min ±20 ±11 ±8 ±7 50 40 22 16 13 ±20 ±11 ±8 ±7 50 40 22 16 13 75 76 78 78 70 74 76 78 78 76 77 78 79 72 76 78 80 79 Efficiency (%, Typ) APPLICATIONS The WRA_N-2W & WRB_N-2W Series are specially designed for applications where a wide range input voltage power supplies are isolated from the input power supply in a distributed power supply system on a circuit board. These products apply to: 1) Where the voltage of the input power supply is wide range (voltage range≤2:1); 2) Where isolation is necessary between input and output(isolation voltage≤ 1500VDC); 3) Where the regulation of the output voltage and the output ripple noise are demanded. W RA2405N-2W W RA2409N-2W W RA2412N-2W W RA2415N-2W W RB2403N-1W6 W RB2405N-2W W RB2409N-2W W RB2412N-2W W RB2415N-2W *Input voltage can’t exceed this value, or will cause the permanent damage. Note: The load shouldn't be less than 10%, otherwise ripple will increase dramatically. Operation under 10% load will not damage the converter; However, they may not meet all specification listed. OUTPUT SPECIFICATIONS Item Output power Test conditions Refer to above products program Refer to recommended circuit Min 0.2 ±1 ±3 ±0.5 ±0.2 Typ M ax 2 ±3 ±5 ±1* ±0.5 ±0.03 50 300 100 %/ °C m Vp-p KHz % Units W MODEL SELECTION WRB2405N-2W Rated Power Package Style Output Voltage Input Voltage Product Series P ositive voltage accuracy Negative voltage accuracy Refer to recommended circuit Load regulation Line regulation Temperature drift Ripple & Noise** Switching frequency From 10% to 100% load Input Voltage From Low to High Refer to recommended circuit 20MHz bandwidth 100% load, input voltage range *Dual output models unbalanced load: ±5%. **Test ripple and noise by “parallel cable” m ethod. See detailed operation instructions at Testing of Power Converter section, application notes. MORNSUN Science & Technology co.,Ltd. Address: 2th floor 6th building, Hangzhou Industrial District, Guangzhou, China Tel: 86-20-38601850 Fax: 86-20-38601272 http://www.mornsun-power.com ISOLATION SPECIFICATIONS I tem Isolation voltage Isolation resistance Isolation Capacitance Test conditions Tested for 1 minute and 1 mA max Test at 500VDC Input/Output WRA_N_2W&WRB_N_2W Min 1500 1000 Typ Max Units VDC MΩ 85 A/1-2008 pF Page 1 of 2 MORNSUN reserves the copyright Specifications subject to change without notice. COMMON SPECIFICATIONS Item Storage humidity Operating temperature Storage temperature Temp. rise at full load Lead temperature No-load power consumption Cooling Short circuit protection Case material MTBF W eight 1000 4.8 1.5mm from case for 10 seconds 0.2 Free air convection Continuous, automatic recovery Plastic(UL94-Vo) K hours g -40 -55 15 300 W Test Conditions Min Typ Max 95 85 125 °C Units % Recommended Circuit All the WRA_N-2W & WRB_N-2W Series h ave been tested according to the following recommended testing circuit before leaving factory (Figure 1). This series should be tested under load. Vin Ci n +Vout DC DC 0V -Vout GND Single Output Vin Cin +Vout DC DC 0V GND (Figure 1) If you want to further you decrease can the Note: 1. All specifications measured at TA=25° C, humidity
WRA2409N-2W 价格&库存
很抱歉,暂时无法提供与“WRA2409N-2W”相匹配的价格&库存,您可以联系我们找货
