WRB4809T-3W
WRB4809T-3W
    MORNSUN(金升阳)
    WRB4809T-3W - 3W SINGLE OUTPUT DC/DC CONVERTER - MORNSUN Science& Technology Ltd.
WRB4809T-3W 数据手册
WRB_T-3W Series WIDE INPUT ISOLATED & REGULATED 3W SINGLE OUTPUT DC/DC CONVERTER FEATURES ● Efficiency up to 81% ● Operating Temperature: -40°C~+85°C ● 1500VDC Isolation ● UL94-V0 Package ● No External Component Required ● Industry Standard Pinout ● MTBF>1,000,000 hours PRODUCT PROGRAM Part Number WRB0503T-2W WRB0505T-3W WRB0509T-3W WRB0512T-3W WRB0515T-3W WRB1203T-2W WRB1205T-3W WRB1209T-3W WRB1212T-3W Input Voltage (VDC) Nominal Range Max Max 600 600 Output Current (mA) Min 60 60 33 25 20 60 60 33 25 20 90 60 33 25 20 90 60 33 25 20 Voltage (VDC) 3.3 5 9 12 15 3.3 5 9 12 15 3.3 5 9 12 15 3.3 5 9 12 15 Efficiency (%, Typ) 66 68 70 70 71 72 75 77 78 79 73 76 78 80 80 73 77 78 80 81 5 4.5~9 11 330 250 200 600 600 12 9~18 22 330 250 200 900 600 APPLICATIONS The WRB_T-3W Series are specially designed for applications where a wide range input voltage power supplies are isolated from the input power supply in a distributed power supply system on a circuit board. These products apply to: 1) Where the voltage of the input power supply is wide range (voltage range: 2:1); 2) Where isolation is necessary between input and output (Isolation Voltage≤1500VDC); 3) Where the regulation of the output voltage and the output ripple noise are demanded. WRB1215T-3W WRB2403T-3W WRB2405T-3W WRB2409T-3W WRB2412T-3W WRB2415T-3W WRB4803T-3W WRB4805T-3W WRB4809T-3W WRB4812T-3W WRB4815T-3W 24 18~36 40 330 250 200 900 600 48 36~72 80 330 250 200 MODEL SELECTION ISOLATION SPECIFICATIONS Item Isolation voltage Isolation resistance Isolation Capacitance Test conditions Flash tested for 60 seconds and 1mA Test at 500VDC Input/Output Min 1500 1000 100 Typ Max Units VDC MΩ PF WRB2405T-3W Rated Power Package Style Output Voltage Input Voltage Product Series OUTPUT SPECIFICATIONS Item Output Power Output Voltage Accuracy Load Regulation Voltage Regulation Temperature Drift(Vout) Ripple Noise Switching Frequency Test Conditions See Below Products Program Refer To Recommended Circuit From 10% To 100% Load Input Voltage From Low To High Refer To Recommended Circuit 20MHz Bandwidth 20MHz Bandwidth 100% Load, Nominal Input Voltage Min 0.3 Typ ±1 ±0.1 ±0.2 30 50 300(PFM) Max 3 ±3 ±1 ±0.5 0.03 50 100 Units W % %/°C mVp-p KHZ MORNSUN Science& Technology Ltd. Address: 2th floor 6th building, Huangzhou Industrial District, Guangzhou, China Tel: 86-20-38601850 Fax: 86-20-38601272 Http://www.mornsun-power.com Note: 1.All specifications measured at TA=25°C, humidity1,000,000 hours Recommended Circuit All the WRB_T-3W Series have been tested according to the following recommended testing circuit before leaving factory. This series should be tested under load(Figure 1). Vin Cin GND Vout DC DC 0V TYPICAL CHARECTERISTICS Temperature Derating Graph If you want to further decrease the input/output ripple, you can increase capacitance properly or choose capacitors with low ESR. However, the capacitance should not be too high(Table 1) External Capacitor Table(Table 1) Vin 5V&12V 24V&48V Cin 100uF 22uF Cout (0~70℃) 100uF (electrolytic capacitor) Cout (-40~85℃) 47uF (tantalum capacitor) Recommended Reflow Soldering Profil e Operating Temp.( C ) FOOTPRINT DETAILS 242 32 2 16151 4 3 1 P in 22,23 Fu ncti on Vin GND +Vo 0V NC (Top Vie w) 2,3 14 16 Input Current Nominal input voltage range.The input current of the power supply must be sufficient to the startup current (Ip) of the DC/DC module (Figure 2) Input Current(A) 123 9 101 1 2 1 Oth ers OUTLINE DIMENSIONS 32.5 [1.28] 27.9 [1.10] 8.0 [0.31] 7.5 [0.30] Ip Input Voltage Range 22.5min [0.886] 19.2 [0.75] 20.5 [0.81] 26.4 [1.04] (Top View) 1.5 [0.06] 19.7 [0.78] R1.5 [R0.06] Input Voltage (V) No parallel connection or plug and play. 0.3 [0.01] 2.5 [0.10] 1.5 [0.06] 0.15 Note: Unit: mm(inch); Tolerance: ±0.25mm. APPLICATION NOTE Output Load In order to ensure the product operate efficiently and reliably, in addition to a max load (namely full load), a minimum load is specified for this kind of DC/DC converter. Make sure the specified range of input voltage is not exceeded, the minimum output load no less than 10% full load, If the actual load is less than the specified minimum load, the output ripple may increase sharply. If the actual output power is very small, please add an appropriate resistor as extra loading,or contact our company for other lower output power products. MORNSUN reserves the copyright For any design change and upgrade, we will not make any prior notification A/1-2007 Page 2 of 2
WRB4809T-3W 价格&库存
很抱歉,暂时无法提供与“WRB4809T-3W”相匹配的价格&库存,您可以联系我们找货
